      MCU @Dominik F. last edited by
      @dominik-f Zeig mal das Objekt-Bild:
      Dominik F. 1 Reply Last reply Reply Quote 0
      • Dominik F.
        Dominik F. @MCU last edited by
        @mcu
        das ist der Inhalt:
          "configName": "transparent",
          "0_userdata.0.jarvis.system.cssThemes.01_jarvisPageContainerBG": {
            "background": "url(\"https://images.hdqwalls.com/download/3d-cgi-geometry-pattern-bo-3840x2160.jpg\")"
          "0_userdata.0.jarvis.system.cssThemes.02_bodyDarkjarvisHeaderBG": {
            "background": "rgba(0,0,0,0.45) !important"
          "0_userdata.0.jarvis.system.cssThemes.03_jarvisTabsContainerBG": {
          "0_userdata.0.jarvis.system.cssThemes.04_jarvisWidgetContainerBG": {
          "0_userdata.0.jarvis.system.cssThemes.05_bodyDarkJarvisWidgetBG": {
            "background": "rgba(0,0,0,0.45)"
          "0_userdata.0.jarvis.system.cssThemes.06_bodyLightJarvisWidgetBG": {
            "background": "rgba(255,255,255,1)"
          "0_userdata.0.jarvis.system.cssThemes.07_bodyDarkJarvisTabsContainerBG": {
          "0_userdata.0.jarvis.system.cssThemes.08_qTableContainerBG": {
            "background": "transparent !important"
          "0_userdata.0.jarvis.system.cssThemes.09_qHeaderBorderedBG": {
            "border": "1px solid transparent !important"
          "0_userdata.0.jarvis.system.cssThemes.10_jarvisWidgetIconBG": {
          "0_userdata.0.jarvis.system.cssThemes.12_jarvisHeader": {
          "0_userdata.0.jarvis.system.cssThemes.13_jarvisSidebar": {
            "background": "rgba(0,0,0,0.45) !important; "
          "0_userdata.0.jarvis.system.cssThemes.14_jarvisSidebarItemPage": {},
          "0_userdata.0.jarvis.system.cssThemes.15_jarvisSidebarItemPageSelected": {},
          "0_userdata.0.jarvis.system.cssThemes.16_jarvisStateListItemPopup": {},
          "0_userdata.0.jarvis.system.cssThemes.17_jarvisWidgetHeader": {
            "background-color": "#606060 !important"
          "0_userdata.0.jarvis.system.cssThemes.18_jarvisTabs": {},
          "0_userdata.0.jarvis.system.cssThemes.19_qItemDark": {
            "background-color": "transparent"
          "0_userdata.0.jarvis.system.cssThemes.20_jarvisWidgetModuleStateList": {
            "background-color": "#303030"
          "0_userdata.0.jarvis.system.cssThemes.21_jarvisStateListItemBody": {},
          "0_userdata.0.jarvis.system.cssThemes.22_jarvisJsonTable": {
            "background-color": "#303030 !important"
          "0_userdata.0.jarvis.system.cssThemes.23_rowItemsCenterqCardSectionVert": {
          "0_userdata.0.jarvis.system.cssThemes.24_qCardActioinsHorizRowJustifyEnd": {
          "0_userdata.0.jarvis.system.cssThemes.25_jarvisPageContainerScroll": {},
          "0_userdata.0.jarvis.system.cssThemes.26_jarvisPageContainerTextArea": {},
          "0_userdata.0.jarvis.system.cssThemes.27_qSliderThumb": {},
          "0_userdata.0.jarvis.system.cssThemes.28_notificationDrawerButton": {
            "display": "none !important"
          "0_userdata.0.jarvis.system.cssThemes.29_jarvisDateTimeClock": {},
          "0_userdata.0.jarvis.system.cssThemes.30_qToggleThumb": {},
          "0_userdata.0.jarvis.system.cssThemes.31_jarvisSidebarItem": {},
          "0_userdata.0.jarvis.system.cssThemes.32_jarvisPage": {},
          "0_userdata.0.jarvis.system.cssThemes.33_jarvisIconPath": {},
          "0_userdata.0.jarvis.system.cssThemes.34_qSliderqSliderTrack": {},
          "0_userdata.0.jarvis.system.cssThemes.50_mediaColorCover": {
            "background-color": "transparent !important"
          "0_userdata.0.jarvis.system.cssThemes.51_mediaControls": {
          "0_userdata.0.jarvis.system.cssThemes.52_mediaTrackInformation": {
            "background": "rgba(25, 118, 210, 0) !important"
          "0_userdata.0.jarvis.system.cssThemes.53_mediaTrackDuration": {
            "background": "white"
          "0_userdata.0.jarvis.system.cssThemes.54_mediaTrackProgress": {
            "background": "blue"
          "0_userdata.0.jarvis.system.cssThemes.55_mediaControlsJarvisIconSvg": {
            "color": "white"
          "0_userdata.0.jarvis.system.cssThemes.56_mediaControlsControlsLeftQbtnwrapper": {
          "0_userdata.0.jarvis.system.cssThemes.57_mediaControlsQbtngroupQbtnitem": {
          "0_userdata.0.jarvis.system.cssThemes.colorPrimary": "#1976d2",
          "0_userdata.0.jarvis.system.cssThemes.colorSecondary": "#26a69a",
          "0_userdata.0.jarvis.system.cssThemes.colorAccent": "#9c27b0",
          "0_userdata.0.jarvis.system.cssThemes.darkMode": true
        da müsste ja eigentlich "normal" dann drin stehen.
        Was mir aufgefallen ist, ist das in ThemeArray beide Themes drin stehen. Ist das so richtig?
          sigi234 Forum Testing Most Active @MCU last edited by
          @mcu sagte in jarvis v3.0.0 - just another remarkable vis:
          configChoose die unterschiedlichen Varianten angezeigt.
          Habe ich nicht?
          Dominik F. M 2 Replies Last reply Reply Quote 0
          • Dominik F.
            Dominik F. @sigi234 last edited by Dominik F.
            @sigi234 sagte in jarvis v3.0.0 - just another remarkable vis:
            Habe ich nicht?
            Dazu muss man einen Namen für die ConfigTheme festlegen in dem DP 0_userdata.0.jarvis.system.cssThemes.theme.themeName. Ohne Name wird keine Config gespeichert. Dann noch die Config im ThemeArray speichern und dann entsteht der Datenpunkt
              MCU @sigi234 last edited by
              @sigi234 Wenn man in das Array die Config auch schreiben lassen möchte muss der 0_userdata.0.jarvis.system.cssThemes.theme.themeSaveInArray auf true stehen!. Sonst wird nichts in Array geschrieben.
                MCU @Dominik F. last edited by MCU
                @dominik-f Da hast bei Deinem "normal" anscheinend nicht 0_userdata.0.jarvis.system.cssThemes.theme.themeSaveInArray auf true stehen gehabt?
                "normal" steht nicht im Array? Wo steht sie bei Dir?
                • Dominik F.
                  @mcu
                  doch eigentlich schon. Hier mein ThemeArray:
                  Dort stehen beide drin. Ich hab normal auch zu erst gemacht
                      "configName": "normal",
                      "0_userdata.0.jarvis.system.cssThemes.01_jarvisPageContainerBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.02_bodyDarkjarvisHeaderBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.04_jarvisWidgetContainerBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.05_bodyDarkJarvisWidgetBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.06_bodyLightJarvisWidgetBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.08_qTableContainerBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.09_qHeaderBorderedBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.10_jarvisWidgetIconBG": {},
                      "0_userdata.0.jarvis.system.cssThemes.12_jarvisHeader": {},
                      "0_userdata.0.jarvis.system.cssThemes.50_mediaColorCover": {},
                      "0_userdata.0.jarvis.system.cssThemes.51_mediaControls": {},
                      "0_userdata.0.jarvis.system.cssThemes.52_mediaTrackInformation": {},
                      "0_userdata.0.jarvis.system.cssThemes.53_mediaTrackDuration": {},
                      "0_userdata.0.jarvis.system.cssThemes.54_mediaTrackProgress": {},
                      "0_userdata.0.jarvis.system.cssThemes.55_mediaControlsJarvisIconSvg": {},
                      "0_userdata.0.jarvis.system.cssThemes.56_mediaControlsControlsLeftQbtnwrapper": {},
                      "0_userdata.0.jarvis.system.cssThemes.57_mediaControlsQbtngroupQbtnitem": {},
                      "0_userdata.0.jarvis.system.cssThemes.colorPrimary": "DodgerBlue",
                        "color": "white"
                    @dominik-f Ok Und configChoose? Was steht da drin? Klick mal drauf.
                    • Dominik F.
                      @mcu
                      da ist normal und transparent zur Auswahl
                        @dominik-f Dann das auswählen wie oben beschrieben und dann das andere was oben schon steht.
                        Willst die du die auf die Button legen?
                          SevenUp last edited by SevenUp
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/module/statehtml/videostream/alternativer-stream
                          Ich nutze für meinen 3D Drucker die SW octoprint. Dort kann auch eine Webcam eingebunden werden. Der Stream wird direkt im octoprint Fenster angezeigt werden, kann aber auch über die Adresse
                          http://192.168.xx.xx/webcam/?action=stream
                          aufgerufen werden.
                          Nun versuche ich den Stream in Jarvis einzubinden und habe es mit den oben zitierten Anleitung probiert. Leider ohne Erfolg (kein Bild).
                          VLC kann den Link/Stream öffnen und zeigt mir an, dass es ein MJPG Format ist.
                          Wie mich das weiterbringen soll, weiß ich aber nicht... 🙂
                          Hat evtl. jemand ein ähnliches Vorhaben bereits umgesetzt oder hat erstmal weitere Tipps?
                          EDIT: man sollte nicht zu schnell aufgeben und auch alle Lösungsvorschläge durchprobieren 🙂 Das war die Lösung, sowohl für Webstream der Kamera, als auch für die Anzeige des Thumbnails des Druckjobs:
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/beispiele/module/html-dp-objektids/bilder-aus-dp-anzeigen
                            MCU @SevenUp last edited by
                            @sevenup Als iFrame einbinden?
                            • Dominik F.
                              @mcu
                              Ich verstehe gerade nicht was sich jetzt verändert hat?
                              Das was ich auswähle wird nicht in ThemeConfig geschrieben.
                              Auf die Button legen hat funktioniert, die Theme verändern sich.
                              Du hast in deiner Doku geschrieben, dass man sich Theme abspeichern kann und ich versuche gerade ein abgespeichert Theme wieder aufzurufen.
                              M U 2 Replies Last reply Reply Quote 0
                                @dominik-f Du hast Recht, da scheint noch was zu klemmen. Die Funktion ist nicht aktiv. Ich schau mal . Melde mich.
                                • Dominik F.
                                  @mcu
                                  Vielleicht hilft es dir ja beim Suchen, das zweite Theme, transparent, lässt sich auf deine Weise auswählen, nur das erste, normal, nicht
                                  • U
                                    uwe72 @Dominik F. last edited by
                                    @MCU
                                    Wäre es irgendwie möglich über binding den Schalter oben rechts "auszugrauen" oder sichtbar/unsichtbar zu schalten?
                                    Aktuell habe ich die ganze Zeile auf unsichtbar, schöner wäre es wenn nur der Switch betroffen wäre.
                                    Ich weiß, ihr erklärt mich für verrückt, aber wenn man den Schalter schnell hin und her schaltet kommt es zu Problemen, da die Datenpunkte vom Umschalten durch den Adapter noch nicht verarbeitet wurden. Von dem her könnte ich warten bis der Adpater die Bestätigungen schickt und dann den Switch wieder aktivieren.
                                      MCU @uwe72 last edited by
                                      @uwe72 Du kannst ja den Hintergrund verändern, aber nicht eine einzelne Komponente aus dem Body.
                                        @dominik-f Das ist ja schon das aktive. Nee die Funktion gibt es noch gar nicht im Programm. Ich dachte sie wäre drin.
                                        • Dominik F.
                                          @mcu
                                          Okay, kannst du mir kurz sagen, was bereits aktiv ist?
                                          Also zwischen 2 Themes wechseln funktioniert, das hab ich hinbekommen.
                                            @dominik-f @sigi234 Doku aktualisieren. Bitte das Programm neu laden aus der Doku. Und mit der alten Programmversion austauschen, drüberkopieren. Sonst ist alles aktiv, hoffe ich.
                                            254
                                            4489
                                            2660122
