      J.M @dslraser last edited by
      Es funktioniert. Vielen Dank. Muss nur morgen den Aliasnamen anpassen dann sieht es perfekt aus.
      • dirk1962
        dirk1962 @s.bormann last edited by
        Hallo @s-bormann,
        der link zum Entwicklungs-Thread fehlt hier und der link im Support-Thread zum Entwicklungs-Thread funktioniert nicht.
        Grundsätzlich finde ich die Aufteilung sinnvoll.
        • dslraser
          dslraser Forum Testing Most Active @s.bormann last edited by dslraser
          @s-bormann
          Du könntest den Thread Titel hier noch anpassen ?
          • s.bormann
            s.bormann Most Active @dirk1962 last edited by
            @dirk1962 Hi, danke für den Hinweis, den Link habe ich korrigiert.
            • s.bormann
              s.bormann Most Active @buchner51 last edited by
              @buchner51 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
              @s-bormann
                "nuki-extended.0.smartlocks": {
                  "common": {
                    "name": "Nuki Smartlocks",
                    "write": false
                  "type": "channel",
                  "native": {},
                  "from": "system.adapter.nuki-extended.0",
                  "user": "system.user.admin",
                  "ts": 1622990362526,
                  "_id": "nuki-extended.0.smartlocks",
                  "acl": {
                    "object": 1636,
                    "owner": "system.user.admin",
                "nuki-extended.0.smartlocks.haustür_": {
                  "common": {
                    "name": "Haustür ",
                    "write": false
                  "type": "channel",
                  "native": {},
                  "ts": 1622990362528,
                  "_id": "nuki-extended.0.smartlocks.haustür_",
                  "acl": {
                    "object": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION": {
                  "common": {
                    "name": "Trigger an action",
                    "role": "value",
                    "type": "number",
                    "write": true,
                    "states": {
                      "0": "NO_ACTION",
                      "1": "UNLOCK",
                      "2": "LOCK",
                      "3": "UNLATCH",
                      "4": "LOCK_N_GO",
                      "5": "LOCK_N_GO_WITH_UNLATCH"
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK": {
                  "common": {
                    "name": "Trigger LOCK action",
                    "role": "button",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO": {
                  "common": {
                    "name": "Trigger LOCK_N_GO action",
                    "role": "button",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH": {
                  "common": {
                    "name": "Trigger LOCK_N_GO_WITH_UNLATCH action",
                    "role": "button",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH": {
                  "common": {
                    "name": "Trigger UNLATCH action",
                    "role": "button",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK": {
                  "common": {
                    "name": "Trigger UNLOCK action",
                    "role": "button",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.bridgeId": {
                  "common": {
                    "name": "Bridge ID of the Nuki",
                    "role": "value",
                    "type": "number",
                    "write": false
                  "type": "state",
                  "native": {},
                  "ts": 1622990362529,
                  "_id": "nuki-extended.0.smartlocks.haustür_.bridgeId",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.hex": {
                  "common": {
                    "name": "Hex ID of the Nuki",
                    "role": "text",
                    "type": "string",
                    "write": false
                  "type": "state",
                  "native": {},
                  "ts": 1622990362563,
                  "_id": "nuki-extended.0.smartlocks.haustür_.hex",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.id": {
                  "common": {
                    "name": "ID of the Nuki",
                    "role": "value",
                    "type": "number",
                    "write": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.id",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.info": {
                  "common": {
                    "name": "Additional Information",
                    "write": false
                  "type": "channel",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.info",
                  "acl": {
                    "object": 1636,
                "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion": {
                  "common": {
                    "name": "The firmware version",
                    "role": "value",
                    "type": "number",
                    "write": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.name": {
                  "common": {
                    "name": "Name of the Bridge / Nuki",
                    "role": "text",
                    "type": "string",
                    "write": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.name",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state": {
                  "common": {
                    "name": "Current states",
                    "write": false
                  "type": "channel",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state",
                  "acl": {
                    "object": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState": {
                  "common": {
                    "name": "Indicates battery charge level",
                    "role": "value",
                    "type": "number",
                    "write": false
                  "type": "state",
                  "native": {},
                  "ts": 1622995898502,
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.batteryCharging": {
                  "common": {
                    "name": "Indicates battery charging",
                    "role": "indicator",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "ts": 1622995898501,
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCharging",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.batteryCritical": {
                  "common": {
                    "name": "Indicates critical battery level",
                    "role": "indicator.lowbat",
                    "type": "boolean",
                    "write": true,
                    "read": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCritical",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.deviceType": {
                  "common": {
                    "name": "Type of device",
                    "role": "value",
                    "type": "number",
                    "write": false,
                    "states": {
                      "0": "Nuki Smart Lock",
                      "2": "Nuki Opener"
                  "type": "state",
                  "native": {},
                  "ts": 1622990531628,
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.deviceType",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.doorState": {
                  "common": {
                    "name": "Türsensor-DoorClosed(2)-DoorOpen(3)",
                    "role": "value",
                    "type": "number",
                    "write": false,
                    "states": {
                      "0": "UNAVAILABLE",
                      "1": "DEACTIVATED",
                      "2": "DOOR_CLOSED",
                      "3": "DOOR_OPENED",
                      "4": "DOOR_STATE_UNKNOWN",
                      "5": "CALIBRATING"
                    "custom": {
                      "iqontrol.0": {
                        "0": "",
                        "1": "",
                        "2": "",
                        "enabled": true,
                        "invert": false,
                        "confirm": false,
                        "pincode": "",
                        "step": "",
                        "roundDigits": 2,
                        "timeFormat": "x",
                        "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
                        "targetValueId": "",
                        "statesAddInput": false,
                        "statesAddInputCaption": "Enter other value...",
                        "showOnlyTargetValues": false,
                        "readonly": false,
                        "unit": "",
                        "unit_zero": "LOCKED",
                        "unit_one": "UNLATCHED",
                        "min": "",
                        "max": "",
                        "type": "number",
                        "role": "value",
                        "targetValues": "",
                        "states": {
                          "DOOR_CLOSED": "true",
                          "DOOR_OPENED": "false"
                        "timeDisplayDontShowDistance": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.doorState",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                  "ts": 1642363067003
                "nuki-extended.0.smartlocks.haustür_.state.doorStateName": {
                  "common": {
                    "name": "Current door-state name of the Nuki",
                    "role": "text",
                    "type": "string",
                    "write": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.doorStateName",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate": {
                  "common": {
                    "name": "Timestamp of last data update / refresh",
                    "role": "date",
                    "type": "string",
                    "write": false
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate": {
                  "common": {
                    "name": "Timestamp of last state change",
                    "role": "date",
                    "type": "string",
                    "write": false
                  "type": "state",
                  "native": {},
                  "ts": 1622990362530,
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.state.lockState": {
                  "common": {
                    "name": "Motorschloss-Locked(1)-Unlocked(3)",
                    "role": "value",
                    "type": "number",
                    "write": false,
                    "states": {
                      "0": "UNCALIBRATED",
                      "1": "LOCKED",
                      "2": "UNLOCKING",
                      "3": "UNLOCKED",
                      "4": "LOCKING",
                      "5": "UNLATCHED",
                      "6": "UNLOCKED_LOCK_N_GO",
                      "7": "UNLATCHING",
                      "254": "MOTOR_BLOCKED",
                      "255": "UNDEFINED"
                    "custom": {
                      "iqontrol.0": {
                        "0": "",
                        "1": "",
                        "3": "",
                        "enabled": true,
                        "invert": false,
                        "confirm": false,
                        "pincode": "",
                        "step": "",
                        "roundDigits": 2,
                        "timeFormat": "x",
                        "readonly": false,
                        "unit": "",
                        "unit_zero": "",
                        "unit_one": "",
                        "min": "",
                        "max": "",
                        "type": "number",
                        "role": "value",
                        "targetValues": {},
                        "states": {
                          "1": "true",
                          "3": "false"
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.lockState",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                  "ts": 1642363118406
                "nuki-extended.0.smartlocks.haustür_.state.locked": {
                  "common": {
                    "name": "Indication if door is locked (boolean of lockState)",
                    "role": "sensor.lock",
                    "type": "boolean",
                    "write": false,
                    "states": {
                      "0": "false",
                      "1": "true",
                      "2": "false",
                      "3": "false",
                      "4": "true",
                      "5": "false",
                      "6": "false",
                      "7": "false",
                      "254": "false",
                      "255": "false"
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.locked",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                  "ts": 1641742002315
                "nuki-extended.0.smartlocks.haustür_.state.mode": {
                  "common": {
                    "name": "Operation Mode of the Nuki or Opener",
                    "role": "value",
                    "type": "number",
                    "write": false,
                    "states": {
                      "0": "UNINITIALIZED",
                      "1": "PAIRING",
                      "2": "NORMAL",
                      "3": "CONTINUOUS",
                      "4": "MAINTENANCE"
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.state.mode",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                "nuki-extended.0.smartlocks.haustür_.type": {
                  "common": {
                    "role": "value",
                    "type": "number",
                    "write": false,
                    "states": {
                      "2": "Nuki Opener"
                  "type": "state",
                  "native": {},
                  "_id": "nuki-extended.0.smartlocks.haustür_.type",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
              meinst du so als Json?
              habe mir das jetzt mal in Ruhe angeschaut. Das Nuki implementiert das ganz anders, als es bei meiner Keymatic der Fall ist (die hatte ich als Vorlage genommen). Aber ich glaube, mit ein paar Anpassungen sollte es jetzt laufen:
              • Bitte die aktuelle Github-Version laden
              • Da sind beim Türschloss folgende neue Optionen drin, die so konfiguriert werden müssen:
              • Als Datenpunkte konfigurierst Du folgendes:
              • Beim Datenpunkt state.locked gehst Du auf den Schrabenschlüssel und konfigurierst folgendes:
                • Typ: Bool
                • Rolle: Schalter
                • Target-Value-List:
                  • true -> nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK --> true
                  • false -> nuki-extended.0.smartlocks.haustür_._ACTION.LOCK --> true
              Bitte probier das mal so und gib Rückmeldung. Wenn das klappt, stelle ich den Beitrag ins Wiki.
              J B 2 Replies Last reply Reply Quote 0
              • s.bormann
                @dslraser sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis:
                @dslraser sagte in Test Adapter iQontrol 1.11.x Vis:
                @s-bormann , oder auch andere
                sollte ich mit dem Blockly Kram lieber einen anderen Thread eröffnen ? Ich möchte hier auch nicht damit nerven.
                Also wegen mir nicht, ist doch spannend, was Du entwickelst!
                Aber generell könnte man überlegen, einen iQontrol-Entwicklungs-Thread zu machen, in dem Github-Alpha-Tests und neue Dinge erprobt werden und einen iQontrol-Support-Thread, der dann eher für reine Anwender gedacht ist. Meinungen hierzu?
                Gern, dann mach Du die ruhig auf.
                Erledigt. Sag mal, um noch mal auf die Sortierung zurück zu kommen: Sortieren nach Wert, macht das für die NAMES und PARENTNAMES-Listen wirklich Sinn? Eigentlich macht es doch nur Sinn für die Datenpunkt-Listen, die dann weiter verarbeitet werden. Oder? Bin mir gerade selbst nicht ganz sicher, was sinnvoll ist. Hast Du ein Beispiel, wo Du die Sortierung bräuchtest?
                Die Sortierung für die Namenslisten mit Wert, also die Sortierung nach Wert und nicht alphabetisch wäre für die Alexa Ansagen und auch Telegram/E-Mail meiner Meinung nach schöner, weil dann bei z.B. mehreren leeren Batterien die mit dem schlechtesten Werten zuerst angesagt werden würden.
                Bei Listen ohne Wert ist alphabetisch hingegen genau richtig, denke ich.
                Ist jetzt auf Github zum Testen.
                • dslraser
                  @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                  funktioniert 👍
                  aber
                  iQontrol startet bei mir nicht mehr ?
                  s.bormann da_Woody 2 Replies Last reply Reply Quote 0
                  • s.bormann
                    funktioniert 👍
                    aber
                    Ich befürchte, das ist doch eine Inkompatibilität wegen des neuen Sockets. Hast Du den web-Adapter schon geupdated?
                    • dslraser
                      @s-bormann
                      nein, ich habe nicht geupdatet. Hier ist schonmal was ? (zwei Semikolon, ist aber nur LOG, oder ?)
                      • s.bormann
                        @s-bormann
                        Ich nehme die Zeile 13591 wieder raus. Die hat einen Fehler im neuen Socket abgefangen, scheint aber jetzt Probleme mit dem alten Socket zu machen. Ich eröffne ein Issue im neuen Socket-Github, dann soll der Fehler dort gefixed werden.
                        s.bormann 1 Reply Last reply Reply Quote 1
                        • s.bormann
                          s.bormann Most Active @s.bormann last edited by
                          @s-bormann
                          Sollte jetzt wieder laufen
                          • dslraser
                            macht es, danke 👍
                            • da_Woody
                              da_Woody @dslraser last edited by
                              @dslraser jetzt schon egal, aber da war doch was mit siocketio und web 4.0. gestern doch zurückgenommen und dann 4.0.1 aufgetaucht.
                              ich hatte zwar keine probs, aber es gab themen dazu...
                                J.M @s.bormann last edited by
                                @s-bormann Dank deiner Bilder und der Anpassung habe ich es jetzt auch hinbekommen. Habe auch ein Nuki verbaut und auch schon mehrere Sachen vorher probiert, ohne Erfolg. Endlich Zeigt er den richtigen Status an. Danke
                                • s.bormann
                                  s.bormann Most Active last edited by s.bormann
                                  Soo, ich glaube die Listen nähern sich der finalen Version:
                                  Als vorerst letztes geplantes Feature habe ich jetzt noch LOGs eingefügt. Damit kann man Änderungen an Datenpunkten loggen und als JSON-Table visualisieren.
                                  Als Beispiel habe ich das bei den Service-Messages mal mit eingefügt. Ein passendes Widget wird dabei auch gleich erstellt.
                                  Ergebnis:
                                  da_Woody JLeg 2 Replies Last reply Reply Quote 3
                                  • da_Woody
                                    da_Woody @s.bormann last edited by
                                    @s-bormann hehe, ich bin froh, wenn ich keine logs sehe! 😄
                                    • dslraser
                                      dslraser Forum Testing Most Active @dirk1962 last edited by dslraser
                                      @dirk1962 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                                      Hallo @dslraser,
                                      in den alten Blocklys hast Du zum Schluß die Versions-Nr. mit angezeigt.
                                      Hat keine Eile, könnte aber für die Zukunft durchaus Sinn machen.
                                      Hallo Dirk,
                                      mit der Versionsnummer hattest Du natürlich recht.
                                      Ich lade nachher mal eine neue Version (0.2) hoch. In dieser Version habe ich noch einiges geändert.
                                      Diese Version soll als Vorlage dienen für alle Geräte/Listen mit „zwei Zuständen“.
                                      Mit zwei Zuständen meine ich z.B
                                      • Steckdosen an/aus
                                      • Lichter an/aus
                                      • Bewegungsmelder aktiv/inaktiv
                                      • Batterien LOWBAT leer/sind okay
                                      • Batterien in Prozent kleiner X Prozent/sind okay
                                      • Batterien in Volt kleiner X Volt/sind okay
                                      • usw. usw. usw.
                                      Für reine Listen wie Temperaturen/Luftfeuchtigkeit usw. mache ich noch eine kleinere Version als Vorlage.
                                      Eine Version mit 3 Zuständen kommt dann später noch. Das sind z.B. Fenster/Türen oder Rollos usw.
                                      Die könnten ja z.B. geschlossen/gekippt oder geöffnet sein.
                                      So müsste man mit 3 Blocklys alles abdecken können. (und die Pflege wird dann für mich einfacher)
                                      PS: In dieser Version habe ich noch etwas neues eingebaut, wenn Alexa verwendet wird. Wenn also Alexa_verwenden auf wahr steht, dann wird nach dem speichern bzw. beim Blockly Start der iot Adapter, wenn vorhanden die Instanz 0 und die Instanz 1 neu gestartet. Damit erübrigt sich dann das öffnen und schließen des iot Adapters vor einer neuen Geräte suche. Durch diesen Neustart sollten neue Geräte direkt gepuscht werden und von Alexa in der Amazon Gerätesuche immer gefunden werden. 22.02.2022 Erstmal wieder deaktiviert.
                                      PPS: Ich habe vorhin alle meine Blockly und dazugehörigen Datenpunkte gelöscht und habe in ca. 30 Minuten mit der Vorlage (0.2) alle diese Blockly (bis auf Fenster und Türen) neu erstellt. Ich habe aber auch alles so benannt wie vorher. Alle Ansagen (Routinen) sowie Telegram/EMAIL und die schon bestehenden Widget und andere iQontrol Einstellungen funktionierten wie vorher. In der Vorlage müssen dann nur die Einstellungen (also die Variablen) angepasst werden.
                                      EDIT: hier nun mal zum testen die Vorlage 2 in der Version 0.2 (in dieser Vorlage sind noch meine Einstellungen für Batterien---LOWBAT. Wenn benötigt, dann kann ich noch ein weiteres Beispiel mit meinen Voreinstellungen zum Vergleich wie ich was eingestellt habe hier rein stellen)
                                      Vorlage_2_Version_0_2.zip
                                      EDIT2: hier nun mal zum testen die Vorlage 1 in der Version 0.2 (in dieser Vorlage sind noch meine Einstellungen für Temperaturen)
                                      Vorlage_1_Version_0_2.zip
                                      EDIT: 07.02.2022
                                      Bisher war hier nach dem erstellen der Listen immer ein Leerzeichen nach dem Komma oder nach dem Semikolon. Ich habe eben eine neue Liste erstellt, die scheint jetzt ohne Leerzeichen zu sein.
                                      Ich habe die beiden Vorlagen (Vorlage_01 und Vorlage_02) darauf angepasst.
                                      Vorlage_1_Version_0_3.zip
                                      Vorlage_2_Version_0_3.zip
                                      je nach dem ob mit oder ohne Leerzeichen erfolgt ein Zeilenumbruch, oder eben nicht
                                      dirk1962 1 Reply Last reply Reply Quote 5
                                        Aachen1305 @martinschm last edited by
                                        @martinschm
                                        Kannst Du mir verraten, wie Du die Post Benachrichtigung gemacht hast?
                                        Stephan
                                          martinschm @Aachen1305 last edited by
                                          @aachen1305 said in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                                          @martinschm
                                          Stephan
                                          Ich glaube du verwechselst mich. Sowas hab ich nicht umgesetzt.
                                            @martinschm
                                            Es scheint so.
                                            Bin ich bei den 6500 Beiträgen wohl durcheinander gekommen.
                                            Sorry, dacht Du hättest eine Kachel mit der Post Benachrichtigung in deiner Vis gehabt.
                                            Such ich mich nochmals durch 😀
                                            296
                                            7637
                                            6953403
