    4. TESTER: Neuer Adapter Webuntis
      Seamen last edited by
      Sehr gute idee! werde ich mir definitiv anschauen!
      • O
        oxident @Newan last edited by
        @newan Gesagt, getan. Musste ja nicht lange auf den nächsten Ausfall warten 😉
        		"id": 123,
        		"date": 20220126,
        		"startTime": 1120,
        		"endTime": 1240,
        		"code": "irregular",
        		"kl": [
        				"id": 123,
        				"name": "7e",
        				"longname": "LEHRER"
        		"te": [
        				"id": 123,
        				"name": "XXX",
        		"su": [
        				"id": 123,
        				"name": "En",
        				"longname": "Englisch"
        		"ro": [
        				"id": 123,
        				"name": "E1.02",
        				"longname": "Klassenraum XX",
        				"orgid": 99,
        				"orgname": "TU3"
        		"lsnumber": 123,
        		"sg": "Sp_7e"
        		"id": 123,
        		"date": 20220126,
        		"startTime": 1120,
        		"endTime": 1240,
        		"code": "cancelled",
        		"kl": [
        				"id": 123,
        				"name": "7e",
        		"te": [
        				"id": 123,
        				"name": "XXX",
        		"su": [
        				"id": 123,
        				"name": "Sp",
        				"longname": "Sport"
        		"ro": [
        				"id": 123,
        				"name": "TU3",
        				"longname": "Turnhalle 3"
        		"lsnumber": 123,
        		"sg": "Sp_7e",
        		"activityType": "Unterricht"
        		"id": 123,
        		"date": 20220126,
        		"startTime": 1340,
        		"endTime": 1500,
        		"kl": [
        				"id": 123,
        				"name": "7e",
        		"te": [
        				"id": 123,
        				"name": "LEHRER",
        				"longname": "LEHRER",
        				"orgid": 123,
        				"orgname": "VOIM"
        		"su": [
        				"id": 123,
        				"name": "LeZ",
        				"longname": "Lernzeit"
        		"ro": [
        				"id": 123,
        				"name": "XXX",
        				"longname": "Klassenraum 7e"
        		"lsnumber": 123,
        		"sg": "LeZ_7e",
        		"id": 123,
        		"date": 20220126,
        		"startTime": 800,
        		"endTime": 920,
        		"kl": [
        				"id": 123,
        				"name": "7d",
        				"id": 356,
        				"name": "7e",
        				"id": 361,
        				"name": "7f",
        		"te": [
        				"id": 123,
        				"name": "LEHRER",
        		"su": [
        				"id": 123,
        				"name": "Reli",
        				"longname": "Religion"
        		"ro": [
        				"id": 123,
        				"name": "XXX",
        				"longname": "Klassenraum 10a"
        		"lsnumber": 123,
        		"sg": "Reli_123",
        		"id": 123,
        		"date": 20220126,
        		"startTime": 945,
        		"endTime": 1105,
        		"kl": [
        				"id": 123,
        				"name": "7e",
        		"te": [
        				"id": 123,
        				"name": "LEHRER",
        				"id": 123,
        				"name": "LEHRER",
        				"orgid": 123,
        				"orgname": "VOIM"
        		"su": [
        				"id": 123,
        				"name": "LeZ Klassenrat",
        				"longname": "Lernzeit Klassenrat"
        		"ro": [
        				"id": 123,
        				"name": "XXX",
        		"lsnumber": 123,
        		"sg": "LeZKlassenrat_7e",
        Ich denke mal, die generelle Struktur kennst Du ja sicherlich 😉
        Interessant ist an dieser Stelle, dass zwei Stunden ausfallen ("code": "cancelled") und eine Stunde Vertretung ist (vermute ich mal) -> "code": "irregular".
        Newan 1 Reply Last reply Reply Quote 0
        • Newan
          Newan @oxident last edited by
          @oxident Mega!
          Ja das bauen wir ein. "irregular" ist schon amüsant.
          • Newan
            @ldittmar sagte in TESTER: Neuer Adapter Webuntis:
            Das sollte ggf. in die Konfig-Seite rein.
            -> Done, habe einen Link zur späteren Anleitung eingebunden. Muss nur einer ne Anleitung schreiben. AM besten per md-Datei auf github im Repo.
            @oxident:
            Vielleicht könnte man alles nach aktuellem Tag und den Folgetag gliedern. Also quasi als oberste Ebene der DP "current" und "1d" oder "nextday" verwenden. Schwierig wird da ggf. noch das Handling von Wochenenden und Ferien.
            Folgende Logik ist aktiv: Wenn die Funktion getOwnTimetableForToday null zurückgibt, gehe ich von Wochenende aus. Dann wird nextBusinessDay gesucht und dann abgefragt. Wenn dann auch leer ist Ferien und die Datenpunkte bleiben leer bzw. werden entfernt.
            -> wäre das für die Anleitung
            Habe jetzt einfch 0 und 1 gemacht als Index. Problem ist das ja wie oben nicht immer current zieht und mir keine passende Namen eingefallen sind. Es wird aber das ausgelesene Datum angegeben.
            Parallel dazu könnte man so auch Vertretungsunterricht (oder Distanzlernen) abfangen. Die entsprechenden "codes" kenne ich zwar nicht, aber man könnte generell, wenn bei einer Schulstunde ein "code" <> "cancelled" vorhanden ist einen Zähler (z. B. "exceptions") inkrementieren. Dann weiß man, dass an diesem Tag irgendwas "komisch" ist 😉
            Das ist wie folgt gelöst. In der Stunde wird angezeigt ob "Vertretung" oder ausfällt. AM tag wir mit exception angezeigt ob was komisch oder nicht ist. Schaut mal ob das so nutzbar und praktikabel ist. Auch hier wäre ein Eintrag in der Anleitung hilfreich
            • Newan
              Update online, happy testing
                elektrickser.de @Newan last edited by
                @newan ich hab gesteren nen Fork gezogen und mit der Readme für Github begonnen.
                Sollte ich diese auf English machen oder in Deutsch halten?
                Ich bin noch neu mit VScode und Git und deswegen klappts mit dem Pullrequest noch nicht so. eventuell schiebe ich dir die dann per Github hoch.
                Newan E 2 Replies Last reply Reply Quote 0
                • Newan
                  Newan @elektrickser.de last edited by
                  @elektrickser-de Am besten beides 🙂
                  Pull ist denkbar einfach. In deinem Fork einfach nen commit machen und dann in github auf der Webseite einen PR stellen, Rest geht vom system quasi alleine.
                    elektrickser.de @elektrickser.de last edited by
                    @Newan
                    ich finde jetzt erstmal diesen Request interesant:
                    (async) getTimetableForRange(rangeStart, rangeEnd, id, type, validateSessionopt) → {Promise.<Array>}
                    Get the timetable for a given Date range for specific element
                      @Newan
                      weitere interesannte Abfragen:
                      Hausaufgaben:
                      (async) getHomeWorksFor(rangeStart, rangeEnd, validateSessionopt) → {Promise.<Array>}
                      Source:
                              index.js, line 383
                      Parameters:
                      Name 	Type 	Attributes 	Default 	Description
                      rangeStart 	Date
                      rangeEnd 	Date
                      validateSession 	boolean 	<optional>
                      	true
                      Returns:
                      Type:
                          Promise.<Array>
                      Stundenplan für einen Datumbereich, z.b. immer für die aktuelle Woche oder immer für die nächsten 7 Tage
                      (async) getOwnTimetableForRange(rangeStart, rangeEnd, validateSessionopt) → {Promise.<Array>}
                      Get your own timetable for a given Date range Note: You can't use this with anonymous login
                      Source:
                              index.js, line 316
                      Parameters:
                      rangeStart 	Date
                      rangeEnd 	Date
                      validateSession 	Boolean 	<optional>
                      	true
                      Returns:
                      Type:
                          Promise.<Array>
                        ich habe den Adapter zum testen installiert. Leider bekomme ich immer folgende Fehlermeldung:
                        webuntis.0	2022-01-26 13:23:24.768	error	Login WebUntis failed
                        webuntis.0	2022-01-26 13:23:24.767	error	Error: Failed to login. {"jsonrpc":"2.0","id":"error","error":{"message":"invalid schoolname","code":-8500}}
                        Die Schule heißt Gymnasium+Loxstedt, dies habe ich in der config bei "School secret" eingetragen. Ist das so korrekt?
                        Malte
                        • Newan
                          @seamen
                          school: Gymnasium+Loxstedt
                          baseUrl: kephiso.webuntis.com
                          S O 2 Replies Last reply Reply Quote 0
                            Seamen @Newan last edited by
                            @newan
                            Das habe ich genau so drin.
                            • Newan
                              Newan @Seamen last edited by
                              @seamen Gerne kannst du mir den Login per PN senden und ich schaue mal.
                              • O
                                oxident @Newan last edited by oxident
                                @Seamen Also bei mir (andere Schule) war es ein Leerzeichen anstelle +
                                Newan S 2 Replies Last reply Reply Quote 0
                                • Newan
                                  @oxident danke, der Tipp hilft. Bitte in der Anleitung aufnehmen @elektrickser-de
                                  • Newan
                                    @elektrickser-de Anleitung:
                                    Feld code: regular = "Unterricht normal"; irregular = "Unterricht in vertrettung (so zumindest derzeit die Vermutung); canceld = " Stunde fällt aus"
                                      J.M last edited by
                                      Guten Abend. Habe mir auch diesen Adapter gewünscht. Leider stellt unsere Schule keine Login Daten zur Verfügung so das wir uns als Anonymous anmelden. Wäre es möglich dies einzubauen?
                                      • Newan
                                        Newan @J.M last edited by
                                        @j-m Kannst du mir ein wenig mehr berichten wie das geht? wie heißt die Schule und welche Daten findet man dann da?
                                          J.M @Newan last edited by
                                          @newan Wir müssen die Schule suchen und dann die Klasse angeben. Die Gutenberg Schule in 13055 Berlin hat dies z.B.
                                          Wir sehen dann nur den Stundenplan und die News der Schule. Aber das würde mir auch reichen ;).
                                          E Newan 2 Replies Last reply Reply Quote 0
                                          • Newan
                                            Newan @ldittmar last edited by
                                            @ldittmar Newsfeed ist implementiert!
                                            31.7k
                                            79.8k
                                            191
                                            22592
