    4. Material Design Widgets: Calendar Widget
    • N
      nousefor82 @Dirni last edited by nousefor82
      @Scrounger
      Servus,
      ich hab ja wie in github beschrieben ein Problem mit der Darstellung wiederkehrender ganztägiger Termine; in dem Fall mit den Geburtstagen. Diese werden über 2 Tage angezeigt:
      Wenn ich den Table anzeigen lasse, passt alles:
      Ich verwende dein script mit angepasstem Datenpunkt und ical-Instanz sowie angepassten Farben:
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.0.data.table]`);
      instances.on(ical2CalendarWidget);
      // remove this, if you know to use your own datapoint
      let datapointId = 'javascript.0.scriptEnabled.common.Kalender.ical2calendar2'
      createState(datapointId, "[]", {
        read: true,
        write: false,
        desc: "JSON String for Calendar Widget",
        type: "string",
        def: "[]"
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'Jörg') {
                              return '#58ACFA';
                          } else if (calendarName === 'Simone') {
                              return '#E2A9F3'
                          } else if (calendarName === 'Müllentsorgung') {
                              return '#ffffdf'
                          } else if (calendarName === 'Feiertage') {
                              return '#FA5882'
                          } else if (calendarName === 'Ferien') {
                              return '#fdfdfd'
                          } else if (calendarName === 'Geburtstage') {
                              return '#81F79F'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#111111'
                              return '#111111'
                              return '#111111'
                              return '#111111'
                              return '#111111'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState(datapointId, JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
      Beim Start kommt es zu folgender Fehlermeldung:
      javascript.0 (2992) script.js.common.Kalender.Skript_2: ical2MaterialDesignCalendarWidget: message: Cannot read property 'split' of undefined, stack: TypeError: Cannot read property 'split' of undefined at ical2CalendarWidget (script.js.common.Kalender.Skript_2:60:52) at script.js.common.Kalender.Skript_2:208:1 at script.js.common.Kalender.Skript_2:209:3 at Script.runInContext (vm.js:131:20) at Script.runInNewContext (vm.js:137:17) at execute (C:\iobroker\SmartHome\node_modules\iobroker.javascript\main.js:1483:27) at prepareScript (C:\iobroker\SmartHome\node_modules\iobroker.javascript\main.js:1691:38) at C:\iobroker\SmartHome\node_modules\iobroker.javascript\main.js:1791:17 at Immediate._onImmediate (C:\iobroker\SmartHome\node_modules\iobroker.javascript\main.js:1281:17) at processImmediate (internal/timers.js:458:21)
      Woran könnte das liegen?
      • X14n
        X14n @Scrounger last edited by
        @scrounger
        Ist es eigentlich möglich, anstelle den Monat, eine bestimmte Anzahl Wochen (zb 6 Wochen) anzuzeigen? Beginnen würde die Anzeige dann bei der aktuellen Kalenderwoche.
        X14n
          Hallo Leute
          Bekomme seit neuem diese Fehlermeldung. Fange aber nichts an damit. Kann jemand helfen?
          javascript.0 (7922) script.js.Visualisierung.kalender_Dirni: ical2MaterialDesignCalendarWidget: message: Cannot read property 'split' of undefined, stack: {e.stack}
            Kusi @Scrounger last edited by
            @scrounger Ist es möglich bei der Wochenansicht die Abstände zwischen den einzelnen vollen Stunden zu verkleinern, damit man den ganzen Tag ohne zu Scrollen sieht?
              mguenther last edited by
              Hallo Zusammen,
              ich habe mich den ganzen Sonntag hingesetzt und habe einen Monatskalender nun auch in meiner VIS. Muss nun noch Finetuning betreiben und komme an einer Stelle nicht weiter. Die Kalendereinträge selber - kann ich da die Schriftgröße z.B. in der Monatsansicht anpassen? Oder z.B. in der Monatsansicht die Nummerierung der Tage in der Größe variieren bzw. den Abstand zwischen Nummer des Tages und Ereignis?
              Hintergrund - ich habe nur eine kleine Ansicht - reicht uns. Bei Details können wir uns die Tagesansicht anschauen. Allerdings "rutscht" das Ereignis nun heraus:
              1. Frage - wenn ein Ereignis angezeigt wird und es passt nicht in die Darstellung, erscheint "1 more" - wo lässt sich denn 1 more ändern?
              danke
              Marcus
                mguenther @mguenther last edited by
                @Scrounger
                könntest du mir weiterhelfen? Bis jetzt habe ich noch keine Lösung oder Alternative gefunden...
                • Scrounger
                  Scrounger Developer @mguenther last edited by
                  @mguenther
                  Also Schriftgröße, Farben und. Schriftarten kann man über den Vis Editor ändern. Alles andere sollte per CSS überschreiben gehen.
                    mguenther @Scrounger last edited by mguenther
                    @scrounger
                    hmmm, danke für deine Antwort - wo kann ich denn z.B. den Abstand ändern, so dass der Text des Ereignisses etwas mehr an die Tagesbeschriftung in der Monatsansicht "heranrutscht". Ich habe auch schon einiges im VIS Editor "ausprobiert" - finde aber irgendwie nicht die richtige Einstellung.
                    Hier noch einmal ein aktuelles Beispiel, was meine Frage hoffentlich verdeutlicht:
                    Um den 24.1. im Bild ist ein blauer Kreis um die 24 - Farbe kann ich anpassen, wo kann ich denn z.B. die Größe von dem Kreis anpassen? Vielleicht lässt sich ja auch die Form ändern. Ich habe auch die Schriftgröße der Termine schon angepasst, daran liegt es nicht. Ich hoffe, dass durch die Anpassung der Form um die 24 zum einen, das Datum weiter nach oben rutscht und auch Einträge damit höher rutschen.
                    Und ich würde gerne "x more" in einen anderen Text ändern - das finde ich nirgends und wüsste momentan nicht, wo ich durch CSS die richtige Klasse finde...
                      @scrounger
                      @all
                      mal ein update, wie ich es bis jetzt hinbekommen habe - es hat sich nicht wirklich viel verändert, man kann zumindest die Inhalte von Ereignissen jetzt lesen - mir fehlt immer noch die "Verkleinerung" des blauen Kreis um das Datum des aktuellen Tages und die Änderung der Anmerkung "1 more". Auch mehrmaliges Durchlesen der Anleitung bringt mich überhaupt nicht weiter - Schade...
                      Scrounger M 2 Replies Last reply Reply Quote 0
                      • Scrounger
                        @mguenther
                        Größe des Kreises kann per CSS überschrieben werden.
                        Text "More" kann man glaub im Editor einstellen, müsste ich auch nachschauen. Wenn nicht dann nimmt er die Sprache des Browsers, bei mir steht das "mehr".
                        M D3ltoroxp 2 Replies Last reply Reply Quote 0
                          Danke für deine Antwort
                          @scrounger sagte in Material Design Widgets: Calendar Widget:
                          @mguenther
                          das finde ich einfach nicht - hast du da noch den Hinweis, was ich unter css einstellen muss? Ich hatte auch schon -glaube ich- icon-size, icon-form probiert (ich hatte bei den anderen widgets von dir ähnliche Einstellungen gefunden), aber ich habe es einfach nicht hinbekommen. Für den Kalender finde ich in der Anleitung leider nicht so viel.
                          das ist ja komisch - ich habe alle Rechner ausprobiert - bei mir steht immer nur "more" - liegt das ggf. an der Sprache von meinem PI? Aber auch egal, ich hatte gehofft, ich könne auch ein anderes Wort nutzen.
                            helfi9999 @Scrounger last edited by helfi9999
                            @scrounger Hallo,
                            habe seit letzter Woche Probleme das ich kein Widget mehr einbinden kann in der Vis oder gar sehe.
                            Habe eben einen Log Ausdruck gemacht:
                            2022-03-06 08:22:17.859 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.alerts.close_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.861 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.alerts.close_icon_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.862 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.default.primary" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.867 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.default.secondary" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:17.876 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.vertical.primary" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.880 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.vertical.secondary" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:17.881 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:17.882 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.border" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:17.883 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.background_day" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.884 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.background_other_month" has been written without ack-flag with value "#f7f7f7"
                            2022-03-06 08:22:17.890 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.button_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.899 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.button_background_today" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.902 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.button_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.908 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.button_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:17.909 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.button_text_today" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:17.914 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.control_panel_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.923 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.control_panel_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.926 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.control_panel_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.928 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.control_panel_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:17.933 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.header_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.942 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.header_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:17.946 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.header_text_today" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.950 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.header_text_past" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:17.954 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.weeks_background" has been written without ack-flag with value "#f7f7f7"
                            2022-03-06 08:22:17.958 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.weeks_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:17.962 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.time_axis_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.965 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.time_axis_background_header" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.968 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.calendar.time_axis_text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.972 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.975 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.background_chart" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:17.979 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.global" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.982 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.value" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.986 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.y_axis_title" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.990 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.y_axis_values" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:17.995 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.y_axis_gridlines" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:17.999 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.y_axis_zeroline" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.002 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.x_axis_title" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.006 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.x_axis_values" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.010 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.x_axis_gridlines" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.013 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.x_axis_zeroline" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.014 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.legend" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.019 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.tooltip_background" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.022 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.tooltip_title" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.026 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.tooltip_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.031 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.bar.hover" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.034 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.bar.hover_border" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.037 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.pie.value" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.038 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.pie.hover" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.048 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.pie.border" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.051 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.charts.pie.border_hover" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.056 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.060 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.background_title" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.061 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.background_body" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.067 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.title" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.070 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.subTitle" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.076 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.card.text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.079 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.080 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.border" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.081 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.086 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.text_off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.092 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.text_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.096 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.checkbox.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.097 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.button_icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.098 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.103 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.header_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.105 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.header_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.112 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.footer_background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.114 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.close_button_text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.115 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.close_button_press" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.120 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.close_button_icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.126 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.close_button_fullscreen_press" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.128 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.divider" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.134 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.dialog.overlay" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.135 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.background_off" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.139 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.background_on" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.144 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.pressed" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.147 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.icon_off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.147 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.icon_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.152 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.lock_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.157 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.button.icon.lock_icon_background" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.160 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.header" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.164 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.header_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.165 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.174 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.background_items" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.177 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.181 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.text_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.185 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.subText" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.189 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.value_text" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.198 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.icon" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.201 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.button" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.205 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.button_hover" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.238 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.icon_list.lock_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.242 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.text" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.243 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.label" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.244 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.label_selected" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.245 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.appendix" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.246 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.message" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.246 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.counter" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.247 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.border" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.248 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.border_hover" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.249 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.border_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.250 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.icon_clear" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.251 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.icon_collapse" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.252 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.252 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.hover" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.253 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.selected" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.254 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.effect" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.254 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.icon" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.255 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.256 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.subText" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.256 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.input.menu.value" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.257 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.material_design_icon.color" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.257 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.258 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.header_main" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.259 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.header_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.260 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.background_off" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.280 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.background_on" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.330 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.hover" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.332 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.selected" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.333 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.334 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.subText" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.334 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.text_right" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.335 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.subText_right" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.336 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.header" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.336 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.divider" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.337 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.icon_off" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.338 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.list.icon_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.339 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.track_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.340 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.track" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.350 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.351 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.track_condition1" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.352 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.track_condition2" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:18.352 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.progress.circular_background" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.353 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.354 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.control" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.355 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.control_before" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.356 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.control_behind" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.356 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.text" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.357 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.text_prepand" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.358 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.tick" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.359 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.tick_before" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.359 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.tick_after" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.360 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.control_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.361 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.slider.control_text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.362 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.on" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.363 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.on_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.364 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.364 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.off_hover" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.365 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.track" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.366 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.text_off" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.367 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.text_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.367 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.switch.lock_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.368 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.background" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.368 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.row_header_background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.369 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.row_header_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.369 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.row_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.370 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.row_hover" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.370 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.row_text" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.371 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.border" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.371 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.table.dividers" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.372 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.background" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.373 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.373 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.title" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.374 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.menu_background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.397 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.header_background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.452 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.header_text" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.455 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_background" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.456 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_hover" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.457 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_selected" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.458 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.458 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.459 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_icon_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.465 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.466 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_icon_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.467 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_text_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.467 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_text_disabled" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.468 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_icon_disabled" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:18.469 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_divider" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:18.470 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_icon_toggle" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.471 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_backdrop_background_text_off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.471 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.item_backdrop_background_text_on" has been written without ack-flag with value "rgba(0,0,0,0.5)"
                            2022-03-06 08:22:18.472 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_background_all" has been written without ack-flag with value "#1e88e566"
                            2022-03-06 08:22:18.473 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.474 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_hover" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.475 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_selected" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.477 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_text" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.478 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_text_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.479 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_divider" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.480 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_backdrop_background_text_off" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.480 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.top_app_bar.subItem_backdrop_background_text_on" has been written without ack-flag with value "rgba(0,0,0,0.5)"
                            2022-03-06 08:22:18.481 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.value.text" has been written without ack-flag with value "#1e88e566"
                            2022-03-06 08:22:18.482 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.value.prepand" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.483 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.value.append" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.484 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.value.icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.485 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.title" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.486 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.subTitle" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.486 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.datapoints.desc" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.502 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.datapoints.value" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.503 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.datapoints.icon" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.504 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.active" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.504 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.notActive" has been written without ack-flag with value "#008000"
                            2022-03-06 08:22:18.505 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.notConnected" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.509 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.deactivated" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:18.511 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.schedule" has been written without ack-flag with value "#A9A9A9"
                            2022-03-06 08:22:18.511 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.extension" has been written without ack-flag with value "#90EE90"
                            2022-03-06 08:22:18.512 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.statusBar.once" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.565 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.icons.upgradeable" has been written without ack-flag with value "#ec0909"
                            2022-03-06 08:22:18.569 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.icons.logParser.warn" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.570 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.icons.logParser.error" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:18.571 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.background" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.571 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.border" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.572 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.border_hover" has been written without ack-flag with value "#a1a1a1"
                            2022-03-06 08:22:18.573 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.border_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.576 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.576 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.label" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.577 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.577 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_0" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.578 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_1" has been written without ack-flag with value "#808080"
                            2022-03-06 08:22:18.578 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_2" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.579 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_3" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.580 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_4" has been written without ack-flag with value "rgba(161, 161, 161, 0.26)"
                            2022-03-06 08:22:18.581 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_5" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.581 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_6" has been written without ack-flag with value "#000000"
                            2022-03-06 08:22:18.582 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_7" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.583 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_8" has been written without ack-flag with value "#008000"
                            2022-03-06 08:22:18.583 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_9" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:18.595 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_10" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.596 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_11" has been written without ack-flag with value "#FFA500"
                            2022-03-06 08:22:18.597 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_12" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.597 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_13" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.598 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_14" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.598 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_15" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.599 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_16" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.599 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_17" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.600 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_18" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.600 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.default_19" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.615 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.alerts.close_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.616 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.alerts.close_icon_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.616 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.default.primary" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.617 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.default.secondary" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.618 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.vertical.primary" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.619 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.vertical.secondary" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.619 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.627 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.border" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:18.673 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.background_day" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.674 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.background_other_month" has been written without ack-flag with value "#f7f7f7"
                            2022-03-06 08:22:18.675 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.button_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.676 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.button_background_today" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.676 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.button_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.677 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.button_text" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.677 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.button_text_today" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.678 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.control_panel_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.679 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.control_panel_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.680 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.control_panel_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.680 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.control_panel_text" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.681 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.header_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.692 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.header_text" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.693 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.header_text_today" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.697 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.header_text_past" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:18.698 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.weeks_background" has been written without ack-flag with value "#f7f7f7"
                            2022-03-06 08:22:18.699 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.weeks_text" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.699 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.time_axis_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.700 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.time_axis_background_header" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.701 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.calendar.time_axis_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.702 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.702 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.background_chart" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.703 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.global" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.703 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.value" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.704 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.y_axis_title" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.705 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.y_axis_values" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.706 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.y_axis_gridlines" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.706 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.y_axis_zeroline" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.707 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.x_axis_title" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.708 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.x_axis_values" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.720 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.x_axis_gridlines" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.721 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.x_axis_zeroline" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.722 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.legend" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.728 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.tooltip_background" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.763 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.tooltip_title" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.765 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.tooltip_text" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.766 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.bar.hover" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.767 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.bar.hover_border" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.767 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.pie.value" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.768 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.pie.hover" has been written without ack-flag with value "rgba(68, 115, 158, 0.8)"
                            2022-03-06 08:22:18.769 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.pie.border" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.776 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.charts.pie.border_hover" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.777 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.778 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.background_title" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.779 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.background_body" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.779 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.title" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.780 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.subTitle" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.781 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.card.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.781 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.782 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.border" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.782 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.783 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.text_off" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.784 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.text_on" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.785 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.checkbox.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.785 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.button_icon" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.786 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.787 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.header_background" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.788 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.header_text" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.789 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.footer_background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.789 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.close_button_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.790 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.close_button_press" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.791 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.close_button_icon" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.792 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.close_button_fullscreen_press" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.792 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.divider" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.793 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.dialog.overlay" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.794 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.background_off" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.795 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.background_on" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.796 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.pressed" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.814 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.icon_off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.819 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.icon_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.865 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.869 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.button.icon.lock_icon_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.870 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.header" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.874 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.header_icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.875 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.876 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.background_items" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.877 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.877 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.text_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.878 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.subText" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.879 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.value_text" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.880 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.881 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.button" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.881 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.button_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.882 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.icon_list.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.883 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.884 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.label" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.884 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.label_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.885 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.appendix" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.886 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.message" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.887 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.counter" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.887 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.border" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:18.888 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.border_hover" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.889 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.border_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.890 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.icon_clear" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.895 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.icon_collapse" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.896 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.897 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.hover" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.897 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.selected" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.898 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.effect" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.899 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.899 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.900 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.subText" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.900 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.input.menu.value" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.901 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.material_design_icon.color" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.917 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.918 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.header_main" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.974 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.header_icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.976 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.background_off" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.977 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.background_on" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.979 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.hover" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.982 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.selected" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:18.983 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.983 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.subText" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.984 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.text_right" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.984 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.subText_right" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.985 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.header" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.985 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.divider" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:18.986 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.icon_off" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.986 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.list.icon_on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.987 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.track_background" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:18.987 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.track" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.988 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.991 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.track_condition1" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:18.992 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.track_condition2" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:18.992 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.progress.circular_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.993 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:18.993 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.control" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.994 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.control_before" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.994 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.control_behind" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:18.995 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.995 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.text_prepand" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:18.996 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.tick" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:18.996 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.tick_before" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.997 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.tick_after" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.997 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.control_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.998 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.slider.control_text" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:18.998 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.on" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.999 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.on_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:18.999 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.off" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.000 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.off_hover" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.000 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.track" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.001 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.text_off" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.001 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.text_on" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.001 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.switch.lock_icon" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:19.019 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.019 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.row_header_background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.020 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.row_header_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.024 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.row_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:19.078 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.row_hover" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.082 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.row_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.084 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.border" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.085 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.table.dividers" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.086 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.086 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.icon" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.087 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.title" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.087 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.menu_background" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.088 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.header_background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.088 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.header_text" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.092 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:19.095 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_hover" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.096 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_selected" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.097 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.097 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.097 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_icon_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.098 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.098 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_icon_selected" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.099 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_text_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.099 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_text_disabled" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:19.100 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_icon_disabled" has been written without ack-flag with value "rgba(0, 0, 0, 0.38)"
                            2022-03-06 08:22:19.100 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_divider" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.101 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_icon_toggle" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.101 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_backdrop_background_text_off" has been written without ack-flag with value "rgba(0,0,0,0.5)"
                            2022-03-06 08:22:19.102 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.item_backdrop_background_text_on" has been written without ack-flag with value "#1e88e566"
                            2022-03-06 08:22:19.102 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_background_all" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:19.103 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_background" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:19.103 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_hover" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.104 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_selected" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.104 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.105 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_text_selected" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.105 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_divider" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.105 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_backdrop_background_text_off" has been written without ack-flag with value "rgba(0,0,0,0.5)"
                            2022-03-06 08:22:19.106 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.top_app_bar.subItem_backdrop_background_text_on" has been written without ack-flag with value "#1e88e566"
                            2022-03-06 08:22:19.106 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.value.text" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.107 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.value.prepand" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.107 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.value.append" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.108 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.value.icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.108 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.title" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.109 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.subTitle" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:19.109 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.datapoints.desc" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.109 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.datapoints.value" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:19.110 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.datapoints.icon" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.110 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.active" has been written without ack-flag with value "#008000"
                            2022-03-06 08:22:19.111 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.notActive" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:19.111 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.notConnected" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:19.112 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.deactivated" has been written without ack-flag with value "#A9A9A9"
                            2022-03-06 08:22:19.112 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.schedule" has been written without ack-flag with value "#90EE90"
                            2022-03-06 08:22:19.113 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.extension" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.113 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.statusBar.once" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.114 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.icons.upgradeable" has been written without ack-flag with value "#ec0909"
                            2022-03-06 08:22:19.114 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.icons.logParser.warn" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:19.131 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.icons.logParser.error" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:19.132 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.background" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.133 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.border" has been written without ack-flag with value "#a1a1a1"
                            2022-03-06 08:22:19.133 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.border_hover" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.134 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.border_selected" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.228 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.text" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.230 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.label" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.231 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.scripts.adapterStatus.select.icon" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.232 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_0" has been written without ack-flag with value "#44739e"
                            2022-03-06 08:22:19.233 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_1" has been written without ack-flag with value "#FFFFFF9C"
                            2022-03-06 08:22:19.234 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_2" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.234 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_3" has been written without ack-flag with value "rgba(0, 0, 0, 0.54)"
                            2022-03-06 08:22:19.235 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_4" has been written without ack-flag with value "#9E9E9E"
                            2022-03-06 08:22:19.236 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_5" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.236 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_6" has been written without ack-flag with value "#BDBDBD"
                            2022-03-06 08:22:19.237 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_7" has been written without ack-flag with value "rgba(0, 0, 0, 0)"
                            2022-03-06 08:22:19.238 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_8" has been written without ack-flag with value "#008000"
                            2022-03-06 08:22:19.238 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_9" has been written without ack-flag with value "#FFD700"
                            2022-03-06 08:22:19.239 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_10" has been written without ack-flag with value "#B22222"
                            2022-03-06 08:22:19.239 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_11" has been written without ack-flag with value "#FFA500"
                            2022-03-06 08:22:19.240 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_12" has been written without ack-flag with value "#303030"
                            2022-03-06 08:22:19.241 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_13" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.241 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_14" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.242 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_15" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.242 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_16" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.243 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_17" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.244 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.dark.default_18" has been written without ack-flag with value "#FFFFFF"
                            2022-03-06 08:22:19.462 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.today" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.463 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.weeks" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.464 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.button" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.464 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.button_today" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.465 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.event" has been written without ack-flag with value "12"
                            2022-03-06 08:22:19.465 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.calendar.time_axis" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.466 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.value" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.466 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.y_axis_title" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.467 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.y_axis_values" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.491 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.x_axis_title" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.492 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.x_axis_values" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.493 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.legend" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.493 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.tooltip_title" has been written without ack-flag with value "20"
                            2022-03-06 08:22:19.494 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.charts.tooltip_text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.495 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.card.title" has been written without ack-flag with value "24"
                            2022-03-06 08:22:19.496 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.card.subTitle" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.499 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.card.text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.499 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.checkbox.value" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.500 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.dialog.title" has been written without ack-flag with value "30"
                            2022-03-06 08:22:19.501 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.dialog.button" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.502 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.icon_list.header" has been written without ack-flag with value "20"
                            2022-03-06 08:22:19.502 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.icon_list.text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.503 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.icon_list.subText" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.504 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.icon_list.value" has been written without ack-flag with value "12"
                            2022-03-06 08:22:19.504 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.505 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.label" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.506 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.appendix" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.507 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.message" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.507 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.counter" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.531 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.dropdown.text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.532 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.dropdown.subText" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.533 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.input.dropdown.value" has been written without ack-flag with value "14"
                            2022-03-06 08:22:19.533 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.list.header_main" has been written without ack-flag with value "20"
                            2022-03-06 08:22:19.534 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.list.header" has been written without ack-flag with value "20"
                            2022-03-06 08:22:19.535 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.list.text" has been written without ack-flag with value "16"
                            2022-03-06 08:22:19.557 - info: admin.0 (30318) State value to set for "vis-materialdesign.0.fontSizes.default_9" has to be type "number" but received type "string"
                            2022-03-06 08:22:19.557 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.default_10" has been written without ack-flag with value "40"
                            2022-03-06 08:22:19.558 - info: admin.0 (30318) State value to set for "vis-materialdesign.0.fontSizes.default_10" has to be type "number" but received type "string"
                            2022-03-06 08:22:19.558 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.fontSizes.default_11" has been written without ack-flag with value "60"
                            2022-03-06 08:22:19.559 - info: admin.0 (30318) State value to set for "vis-materialdesign.0.fontSizes.default_11" has to be type "number" but received type "string"
                            2022-03-06 08:22:19.782 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.lastchange" has been written without ack-flag with value "1646551336942"
                            2022-03-06 08:22:19.804 - warn: admin.0 (30318) Read-only state "vis-materialdesign.0.colors.light.scripts.adapterStatus.select.icon" has been written without ack-flag with value "#FFFFFF"
                            Hat vielleicht jemand das gleiche Problem und eventuell gelöst.
                            Mein System:
                            PlatformBetriebssystem:linux
                            Architektur:x64
                            CPUs:4
                            Geschwindigkeit:2240 MHz
                            Modell:Intel(R) Celeron(R) CPU J3160 @ 1.60GHz
                            RAM:4 GB
                            System-Betriebszeit:1 T. 00:38:06
                            Node.js:v14.19.0
                            time:1646546936489
                            timeOffset:-60
                            Adapter-Anzahl:400
                            NPM:6.14.16
                            Datenträgergröße:19.5 GB
                            freier Festplattenspeicher:14.6 GB
                            Betriebszeit:1 T. 00:38:00
                            Aktive Instanzen:30
                            Pfad:/opt/iobroker/
                            • D3ltoroxp
                              D3ltoroxp @Scrounger last edited by
                              @scrounger said in Material Design Widgets: Calendar Widget:
                              @mguenther
                              Größe des Kreises kann per CSS überschrieben werden.
                              Text "More" kann man glaub im Editor einstellen, müsste ich auch nachschauen. Wenn nicht dann nimmt er die Sprache des Browsers, bei mir steht das "mehr".
                              Kann man das More deaktivieren, so das er alles anzeigt, was an dem Tag eingetragen ist ?
                              Ich meine wenn ich auf der View auf Tag oder Woche klicke und dann zurück auf Monat, ist das Mehr weg und es stehen dann mehrere Einträge auf dem Datum.
                              Auch springt das Datum nicht weiter, erst wenn ich am Tablet was mache oder dort etwas bediene in der View, aktualisiert sich das Datum. Kann man das automatisieren ? Das er nachts irgendwann einmal aktualisiert.
                              Hab das über den FullyBrowser probiert, er lädt um 3 Uhr nachts einmal die Base URL neu, aber das bringt nichts.
                              • D3ltoroxp
                                D3ltoroxp @helfi9999 last edited by
                                @helfi9999 Ich hatte neulich ein ähnliches Problem, ich war am gestalten einer View, irgendwas ist passiert und alles war weg, ich konnte auch nichts neues hinzufügen oder ändern, war einfach nichts mehr sichtbar, ich habe dann ein Backup eingespielt und danach war wieder alles iO. Ich mehr kann ich dazu leider auch nicht sagen. Wer weiß was ich gedrückt habe oder irgendwo aus versehen eingetragen habe, das es so kam.
                                  mguenther @D3ltoroxp last edited by
                                  @d3ltoroxp sagte in Material Design Widgets: Calendar Widget:
                                  @mguenther
                                  ich habe es bis jetzt nicht hinbekommen, leider auch nicht die Reduzierung der Kreisform. Naja, mal sehen - momentan nutze ich es halt so, wird aber hoffentlich noch eine Alternative irgendwann auftauchen. Ich bin zu dämlich dazu 🙂
                                    helfi9999 @D3ltoroxp last edited by
                                    @d3ltoroxp Hallo
                                    habe jetzt auch mal ein Backup eingespielt und schwupps ist alles wieder da.
                                    Danke für die Info.
                                    • D3ltoroxp
                                      Frage, ich habe im Kalender einen neuen Erstellt, "Ferien" diesen habe ich mit Ferien BW gefüllt. Wie sehe ich das nun im Calendar Widget ?
                                      Aber so siehts im Widget aus.
                                      Sollte hier nicht über alle Tage ein grüner Balken zu sehen sein ?
                                      • Ro75
                                        Ro75 last edited by
                                        Hallo. Wie werden ältere Termine (< heute) dargestellt? Im ICal - Adapter habe ich 30 bei "Vergangene Tage" eingetragen. In den Datenpunkte tauchen aber nur Termine ab dem heutigen Tag auf. Ich verwende aktuell die Version 1.12.1.
                                          alexmi last edited by
                                          ich habe alles erfolgreich installiert, aber im Kalender werden keine Farben dargestellt. alles nur schwarz/weiß. Außerdem werden mehrtätige Termine auch nicht über mehrere Tage anzeigt, sondern nur am ersten Tag.
                                          Ich hoffe mir kann jemand helfen.
                                          Vielen Dank im Voraus! 🙂
                                          • Damrak2022
                                            Damrak2022 @alexmi last edited by
                                            @alexmi Ich komme so langsam voran und habe meine 9 Kalender über ical direkt eingebunden.
                                            Wenn ich das richtig verstehe müsste er doch die Kalenderfarben aus dem ical Kalender übernehmen.
                                            Das klappt aber bei mir nicht so ganz. Ich habe extra mal einen Testtermin im ioBroker Kalender angelegt
                                            Im Javascript habe ich das geändert:
                                            function getMyCalendarColor(calendarName) {
        // assign colors via the calendar names, use calendar name as set in ical
        if (calendarName === 'ioBroker') {
        return '#F16BBFB';
        } else if (calendarName === 'Finanzen') {
        return '#DA0B05'
        } else if (calendarName === 'calendar3') {
        return '#32a852'
                                                            function getMyCalendarTextColor(calendarName) {
        if (calendarName === 'calendar1') {
        return '#FFFFFF';
        } else if (calendarName === 'calendar2') {
        return '#FFFFFF'
        return '#FFFFFF'
                                            Eigentlich sollte der Testtermin in türkis angezeigt werden.
                                            vis
                                            45
                                            200
                                            31436
