    • Dominik F.
      Dominik F. @MCU last edited by
      @mcu
      Das wäre super, dann kann ich gleich mal testen wie das so funktioniert.
        SlipKoRn_DH88 last edited by
        @mcu
        @mcu said in jarvis v3.0.0 - just another remarkable vis:
        @uwe72 https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/slider/thumb-groesse-aendern
        Super! Was ist denn nun der nächste Schritt?
          MCU @SlipKoRn_DH88 last edited by
          @slipkorn_dh88 ? Welchen Schritt wohin?
            MCU @Dominik F. last edited by MCU
            @dominik-f
            {"configName":"transparent","0_userdata.0.jarvis.system.cssThemes.01_jarvisPageContainerBG":{"background":"url(\"https://images.hdqwalls.com/download/3d-cgi-geometry-pattern-bo-3840x2160.jpg\")"},"0_userdata.0.jarvis.system.cssThemes.02_bodyDarkjarvisHeaderBG":{"background":"rgba(0,0,0,0.45) !important"},"0_userdata.0.jarvis.system.cssThemes.03_jarvisTabsContainerBG":{"background":"rgba(0,0,0,0.45) !important"},"0_userdata.0.jarvis.system.cssThemes.04_jarvisWidgetContainerBG":{"background":"rgba(0,0,0,0.45) !important"},"0_userdata.0.jarvis.system.cssThemes.05_bodyDarkJarvisWidgetBG":{"background":"rgba(0,0,0,0.45)"},"0_userdata.0.jarvis.system.cssThemes.06_bodyLightJarvisWidgetBG":{"background":"rgba(255,255,255,1)"},"0_userdata.0.jarvis.system.cssThemes.07_bodyDarkJarvisTabsContainerBG":{"background":"rgba(0,0,0,0.45) !important"},"0_userdata.0.jarvis.system.cssThemes.08_qTableContainerBG":{"background":"transparent !important"},"0_userdata.0.jarvis.system.cssThemes.09_qHeaderBorderedBG":{"border":"1px solid transparent !important"},"0_userdata.0.jarvis.system.cssThemes.10_jarvisWidgetIconBG":{"background":"rgba(0,0,0,0.45)"},"0_userdata.0.jarvis.system.cssThemes.12_jarvisHeader":{"background":"rgba(0,0,0,0.45) !important"},"0_userdata.0.jarvis.system.cssThemes.13_jarvisSidebar":{"background":"rgba(0,0,0,0.45) !important; "},"0_userdata.0.jarvis.system.cssThemes.50_mediaColorCover":{"background-color":"transparent !important"},"0_userdata.0.jarvis.system.cssThemes.51_mediaControls":{"background":"transparent !important"},"0_userdata.0.jarvis.system.cssThemes.52_mediaTrackInformation":{"background":"rgba(25, 118, 210, 0) !important"},"0_userdata.0.jarvis.system.cssThemes.53_mediaTrackDuration":{"background":"white"},"0_userdata.0.jarvis.system.cssThemes.54_mediaTrackProgress":{"background":"blue"},"0_userdata.0.jarvis.system.cssThemes.55_mediaControlsJarvisIconSvg":{"color":"white"},"0_userdata.0.jarvis.system.cssThemes.56_mediaControlsControlsLeftQbtnwrapper":{"background":"transparent !important"},"0_userdata.0.jarvis.system.cssThemes.57_mediaControlsQbtngroupQbtnitem":{"background":"transparent !important"},"0_userdata.0.jarvis.system.cssThemes.colorPrimary":"#1976d2","0_userdata.0.jarvis.system.cssThemes.colorSecondary":"#26a69a"}
              SlipKoRn_DH88 @MCU last edited by
              @mcu
              @slipkorn_dh88 Hab es jetzt mit Deinen Selektoren angepasst.
              Sorry, wollte diesen Beitrag zitieren. Es geht um das Programm für CSSThemes✌
                MCU @SlipKoRn_DH88 last edited by MCU
                @slipkorn_dh88 Ist in der Doku vorhanden. Doku lesen und loslegen.
                Wenn etwas in der Doku fehlen sollte oder unschlüssig ist, dann kurze Info und ich werde es deutlicher erklären.
                  sigi234 Forum Testing Most Active @MCU last edited by sigi234
                  @mcu
                  Hallo, im Skript muss ich ja nix machen, oder?
                    MCU @sigi234 last edited by
                    @sigi234 Nein. Hast du eine zusätzliche Instanz und dort einen CSS-DP gelöscht?
                      @mcu sagte in jarvis v3.0.0 - just another remarkable vis:
                      Nein
                        MCU @sigi234 last edited by MCU
                        @sigi234 Bitte die Dokuseite aktualisieren und die CSSThemes komplett neu holen.
                        Vor dem Neustart, den DP
                        cssOriginal löschen. Da sonst keine Kopie erzeugt wird. Danke.
                          Skript neu erstellen?
                            @sigi234 Neu laden und drüber kopieren ins das alte, oder komplett neu.
                              Ok
                              Hinweis:
                              Im Änderungsprotokoll ist Javascript cssthemes nicht verlinkt
                              20:43:36.354	info	javascript.0 (13760) Start javascript script.js.Jarvis.CSS_Themes_MCU
                              20:43:36.382	info	javascript.0 (13760) script.js.Jarvis.CSS_Themes_MCU: Script "script.js.Jarvis.CSS_Themes_MCU" wurde für CSSThemes v1.0.0 gestartet!
                              20:43:36.386	info	javascript.0 (13760) script.js.Jarvis.CSS_Themes_MCU: registered 95 subscriptions and 0 schedules
                              20:43:38.390	info	javascript.0 (13760) script.js.Jarvis.CSS_Themes_MCU: Logging CSSThemes wurde eingeschaltet
                              20:43:38.390	warn	javascript.0 (13760) script.js.Jarvis.CSS_Themes_MCU: Logging CSSThemes CSS Änderungen wurde ausgeschaltet! Komplette CSS wird nicht ins log geschrieben!
                              20:43:41.399	warn	javascript.0 (13760) script.js.Jarvis.CSS_Themes_MCU: **** CSS Original wurde in cssOriginal-DP einmalig kopiert! ****
                                @sigi234 sagte in jarvis v3.0.0 - just another remarkable vis:
                                In der Doku korrigiert. Musste den alten javascript Eintrag entfernen, da das Dokumentationstool mit der Anzahl der Zeilen >1000 anscheinend nicht klar kommt.
                                Danke.
                                  @dominik-f
                                  Bitte das Script aus der Doku neu laden und den DP cssOriginal in den settings löschen. Da dürfte momentan keine Eintrag drin sein?
                                  Dominik F. 1 Reply Last reply Reply Quote 0
                                  • Dominik F.
                                    @mcu
                                    Bei mir ist da ein Eintrag drin. Hatte aber zwischendurch auch mal das Script neu geladen und alle Datenpunkte gelöscht gehabt.
                                    Dominik F. 1 Reply Last reply Reply Quote 1
                                    • Dominik F.
                                      Dominik F. @Dominik F. last edited by
                                      @dominik-f
                                      Ich hab mir nun meine Orginal CSS als "normal" abgespeichert und deine CSS als "transparent". Ich hadere im Moment damit, wie ich die jeweilige Config wieder aufrufen kann
                                        @dominik-f Es wird ja im configChoose die unterschiedlichen Varianten angezeigt. Die richtige auswählen. Config FromArray auslösen.
                                        -> die Config ist im themeConfig . Dann configLoad um diese Config in die Selektoren zu schreiben und dann configShow um sie anzuzeigen.
                                        Dominik F. sigi234 2 Replies Last reply Reply Quote 0
                                        • Dominik F.
                                          Dominik F. @MCU last edited by Dominik F.
                                          @mcu
                                          Wenn ich die variante auswähle und config from array auslöse passiert bei mir nichts, also themeconfig bleibt gleich
                                          p.s.: den Datenpunkt configShow habe ich nicht
                                            @dominik-f Zeig mal das Objekt-Bild:
                                            254
                                            4489
                                            2658294
