    3. Entwicklung
    4. Problem beim integrationstest mit github-actions
    • AlCalzone
      AlCalzone Developer @apollon77 last edited by
      @apollon77 Aber warum läuft es lokal dann durch?
      @oliverio sagte in Problem beim integrationstest mit github-actions:
      ja lokal (debian im buanet) läuft es immer astrein durch.
      Nur um sicher zu gehen: @OliverIO wenn du lokal auf deinem Dev-Rechner ohne ioBroker den entsprechenden Befehl ausführst, siehe https://forum.iobroker.net/post/751003, dann läuft das Testing durch?
      • OliverIO
        OliverIO @AlCalzone last edited by
        @alcalzone
        ja, ist ein docker-container von buanet
        hier das log für test:integration
        > iobroker.mytime@0.7.12 test:integration /opt/iobroker/ioBroker.mytime
        > DEBUG=testing:* & mocha test/integration --exit
        Running tests in /tmp/test-iobroker.mytime
         Test the adapter (in a live environment)
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN test-iobroker.mytime@1.0.0 No description
        npm WARN test-iobroker.mytime@1.0.0 No repository field.
        added 2 packages from 2 contributors in 5.557s
        21 packages are looking for funding
         run `npm fund` for details
        Deprecated! Please use require("@iobroker/db-objects-file").Server in tests to start a server and then use require("@iobroker/db-objects-file").Client to connect with a client against this server!
        Server Data File: /tmp/test-iobroker.mytime/iobroker-data/objects.json
        Server Objects DB uses file write interval of 5000 ms
        Server  Redis inMem-objects listening on port 9001
        Redis Objects: Use Redis connection: 127.0.0.1:19001
        Objects client ready ... initialize now
        Objects create System PubSub Client
        Objects client initialize lua scripts
        Objects connected to redis: 127.0.0.1:19001
        Deprecated! Please use require("@iobroker/db-states-file").Server in tests to start a server and then use require("@iobroker/db-states-file").Client to connect with a client against this server!
        Server Data File: /tmp/test-iobroker.mytime/iobroker-data/states.json
        Server States DB uses file write interval of 30000 ms
        redis psubscribe cfg.o.*
        Server  Redis inMem-states listening on port 9000
        Redis States: Use Redis connection: 127.0.0.1:19000
        States create System PubSub Client
        States connected to redis: 127.0.0.1:19000
        Server Redis Publish Object system.adapter.test.0={"common":{},"type":"instance","_id":"system.adapter.test.0"}
        Objects system redis pmessage */cfg.o.system.adapter.test.0:{"common":{},"type":"instance","_id":"system.adapter.test.0"}
        Server Redis Publish Object system.adapter.mytime.0.alive={"_id":"system.adapter.mytime.0.alive","type":"state","common":{"name":"mytime.0 alive","type":"boolean","read":true,"write":true,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217856,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.alive:{"_id":"system.adapter.mytime.0.alive","type":"state","common":{"name":"mytime.0 alive","type":"boolean","read":true,"write":true,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217856,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.connected={"_id":"system.adapter.mytime.0.connected","type":"state","common":{"name":"mytime.0 is connected","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217866,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.connected:{"_id":"system.adapter.mytime.0.connected","type":"state","common":{"name":"mytime.0 is connected","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217866,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.compactMode={"_id":"system.adapter.mytime.0.compactMode","type":"state","common":{"name":"mytime.0.compactMode","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217872,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.compactMode:{"_id":"system.adapter.mytime.0.compactMode","type":"state","common":{"name":"mytime.0.compactMode","type":"boolean","read":true,"write":false,"role":"indicator.state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217872,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.cpu={"_id":"system.adapter.mytime.0.cpu","type":"state","common":{"name":"mytime.0.cpu","type":"number","read":true,"write":false,"role":"indicator.state","unit":"% of one core"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217878,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.cpu:{"_id":"system.adapter.mytime.0.cpu","type":"state","common":{"name":"mytime.0.cpu","type":"number","read":true,"write":false,"role":"indicator.state","unit":"% of one core"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217878,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.cputime={"_id":"system.adapter.mytime.0.cputime","type":"state","common":{"name":"mytime.0.cputime","type":"number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217884,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.cputime:{"_id":"system.adapter.mytime.0.cputime","type":"state","common":{"name":"mytime.0.cputime","type":"number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217884,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.memHeapUsed={"_id":"system.adapter.mytime.0.memHeapUsed","type":"state","common":{"name":"mytime.0 heap actually Used","type":"number","read":true,"write":false,"role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217890,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.memHeapUsed:{"_id":"system.adapter.mytime.0.memHeapUsed","type":"state","common":{"name":"mytime.0 heap actually Used","type":"number","read":true,"write":false,"role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217890,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.memHeapTotal={"_id":"system.adapter.mytime.0.memHeapTotal","type":"state","common":{"name":"mytime.0 total Size of the Heap","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217895,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.memHeapTotal:{"_id":"system.adapter.mytime.0.memHeapTotal","type":"state","common":{"name":"mytime.0 total Size of the Heap","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217895,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.memRss={"_id":"system.adapter.mytime.0.memRss","type":"state","common":{"name":"mytime.0 resident Set Size","desc":"Resident set size","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217901,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.memRss:{"_id":"system.adapter.mytime.0.memRss","type":"state","common":{"name":"mytime.0 resident Set Size","desc":"Resident set size","read":true,"write":false,"type":"number","role":"indicator.state","unit":"MB"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217901,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.uptime={"_id":"system.adapter.mytime.0.uptime","type":"state","common":{"name":"mytime.0 uptime","type":"number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217906,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.uptime:{"_id":"system.adapter.mytime.0.uptime","type":"state","common":{"name":"mytime.0 uptime","type":"number","read":true,"write":false,"role":"indicator.state","unit":"seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217906,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.inputCount={"_id":"system.adapter.mytime.0.inputCount","type":"state","common":{"name":"mytime.0 events input counter","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217912,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.inputCount:{"_id":"system.adapter.mytime.0.inputCount","type":"state","common":{"name":"mytime.0 events input counter","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217912,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.outputCount={"_id":"system.adapter.mytime.0.outputCount","type":"state","common":{"name":"mytime.0 events output counter","desc":"State's outputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217917,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.outputCount:{"_id":"system.adapter.mytime.0.outputCount","type":"state","common":{"name":"mytime.0 events output counter","desc":"State's outputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217917,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.eventLoopLag={"_id":"system.adapter.mytime.0.eventLoopLag","type":"state","common":{"name":"mytime.0 Node.js event loop lag","desc":"Node.js event loop lag in ms averaged over 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"ms"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217923,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.eventLoopLag:{"_id":"system.adapter.mytime.0.eventLoopLag","type":"state","common":{"name":"mytime.0 Node.js event loop lag","desc":"Node.js event loop lag in ms averaged over 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"ms"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217923,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.sigKill={"_id":"system.adapter.mytime.0.sigKill","type":"state","common":{"name":"mytime.0 kill signal","type":"number","read":true,"write":false,"desc":"Process id that must survive. All other IDs must terminate itself","role":"state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217929,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.sigKill:{"_id":"system.adapter.mytime.0.sigKill","type":"state","common":{"name":"mytime.0 kill signal","type":"number","read":true,"write":false,"desc":"Process id that must survive. All other IDs must terminate itself","role":"state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217929,"user":"system.user.admin"}
        Server Redis Publish Object system.adapter.mytime.0.logLevel={"_id":"system.adapter.mytime.0.logLevel","type":"state","common":{"name":"mytime.0 loglevel","type":"string","read":true,"write":true,"desc":"Loglevel of the adapter. Will be set on start with defined value but can be overridden during runtime","role":"state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217934,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.system.adapter.mytime.0.logLevel:{"_id":"system.adapter.mytime.0.logLevel","type":"state","common":{"name":"mytime.0 loglevel","type":"string","read":true,"write":true,"desc":"Loglevel of the adapter. Will be set on start with defined value but can be overridden during runtime","role":"state"},"native":{},"from":"system.adapter.mytime.0","ts":1643709217934,"user":"system.user.admin"}
        Server Redis Publish Object mytime.0.info={"_id":"mytime.0.info","type":"channel","common":{"name":"Information"},"native":{"counter":{}},"from":"system.adapter.mytime.0","ts":1643709217940,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.mytime.0.info:{"_id":"mytime.0.info","type":"channel","common":{"name":"Information"},"native":{"counter":{}},"from":"system.adapter.mytime.0","ts":1643709217940,"user":"system.user.admin"}
        Server Redis Publish Object mytime.0.info.connection={"_id":"mytime.0.info.connection","type":"state","common":{"role":"indicator.connected","name":"Device or service connected","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.mytime.0","ts":1643709217945,"user":"system.user.admin"}
        Objects system redis pmessage */cfg.o.mytime.0.info.connection:{"_id":"mytime.0.info.connection","type":"state","common":{"role":"indicator.connected","name":"Device or service connected","type":"boolean","read":true,"write":false,"def":false},"native":{},"from":"system.adapter.mytime.0","ts":1643709217945,"user":"system.user.admin"}
        2022-02-01 10:53:37.960  - info: mytime.0 (3535) starting. Version 0.7.12 in /tmp/test-iobroker.mytime/node_modules/iobroker.mytime, node: v14.18.2, js-controller: 4.0.0-alpha.46-20220119-9e487e55
        2022-02-01 10:53:37.999  - debug: mytime.0 (3535) main onReady start
        2022-02-01 10:53:38.002  - debug: mytime.0 (3535) main onReady open mytime
        2022-02-01 10:53:38.004  - debug: mytime.0 (3535) init
        2022-02-01 10:53:38.006  - debug: mytime.0 (3535) setState connection true
        2022-02-01 10:53:38.008  - debug: mytime.0 (3535) setCountdownInfo {}
        2022-02-01 10:53:38.010  - debug: mytime.0 (3535) setTimeseriesInfo {}
        Server memory publish system.adapter.mytime.0.logLevel {"val":"debug","ack":true,"ts":1643709218015,"q":0,"from":"system.adapter.mytime.0","lc":1643709218015}
        Server Redis Publish State system.adapter.mytime.0.logLevel={"val":"debug","ack":true,"ts":1643709218015,"q":0,"from":"system.adapter.mytime.0","lc":1643709218015}
        Server memory publish system.adapter.mytime.0.alive {"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        Server Redis Publish State system.adapter.mytime.0.alive={"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        Server memory publish system.adapter.mytime.0.connected {"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        Server Redis Publish State system.adapter.mytime.0.connected={"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        Server memory publish system.adapter.mytime.0.memRss {"val":66.08,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        Server Redis Publish State system.adapter.mytime.0.memRss={"val":66.08,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        Server memory publish system.adapter.mytime.0.memHeapTotal {"val":47.61,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        Server Redis Publish State system.adapter.mytime.0.memHeapTotal={"val":47.61,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        States system redis pmessage */system.adapter.mytime.0.logLevel:{"val":"debug","ack":true,"ts":1643709218015,"q":0,"from":"system.adapter.mytime.0","lc":1643709218015}
        States system redis pmessage */system.adapter.mytime.0.alive:{"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        States system redis pmessage */system.adapter.mytime.0.connected:{"val":true,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017,"expire":true}
        States system redis pmessage */system.adapter.mytime.0.memRss:{"val":66.08,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        States system redis pmessage */system.adapter.mytime.0.memHeapTotal:{"val":47.61,"ack":true,"ts":1643709218017,"q":0,"from":"system.adapter.mytime.0","lc":1643709218017}
        Server memory publish system.adapter.mytime.0.memHeapUsed {"val":13.79,"ack":true,"ts":1643709218025,"q":0,"from":"system.adapter.mytime.0","lc":1643709218025}
        Server Redis Publish State system.adapter.mytime.0.memHeapUsed={"val":13.79,"ack":true,"ts":1643709218025,"q":0,"from":"system.adapter.mytime.0","lc":1643709218025}
        Server memory publish system.adapter.mytime.0.uptime {"val":1,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server Redis Publish State system.adapter.mytime.0.uptime={"val":1,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server memory publish system.adapter.mytime.0.inputCount {"val":3,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server Redis Publish State system.adapter.mytime.0.inputCount={"val":3,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server memory publish system.adapter.mytime.0.outputCount {"val":9,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server Redis Publish State system.adapter.mytime.0.outputCount={"val":9,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server memory publish system.adapter.mytime.0.compactMode {"val":false,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server Redis Publish State system.adapter.mytime.0.compactMode={"val":false,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        States system redis pmessage */system.adapter.mytime.0.memHeapUsed:{"val":13.79,"ack":true,"ts":1643709218025,"q":0,"from":"system.adapter.mytime.0","lc":1643709218025}
        States system redis pmessage */system.adapter.mytime.0.uptime:{"val":1,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        States system redis pmessage */system.adapter.mytime.0.inputCount:{"val":3,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        States system redis pmessage */system.adapter.mytime.0.outputCount:{"val":9,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        States system redis pmessage */system.adapter.mytime.0.compactMode:{"val":false,"ack":true,"ts":1643709218026,"q":0,"from":"system.adapter.mytime.0","lc":1643709218026}
        Server memory publish mytime.0.info.connection {"val":false,"ack":true,"ts":1643709218037,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709214918}
        Server Redis Publish State mytime.0.info.connection={"val":false,"ack":true,"ts":1643709218037,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709214918}
        Server memory publish mytime.0.info.connection {"val":true,"ack":true,"ts":1643709218038,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709218038}
        Server Redis Publish State mytime.0.info.connection={"val":true,"ack":true,"ts":1643709218038,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709218038}
        States system redis pmessage */mytime.0.info.connection:{"val":false,"ack":true,"ts":1643709218037,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709214918}
        States system redis pmessage */mytime.0.info.connection:{"val":true,"ack":true,"ts":1643709218038,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709218038}
        2022-02-01 10:53:38.044  - info: mytime.0 (3535) state mytime.0.info.connection changed: false (ack = true)
        Server memory publish system.adapter.mytime.0.cpu {"val":0,"ack":true,"ts":1643709218040,"q":0,"from":"system.adapter.mytime.0","lc":1643709218040}
        Server Redis Publish State system.adapter.mytime.0.cpu={"val":0,"ack":true,"ts":1643709218040,"q":0,"from":"system.adapter.mytime.0","lc":1643709218040}
        Server memory publish system.adapter.mytime.0.cputime {"val":1.24,"ack":true,"ts":1643709218041,"q":0,"from":"system.adapter.mytime.0","lc":1643709218041}
        Server Redis Publish State system.adapter.mytime.0.cputime={"val":1.24,"ack":true,"ts":1643709218041,"q":0,"from":"system.adapter.mytime.0","lc":1643709218041}
        States system redis pmessage */system.adapter.mytime.0.cpu:{"val":0,"ack":true,"ts":1643709218040,"q":0,"from":"system.adapter.mytime.0","lc":1643709218040}
        States system redis pmessage */system.adapter.mytime.0.cputime:{"val":1.24,"ack":true,"ts":1643709218041,"q":0,"from":"system.adapter.mytime.0","lc":1643709218041}
        2022-02-01 10:53:38.047  - info: mytime.0 (3535) state mytime.0.info.connection changed: true (ack = true)
        The adapter started successfully.
           ✔ The adapter starts (6213ms)
        Server memory publish system.adapter.mytime.0.sigKill {"val":-1,"ack":false,"ts":1643709223038,"q":0,"from":"system.host.testing","lc":1643709223038}
        Server Redis Publish State system.adapter.mytime.0.sigKill={"val":-1,"ack":false,"ts":1643709223038,"q":0,"from":"system.host.testing","lc":1643709223038}
        States system redis pmessage */system.adapter.mytime.0.sigKill:{"val":-1,"ack":false,"ts":1643709223038,"q":0,"from":"system.host.testing","lc":1643709223038}
        2022-02-01 10:53:43.043  - info: mytime.0 (3535) Got terminate signal TERMINATE_YOURSELF
        2022-02-01 10:53:43.044  - debug: mytime.0 (3535) main onUnload try
        2022-02-01 10:53:43.045  - debug: mytime.0 (3535) closeConnections
        2022-02-01 10:53:43.046  - debug: mytime.0 (3535) deleteObservers
        2022-02-01 10:53:43.047  - info: mytime.0 (3535) cleaned everything up...
        2022-02-01 10:53:43.048  - info: mytime.0 (3535) terminating
        2022-02-01 10:53:43.049  - info: mytime.0 (3535) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        Server memory publish mytime.0.info.connection {"val":false,"ack":true,"ts":1643709223052,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709223052}
        Server Redis Publish State mytime.0.info.connection={"val":false,"ack":true,"ts":1643709223052,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709223052}
        States system redis pmessage */mytime.0.info.connection:{"val":false,"ack":true,"ts":1643709223052,"q":0,"from":"system.adapter.mytime.0","user":"system.user.admin","lc":1643709223052}
        mytime.0(3535) Redis QUIT received, close connection
        Server States 127.0.0.1:48802 close Redis connection
        Server States 127.0.0.1:48804 close Redis connection
        Server States 127.0.0.1:48806 close Redis connection
        Server Objects 127.0.0.1:52030 close Redis connection
        Server Objects 127.0.0.1:52034 close Redis connection
        Server Objects 127.0.0.1:52032 close Redis connection
        Server Redis QUIT received, close connection
        Server Objects 127.0.0.1:52016 close Redis connection
        Server Objects 127.0.0.1:52018 close Redis connection
        Server States 127.0.0.1:48786 close Redis connection
        Server States 127.0.0.1:48788 close Redis connection
         1 passing (31s)
        • AlCalzone
          AlCalzone Developer @OliverIO last edited by
          @oliverio Ich schau mir das auf Windows mal an. Weil ichs aber grade sehe: Alle Libraries, die nur im Frontend benötigt werden, haben in dependencies nix zu suchen. Die werden beim Kompilieren gebundlet und dann als eine Datei ausgeliefert.
          Mindestens folgende gehören stattdessen in die devDependencies:
          "@iobroker/adapter-react": "^2.0.15",
          "@material-ui/icons": "^4.11.2",
          "@material-ui/lab": "^4.0.0-alpha.60",
          "@material-ui/pickers": "^3.3.10",
          "@material-ui/core": "^4.12.3",
          "react": "^17.0.2",
          "react-dom": "^17.0.2",
          "react-icons": "^4.3.1",
          "prop-types": "^15.8.1",
          • AlCalzone
            Also bei mir läuft's auch unter Windows nicht:
            npm ERR! code 1
            npm ERR! path C:\Users\domin\AppData\Local\Temp\test-iobroker.mytime\node_modules\iobroker.vis
            npm ERR! command failed
            npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node main.js --install
            npm ERR! C:\Users\domin\AppData\Local\Temp\test-iobroker.mytime\node_modules\@iobroker\js-controller-adapter\build\lib\adapter\adapter.js:61
            npm ERR!         throw new Error(`Cannot find ${configFileName}`);
            npm ERR!         ^
            npm ERR!
            npm ERR! Error: Cannot find C:/Users/domin/AppData/Local/Temp/test-iobroker.mytime/iobroker-data/iobroker.json
            npm ERR!     at new Adapter (C:\Users\domin\AppData\Local\Temp\test-iobroker.mytime\node_modules\@iobroker\js-controller-adapter\build\lib\adapter\adapter.js:61:15)
            npm ERR!     at Object.<anonymous> (C:\Users\domin\AppData\Local\Temp\test-iobroker.mytime\node_modules\iobroker.vis\main.js:20:24)
            npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1101:14)
            npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
            npm ERR!     at Module.load (node:internal/modules/cjs/loader:981:32)
            npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
            npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:79:12)
            npm ERR!     at node:internal/main/run_main_module:17:47
            Das liegt wohl wirklich daran, dass beim npm install schon die DB laufen muss. Ich nehm das in meinen PR für die nächste Testing-Version mit auf.
              apollon77 @AlCalzone last edited by
              @alcalzone sagte in Problem beim integrationstest mit github-actions:
              Hängen bleiben oder so einen fehler werfen sollte es aber dennoch nicht
              • AlCalzone
                @apollon77 Im Testing wird alles auf einmal installiert (npm install --production), aber da läuft weder der Controller (weil er gerade auch installiert wird), noch wurde setup first ausgeführt. vis scheint aber davon auszugehen.
                  @alcalzone ich dachte an sich das (zumindestens früher) das install auch geht wennes auch ist ... deswegen -> issue anlegen bei vis!
                  • AlCalzone
                    @apollon77 sagte in Problem beim integrationstest mit github-actions:
                    Ich denke das ist spezifisch ein Problem im Testing-Setup, wo bei der Installation noch gar nichts aus dem ioBroker-Umfeld existiert.
                      @alcalzone Interessant ist: Wenn ich "npm install iobroker.vis" mache dann ist dem post install Skript egal das ioBroker nicht läuft - wie es soll ... warum ist es beim testing nicht?
                      • OliverIO
                        also,
                        nach dem neu sortieren der dependencies laufen die tests nun durch.
                        warum das so ist weiß ich nicht.
                        falls da was fehlte oder ein konflikt entstanden ist, dann sollten die fehlermeldungen auch irgendwie erscheinen. ansonsten ist das wirklich schwierig. rauszufinden.
                        ich verstehe natürlich, das wenn der test auf unterschiedlichen platformen (github/lokal) unterschiedliche ergebnisse liefert, eine fehlersuche sehr schwer ist.
                        • AlCalzone
                          AlCalzone Developer @OliverIO last edited by AlCalzone
                          Lass mich das auch mal nachstellen.
                          Edit: Also auch mit deinem aktuellen Stand gehts bei mir lokal nicht. Das müsste daran liegen, dass versucht wird, die iobroker-Basis-Konfig anzupassen, bevor sie von js-controller erstellt wird.
                          • AlCalzone
                            @OliverIO Hab das Problem gefunden. Wenn das Testing erst den Controller installiert und in einem separaten Schritt die Adapter, dann läuft es 1A.
                            Testing v2.5.4 sollte bestenfalls heute noch kommen.
                            • OliverIO
                              @alcalzone
                              super, danke.
                              • AlCalzone
                                @oliverio Ist released, magst du direkt mal testen?
                                OliverIO 1 Reply Last reply Reply Quote 1
                                • OliverIO
                                  @alcalzone
                                  https://github.com/oweitman/ioBroker.mytime/actions/runs/1781578934
                                  lasse diese action nochmal laufen.
                                  ist für alles soweit gut, nur node14 macos schief gegangen.
                                  • AlCalzone
                                    ja, passiert ab und an
                                    Sieht gut aus!
                                    2138
