    4. Alpha Test js-controller 4.0
    • opossum
      opossum @apollon77 last edited by
      Hallo, @apollon77,
      ich könnte die Datei hier hochladen, wäre das ok?
        apollon77 @opossum last edited by apollon77
        @opossum klar, wobei an sich haben wirs ja denke gefixt. Also lass es jetzt ... nur falls es noch kaputt ist
        opossum 1 Reply Last reply Reply Quote 0
        • opossum
          Hallo, @apollon77,
          ich habe das Log ja bei Bedarf, ist bis jetzt noch ok, läuft alles. Der DeConz-Adapter wirft noch ein paar Warnungen wegen falscher Feldtypen aus.
          deconz.0 2022-02-01 23:39:04.828	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:39:04.828	warn	Object Groups.2.xy is invalid: Default value has to be stringified but received type "object"
          deconz.0 2022-02-01 23:39:04.820	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:39:04.820	warn	Object Groups.65520.xy is invalid: Default value has to be stringified but received type "object"
          deconz.0 2022-02-01 23:38:36.485	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:38:36.485	warn	Object Groups.2.xy is invalid: Default value has to be stringified but received type "object"
          deconz.0 2022-02-01 23:38:36.431	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:38:36.430	warn	Object Groups.65520.xy is invalid: Default value has to be stringified but received type "object"
          deconz.0 2022-02-01 23:30:32.366	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:30:32.366	warn	Object Groups.2.xy is invalid: Default value has to be stringified but received type "object"
          deconz.0 2022-02-01 23:30:32.359	warn	This object will not be created in future versions. Please report this to the developer.
          deconz.0 2022-02-01 23:30:32.358	warn	Object Groups.65520.xy is invalid: Default value has to be stringified but received type "object"
          Geht das als Issue an den Entwickler vom DeConz-Adapter oder reicht es , das hier abzubilden?
          apollon77 Michael Schmitt 2 Replies Last reply Reply Quote 0
            @opossum bitte GitHub issues. Die wenigsten devs lesen hier mit. Ggf nach Adapter Updates prüfen.
            • opossum
              Hallo, @apollon77,
              ist erstellt.
              • MalleRalle
                MalleRalle last edited by
                Moin @apollon77
                mit dem neuen Controller habe ich bei all meinen Geräten diese Fehlermeldung im Alexa2 Adapter:
                (90262) Object Echo-Devices.90F0071865310GRK.Commands.speak-volume is invalid: obj.common.min is only allowed on obj.common.type "number", received "mixed"
                Issue ist angelegt im Alexa2 Git
                  apollon77 @MalleRalle last edited by
                  @malleralle Ich denke das ,üssen wir im controller fixen, aber danke!!
                    arteck Developer Most Active @apollon77 last edited by
                    @apollon77 sagte in Alpha Test js-controller 4.0:
                    Wars das schon ... mehr habt Ihr nicht zu bieten duck ;-)))
                    einmal mit Profi arbeiten...
                      A Former User @arteck last edited by
                      @arteck @apollon77
                      wenn hier nix mehr kommt, dann einfach als Beta releasen, das installieren 80% ... dann gibts genug zu meckern.. 🙂
                        Alles gut, es sind noch 2 Kleinigkeiten gekommen weil auch die Adpter-Entwickler mit testen was super ist.Ich denke Richtung Wochenende (wenn alles klappt) könnte eine Beta klappen ...
                        Und aus Erfahrung sind Beta/Latest maximal 20% :-))
                        • dontobi
                          dontobi last edited by
                          Ich habe soeben meinen ioBroker Docker Container aktualisiert. Bis jetzt läuft alles und in den Logs sehe ich erst einmal keine Meldungen.
                            mrjeschke @apollon77 last edited by
                            @apollon77
                            Moin,
                            Wenn ich in den Systemeinstellungen auf den neuen Reiter Lizenzen
                            gehe und dort Benutzernamen und Passwort eingebe, sehe ich dort
                            meine VIS-Lizenz. Beim speicher kommt aber ein Error.
                            Cannot read licenses: Cannot decode password: Cannot read properties of undefined (reading 'secret')
                            foxriver76 1 Reply Last reply Reply Quote 1
                            • foxriver76
                              foxriver76 Developer @mrjeschke last edited by
                              @maik-0 Danke fürs melden fix kommt heute Abend
                                msauer last edited by
                                Der LGTV Adapter zeigt eine seltsame Meldung im Log
                                Object states.input is invalid: obj.common.states has an invalid type! Expected "object", received "object"
                                was denn nun? object oder object?
                                Ich habe zwar ein Issue aufgemacht, aber das könnte auch am JS liegen, oder?
                                foxriver76 apollon77 2 Replies Last reply Reply Quote 0
                                • foxriver76
                                  foxriver76 Developer @msauer last edited by
                                  @msauer ist schon gefixt auf master, es wird null gesetzt.
                                    apollon77 @msauer last edited by
                                    @msauer Neue @next kommt heute späten Nachmittag vorauss
                                      Hallo Zusammen,
                                      @next ist aktualisiert auf die alpha.70:
                                      • (foxriver76) Do not overwrite custom certificates when updating certificates on "setup first" - reported by @Mark-Sau on GitHub
                                      • (foxriver76) Also allow min/max to be set for "mixed" type state objects - reported by @MalleRalle
                                      • (foxriver76) Allow to set "null" for common.states and not log error for object (but has no effect on extend, so value does not get deleted!) - reported by @HGlab on GitHub
                                      • (foxriver76) Fix error when using certificate manager in Admin5 - reported by @maik-0
                                        lonsimbt @apollon77 last edited by
                                        @apollon77
                                        Die Installation der alpha.70 ist bei mir gestern Abend erstaunlich problemlos durchgelaufen. Keine Fehler nur einige wenige Warnhinweise im LOG wegen falscher Typen bei zwei Adaptern. Mein System lief auch vorher schon mit jsonl.
                                        Ich würde gerne mehr berichten, bin im Moment aber nur sehr beeindruckt von Eurer Entwicklungsarbeit!
                                        Gruß Marco
                                          Hi All,
                                          ich habe gerade @next mit der alpha.72 aktualisiert:
                                          • (Apollon77) Optimize adapter proces initialization handling - reported by @arteck
                                          Diese Version ist damit der ReleaseCandidate für Beta/Latest
                                            apollon77 @lonsimbt last edited by
                                            @lonsimbt sagte in Alpha Test js-controller 4.0:
                                            Den Dank kann ich nur generell an alle zurückgeben die hier so "früh" mittesten 🙂 Das hilft ungemein wenn wir die nächsten Tage dann damit ins Beta/Latest gehen das es auch für diese User keine zu bösen Überraschungen gibt.
                                            Vielen Dank für Eure Unterstützung!
                                            1.0k
                                            196
                                            25762
