    4. JavaScript
    5. [Vorlage] upnp Media Player
      Berchemer @Jey Cee last edited by Berchemer
      @jey-cee
      Kannst Du etwas mit den folgenden Meldungen anfangen?
      Unexpected answer from upnp service: {"statusCode":500,"body":"<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>","headers":{"content-length":"347","content-type":"text/xml; charset=\"utf-8\"","ext":"","server":"Linux UPnP/1.0 Sonos/67.1-25031 (ZPS21)","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.0.73:1400","port":"1400","hostname":"192.168.0.73","hash":null,"search":null,"query":null,"pathname":"/MediaRenderer/AVTransport/Control","path":"/MediaRenderer/AVTransport/Control","href":"http://192.168.0.73:1400/MediaRenderer/AVTransport/Control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:AVTransport:1#Play\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":298}}} Sent message: {"uri":"http://192.168.0.73:1400/MediaRenderer/AVTransport/Control","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:AVTransport:1#Play\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":" \n <s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n <s:Body><u:Play xmlns:u=\"urn:schemas-upnp-org:service:AVTransport:1\"><InstanceID>0</InstanceID><Speed>1</Speed></u:Play></s:Body>\n </s:Envelope>"}
      Unexpected answer from upnp service: {"statusCode":405,"body":"<html><head><title>405 Method Not Allowed</title></head><body><h1>Method Not Allowed</h1><p>The requested URL cannot be accessed with the requested method.</p></body></html>","headers":{"content-type":"text/html","content-length":"173"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.0.81","port":80,"hostname":"192.168.0.81","hash":null,"search":null,"query":null,"pathname":"/:8080AVTransport/control","path":"/:8080AVTransport/control","href":"http://192.168.0.81/:8080AVTransport/control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":431}}} Sent message: {"uri":"http://192.168.0.81:8080AVTransport/control","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":" \n <s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n <s:Body><u:SetAVTransportURI xmlns:u=\"urn:schemas-upnp-org:service:AVTransport:1\"><InstanceID>0</InstanceID><CurrentURI>http://192.168.0.131:8082/vis.0/Sounds01/google.tts.mp3</CurrentURI><CurrentURIMetaData></CurrentURIMetaData></u:SetAVTransportURI></s:Body>\n </s:Envelope>"}
        @jey-cee
        Und beim Sonos (die obere der beiden o.g. Meldungen) kommt noch folgende Fehlermeldung im Log von ioBroker:
        Cannot remove track: RequestFailedError: Got status 500 when invoking /MediaRenderer/AVTransport/Control
          Berchemer @Berchemer last edited by
          @berchemer sagte in [Vorlage] upnp Media Player:
          könnte es damit zusammenhängen, dass der UPNP-Adapter anscheinend die URL falsch aufbaut?
          statt
          http://192.168.0.81:8080/AVTransport/control
          • Jey Cee
            Jey Cee Developer @Berchemer last edited by
            @berchemer Status 500 ist die Rückmeldung vom Gerät das es ein internes Problem gab. Die Sonos gibt den Fehler Code 701 als Nachricht zurück, was soweit ich das auf die schnelle herausgefunden habe auf ein Verbindungsproblem hindeutet.
            https://en.community.sonos.com/troubleshooting-228999/an-error-occurred-while-adding-songs-to-the-queue-701-6795301
            Ja der zweite Fehler dürfte daraus resultieren. Die Frage ist warum das falsch ist.
            Kannst du mal das entsprechende Objekt AVTransport öffnen und hier posten.
              @jey-cee sagte in [Vorlage] upnp Media Player:
              Gerne, aber das System sagt mir etwas von "Payload too large" und verweigert das Absenden 😞
                Habe es hier als Anhang gepostet:
                https://github.com/iobroker-community-adapters/ioBroker.upnp/issues/104
                Berchemer created this issue in iobroker-community-adapters/ioBroker.upnp
                open [Bug]: Adapter seems to create wrong url #104
                  Btw: Die Einstellung automatisch erkennen kann ich ja nachvollziehen.
                  Was bedeutet aber die EInstellung "Automatisch Abonnement"?
                  • Jey Cee
                    @berchemer upnp sieht vor das ein Dienst seinen Aktuellen Zustand mitteilt wenn ein Client ihn Abonniert.
                    So muss er nicht immer Abfragen.
                    Aber was übermittelt wird hängt vom Dienst ab. Bei MediaRender war das soweit ich mich erinnere nur infos über die Wiedergabe, also was gespielt wird, play, pause, stop.
                      Berchemer last edited by Berchemer
                      Und weitere Frage zum Adapter:
                      Im Objekte-Tab von ioBroker ist unter den Einstellungen, wo man auch die History-Daten einstellen kann, auch UPNP mit der Möglichkeit "Aktiviert/Nicht aktiviert" auswählbar. Was bewirkt denn das Aktivieren???
                      • Jey Cee
                        @berchemer funktioniert nur bei dem dp request und bietet die Möglichkeit den Zyklisch aus zu führen.
                        Das wurde für die Fritzbox fraktion eingebaut die damit den Aktuellen traffic überwachen. Da die FritzBox die Werte nicht von sich aus preis gibt, auch wenn Abonniert.
                          jensven last edited by
                          @Jey-Cee
                          wollte das script jetzt auch mal ausprobieren.
                          Ich habe in der fritzbox den upnp dienst aktiviert und dort auch eine Stream für internet Dario eingestellt.
                          Mit meinem Gerät kann ich so auch direkt drauf zugreifen.
                          Adapter läuft und finde dann auch im Objekt Baum einige pfade zu der fritzbox
                          Ist es nun möglich über das Script den Media Player zu steuern?
                          Du schreibt dass Widergabelisten nicht funktionieren, bin mir aber nun nicht sicher ob ein eingesteller stream als solche Widergabeliste deklariert wird
                          • Jey Cee
                            Jey Cee Developer @jensven last edited by
                            @jensven sagte in [Vorlage] upnp Media Player:
                            Welchen Media Player? Die FritzBox selber ist ja kein Media Palyer.
                              jensven @Jey Cee last edited by jensven
                              @jey-cee
                              Habe zuerst den Player nicht erhalten, da dachte ich das muss über die fritzbox gesteuert werden.
                              Nach einem neustart des adapters habe ich jetzt doch den Player.
                              Wenn ich nun über die erstellen Buttons von dem script den player steuern möchte passiert folgendes:
                              1.
                              javascript.0
                              2023-08-15 17:30:44.299	warn	at Object.<anonymous> (script.js.upnp:81:25)
                              javascript.0
                              2023-08-15 17:30:44.298	warn	getState "upnp.0.HMT_600.MediaRenderer.RenderingControl.Mute" not found (3)
                              • Wenn ich den Volume Down button anklicke passiert nichts
                              • Wenn ich den Volume Up Button anklicke dann wirds stumm, wobei das "Mute" Logo nicht auf dem Display des Geräts angezeigt wird. Erst wenn ich mit der Fernbedienung die Lautstärke ändere kommt der Ton wieder
                              Wenn ich unter MediaControl auf Pause klicke dann unterbricht die Widergabe für ~1 Sekunde
                              javascript template
                              1824
