    4. help please - iobroker läuft nicht
      Pahan @Thomas Braun last edited by
      @thomas-braun sagte in help please - iobroker läuft nicht:
      ps aux | grep io
      pi@raspberrypi:~ $ ps aux | grep io
      root        13  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/0]
      root        16  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/1]
      root        21  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/2]
      root        26  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/3]
      root        59  0.0  0.0      0     0 ?        I<   21:44   0:00 [blkcg_punt_bio]
      root        63  0.0  0.0      0     0 ?        I<   21:44   0:00 [rpciod]
      root        65  0.0  0.0      0     0 ?        I<   21:44   0:00 [xprtiod]
      root        67  0.0  0.0      0     0 ?        I<   21:44   0:00 [nfsiod]
      root        76  0.0  0.0      0     0 ?        I<   21:44   0:00 [DWC Notificatio]
      message+   373  0.0  0.0   6712  3424 ?        Ss   21:45   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
      grafana    494  0.1  1.0 948740 43216 ?        Ssl  21:45   0:04 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
      pi         865  0.0  0.0   7348   516 pts/0    S+   22:31   0:00 grep --color=auto io
      pi@raspberrypi:~ $
        Thomas Braun Most Active @Pahan last edited by
        @pahan
        Da läuft halt gar nix.
          ls -l
          pi@raspberrypi:/opt/iobroker $ ls -l
          total 500
          drwxrwxr-x+   2 iobroker iobroker   4096 Jan 13 21:32 backups
          -rwxrwxrwx+   1 iobroker iobroker    861 Jan 26 21:29 INSTALLER_INFO.txt
          lrwxrwxrwx    1 iobroker iobroker     22 Jan 26 21:29 iob -> /opt/iobroker/iobro                      ker
          -rwxr-xr-x+   1 iobroker iobroker      0 Jan 26 21:29 iobroker
          drwxrwxr-x+   7 iobroker iobroker   4096 Jan 22 12:14 iobroker-data
          drwxrwxr-x+   2 iobroker iobroker   4096 Jan 26 21:25 log
          drwxrwxr-x+ 855 iobroker iobroker  32768 Jan 19 22:50 node_modules
          -rw-rwxr--+   1 iobroker iobroker   2181 Jan 19 22:50 package.json
          -rw-rwxr--+   1 iobroker iobroker 445073 Jan 19 22:50 package-lock.json
          -rw-rwxr--+   1 iobroker iobroker   5693 Jan 13 21:35 reinstall.js
          which iobroker
          liefert
          /usr/bin/iobroker
            @pahan
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
              @pahan
              cd /opt/iobroker
              liefert:
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm ERR! code ENOSPC
              npm ERR! syscall write
              npm ERR! errno -28
              npm ERR! nospc ENOSPC: no space left on device, write
              npm ERR! nospc There appears to be insufficient space on your system to finish.
              npm ERR! nospc Clear up some disk space and try again.
              ...wobei es ein Pi4 mit 4GB und 32GB Speicherkarte ist und es vorher reichlich Platz vorhanden war. Kann mir die Fehlermeldung nicht erklären
                @pahan
                df -h
                  @pahan
                  df -h
                  pi@raspberrypi:/opt/iobroker $ df -h
                  Filesystem      Size  Used Avail Use% Mounted on
                  /dev/root        15G   15G     0 100% /
                  devtmpfs        1.8G     0  1.8G   0% /dev
                  tmpfs           1.9G     0  1.9G   0% /dev/shm
                  tmpfs           1.9G  8.5M  1.9G   1% /run
                  tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                  tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
                  /dev/mmcblk0p1  253M   49M  204M  20% /boot
                  tmpfs           384M     0  384M   0% /run/user/1000
                  scheint eine 16GB zu sein, die zu 100% voll ist? Nicht schlecht... War vorher definitiv nicht
                    @pahan sagte in help please - iobroker läuft nicht:
                    Nee, vorher war sie leerer...
                    Musst du Mal mit du oder ncdu schauen, was da aus dem Ruder gelaufen ist. Kameras am Start?
                      Kameras laufen nicht auf dem Raspi. Es war grundsätzlich alles OK. Lief alles gut und schnell, bis eben auf den UPNP adapter. Der produzierte ständig Fehlermeldungen. Diesen habe ich deinstalliert und seitdem ging es los. Da wurde wohl viel Datenmüll generiert, oder? Soll ich daraufmal schauen und ggf. irgendwelche kryptischen Sachen über den Windows PC löschen ?
                        Was würdest du denn als kryptisch bezeichnen?
                          weiß ich noch nicht, aber ich vermute mal irgendeine übergroße Datei, die seit dem Ausfall erstellt wurde....nur so als Idee?
                            @pahan
                            ncdu
                            ist installiert? Dann schau damit nach.
                              @pahan
                              ncdu
                              --- /opt/iobroker ------------------------------------------------------------------------------------
                                  6.6 GiB [##########] /log
                                755.2 MiB [#         ] /node_modules
                                346.8 MiB [          ] /iobroker-data
                                 80.8 MiB [          ] /backups
                                436.0 KiB [          ]  package-lock.json
                                  8.0 KiB [          ]  reinstall.js
                                  4.0 KiB [          ]  package.json
                                  4.0 KiB [          ]  INSTALLER_INFO.txt
                                  4.0 KiB [          ]  .npmrc
                              @   0.0   B [          ]  iob
                                  0.0   B [          ]  iobroker
                                @pahan
                                Wie erwartet sind dir da die Log Files um die Ohren geflogen. Lösch die mal. Zumindest die ältesten. Und dann musst du mal reinschauen was dein System da so treibt.
                                  @pahan
                                  sieht so ja, ja...
                                  wie lösche ich am besten eine bestimmte Datei und welche hiervon würde sich hierzu eignen?
                                  pi@raspberrypi:/opt/iobroker/log $ ls -l
                                  total 6893644
                                  -rw-rwxr--+ 1 iobroker iobroker      90160 Jan 16 00:00 iobroker.2022-01-15.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker      87270 Jan 17 00:00 iobroker.2022-01-16.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker      96656 Jan 18 00:00 iobroker.2022-01-17.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker      98687 Jan 19 00:00 iobroker.2022-01-18.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker     143200 Jan 20 00:00 iobroker.2022-01-19.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker     136465 Jan 21 00:00 iobroker.2022-01-20.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3811752771 Jan 21 23:59 iobroker.2022-01-21.log
                                  -rw-rwxr--+ 1 iobroker iobroker   73853799 Jan 22 00:06 iobroker.2022-01-21.log.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3172790272 Jan 22 23:59 iobroker.2022-01-22.log
                                  -rw-rwxr--+ 1 iobroker iobroker          0 Jan 23 23:59 iobroker.2022-01-23.log
                                  -rw-rwxr--+ 1 iobroker iobroker          0 Jan 24 23:59 iobroker.2022-01-24.log
                                  -rw-rwxr--+ 1 iobroker iobroker          0 Jan 25 23:59 iobroker.2022-01-25.log
                                  -rw-rwxr--+ 1 iobroker iobroker          0 Jan 26 21:25 iobroker.2022-01-26.log
                                  -rw-rwxr--+ 1 iobroker iobroker          0 Jan 23 00:00 iobroker-audit.json
                                  lrwxrwxrwx  1 iobroker iobroker         23 Jan 26 21:25 iobroker.current.log -> iobroker.2022-01-26.log
                                  wahrscheinlich die mit 3811752771 bytes?
                                  Und was kann ich danach machen? Wieder wie damals "iobroker add admin" ?
                                    Thomas Braun Most Active @Pahan last edited by Thomas Braun
                                    @pahan
                                    Lösch das dickste Ding.
                                    sudo -u iobroker rm /opt/iobroker/log/iobroker.2022-01-21.log
                                    An dem Tag ist dir da was um die Ohren geflogen.
                                    Schau dann in das iobroker.2022-01-21.log.gz rein. Da steht der Verlauf drin.
                                    Danach musste die Kiste auch wieder Luft zum Atmen haben. Mal neu starten.
                                      @Pahan
                                      ab dem 21. ist dein log explodiert. Hast fuvda ein paar Instanzen auf debug gestellt.
                                      stell sie wieder zurück. Ab dem 23. war wohl die Karte voll, dass die logs nicht mehr drauf passten
                                        Hallo Leute,
                                        habe die größte log-Datei gelöscht, Pi rebootet,
                                        jedoch keine Änderung spürbar. Ich bin nach wie vor bei Schritt 1:
                                        Alle diese Eingaben :
                                        iobroker fix
                                        iobroker add admin
                                        iobroker restart
                                        iobroker list adapters
                                        iobroker list instances
                                        iobroker status
                                        liefern absolut keine Reaktion
                                        d.h. ich bin wohl noch weit entfernt, etwas von debug wegzustellen 😞
                                          @pahan
                                          cd /opt/iobroker
                                            @pahan
                                            cd /opt/iobroker
                                            sorry, hatte ich vergessen. Klar, hattest du ja oben schon erwähnt.
                                            Diese Eingabe liefert folgendes:
                                            > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                            > node lib/preinstallCheck.js
                                            NPM version: 6.14.15
                                            > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                                            > node iobroker.js setup first
                                            object _design/custom updated
                                            object _design/system updated
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            + iobroker.js-controller@3.3.22
                                            updated 4 packages in 103.877s
                                            111 packages are looking for funding
                                              run `npm fund` for details
                                            3854
