    3. Einsteigerfragen
    4. KNX Adapter läuft nicht
      Rookie 0 last edited by
      pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker logs --watch
      2022-01-31 17:36:42.377  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:36:42.386  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:36:42.389  - info: knx.1 (4737) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:36:42.401  - info: knx.1 (4737) terminating
      2022-01-31 17:36:42.404  - info: knx.1 (4737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:36:42.958  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:36:45.458  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4752
      2022-01-31 17:36:48.672  - info: knx.1 (4752) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:36:48.765  - warn: knx.1 (4752) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:36:48.770  - info: knx.1 (4752) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:36:48.938  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:36:48.949  - info: knx.1 (4752) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:36:48.961  - info: knx.1 (4752) terminating
      2022-01-31 17:36:48.964  - info: knx.1 (4752) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:36:48.994  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:36:49.532  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:36:52.056  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4767
      2022-01-31 17:36:55.253  - info: knx.1 (4767) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:36:55.368  - warn: knx.1 (4767) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:36:55.373  - info: knx.1 (4767) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:36:55.473  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:36:55.484  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:36:55.512  - info: knx.1 (4767) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:36:55.522  - info: knx.1 (4767) terminating
      2022-01-31 17:36:55.525  - info: knx.1 (4767) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:36:56.085  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:36:58.556  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4782
      2022-01-31 17:37:01.748  - info: knx.1 (4782) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:37:01.870  - warn: knx.1 (4782) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:37:01.874  - info: knx.1 (4782) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:37:01.968  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:37:01.995  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:37:02.026  - info: knx.1 (4782) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:37:02.036  - info: knx.1 (4782) terminating
      2022-01-31 17:37:02.039  - info: knx.1 (4782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:37:02.598  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:37:05.054  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4797
      2022-01-31 17:37:08.236  - info: knx.1 (4797) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:37:08.328  - warn: knx.1 (4797) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:37:08.333  - info: knx.1 (4797) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:37:08.806  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:37:08.818  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:37:08.818  - info: knx.1 (4797) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:37:08.833  - info: knx.1 (4797) terminating
      2022-01-31 17:37:08.837  - info: knx.1 (4797) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:37:09.436  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:37:11.880  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4812
      2022-01-31 17:37:15.049  - info: knx.1 (4812) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:37:15.179  - warn: knx.1 (4812) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:37:15.184  - info: knx.1 (4812) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:37:15.623  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:37:15.631  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:37:15.631  - info: knx.1 (4812) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 17:37:15.642  - info: knx.1 (4812) terminating
      2022-01-31 17:37:15.645  - info: knx.1 (4812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-31 17:37:16.277  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-31 17:37:18.698  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4827
      2022-01-31 17:37:21.936  - info: knx.1 (4827) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
      2022-01-31 17:37:22.034  - warn: knx.1 (4827) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
      2022-01-31 17:37:22.040  - info: knx.1 (4827) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
      2022-01-31 17:37:22.453  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
      2022-01-31 17:37:22.462  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
      2022-01-31 17:51:23.128  - info: host.raspberrypi stopInstance system.adapter.knx.2 send kill signalocess=true)x, node: v14.18.3, js-controller: 3.3.225) not possible because of cancelled connection.D : 0 SeqCntIN : 0 SeqCntOUT : 0  msgC
        Rookie 0 @Rookie 0 last edited by
        ist das so ok?
        Danke schonmal!
        Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Rookie 0 last edited by
          @rookie-0
          Deine Systemzeit steht offenbar auf London-Zeit. Stell das auf Berlin/MEZ um
          • Glasfaser
            Glasfaser @Rookie 0 last edited by
            @rookie-0
            Oben im Screenshot ist die Instanz knx.2
            und im Log knx.1 !?
            Wieviel instanzen hast du !?
              Rookie 0 @Glasfaser last edited by
              Eine Instanz. Der Rest ist eigentlich raus gelöscht...
                System Zeit hatte ich eigentlich schon auf berlin gesetzt.
                Geht doch über rasperry-config oder?
                  Thomas Braun Most Active @Rookie 0 last edited by Thomas Braun
                  @rookie-0 Ja. Die geloggten Zeitstempel deuten aber auf eine Stunde Differenz hin.
                  date && date -u
                  liefert?
                    @rookie-0
                    iobroker list instances
                    iobroker update -i
                      Rookie 0 @Thomas Braun last edited by
                      Mon 31 Jan 20:08:12 CET 2022
                      Mon 31 Jan 19:08:12 UTC 2022
                        • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        • system.adapter.discovery.0 : discovery : raspberrypi - enabled
                          system.adapter.knx.1 : knx : raspberrypi - disabled, bind: 127.0.0.1
                        • system.adapter.knx.2 : knx : raspberrypi - enabled, bind: 192.168.178.37
                        • instance is alive
                          Rookie 0 @Rookie 0 last edited by Rookie 0
                          R
                          Rookie 0
                          32 minutes ago
                          pi@raspberrypi:~ $ iobroker update -i
                          Used repository: default
                          hash changed or no sources cached => force download of new sources
                          update done
                          Adapter "admin" : 5.2.3 , installed 5.2.3
                          Adapter "backitup" : 2.2.3 , installed 2.2.3
                          Adapter "discovery" : 2.7.3 , installed 2.7.3
                          Controller "js-controller" : 3.3.22 , installed 3.3.22
                          Adapter "knx" : 2.0.5 , installed 2.0.5
                          R Thomas Braun 2 Replies Last reply Reply Quote 0
                            kann es an einer verkehrten physikalischen adresse liegen?
                              @rookie-0
                              Bitte in CodeTags setzen. Danke.
                                hiermit geschehen...
                                Thomas Braun T 2 Replies Last reply Reply Quote 0
                                  @rookie-0
                                  Nö, noch nicht geschehen.
                                  Ist meist falsch. Lös das Binding auf.
                                    tombox @Rookie 0 last edited by
                                    @rookie-0
                                    Also sicherstellen das nur eine instance läuft.
                                    Dann die IP und Physikalische adresse des gateways doppelt checken
                                    OpenKnx Adapter ausprobieren.
                                      Rookie 0 @tombox last edited by
                                      Ich habe es endlich hinbekommen.
                                      Die IP des Gateway war falsch...
                                      Danke an Alle!
                                        Jetzt würde ich gerne eine Visu installieren.
                                        Ich bekomme jedoch eine rote Meldung, wenn ich den Adapter hinzufügen möchte.
                                        Keine Versionsinfo für web
                                        Steht dann da und Hinzufügen ist ausgegraut.
                                        Was mache ich jetzt schon wieder verkehrt?
                                          Ok, der Webadapter fehlt wohl.
                                          Den bekomme ich aber nicht installiert. Woran liegt es?
                                          $ iobroker add web auto --host raspberrypi
                                          NPM version: 6.14.15
                                          npm install iobroker.web@3.4.16 --loglevel error --prefix "/opt/iobroker" (System call)
                                          npm ERR! Cannot read property 'match' of undefined
                                          npm ERR! /home/iobroker/.npm/_logs/2022-02-01T08_53_20_360Z-debug.log
                                          host.raspberrypi Cannot install iobroker.web@3.4.16: 1
                                          ERROR: Process exited with code 25
                                          1224
