    4. Alpha Test js-controller 4.0
    • Feuersturm
      Feuersturm @apollon77 last edited by Feuersturm
      @apollon77 Jup, Master und Slave sind jetzt auf js-controller 4.0 und die Meldungen sind nicht mehr da.
      System startet ohne Probleme und bisher keine Probleme ersichtlich.
      Habe gerade den Slave Host neu gestartet, indem ich eine Logging Änderung für Seq im Host konfiguriert habe was zum Neustart des Hosts geführt hat.
      Im Log stand dann folgendes:
      2022-01-31 23:26:17.539 - debug: history.1 (9160) Plugin sentry destroyed
      2022-01-31 23:26:17.517 - info: host.ioBrokerNew received SIGTERM
      2022-01-31 23:26:17.542 - info: discovery.0 (9175) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-01-31 23:26:17.547 - info: history.1 (9160) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-01-31 23:26:17.566 - info: host.ioBrokerNew stopInstance system.adapter.history.1 (force=false, process=true)
      2022-01-31 23:26:17.570 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-01-31 23:26:17.583 - info: discovery.0 (9175) Got terminate signal TERMINATE_YOURSELF
      2022-01-31 23:26:17.593 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 send kill signal
      2022-01-31 23:26:18.332 - info: host.ioBrokerNew instance system.adapter.history.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-01-31 23:26:18.594 - info: host.ioBrokerNew instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-01-31 23:26:18.598 - info: host.ioBrokerNew All instances are stopped.
      2022-01-31 23:26:18.638 - error: host.ioBrokerNew uncaught exception: Connection is closed.
      2022-01-31 23:26:18.640 - error: host.ioBrokerNew Error: Connection is closed.
      at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24)
      at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
      at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2662:37)
      at Immediate. (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2708:33)
      at processImmediate (internal/timers.js:466:21)
      2022-01-31 23:26:18.644 - info: host.ioBrokerNew stopInstance system.adapter.history.1 (force=false, process=false)
      2022-01-31 23:26:18.646 - info: host.ioBrokerNew stopInstance system.adapter.discovery.0 (force=false, process=false)
      2022-01-31 23:26:18.649 - info: host.ioBrokerNew iobroker _restart
      2022-01-31 23:26:18.915 - info: host.ioBrokerNew terminated
      2022-01-31 23:26:18.919 - info: host.ioBrokerNew terminated
      2022-01-31 23:26:21.591 - info: host.ioBrokerNew iobroker.js-controller version 4.0.0 js-controller starting
      2022-01-31 23:26:21.603 - info: host.ioBrokerNew Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-01-31 23:26:21.605 - info: host.ioBrokerNew hostname: ioBrokerNew, node: v14.18.1
      2022-01-31 23:26:21.607 - info: host.ioBrokerNew ip addresses: 192.168.178.78 fe80::d4a0:37ff:fe8e:f0c1
      2022-01-31 23:26:22.091 - info: host.ioBrokerNew connected to Objects and States
      2022-01-31 23:26:22.123 - info: host.ioBrokerNew added notifications configuration of host
      2022-01-31 23:26:23.102 - info: host.ioBrokerNew 59 instances found
      2022-01-31 23:26:23.199 - info: host.ioBrokerNew starting 2 instances
      2022-01-31 23:26:23.415 - info: host.ioBrokerNew instance system.adapter.history.1 started with pid 9238
      2022-01-31 23:26:25.047 - debug: history.1 (9238) Redis Objects: Use Redis connection: 192.168.178.77:9001
      2022-01-31 23:26:25.156 - debug: history.1 (9238) Objects client ready ... initialize now
      2022-01-31 23:26:25.160 - debug: history.1 (9238) Objects create System PubSub Client
      2022-01-31 23:26:25.164 - debug: history.1 (9238) Objects create User PubSub Client
      2022-01-31 23:26:25.287 - debug: history.1 (9238) Objects client initialize lua scripts
      2022-01-31 23:26:25.297 - debug: history.1 (9238) Objects connected to redis: 192.168.178.77:9001
      2022-01-31 23:26:25.361 - debug: history.1 (9238) Redis States: Use Redis connection: 192.168.178.77:9000
      2022-01-31 23:26:25.396 - debug: history.1 (9238) States create System PubSub Client
      2022-01-31 23:26:25.398 - debug: history.1 (9238) States create User PubSub Client
      2022-01-31 23:26:25.463 - debug: history.1 (9238) States connected to redis: 192.168.178.77:9000
      2022-01-31 23:26:25.989 - debug: history.1 (9238) Plugin sentry Initialize Plugin (enabled=true)
      2022-01-31 23:26:26.362 - info: history.1 (9238) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
      2022-01-31 23:26:27.423 - info: host.ioBrokerNew instance system.adapter.discovery.0 started with pid 9253
      2022-01-31 23:26:30.270 - info: discovery.0 (9253) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
        mrjeschke @apollon77 last edited by mrjeschke
        @apollon77
        Nach dem update auf den js-controller 4 bekomme ich wieder invalid
        Type errors.
        2022-01-31 23:45:51.995 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:51.996 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:51.998 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:51.999 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.000 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.000 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.002 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.002 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.003 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.003 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        2022-01-31 23:45:52.004 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
        2022-01-31 23:45:52.005 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
        edit: war etwas zu schnell.
        Fehler war vorher auch schon da, war aber vorher Info, jetzt Warnung
        apollon77 2 Replies Last reply Reply Quote 1
        • amg_666
          amg_666 @apollon77 last edited by
          @apollon77
          update lief durch:
          The object "system.certificates" was updated successfully.
          States DB type migrated from "file" to "jsonl"
          Objects DB type migrated from "file" to "jsonl"
          ioBroker configuration updated
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
          + iobroker.js-controller@4.0.0-alpha.67-20220131-6621d47f
          added 21 packages from 19 contributors, removed 1 package and updated 38 packages in 91.744s
          183 packages are looking for funding
            run `npm fund` for details
          Im Admin kam erstmal nix, das liegt aber glaube ich am Firefox und dem Cache. Nach F5 kam dann
          Update Slave lief auch durch, da kam dann allerdings
             │     New major version of npm available! 6.14.15 -> 8.3.0      │
             │   Changelog: https://github.com/npm/cli/releases/tag/v8.3.0   │
             │               Run npm install -g npm to update!               │
          pi@iostrom:/opt/iobroker $
          pi@iostrom:/opt/iobroker $ + iobroker.js-controller@4.0.0-alpha.67-20220131-6621d47f
          -bash: +: Kommando nicht gefunden.
          pi@iostrom:/opt/iobroker $ added 46 packages from 20 contributors, removed 146 packages and updated 38 packages in 122.123s
          -bash: added: Kommando nicht gefunden.
          pi@iostrom:/opt/iobroker $ 38 packages are looking for funding
          -bash: 38: Kommando nicht gefunden.
          pi@iostrom:/opt/iobroker $   run `npm fund` for details
          Soll npm 8.3.0 installiert werden ???? Ich denke mal nein, oder?
          Fazit: Alle Instanzen grün, System läuft 🙂
          Thomas Braun apollon77 2 Replies Last reply Reply Quote 1
            Thomas Braun Most Active @amg_666 last edited by
            @amg_666 sagte in Alpha Test js-controller 4.0:
            Nein, die Meldung kommt auch nicht vom iobroker sondern von npm selber.
              apollon77 @mrjeschke last edited by apollon77
              @maik-0 ja weil das Objekt falsch ist. In dem Fall definiert ein Objekt einen minimum Wert welcher den falschen datentyp hat. Bitte wie üblich beim Adapter ein issue anlegen
                apollon77 @amg_666 last edited by
                @amg_666 naja schau mal genau hin. Du hattest ein + vor dem npm Befehl und da kamen die bash Fehler her. Und nein funniest keine npm Updates machen ;-))
                  Thomas Braun Most Active @apollon77 last edited by
                  @apollon77
                  Edgy (node17/npm8) Testing meldet beim Upgrade von Adaptern:
                  RangeError: Maximum call stack size exceeded
                  Cannot upgrade: Maximum call stack size exceeded
                  echad@chet:~ $ iobroker update -u && iobroker upgrade all
                  Used repository: live-beta
                  Adapter    "socketio"     : 4.1.0    , installed 4.0.3  [Updatable]
                  Adapter    "web"          : 4.1.0    , installed 4.0.1  [Updatable]
                  Exception in PromiseRejectCallback:
                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:139
                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:128
                              await this.upgradeAdapterHelper(repo, sortedAdapters, forceDowngrade, autoConfirm);
                  echad@chet:~ $
                  apollon77 2 Replies Last reply Reply Quote 0
                    apollon77 @Thomas Braun last edited by
                    @thomas-braun GitHub Issue im Controller bitte
                    Thomas Braun arteck 2 Replies Last reply Reply Quote 0
                      @apollon77
                      Einzeln lief es jetzt durch:
                      iobroker upgrade web
                      war okay, danach war angeblich socketio auch aktualisiert.
                        arteck Developer Most Active @apollon77 last edited by arteck
                        @apollon77 das ist der
                        J:\source\ioBroker\SmartHome2>iobroker upgrade all
                        J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:139
                        J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:128
                          @maik-0 Neue info Adapter Version auf GitHub (und auf dem Weg ins Repo) 1.9.18 sollte das fixen
                            @thomas-braun sagte in Alpha Test js-controller 4.0:
                            Ja das liegt an internen dependencies. "unrelated"
                              @thomas-braun @arteck Grund gefunden
                              opossum 1 Reply Last reply Reply Quote 1
                              • opossum
                                opossum @apollon77 last edited by opossum
                                Hallo, @apollon77,
                                habe meine Testinstallation mit dem Update versehen. Lief alles sauber durch. Nach dem Update abgefragt:
                                debian@iobrokertest:/opt/iobroker$ iobroker status
                                Objects type: jsonl
                                States  type: jsonl
                                Auch die Meldung im Admin habe ich bestätigt. Danke für die super Arbeit.
                                Habe nach dem Update versucht, den Adapter Backitup von 2.2.1 auf 2.2.3 anzuheben, das ging leider nicht korrekt durch.
                                Folgende Meldungen im Log:
                                backitup.0 2022-02-01 16:25:22.031	error	backitup.0 already running
                                backitup.0 2022-02-01 16:24:50.013	error	backitup.0 already running
                                backitup.0 2022-02-01 16:24:18.025	error	backitup.0 already running
                                backitup.0 2022-02-01 16:23:46.142	error	backitup.0 already running
                                backitup.0 2022-02-01 16:23:31.285	error	backitup.0 already running
                                backitup.0 2022-02-01 16:22:59.313	error	backitup.0 already running
                                backitup.0 2022-02-01 16:22:27.386	error	backitup.0 already running
                                backitup.0 2022-02-01 16:22:24.131	error	Cannot read property 'getErrorText' of undefined
                                backitup.0 2022-02-01 16:22:24.129	error	TypeError: Cannot read property 'getErrorText' of undefined at Adapter.terminate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:241:64) at finishUnload (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8349:26) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.backitup/main.js:155:13) at Adapter.emit (events.js:400:28) at process.stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8376:22) at Object.onceWrapper (events.js:520:26) at process.emit (events.js:412:35)
                                Adapter wechselt zwischen rot und grün. Bringt aber laufend diesen Fehler. Auch nach Deinstallation und Neuinstallation gab es folgende Warnungen/Errors:
                                backitup.0 2022-02-01 16:39:17.887	warn	Got terminate signal. Checking desired PID: 2821 vs own PID 2348
                                backitup.0 2022-02-01 16:39:17.861	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                                backitup.0 2022-02-01 16:38:47.266	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                backitup.0 2022-02-01 16:38:47.262	error	backitup.0 already running
                                backitup.0 2022-02-01 16:38:45.884	warn	Got terminate signal. Checking desired PID: 2808 vs own PID 2348
                                backitup.0 2022-02-01 16:38:45.862	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                                backitup.0 2022-02-01 16:38:15.268	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                backitup.0 2022-02-01 16:38:15.265	error	backitup.0 already running
                                backitup.0 2022-02-01 16:38:13.960	warn	Got terminate signal. Checking desired PID: 2797 vs own PID 2348
                                backitup.0 2022-02-01 16:38:13.934	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                                backitup.0 2022-02-01 16:37:43.339	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                backitup.0 2022-02-01 16:37:43.336	error	backitup.0 already running
                                Hätte ich das Adapterupdate vorher machen sollen? Habe noch das Update des Web-Servers auf 3.4.16 durchgeführt, da gab es keine Auffälligkeiten.
                                Downgrade des Backitup auf 2.2.1 durchgeführt, der Fehler bleibt.
                                Habe dann den Fixer ausgeführt:
                                debian@iobrokertest:/opt/iobroker$ iobroker stop
                                debian@iobrokertest:/opt/iobroker$ iobroker fix
                                library: loaded
                                Library version=2021-12-27
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2021-12-27
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/3)
                                Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                                Holen:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
                                Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                                Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                                Holen:5 http://security.debian.org/debian-security bullseye-security/main Sources [95,3 kB]
                                Holen:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [115 kB]
                                Holen:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [74,4 kB]
                                Holen:8 http://deb.debian.org/debian bullseye/main Sources [8.626 kB]
                                Holen:9 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                                Holen:10 http://deb.debian.org/debian bullseye-updates/main Sources.diff/Index [4.995 B]
                                Holen:11 http://deb.debian.org/debian bullseye-updates/main amd64 Packages.diff/Index [4.995 B]
                                Holen:12 http://deb.debian.org/debian bullseye-updates/main Sources T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [238 B]
                                Holen:13 http://deb.debian.org/debian bullseye-updates/main amd64 Packages T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [1.102 B]
                                Holen:14 http://deb.debian.org/debian bullseye/main amd64 Packages [8.183 kB]
                                Holen:15 http://deb.debian.org/debian bullseye/main Translation-en [6.243 kB]
                                Es wurden 23,6 MB in 12 s geholt (1.939 kB/s).
                                Paketlisten werden gelesen… Fertig
                                N: Für das Depot »http://deb.debian.org/debian bullseye InRelease« wurde der »Version«-Wert von »11.1« in »11.2« geändert.
                                Installed gcc-c++
                                Installed python-dev
                                Installed cmake
                                    Checking ioBroker user and directory permissions (2/3)
                                Created /etc/sudoers.d/iobroker
                                Fixing directory permissions...
                                    Checking autostart (3/3)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                debian@iobrokertest:/opt/iobroker$ iobroker start
                                Jetzt läuft es wieder sauber mit BackitUp 2.2.1.
                                Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @opossum last edited by
                                  @opossum sagte in Alpha Test js-controller 4.0:
                                  Knips doch mal den Prozess aus.
                                  opossum 2 Replies Last reply Reply Quote 1
                                  • opossum
                                    opossum @Thomas Braun last edited by opossum
                                    Hallo, @thomas-braun,
                                    danke für die Hilfe. War wohl die Notwendigkeit, den Fixer drüber laufen zu lassen (siehe einen Post höher, habe den noch einmal editiert). Nun läuft es wieder sauber. Hätte wohl vorher die Linuxversion anheben müssen?
                                    • opossum
                                      habe noch einmal auf 2.2.3 hochgezogen, wieder die Fehlermeldung. Dann Deinen Rat befolgt und den
                                      Got terminate signal. Checking desired PID: 0 vs own PID 4383
                                      ausgeknipst. Ergebnis:
                                      backitup.0 2022-02-01 17:02:38.118	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                                      backitup.0 2022-02-01 17:02:38.035	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
                                      Ruhe und läuft, vielen Dank.
                                        Wenn ich mir apt update relevanten Part anschaue: Ja. Regelmäßiger updaten.
                                          apollon77 @opossum last edited by apollon77
                                          @opossum Hast du mal das echte Log von deinem"ersten "Log"? Also das auch /opt/iobroker/log/... ?
                                          Mich würde interessieren welche Prozess IDs (die stehen an sich in der Logzeile) da was geloggt hat. Und auch das volle Log und nicht "gefiltert" 🙂 Sowas hilft immer nicht wirklich um den Fehler eingrenzen zu können.
                                          Aber ja bei dir hat sich ein Prozess nicht beendet und das hat zu den Fehlern geführt.
                                          opossum 1 Reply Last reply Reply Quote 0
                                            Hallo alle miteinander,
                                            ich habe gerade den @next aktualisiert mit der alpha.69. Enthalten sind:
                                            • (Apollon77) Optimize Stop Handling to prevent errors - reported by @Feuersturm
                                            • (Apollon77) Fix upgrade all command - reported by @thomas-braun und @arteck
                                            • (foxriver76) fix error if controller exits before dbs are connected - reported by @opossum
                                            Eine neue Version des Info Adapters ist auch im Latest.
                                            Wars das schon ... mehr habt Ihr nicht zu bieten duck ;-)))
                                            Please check and retest
                                            Ingo
                                            Thomas Braun Feuersturm arteck 4 Replies Last reply Reply Quote 1
                                            196
                                            25822
