    4. Alpha Test js-controller 4.0
      mrjeschke @apollon77 last edited by mrjeschke
      @apollon77
      Nach dem update auf den js-controller 4 bekomme ich wieder invalid
      Type errors.
      2022-01-31 23:45:51.995 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:51.996 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      2022-01-31 23:45:51.998 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:51.999 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      2022-01-31 23:45:52.000 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:52.000 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      2022-01-31 23:45:52.002 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:52.002 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      2022-01-31 23:45:52.003 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:52.003 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      2022-01-31 23:45:52.004 - warn: info.0 (9932) Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
      2022-01-31 23:45:52.005 - warn: info.0 (9932) This object will not be created in future versions. Please report this to the developer.
      edit: war etwas zu schnell.
      Fehler war vorher auch schon da, war aber vorher Info, jetzt Warnung
      apollon77 2 Replies Last reply Reply Quote 1
      • amg_666
        amg_666 @apollon77 last edited by
        @apollon77
        update lief durch:
        The object "system.certificates" was updated successfully.
        States DB type migrated from "file" to "jsonl"
        Objects DB type migrated from "file" to "jsonl"
        ioBroker configuration updated
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
        + iobroker.js-controller@4.0.0-alpha.67-20220131-6621d47f
        added 21 packages from 19 contributors, removed 1 package and updated 38 packages in 91.744s
        183 packages are looking for funding
          run `npm fund` for details
        Im Admin kam erstmal nix, das liegt aber glaube ich am Firefox und dem Cache. Nach F5 kam dann
        Update Slave lief auch durch, da kam dann allerdings
           │     New major version of npm available! 6.14.15 -> 8.3.0      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v8.3.0   │
           │               Run npm install -g npm to update!               │
        pi@iostrom:/opt/iobroker $
        pi@iostrom:/opt/iobroker $ + iobroker.js-controller@4.0.0-alpha.67-20220131-6621d47f
        -bash: +: Kommando nicht gefunden.
        pi@iostrom:/opt/iobroker $ added 46 packages from 20 contributors, removed 146 packages and updated 38 packages in 122.123s
        -bash: added: Kommando nicht gefunden.
        pi@iostrom:/opt/iobroker $ 38 packages are looking for funding
        -bash: 38: Kommando nicht gefunden.
        pi@iostrom:/opt/iobroker $   run `npm fund` for details
        Soll npm 8.3.0 installiert werden ???? Ich denke mal nein, oder?
        Fazit: Alle Instanzen grün, System läuft 🙂
        Thomas Braun apollon77 2 Replies Last reply Reply Quote 1
          Thomas Braun Most Active @amg_666 last edited by
          @amg_666 sagte in Alpha Test js-controller 4.0:
          Nein, die Meldung kommt auch nicht vom iobroker sondern von npm selber.
            apollon77 @mrjeschke last edited by apollon77
            @maik-0 ja weil das Objekt falsch ist. In dem Fall definiert ein Objekt einen minimum Wert welcher den falschen datentyp hat. Bitte wie üblich beim Adapter ein issue anlegen
              apollon77 @amg_666 last edited by
              @amg_666 naja schau mal genau hin. Du hattest ein + vor dem npm Befehl und da kamen die bash Fehler her. Und nein funniest keine npm Updates machen ;-))
                Thomas Braun Most Active @apollon77 last edited by
                @apollon77
                Edgy (node17/npm8) Testing meldet beim Upgrade von Adaptern:
                RangeError: Maximum call stack size exceeded
                Cannot upgrade: Maximum call stack size exceeded
                echad@chet:~ $ iobroker update -u && iobroker upgrade all
                Used repository: live-beta
                Adapter    "socketio"     : 4.1.0    , installed 4.0.3  [Updatable]
                Adapter    "web"          : 4.1.0    , installed 4.0.1  [Updatable]
                Exception in PromiseRejectCallback:
                /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:139
                /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:128
                            await this.upgradeAdapterHelper(repo, sortedAdapters, forceDowngrade, autoConfirm);
                echad@chet:~ $
                apollon77 2 Replies Last reply Reply Quote 0
                  apollon77 @Thomas Braun last edited by
                  @thomas-braun GitHub Issue im Controller bitte
                  Thomas Braun arteck 2 Replies Last reply Reply Quote 0
                    @apollon77
                    Einzeln lief es jetzt durch:
                    iobroker upgrade web
                    war okay, danach war angeblich socketio auch aktualisiert.
                      arteck Developer Most Active @apollon77 last edited by arteck
                      @apollon77 das ist der
                      J:\source\ioBroker\SmartHome2>iobroker upgrade all
                      J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:139
                      J:\source\ioBroker\SmartHome2\node_modules\iobroker.js-controller\lib\setup\setupUpgrade.js:128
                        @maik-0 Neue info Adapter Version auf GitHub (und auf dem Weg ins Repo) 1.9.18 sollte das fixen
                          @thomas-braun sagte in Alpha Test js-controller 4.0:
                          Ja das liegt an internen dependencies. "unrelated"
                            @thomas-braun @arteck Grund gefunden
                            opossum 1 Reply Last reply Reply Quote 1
                            • opossum
                              opossum @apollon77 last edited by opossum
                              Hallo, @apollon77,
                              habe meine Testinstallation mit dem Update versehen. Lief alles sauber durch. Nach dem Update abgefragt:
                              debian@iobrokertest:/opt/iobroker$ iobroker status
                              Objects type: jsonl
                              States  type: jsonl
                              Auch die Meldung im Admin habe ich bestätigt. Danke für die super Arbeit.
                              Habe nach dem Update versucht, den Adapter Backitup von 2.2.1 auf 2.2.3 anzuheben, das ging leider nicht korrekt durch.
                              Folgende Meldungen im Log:
                              backitup.0 2022-02-01 16:25:22.031	error	backitup.0 already running
                              backitup.0 2022-02-01 16:24:50.013	error	backitup.0 already running
                              backitup.0 2022-02-01 16:24:18.025	error	backitup.0 already running
                              backitup.0 2022-02-01 16:23:46.142	error	backitup.0 already running
                              backitup.0 2022-02-01 16:23:31.285	error	backitup.0 already running
                              backitup.0 2022-02-01 16:22:59.313	error	backitup.0 already running
                              backitup.0 2022-02-01 16:22:27.386	error	backitup.0 already running
                              backitup.0 2022-02-01 16:22:24.131	error	Cannot read property 'getErrorText' of undefined
                              backitup.0 2022-02-01 16:22:24.129	error	TypeError: Cannot read property 'getErrorText' of undefined at Adapter.terminate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:241:64) at finishUnload (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8349:26) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.backitup/main.js:155:13) at Adapter.emit (events.js:400:28) at process.stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8376:22) at Object.onceWrapper (events.js:520:26) at process.emit (events.js:412:35)
                              Adapter wechselt zwischen rot und grün. Bringt aber laufend diesen Fehler. Auch nach Deinstallation und Neuinstallation gab es folgende Warnungen/Errors:
                              backitup.0 2022-02-01 16:39:17.887	warn	Got terminate signal. Checking desired PID: 2821 vs own PID 2348
                              backitup.0 2022-02-01 16:39:17.861	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                              backitup.0 2022-02-01 16:38:47.266	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              backitup.0 2022-02-01 16:38:47.262	error	backitup.0 already running
                              backitup.0 2022-02-01 16:38:45.884	warn	Got terminate signal. Checking desired PID: 2808 vs own PID 2348
                              backitup.0 2022-02-01 16:38:45.862	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                              backitup.0 2022-02-01 16:38:15.268	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              backitup.0 2022-02-01 16:38:15.265	error	backitup.0 already running
                              backitup.0 2022-02-01 16:38:13.960	warn	Got terminate signal. Checking desired PID: 2797 vs own PID 2348
                              backitup.0 2022-02-01 16:38:13.934	warn	Got terminate signal. Checking desired PID: 0 vs own PID 2348
                              backitup.0 2022-02-01 16:37:43.339	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              backitup.0 2022-02-01 16:37:43.336	error	backitup.0 already running
                              Hätte ich das Adapterupdate vorher machen sollen? Habe noch das Update des Web-Servers auf 3.4.16 durchgeführt, da gab es keine Auffälligkeiten.
                              Downgrade des Backitup auf 2.2.1 durchgeführt, der Fehler bleibt.
                              Habe dann den Fixer ausgeführt:
                              debian@iobrokertest:/opt/iobroker$ iobroker stop
                              debian@iobrokertest:/opt/iobroker$ iobroker fix
                              library: loaded
                              Library version=2021-12-27
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2021-12-27
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              Holen:1 http://security.debian.org/debian-security bullseye-security InRelease [44,1 kB]
                              Holen:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
                              Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
                              Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                              Holen:5 http://security.debian.org/debian-security bullseye-security/main Sources [95,3 kB]
                              Holen:6 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [115 kB]
                              Holen:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [74,4 kB]
                              Holen:8 http://deb.debian.org/debian bullseye/main Sources [8.626 kB]
                              Holen:9 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                              Holen:10 http://deb.debian.org/debian bullseye-updates/main Sources.diff/Index [4.995 B]
                              Holen:11 http://deb.debian.org/debian bullseye-updates/main amd64 Packages.diff/Index [4.995 B]
                              Holen:12 http://deb.debian.org/debian bullseye-updates/main Sources T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [238 B]
                              Holen:13 http://deb.debian.org/debian bullseye-updates/main amd64 Packages T-2022-01-24-2024.03-F-2022-01-24-2024.03.pdiff [1.102 B]
                              Holen:14 http://deb.debian.org/debian bullseye/main amd64 Packages [8.183 kB]
                              Holen:15 http://deb.debian.org/debian bullseye/main Translation-en [6.243 kB]
                              Es wurden 23,6 MB in 12 s geholt (1.939 kB/s).
                              Paketlisten werden gelesen… Fertig
                              N: Für das Depot »http://deb.debian.org/debian bullseye InRelease« wurde der »Version«-Wert von »11.1« in »11.2« geändert.
                              Installed gcc-c++
                              Installed python-dev
                              Installed cmake
                                  Checking ioBroker user and directory permissions (2/3)
                              Created /etc/sudoers.d/iobroker
                              Fixing directory permissions...
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              debian@iobrokertest:/opt/iobroker$ iobroker start
                              Jetzt läuft es wieder sauber mit BackitUp 2.2.1.
                              Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @opossum last edited by
                                @opossum sagte in Alpha Test js-controller 4.0:
                                Knips doch mal den Prozess aus.
                                opossum 2 Replies Last reply Reply Quote 1
                                • opossum
                                  opossum @Thomas Braun last edited by opossum
                                  Hallo, @thomas-braun,
                                  danke für die Hilfe. War wohl die Notwendigkeit, den Fixer drüber laufen zu lassen (siehe einen Post höher, habe den noch einmal editiert). Nun läuft es wieder sauber. Hätte wohl vorher die Linuxversion anheben müssen?
                                  • opossum
                                    habe noch einmal auf 2.2.3 hochgezogen, wieder die Fehlermeldung. Dann Deinen Rat befolgt und den
                                    Got terminate signal. Checking desired PID: 0 vs own PID 4383
                                    ausgeknipst. Ergebnis:
                                    backitup.0 2022-02-01 17:02:38.118	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                                    backitup.0 2022-02-01 17:02:38.035	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 4.0.0-alpha.67-20220131-6621d47f
                                    Ruhe und läuft, vielen Dank.
                                      Wenn ich mir apt update relevanten Part anschaue: Ja. Regelmäßiger updaten.
                                        apollon77 @opossum last edited by apollon77
                                        @opossum Hast du mal das echte Log von deinem"ersten "Log"? Also das auch /opt/iobroker/log/... ?
                                        Mich würde interessieren welche Prozess IDs (die stehen an sich in der Logzeile) da was geloggt hat. Und auch das volle Log und nicht "gefiltert" 🙂 Sowas hilft immer nicht wirklich um den Fehler eingrenzen zu können.
                                        Aber ja bei dir hat sich ein Prozess nicht beendet und das hat zu den Fehlern geführt.
                                        opossum 1 Reply Last reply Reply Quote 0
                                          Hallo alle miteinander,
                                          ich habe gerade den @next aktualisiert mit der alpha.69. Enthalten sind:
                                          • (Apollon77) Optimize Stop Handling to prevent errors - reported by @Feuersturm
                                          • (Apollon77) Fix upgrade all command - reported by @thomas-braun und @arteck
                                          • (foxriver76) fix error if controller exits before dbs are connected - reported by @opossum
                                          Eine neue Version des Info Adapters ist auch im Latest.
                                          Wars das schon ... mehr habt Ihr nicht zu bieten duck ;-)))
                                          Please check and retest
                                          Ingo
                                          Thomas Braun Feuersturm arteck 4 Replies Last reply Reply Quote 1
                                            @apollon77 sagte in Alpha Test js-controller 4.0:
                                            PROVOZIER MICH NICHT!!!1111111 😉
                                            Ich setzt das edgy-System jetzt auf node@18 und npm@9 !!!
                                            Der neue Adapter ws zickt noch irgendwie:
                                            error: ws.0 (19853) port 8084 already in use
                                            Da habe ich aber noch nicht verstanden, wie der nun mit socketio zusammenspielt oder überhaupt zusammenspielen soll oder den socketio ersetzt.
                                            196
                                            25834
