    4. Zufallsgesteuerte Lampe
      Dragon last edited by Dragon
      Habe es einfach fix nachgebaut...
        <variables>
          <variable id="3wfh1q0Y%)oWzNS3z05I">cnt</variable>
          <variable type="interval" id="Intervall">Intervall</variable>
        </variables>
        <block type="astro" id="B(R9I]6b#hfxw5+Q#1t%" x="-62" y="38">
          <field name="TYPE">sunrise</field>
          <field name="OFFSET">0</field>
            <block type="timeouts_clearinterval" id="^qo0.eRIR}F%mD_H(V[l">
              <field name="NAME">Intervall</field>
            <block type="astro" id="zqF{-`,gtQC!sKjmAOdD">
              <field name="TYPE">sunset</field>
                <block type="controls_if" id="9,X]gkj%/sV;OUBt/Us(">
                    <block type="logic_negate" id=".25J:qS?|;G71+YCJfcD">
                      <value name="BOOL">
                        <block type="get_value" id="VR!iGZx4;d]3vxlmRMl,">
                          <field name="OID">javascript.0.EigeneDatenpunkte.Person_anwesend</field>
                    <block type="procedures_callnoreturn" id="z?:T8x8md;7aEI}zneO+">
                      <mutation name="ZufallLicht"></mutation>
                <block type="on_ext" id="}~ZMD9[{xrsRJGY#FAF0">
                  <value name="OID0">
                    <shadow type="field_oid" id="E*HX]_ht%B}{bt--!`y`">
                      <field name="oid">javascript.0.EigeneDatenpunkte.Person_anwesend</field>
                    <block type="controls_if" id="%3AV$Q@uVu=3!,)*)h`L">
                        <block type="on_source" id="Mz`X)+Vv+=8Al2)c0=uz">
                        <block type="timeouts_clearinterval" id="|Nu5^Y?o)wqe;9;O]I}6">
                      <value name="IF1">
                        <block type="time_compare_ex" id="8nW;cKjt*m*.~rpnB]}W">
                          <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                          <field name="OPTION">not between</field>
                          <value name="START_TIME">
                            <shadow type="text" id="k=u8nlP2f|?@d%0g@yB~">
                              <field name="TEXT">12:00</field>
                            <block type="time_astro" id="GkfGvq68bEH-/=ff,.[X">
                          <value name="END_TIME">
                            <shadow type="text" id=";[HSbpaytMYNoww^,Lb0">
                              <field name="TEXT">18:00</field>
                            <block type="time_astro" id="Lk`AG]vW|5H5x3ET#qUi">
                      <statement name="DO1">
                        <block type="procedures_callnoreturn" id="wM}2T}bME):eulf(HUQR">
        <block type="procedures_defnoreturn" id="1}JoNwFetn#r.CU39RtM" x="463" y="13">
          <field name="NAME">ZufallLicht</field>
          <statement name="STACK">
            <block type="variables_set" id="U{8oI;E.s-(_J0F.w:=B">
              <field name="VAR" id="3wfh1q0Y%)oWzNS3z05I">cnt</field>
                <block type="math_random_int" id="x:^cNx~}gNdOFNC,~04K">
                  <value name="FROM">
                    <shadow type="math_number" id="E=ZW}7A,#Z|(2R;oQN,q">
                      <field name="NUM">1</field>
                  <value name="TO">
                    <shadow type="math_number" id="zJ,Xa=ns/3(qoI:F)J72">
                      <field name="NUM">100</field>
                <block type="timeouts_setinterval" id="{(_qCRR:vF=x-P9ZOBgz">
                  <field name="INTERVAL">1</field>
                    <block type="math_change" id="wvPH.|%4x-sOPwaVxnA9">
                      <value name="DELTA">
                        <shadow type="math_number" id="){;`g8Z_N#54*-yUn8Br">
                          <field name="NUM">-1</field>
                        <block type="controls_if" id="mz^_Tl.0x#*zNMmwutkc">
                            <block type="logic_compare" id="`O=P*PWlqtEn|PNb.Q,q">
                              <field name="OP">LTE</field>
                                <block type="variables_get" id="bqF5QD|~|,n1$Q`sfB|(">
                                <block type="math_number" id="PM-6)A`h@Ez0k_on35bn">
                                  <field name="NUM">0</field>
                            <block type="toggle" id="N$Qd]T]5OGpMm.$HM7$A">
                                <block type="variables_set" id="/gXrXw6D^yKHI){{8m4r">
                                    <block type="math_random_int" id="p$DDu0aGm~@V+]bLQkm+">
                                      <value name="FROM">
                                        <shadow type="math_number" id="I_NJz`G/3BV@!wAziy7P">
                                      <value name="TO">
                                        <shadow type="math_number" id="I-`+q/NA;NRNe_JU@cA$">
        gluecksmann @Dragon last edited by
        @dragon
        Bekomme eine Fehlermeldung wenn ich es importieren will...
        paul53 S G 3 Replies Last reply Reply Quote 0
          paul53 @gluecksmann last edited by
          @gluecksmann sagte: Bekomme eine Fehlermeldung wenn ich es importieren will...
          Ich nicht. Muss also am Markieren des zu kopierenden Bereiches liegen.
            smarthome2020 @gluecksmann last edited by
            @gluecksmann
            Bei mir geht das Reinkopieren auch.
            Danke für das Blockly
              gluecksmann @paul53 last edited by
              Was kann man denn da falsch machen... markiere das alles, kopiere es, und sage dann im Blockly Blöcke importieren
              • David G.
                David G. @gluecksmann last edited by David G.
                @gluecksmann
                So mache ich es.
                Falls mal noch ein paar Lampen bei kommen.
                30min vor Sonnenuntergang wird eine zufällige Zeit (Spanne vorgegeben) ermittelt wann die Simulation beginnt.
                Wenn es dann los geht, werden die Lampen in willkürlicher Reihenfolge in zufälligen Abständen
                (auch hier ist die Spanne vorgegeben) eingeschaltet.
                  gluecksmann @gluecksmann last edited by gluecksmann
                  @gluecksmann
                  jetzt hat der Import funktioniert ...was macht der Datenpunkt anwesenheit? wird das geprüft ob wer da ist?
                    @gluecksmann sagte: was macht der Datenpunkt anwesenheit? wird das geprüft ob wer da ist?
                    Ja, wenn jemand anwesend ist, braucht es keine Anwesenheitssimulation.
                    • David G.
                      David G. @paul53 last edited by
                      Außer man ist zu faul zum Licht einschalten.
                      Hab die immer am laufen 🤣.
                      Haben abends eigentlich nur kleine Lichter an die es gemütlich machen. Da geht das ^^.
                      Fügt sich gut in unsern Alltag ein 😁.
                      • Meister Mopper
                        Meister Mopper @David G. last edited by
                        Im Fall, dass alle Lampen beim Start der Automation aus sind, schalten alle Lampen immer gleich, also an oder aus.
                        Es wäre ja noch genialer, wenn die Lampen zufällig an oder aus gingen, so dass von außen wirklich der Eindruck entsteht, dass Leben im Haus ist.
                        Hat jemand eine Idee, wie man das realisieren könnte?
                        • David G.
                          David G. @Meister Mopper last edited by David G.
                          @meister-mopper
                          Mein Post (3-4 Beiträge) weiter oben.
                          Mehr Zufall geht denke nicht.
                          Zum ausschalten habe ich leicht angepasst (eigener Datenpunkt zum de- aktivieren und anderen Trigger und eigene Funktion) das selbe Skript.
                          Bei den Lampen die berücksichtigt werden habe ich eine Funktion unter den Objekten vergeben nach denen das Skript sucht.
                          • Meister Mopper
                            @david-g
                            Die Logik Deines Scripts erschließt sich mir leider noch nicht. Wo befinden sich im Script die zu schaltenden Lampen?
                            • David G.
                              @meister-mopper
                              Im "id vom selektor".
                              Musst unter den Objekten im Iobroker eine Funktion vergeben (vorher anlegen).
                              Im Beispiel "abend_auto_an".
                              Die nimmt das Skript dann alle.
                              Ist leichter als alles im Skript zu pflegen.
                              • Meister Mopper
                                @david-g sagte in Zufallsgesteuerte Lampe:
                                Genau das kenne/verstehe ich nicht. Wie macht man das konkret?
                                • David G.
                                  @meister-mopper
                                  Hier eine Funktion anlegen
                                  Und hier vergeben
                                  EDIT:
                                  Vergeben kannst du die Funktionen auch im ersten Bild schon.
                                  EDIT 2:
                                  Nutze ich für recht viel die Funktion.
                                  Kann man auch im Trigger verwenden.
                                  Hab zB eine Funktion für die Alarmanlage.
                                  So kann ich alle Kontakte überwachen ohne jeden in Blockly aufzunehmen.
                                  • Meister Mopper
                                    Meister Mopper last edited by Meister Mopper
                                    @david-g
                                    Ah ok, mit aliases habe ich bisher noch nichts gemacht. Bei den Aufzählungen habe ich einige Lampen unter FuncLight.
                                    Die will ich aber nicht alle in eine Zufallsschaltung einbeziehen.
                                    Danke, da muss ich mich erst noch reinfuchsen. Das liest sich sehr interessant.
                                    • David G.
                                      @meister-mopper
                                      Alias braucht man da für nicht. Geht mit jedem Datenpunkt.
                                      Datenpunkte können auch mehrere Funktionen zugeordnet sein.
                                      In FuncLight habe ich alle Lampen. Die Lampen die bei der Simulation angehen sollen zusätzlich noch die entsprechende Funktion.
                                      Manche Lampen haben bei mir funclight, abend_auto_an, abend_auto_aus und noch eine für Lampen die eingeschaltet werden sollen wenn die Alarmanlage auslöst.
                                      • Meister Mopper
                                        @david-g
                                        Super, dass man sie in verschiedene Funktionen einbinden kann, wusste ich nicht. Das eröffnet ja ungeahnte Möglichkeiten!
                                        • David G.
                                          @meister-mopper
                                          Oh ja, als @paul53 mir das mal gezeigt hat hab ich selbiges gedacht.
                                          Mittlerweile auch echt viel drüber am laufen.
                                          Finde eben auch praktisch, dass man es als Trigger und in einem Skript verwenden kann.
                                          Meister Mopper 2 Replies Last reply Reply Quote 0
                                          • Meister Mopper
                                            @david-g
                                            Na dann mal in die Hände gespuckt. Danke Dir nochmal 😀
                                            2721
