    4. Test Adapter OctoPrint
      SevenUp last edited by SevenUp
      Nun habe ich es aber kaputt gespielt: 😕
      Bei mir wurden DP für Thumbnails nicht angezeigt, deshalb habe ich den Adapter neuinstalliert (von v3 auf v3). Danach kommt es zu dem Fehler.
      Neuinstallation bringt nichts, "iobroker upload octoprint" und "... all" auch nicht. Sicherheitshalber ein "iobroker fix" löste das Problem auch nicht.
      Und nu? 🙂
      $ ./iobroker upgrade octoprint@3.0.0
      Update octoprint from @3.0.0 to @3.0.0
      NPM version: 6.14.15npm install iobroker.octoprint@3.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      upload [11] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/octoprint.png octoprint.png image/png
      Update "system.adapter.octoprint.0"
      upload [10] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/jsonConfig.json jsonConfig.json application/json
      upload [9] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [8] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [3] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [1] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [0] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/de/translations.json i18n/de/translations.json application/json
      Adapter "octoprint" updated
      process exited with code 0
      EDIT:
      --> tritt nur mit der alten Admin Oberfläche auf (benötige ich leider weiterhin für den linkeddevices Adapter). Schalte ich auf die neue Oberfläche um, sehe ich auch die Octoprint Config und die Möglichkeit die Plugins zu aktivieren (sah ich in der alten Oberfläche nicht).
      • haus-automatisierung
        haus-automatisierung Developer Most Active @SevenUp last edited by
        @sevenup sagte in Test Adapter OctoPrint:
        Der ioBroker Admin liegt mittlerweile in Version 5 vor. Leider muss man bei der Adapter-Pflege dann aktuell drei verschiedene Dateien aktualisieren, wenn man z.B. ein neues Textfeld im Admin möchte, welches in allen Versionen funktioniert. Da mir dazu die Zeit beim testen und entwickeln fehlt, habe ich alles rausgeworfen und nur die Admin 5 Konfiguration drin gelassen. Zumal ich selbst die "alte UI" gar nicht mehr verwende.
        Hast Du Lust das zu pflegen? 🙂
        S joergeli 2 Replies Last reply Reply Quote 1
          SevenUp @haus-automatisierung last edited by
          @haus-automatisierung verstehe ich vollkommen! Ich würde auch gerne auf den Admin 5 umsteigen, aber linkeddevices unterstützt es noch nicht... Deshalb schalte ich immer zwischen der alten und neue GUI hin und her und manchmal bleibe ich bei der alten hängen.
          Würdest du in der Adapter Beschreibung einen gut sichtbaren Hinweis platzieren, dass man die neue GUI nutzen sollte? Sonst kommt es evtl wie bei mir zu Verwirrungen 🙂
            hetti72 last edited by
            ich bin noch recht neu in dem Thema 3d Druckt und Octoprint. Ich habe nun mal eine Frage zum Seriellen reconnect von Octoprint.
            Gibt es die Möglichkeit über den Adapter in Octoprint den seriellen Reconnect zum Drucker zu triggern? Ich hab beim ersten Blick über die Objekte nichts passendes gefunden.
            Hintergrund: Ich möchte über IOBroker den Drucker mit einem Smart Plug ein bzw. auschalten, der Raspi mit Octoprint soll aber anbleiben. Allerdings verbindet sich Octoprint nicht wieder automatisch mit dem Drucker, wenn dieser ausgeschaltet war.
            gruß,
            Frank
            S Ralf_N 2 Replies Last reply Reply Quote 0
              SevenUp @hetti72 last edited by
              @hetti72 Hallo Frank,
              vielleicht hilft dir dieser Plugin?
              https://plugins.octoprint.org/plugins/portlister/
              "It also (if you have autoconnect turned on), will automatically connect to the printer (if the new port is the same as the one you’ve selected in connection settings) after a reasonable (long) delay to wait for the printer to actually come on."
              • Ralf_N
                Ralf_N @hetti72 last edited by Ralf_N
                @hetti72
                So habe ich das gelöst. Bei mir starte und verbindet sich alles von "alleine"
                PS: Drucker UND ! Octopi hängen bei mir an einem Shelly PlugS
                da_Woody S 2 Replies Last reply Reply Quote 0
                • da_Woody
                  da_Woody @Ralf_N last edited by
                  @ralf_n sagte in Test Adapter OctoPrint:
                  bei mir zwar an einer SP112, aber wozu gibts
                  da brauch ich kein blockly...
                  • Ralf_N
                    Ralf_N @da_Woody last edited by
                    @da_woody
                    weeennn ich aber manuell den Drucker ausschalte um etwas fertiges vom Bett zu bekommen und dabei der PI an bleibt ( weil er gerade noch ein Video rendert ) nutzt dir dein "automatisch bei ..." nix 🙂
                    DA greift dann aber mein blockly, wenn ich dann den Drucker einfach nur wieder an mache 😉
                    @hetti72
                    Schau dir mal die Funktion im Adapter an. Das könnte deine Lösung sein:
                    da_Woody H 2 Replies Last reply Reply Quote 0
                    • Ralf_N
                      @da_woody
                      Nachtrag.
                      Und wenn Matthias schon so einen geilen Adapter zusammen klöppelt, muss man doch auch seinen Funktionsumfang ausschöpfen ! 😉
                      • da_Woody
                        hä? die temperaturen werden nach druck ja automatisch auf 0 gesetzt. da kühlt das bett ab. wozu den drucker ausschalten? wird dadurch nicht schneller kalt... ergibt für mich keinen sinn, aber wie jeder mag... 🙂
                          SevenUp @Ralf_N last edited by
                          @ralf_n oder eben den von mir erwähnten Plugin.
                          Dann kann man sich das Blockly auch sparen 🙂
                          Ralf_N 1 Reply Last reply Reply Quote 0
                          • Ralf_N
                            Ralf_N @SevenUp last edited by
                            @sevenup
                            welches ich bis dato noch nicht kannte.
                            Klingt intersannt und schau ich mir an.
                            Thx.
                              hetti72 @Ralf_N last edited by
                              @ralf_n
                              Vielen Dank,
                              das ist genau das was ich gesucht habe. 👍
                              Danke 🙂
                                hetti72 @SevenUp last edited by
                                Habs mir angeschaut. Ist ganz ok und macht prinzipiell das was ich möchte, aber nicht ganz so elegant wie die Lösung von @Ralf_N
                                Trotzdem Danke
                                • joergeli
                                  joergeli @haus-automatisierung last edited by joergeli
                                  Hallo Matthias,
                                  kein issue, nur eine Frage:
                                  Gibt es einen Grund, warum Du im Octoprint-Adapter V 3.1.0 den bisherigen Datenpunkt
                                  octoprint.0.printjob.progress.printtime_left
                                  in
                                  octoprint.0.printjob.progress.printtimeLeft
                                  umbenannt hast?
                                  Ich frage deshalb, weil ich den "alten" Datenpunkt in einem JavaScript verwende und dieses mir nach der Aktualisierung auf V 3.1.0 Fehler geworfen hat. JS war zwar leicht zu fixen, aber ich denke andere müssten deshalb evtl. auch ihre VIS ändern, wenn sie den "alten" Datenpunkt vewenden?
                                  Jörg
                                  P.S. Hinweis: in github konnte ich kein Issue einstellen, weil das Feld zum Absenden dort ausgegraut war
                                    haus-automatisierung Developer Most Active @joergeli last edited by haus-automatisierung
                                    @joergeli sagte in Test Adapter OctoPrint:
                                    Gibt es einen Grund, warum Du im Octoprint-Adapter V 3.1.0 den bisherigen Datenpunkt ...
                                    Ja, weil alle anderen Datenpunkte auch in CamelCase sind 🙂
                                    Dann hast Du wohl eine erforderliche Information nicht ausgefüllt
                                    • ESP8266
                                      ESP8266 @haus-automatisierung last edited by ESP8266
                                      @haus-automatisierung, Hallo und erst einmal ein Danke für den Super Adapter.
                                      Wäre es in Zukunft möglich, die Lüftergeschwindigkeit, die Flow Rate Einstellung und die Koordinaten von X, Y und Z anzeigen zu lassen?
                                        haus-automatisierung Developer Most Active @ESP8266 last edited by
                                        @esp8266 sagte in Test Adapter OctoPrint:
                                        Müsste ich jetzt suchen, ob und wie ich das über die API bekomme. Hast Du das schon gefunden, dass das geht? Dann muss ich nicht suchen https://docs.octoprint.org/en/master/api/index.html
                                          haus-automatisierung Developer Most Active last edited by
                                          @haus-automatisierung , tut mir Leid, aber ich überlege noch den ganzen Mist einzustampfen.
                                          Danke für die Info?! Entschuldige wenn ich darauf jetzt nicht weiter eingehe. Ich baue das Feature trotzdem ein, wenn es okay ist? 🙂
                                          Habe die Infos in DisplayLayerProgress gefunden. Kommt in der nächsten Version. Mache ich gerade fertig.
                                            haus-automatisierung Developer Most Active last edited by haus-automatisierung
                                            Irgendwan muss es auch mal gut sein.
                                            Das denke ich auch - deswegen bitte Ende mit Offtopic. Hier gibts auch Leute die sich den Thread später durchlesen und nicht durch persönliche Auseinandersetzungen lesen möchten.
                                            Achso: Und ich würde mich zumindest sehr freuen, wenn Du dein Widget hier zur Verfügung stellst oder mal vorstellst. Das hilft ja auch anderen. Und dann gibts sicher auch Upvotes dafür 🙂 Von mir zumindest.
                                            ESP8266 2 Replies Last reply Reply Quote 1
                                            adapter entwicklung adatper updates developer testen
                                            49
                                            461
                                            95690
