    4. Material Design Widgets: Adapter Status
      sigi234 Forum Testing Most Active @Wszene last edited by
      @wszene
      Welche Version von javascript hast du?
      Wszene 1 Reply Last reply Reply Quote 0
      • Wszene
        Wszene @sigi234 last edited by
        @sigi234 sagte in Material Design Widgets: Adapter Status:
        @wszene
        Ich habe die Version 5.2.2.1
        System ist:
        Debian 11 LXC
        Node.js: v14.18.3
        NPM: 6.14.15
        • Glasfaser
          Glasfaser @Glasfaser last edited by Glasfaser
          @Wszene
          @glasfaser sagte in Material Design Widgets: Adapter Status:
          Adapter starten und im Log schauen ob eine Fehlermeldung kommt .
          Ich meinte nicht das Script an sich , sondern was beim Hinzufügen des NPM Modul kommt .
          • Wszene
            Wszene @Glasfaser last edited by
            @Wszene
            Achso
            also nochmal 😁
            javascript.0
            2022-01-28 20:37:13.301	info	State value to set for "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" has to be type "boolean" but received type "string"
            javascript.0
            2022-01-28 20:37:13.247	warn	at processTimers (internal/timers.js:500:7)
            javascript.0
            2022-01-28 20:37:13.247	warn	at listOnTimeout (internal/timers.js:557:17)
            javascript.0
            2022-01-28 20:37:13.247	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2117:34)
            javascript.0
            2022-01-28 20:37:13.247	warn	at Object.<anonymous> (script.js.01-Stube.Lampen.Stehlampe_-_An_Aus:115:29)
            javascript.0
            2022-01-28 20:37:13.247	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20)
            javascript.0
            2022-01-28 20:37:13.243	warn	You are assigning a string to the state "0_userdata.0.001_Alexa.01_Stube.Lampen.Stehlampe" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
            vw-connect.0
            2022-01-28 20:37:13.028	error	failed set state
            vw-connect.0
            2022-01-28 20:37:13.027	error	{"error":{"errorCode":"RS.security.9007","description":"The context has not gained a legitimation due to missing access rights."}}
            vw-connect.0
            2022-01-28 20:37:13.027	error	403
            javascript.0
            2022-01-28 20:37:12.276	info	script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar: registered 0 subscriptions and 1 schedule
            javascript.0
            2022-01-28 20:37:12.267	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
            javascript.0
            2022-01-28 20:37:12.267	info	script.js.06-Autos.Scala_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.266	info	Start javascript script.js.06-Autos.Scala_-_Tabelle-Status
            javascript.0
            2022-01-28 20:37:12.265	info	script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.264	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
            javascript.0
            2022-01-28 20:37:12.264	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.263	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
            javascript.0
            2022-01-28 20:37:12.262	info	script.js.001-VIS.Wetter.Wetter_GRH_-_Werte: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.261	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
            javascript.0
            2022-01-28 20:37:12.261	info	script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.260	info	Start javascript script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
            javascript.0
            2022-01-28 20:37:12.259	info	script.js.001-VIS.Wetter.Wetter_DD_-_Werte: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.258	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Werte
            javascript.0
            2022-01-28 20:37:12.258	info	script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.256	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
            javascript.0
            2022-01-28 20:37:12.256	info	script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.255	info	Start javascript script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
            javascript.0
            2022-01-28 20:37:12.255	info	script.js.001-VIS.Welche_Steckdosen_sind_an: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.253	info	Start javascript script.js.001-VIS.Welche_Steckdosen_sind_an
            javascript.0
            2022-01-28 20:37:12.253	info	script.js.001-VIS.Welche_Lampen_sind_an: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.252	info	Start javascript script.js.001-VIS.Welche_Lampen_sind_an
            javascript.0
            2022-01-28 20:37:12.252	info	script.js.02-Schlafzimmer.Dosen.TV-Bett: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.250	info	Start javascript script.js.02-Schlafzimmer.Dosen.TV-Bett
            javascript.0
            2022-01-28 20:37:12.250	info	script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button: registered 1 subscription and 0 schedules
            javascript.0
            2022-01-28 20:37:12.249	info	Start javascript script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
            javascript.0
            2022-01-28 20:37:12.249	info	script.js.01-Stube.Fernbedienungen.Kino_an_aus: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.247	info	Start javascript script.js.01-Stube.Fernbedienungen.Kino_an_aus
            javascript.0
            2022-01-28 20:37:12.247	info	script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.244	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
            javascript.0
            2022-01-28 20:37:12.231	info	script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.230	info	Start javascript script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
            javascript.0
            2022-01-28 20:37:12.230	info	script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.228	info	Start javascript script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
            javascript.0
            2022-01-28 20:37:12.228	info	script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.227	info	Start javascript script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
            javascript.0
            2022-01-28 20:37:12.227	info	script.js.01-Stube.Schalter.Lampe-Sofatisch: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.225	info	Start javascript script.js.01-Stube.Schalter.Lampe-Sofatisch
            javascript.0
            2022-01-28 20:37:12.121	info	script.js.01-Stube.Schalter.Lampe-Esstisch: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.120	info	Start javascript script.js.01-Stube.Schalter.Lampe-Esstisch
            javascript.0
            2022-01-28 20:37:12.120	info	script.js.01-Stube.Lampen.Stehlampe_-_An_Aus: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.118	info	Start javascript script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
            javascript.0
            2022-01-28 20:37:12.118	info	script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.115	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
            javascript.0
            2022-01-28 20:37:12.112	info	script.js.06-Autos.Kodiaq_-_Tabelle-Status: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.111	info	Start javascript script.js.06-Autos.Kodiaq_-_Tabelle-Status
            javascript.0
            2022-01-28 20:37:12.111	info	script.js.001-VIS.Tankstellen_-_offen-geschlossen: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.109	info	Start javascript script.js.001-VIS.Tankstellen_-_offen-geschlossen
            javascript.0
            2022-01-28 20:37:12.109	info	script.js.06-Autos.Telegram_-_Tankerinnerung: registered 0 subscriptions and 1 schedule
            javascript.0
            2022-01-28 20:37:12.092	info	Start javascript script.js.06-Autos.Telegram_-_Tankerinnerung
            javascript.0
            2022-01-28 20:37:12.092	info	script.js.06-Autos.Telegram_-_Standortwechsel: registered 2 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.090	info	Start javascript script.js.06-Autos.Telegram_-_Standortwechsel
            javascript.0
            2022-01-28 20:37:12.090	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster: registered 8 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.088	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
            javascript.0
            2022-01-28 20:37:12.088	info	script.js.06-Autos.Kodiaq_-_Standheizung: registered 3 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.087	info	Start javascript script.js.06-Autos.Kodiaq_-_Standheizung
            javascript.0
            2022-01-28 20:37:12.086	info	script.js.06-Autos.Scala_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.085	info	Start javascript script.js.06-Autos.Scala_-_Datenpunkte_anlegen
            javascript.0
            2022-01-28 20:37:12.085	info	script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen: registered 0 subscriptions and 0 schedules
            javascript.0
            2022-01-28 20:37:12.079	info	Start javascript script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
            javascript.0
            2022-01-28 20:37:12.079	info	script.js.03-Flur-Kammer.Kammerlicht_schalten: registered 1 subscription and 0 schedules
            javascript.0
            2022-01-28 20:37:12.077	info	Start javascript script.js.03-Flur-Kammer.Kammerlicht_schalten
            javascript.0
            2022-01-28 20:37:12.077	info	script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum: registered 0 subscriptions and 4 schedules
            javascript.0
            2022-01-28 20:37:12.054	info	Start javascript script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
            javascript.0
            2022-01-28 20:37:11.793	info	received all states
            javascript.0
            2022-01-28 20:37:11.343	info	received all objects
            javascript.0
            2022-01-28 20:37:10.139	info	requesting all objects
            javascript.0
            2022-01-28 20:37:10.138	info	requesting all states
            javascript.0
            2022-01-28 20:37:10.100	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.3, js-controller: 3.3.22
            host.ioBroker02
            2022-01-28 20:37:09.239	info	instance system.adapter.javascript.0 started with pid 73225
            host.ioBroker02
            2022-01-28 20:37:06.743	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            javascript.0
            2022-01-28 20:37:06.204	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            javascript.0
            2022-01-28 20:37:06.203	info	terminating
            javascript.0
            2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_DWD-Regenradar
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Überschriften
            javascript.0
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.001-VIS.Welche_Lampen_sind_an
            javascript.0
            javascript.0
            2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Fernbedienungen.AV-Receiver_-_Lautstärke
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.196	info	Stop script script.js.01-Stube.Lampen.Stehlampe_-_An_Aus
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Tankerinnerung
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.200	info	Stop script script.js.06-Autos.Scala_-_Tabelle-Status
            javascript.0
            2022-01-28 20:37:06.200	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Es_regnet_oder_schneit_oder_stürmt
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_Werte
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_GRH_-_MinMax-Temp
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Werte
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_MinMax-Temp
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Wetter.Wetter_DD_-_Überschriften
            javascript.0
            2022-01-28 20:37:06.199	info	Stop script script.js.001-VIS.Welche_Steckdosen_sind_an
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Dosen.TV-Bett
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.02-Schlafzimmer.Taster.Sleeptimer_-_Button
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.Kino_an_aus
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Sender_schalten_-_Alexa
            javascript.0
            2022-01-28 20:37:06.198	info	Stop script script.js.01-Stube.Fernbedienungen.TV_Kanal_-_Hoch_Runter
            javascript.0
            javascript.0
            javascript.0
            2022-01-28 20:37:06.197	info	Stop script script.js.02-Schlafzimmer.Schalter.Schlafzimmerlampe
            javascript.0
            2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Sofatisch
            javascript.0
            2022-01-28 20:37:06.197	info	Stop script script.js.01-Stube.Schalter.Lampe-Esstisch
            javascript.0
            javascript.0
            2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle_Türen-Fenster
            javascript.0
            2022-01-28 20:37:06.196	info	Stop script script.js.06-Autos.Kodiaq_-_Tabelle-Status
            javascript.0
            2022-01-28 20:37:06.196	info	Stop script script.js.001-VIS.Tankstellen_-_offen-geschlossen
            javascript.0
            javascript.0
            2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Telegram_-_Standortwechsel
            javascript.0
            2022-01-28 20:37:06.195	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_Tueren-Fenster
            javascript.0
            2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Standheizung
            javascript.0
            2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Scala_-_Datenpunkte_anlegen
            javascript.0
            2022-01-28 20:37:06.194	info	Stop script script.js.06-Autos.Kodiaq_-_Datenpunkte_anlegen
            javascript.0
            2022-01-28 20:37:06.194	info	Stop script script.js.03-Flur-Kammer.Kammerlicht_schalten
            javascript.0
            2022-01-28 20:37:06.193	info	Stop script script.js.01-Stube.Lampen.Zeitplan_-_Leuchtbaum
            javascript.0
            2022-01-28 20:37:06.190	info	Got terminate signal TERMINATE_YOURSELF
            host.ioBroker02
            2022-01-28 20:37:06.197	info	stopInstance system.adapter.javascript.0 send kill signal
            host.ioBroker02
            2022-01-28 20:37:06.187	info	stopInstance system.adapter.javascript.0 (force=false, process=true)
            • Glasfaser
              Glasfaser @Wszene last edited by
              @wszene
              Fehler gefunden ... trage es oben ein :
              • Wszene
                @wszene
                Sehr schön das scheint es gewesen zu sein
                Jetzt hat sich auch der Datenpunkt "jsonList" gefüllt
                Aber die anderen 3 bleiben leer
                • Glasfaser
                  Glasfaser @Wszene last edited by Glasfaser
                  @wszene sagte in Material Design Widgets: Adapter Status:
                  Die werden erst mit dem View gefüllt ( Auswahl .... )
                  • Wszene
                    OK ich habe die View mal importiert aber die DPs bleiben leer ich habe die View auch aufgerufen
                    Muss ich irgendwo meine eigenen DPs angeben ich habe nur gefunden wo ich die JsonList einfügen muss
                    • Glasfaser
                      @wszene
                      hier bei den beiden Widgets
                      • Wszene
                        Wszene @Glasfaser last edited by Wszene
                        @wszene
                        Ja wenn ich da Filter oder Sortiere passiert leider nichts
                        PS:
                        Habe gerade im Log gesehen das er die falschen DPs ansprechen will
                        web.0
                        2022-01-28 21:03:14.802	warn	State "0_userdata.0.vis.AdapterStatus.filterMode" has no existing object, this might lead to an error in future versions
                        web.0
                        2022-01-28 21:02:49.672	warn	State "0_userdata.0.vis.AdapterStatus.sortMode" has no existing object, this might lead to an error in future versions
                        Glasfaser 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          @wszene
                          Hast du dort ... im Vis Editor bei den beiden Widgets deine Datenpunkte eingetragen !?
                          • Glasfaser
                            und genau das meinte ich !
                            • Wszene
                              Ja aber wo muss ich denn meinen DP im Widget einfügen
                              • Glasfaser
                                @wszene
                                • Wszene
                                  @glasfaser
                                  Danke jetzt geht es
                                  Ich sollte wohl doch ins Bett gehen und morgen weiter machen
                                  Seid 2Uhr wach dann sollte man soetwas um diese Zeit nicht mehr machen
                                  Aber nochmal 1000Dank für deine Geduld
                                  • O
                                    ostseeskipper last edited by ostseeskipper
                                    Für alle die am Anfang Probleme mit den nicht angelegten Datenpunkten haben, werden hier automatisch angelegt wenn sie noch nicht da sind. Zeilen 11 bis 17
                                    // Skript Einstellungen *************************************************************************************************************************************************
                                    // Imports -> müssen im Javascript Adapter unter 'Zusätzliche NPM-Module' eingetragen sein
                                    const moment = require("moment");
                                    const momentDurationFormatSetup = require("moment-duration-format");
                                    // Datenpunkte anlegen falls nicht vorhanden ********************************
                                    if ( !existsState("0_userdata.0.vis.AdapterStatus.jsonList")){createState("0_userdata.0.vis.AdapterStatus.jsonList", false, {type: 'string'})};
                                    if ( !existsState("0_userdata.0.vis.AdapterStatus.restartTrigger")){createState("0_userdata.0.vis.AdapterStatus.restartTrigger", false, {type: 'string'})};
                                    if ( !existsState("0_userdata.0.vis.AdapterStatus.sortMode")){createState("0_userdata.0.vis.AdapterStatus.sortMode", false, {type: 'string'})};
                                    if ( !existsState("0_userdata.0.vis.AdapterStatus.filterMode")){createState("0_userdata.0.vis.AdapterStatus.filterMode", false, {type: 'string'})};
                                    let dpList = '0_userdata.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                                    let dpAdapterRestart = '0_userdata.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                                    let dpSortMode = '0_userdata.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                                    let dpFilterMode = '0_userdata.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                                    let adminUpdatesList = 'admin.0.info.updatesList';                          // Datenpunkt Admin Adapter für verfübare Updates der Adapter
                                    const checkInterval = 30;                                                   // Interval wie oft Status der Adapter aktualisiert werden soll (in Sekunden)
                                    let sprache = 'de';                                                         // Sprache für formatierung Dauer
                                    let formatierungDauer = "dd[T] hh[h] mm[m]";                                // Formatierung der Dauer -> siehe momentjs library
                                    let neustarten = true;                                                      // true: Adapter wird neugestartet, false: Adapter wird gestoppt oder gestartet
                                    let farbeAdapterAktiv = 'green';                                            // Status Bar Farbe wenn Adapter aktiv ist
                                    let farbeAdapterNichtAktiv = 'FireBrick';                                   // Status Bar Farbe wenn Adapter nicht aktiv ist oder Fehler vorliegt
                                    let farbeAdapterDeaktiviert = 'darkgrey';                                   // Status Bar Farbe wenn Adapter deaktiviert ist
                                    let farbeAdapterNichtVerbunden = 'yellow';                                  // Status Bar Farbe wenn Adapter nicht verbunden ist
                                    let farbeAdapterZeitgesteuert = 'lightgreen';                               // Status Bar Farbe wenn Adapter zeitgesteuert ist
                                    let farbeAdapterErweiterung = '#44739e';                                    // Status Bar Farbe wenn Adapter Erweiterung ist
                                    let farbeAdapterSystem = '#44739e';                                         // Status Bar Farbe wenn Adapter mit System gestartet wird
                                    let sortResetAfter = 120;                                                   // Sortierung nach X Sekunden auf sortReset zurücksetzen (0=deaktiviert)
                                    let sortReset = 'memHeapUsed'                                               // Sortierung auf die zurückgesetzt werden soll
                                    let filterResetAfter = 120;                                                 // Filter nach X Sekunden zurücksetzen (0=deaktiviert)
                                    // Fomate für moment Lib
                                    moment.locale(sprache);
                                    // auf .alive Änderungen hören
                                    let aliveSelector = `[id=system.adapter.*.alive]`;
                                    let adapterAliveList = $(aliveSelector);
                                    if (adapterAliveList.length === 0) {
                                        // Fehlermeldung ausgeben, wenn selector kein result liefert
                                        console.error(`no result for selector '${aliveSelector}'`)
                                    } else {
                                        // listener nur für Änderung bei alive
                                        adapterAliveList.on(adapterStatus);
                                    // auf .connection Änderungen hören
                                    let connectionSelector = `[id=*.info.connection]`;
                                    let adapterConnectionList = $(connectionSelector);
                                    if (adapterConnectionList.length === 0) {
                                        console.error(`no result for selector '${connectionSelector}'`)
                                    } else {
                                        adapterConnectionList.on(adapterStatus);
                                    // auf .connected Änderungen hören
                                    let connectedSelector = `[id=system.adapter.*.connected]`;
                                    let adapterConnectedList = $(connectedSelector);
                                    if (adapterConnectedList.length === 0) {
                                        console.error(`no result for selector '${connectedSelector}'`)
                                    } else {
                                        adapterConnectedList.on(adapterStatus);
                                    // auf Änderungen der Sortieung hören
                                    on({ id: dpSortMode, change: 'any' }, adapterStatus);
                                    on({ id: dpSortMode, change: 'any' }, resetSort);
                                    // auf Änderungen der Filter hören
                                    on({ id: dpFilterMode, change: 'any' }, adapterStatus);
                                    on({ id: dpFilterMode, change: 'any' }, resetFilter);
                                    // Funktion adapterStatus alle x Sekunden ausführen
                                    schedule('*/' + checkInterval + ' * * * * *', adapterStatus);
                                    function adapterStatus() {
                                        // Funktion um Status der Adapter abzurufen und als JSON String für das Material Design Widget IconList aufbereiten
                                        try {
                                            let adapterList = [];
                                            let updateList = myHelper().getStateValueIfExist(adminUpdatesList);
                                            for (var i = 0; i <= adapterAliveList.length - 1; i++) {
                                                let id = adapterAliveList[i].replace('.alive', '');
                                                let obj = getObject(adapterAliveList[i].replace('.alive', ''));
                                                let nameArray = id.replace('system.adapter.', '').split(".");
                                                let name = nameArray[0];
                                                name = name.charAt(0).toUpperCase() + name.slice(1);
                                                let nameWithInstance = name;
                                                let adapterInstance = nameArray[1];
                                                if (parseInt(adapterInstance) > 0) {
                                                    nameWithInstance = name + '.' + adapterInstance;
                                                let uptime = (existsState(id + '.uptime')) ? moment.duration(getState(id + '.uptime').val, 'seconds').format(formatierungDauer, 0) : '-';
                                                let image = (myHelper().checkCommonPropertyExist(obj, 'icon')) ? `/${nameArray[0]}.admin/${obj.common.icon}` : 'image-off-outline';
                                                let hasUpdates = updateList && updateList.includes(nameArray[0]);
                                                let newVersion = (hasUpdates) ? '<span class="mdi mdi-update" style="color: #ec0909;"></span>' : '';
                                                let text = `<div style="display: flex; flex-direction: row; line-height: 1.5; padding-right: 8px; align-items: center;">
        <div style="flex: 1">${newVersion} ${nameWithInstance}</div>
        <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic;">${myHelper().getCommonPropertyIfExist(obj, 'version', '-', 'v', '')}</div>
                                                            </div>`
                                                let subText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
        <div style="flex: 1;">CPU</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.cpu', '-', '', ' %')}</div>
        </div>
        <div style="flex: 1;">RAM total</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapTotal', '-', '', ' MB')}</div>
        </div>
        <div style="flex: 1;">RAM verwendet</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memHeapUsed', '-', '', ' MB')}</div>
        </div>
        <div style="flex: 1;">RAM reserviert</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getStateValueIfExist(id + '.memRss', '-', '', ' MB')}</div>
        </div>
        <div style="flex: 1;">Betriebszeit</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${uptime}</div>
        </div>
        <div style="flex: 1;">Modus</div>
        <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic; text-align: right;">${myHelper().getCommonPropertyIfExist(obj, 'mode', '-')}</div>
        </div>`
                                                let statusBarColor = farbeAdapterNichtAktiv;
                                                let status = 3;
                                                if (myHelper().getStateValueIfExist(adapterAliveList[i]) === 'true') {
                                                    statusBarColor = farbeAdapterAktiv;
                                                    status = 0;
                                                    if (existsState(id.replace('system.adapter.', '') + '.info.connection')) {
                                                        if (!getState(id.replace('system.adapter.', '') + '.info.connection').val) {
                                                            statusBarColor = farbeAdapterNichtVerbunden;
                                                            status = 4;
                                                    } else {
                                                        if (myHelper().getStateValueIfExist(adapterAliveList[i].replace('.alive', '.connected')) === 'false') {
                                                            status = 4;
                                                if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'schedule') {
                                                    // Adapter ist zeitgesteuert
                                                    statusBarColor = farbeAdapterZeitgesteuert;
                                                    status = 1;
                                                if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'extension') {
                                                    // Adapter ist Extension
                                                    statusBarColor = farbeAdapterErweiterung;
                                                    status = 1;
                                                if (myHelper().getCommonPropertyIfExist(obj, 'mode') === 'once') {
                                                    // Adapter wird mit System gestartet
                                                    statusBarColor = farbeAdapterSystem;
                                                    status = 1;
                                                if (myHelper().getCommonPropertyIfExist(obj, 'enabled', false).toString() === 'false') {
                                                    // Adapter ist deaktiviert
                                                    statusBarColor = farbeAdapterDeaktiviert;
                                                    status = 2;
                                                adapterList.push({
                                                    text: text,
                                                    subText: subText,
                                                    image: image,
                                                    listType: "buttonState",
                                                    objectId: dpAdapterRestart,
                                                    buttonStateValue: id,
                                                    statusBarColor: statusBarColor,
                                                    showValueLabel: false,
                                                    mode: myHelper().getCommonPropertyIfExist(obj, 'mode'),
                                                    hasUpdates: hasUpdates,
                                                    cpu: parseFloat(myHelper().getStateValueIfExist(id + '.cpu', '0')),
                                                    memHeapTotal: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapTotal', '0')),
                                                    memHeapUsed: parseFloat(myHelper().getStateValueIfExist(id + '.memHeapUsed', '0')),
                                                    memRss: parseFloat(myHelper().getStateValueIfExist(id + '.memRss', '0')),
                                                    uptime: parseFloat(myHelper().getStateValueIfExist(id + '.uptime', 0)),
                                                    status: status,
                                                    lockEnabled: true
                                            let sortMode = myHelper().getStateValueIfExist(dpSortMode, 'name');
                                            if (sortMode === 'name' || sortMode === 'mode') {
                                                adapterList.sort(function (a, b) {
                                                    return a[sortMode].toLowerCase() == b[sortMode].toLowerCase() ? 0 : +(a[sortMode].toLowerCase() > b[sortMode].toLowerCase()) || -1;
                                            } else if (sortMode === 'hasUpdates' || sortMode === 'cpu' || sortMode === 'memHeapTotal' || sortMode === 'memHeapUsed' || sortMode === 'memRss' || sortMode === 'uptime' || sortMode === 'status') {
                                                    return a[sortMode] == b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                                            } else {
                                                // default: nach name sortieren
                                                sortMode = 'name'
                                            // Filter: not connected, updates, deaktiviert, aktiviert
                                            let filterMode = myHelper().getStateValueIfExist(dpFilterMode, null);
                                            if (filterMode && filterMode !== null && filterMode !== '') {
                                                if (filterMode === 'hasUpdates') {
                                                    adapterList = adapterList.filter(function (item) {
                                                        return item.hasUpdates === true;
                                                } else if (filterMode === 'notConnected') {
                                                        return item.status === 4;
                                                } else if (filterMode === 'deactivated') {
                                                        return item.status === 2;
                                                } else if (filterMode === 'activated') {
                                                        return item.status <= 1;
                                            let result = JSON.stringify(adapterList);
                                            if (existsState(dpList) && getState(dpList).val !== result) {
                                                setState(dpList, result, true);
                                            } else {
                                        } catch (err) {
                                            console.error(`[adapterStatus] error: ${err.message}, stack: ${err.stack}`);
                                    // Beim Staren des Skriptes Adapter Status abrufen
                                    adapterStatus();
                                    // Funktion um Adapter zu starten / neu starten
                                    on({ id: dpAdapterRestart }, function (obj) {
                                        var adapter = getObject(obj.state.val.toString());
                                        if (neustarten) {
                                            if (adapter.common && adapter.common.enabled === false) {
                                                // Adapter deaktiviert -> starten
                                                adapter.common.enabled = true;
                                        } else {
                                            if (adapter.common && adapter.common.enabled) {
                                                adapter.common.enabled = !adapter.common.enabled;
                                            } else {
                                        setObject(obj.state.val, adapter);
                                        console.log(`${obj.state.val.replace('system.adapter.', '')} neugestartet`);
                                    function resetSort() {
                                        let sortMode = myHelper().getStateValueIfExist(dpSortMode, null);
                                        if (sortResetAfter > 0) {
                                            setTimeout(function () {
                                                if (sortMode !== null && sortMode === myHelper().getStateValueIfExist(dpSortMode, null)) {
                                                    setState(dpSortMode, sortReset);
                                            }, sortResetAfter * 1000);
                                    function resetFilter() {
                                        if (filterResetAfter > 0) {
                                                if (filterMode !== null && filterMode === myHelper().getStateValueIfExist(dpFilterMode, null)) {
                                                    setState(dpFilterMode, '');
                                            }, filterResetAfter * 1000);
                                    function myHelper() {
                                        return {
                                            getStateValueIfExist: function (id, nullValue = undefined, prepand = '', append = '') {
                                                if (existsState(id)) {
                                                    return prepand + getState(id).val + append;
                                                } else {
                                                    return nullValue;
                                            getCommonPropertyIfExist: function (object, prop, nullValue = undefined, prepand = '', append = '') {
                                                if (myHelper().checkCommonPropertyExist(object, prop)) {
                                                    return prepand + object.common[prop] + append;
                                                } else {
                                                    return nullValue;
                                            checkCommonPropertyExist: function (object, prop) {
                                                if (object && object.common && object.common[prop]) {
                                                    return true;
                                                } else {
                                                    return false;
                                    • daes10
                                      daes10 last edited by
                                      @ostseeskipper Vielen Dank, hat bei mir auch gut funktioniert.
                                      Kann mir aber jemand helfen, warum bei mir überall undefined angezeigt wird?
                                      Hab ich eine Einstellung übersehen? Weil alle Daten werden korrekt abgefragt.
                                      I M L 3 Replies Last reply Reply Quote 0
                                      • I
                                        Idefix01 @daes10 last edited by
                                        Hallöchen, ein super Script.
                                        Nur das mit der Farbe für die Werte funktioniert bei mir nicht, diese bleibt weiterhin grau
                                        let dpList = 'javascript.0.vis.AdapterStatus.jsonList';                     // Datenpunkt für IconList Widget (Typ: Zeichenkette (String))
                                        let dpAdapterRestart = 'javascript.0.vis.AdapterStatus.restartTrigger';     // Datenpunkt für Adapter restart (Typ: Zeichenkette (String))
                                        let dpSortMode = 'javascript.0.vis.AdapterStatus.sortMode';                 // Datenpunkt für Sortieren (Typ: Zeichenkette (String))
                                        let dpFilterMode = 'javascript.0.vis.AdapterStatus.filterMode';             // Datenpunkt für Filter (Typ: Zeichenkette (String))
                                        let farbeAdapterWerte = '#ffffff';                                       // Sekundärfarbe Adapterwerte, einer muss auskommentiert sein !
                                          cst9 last edited by
                                          bei mir ist das Problem, das wenn ich die Filter über ein mobiles Gerät anwähle, wird das Bild vergrößert sprich herangezoomt. Dabei spielt es auch keine Rolle ob man es über die App oder den Browser benutzt, es wird immer komischerweise immer herangezoomt.
                                          Hat jemand das gleiche Problem und wie kann ich das abschalten?
                                          Schöne Grüße
                                            Frank579 @Scrounger last edited by
                                            @scrounger Hallo ich nutze das skript jetzt schon etwas länger, echt klasse gemacht 👍 Habe kürzlich den Weatherunderground Adapter installiert, die Kachel von dem sieht irgendwiw komisch aus, Hast du oder wer anders eine Idee dazu.
                                            Gruß Frank
                                            adapter iconlist material design widgets statusanzeige view view adapter vis
                                            48
                                            144
                                            31540
