    • Dominik F.
      Dominik F. @MCU last edited by
      @mcu
      Hier noch ein anderes von mir:
        "configName": "Grey",
        "0_userdata.0.jarvis.system.cssThemes.01_jarvisPageContainerBG": {},
        "0_userdata.0.jarvis.system.cssThemes.02_bodyDarkjarvisHeaderBG": {},
        "0_userdata.0.jarvis.system.cssThemes.03_jarvisTabsContainerBG": {
          "background-color": "#303030 !important"
        "0_userdata.0.jarvis.system.cssThemes.04_jarvisWidgetContainerBG": {},
        "0_userdata.0.jarvis.system.cssThemes.05_bodyDarkJarvisWidgetBG": {},
        "0_userdata.0.jarvis.system.cssThemes.06_bodyLightJarvisWidgetBG": {},
        "0_userdata.0.jarvis.system.cssThemes.07_bodyDarkJarvisTabsContainerBG": {
        "0_userdata.0.jarvis.system.cssThemes.08_qTableContainerBG": {},
        "0_userdata.0.jarvis.system.cssThemes.09_qHeaderBorderedBG": {},
        "0_userdata.0.jarvis.system.cssThemes.10_jarvisWidgetIconBG": {
          "background": "transparent !important",
          "color": "LightGray"
        "0_userdata.0.jarvis.system.cssThemes.11_bodyDarkJarvisWidgetHeaderTexth6": {},
        "0_userdata.0.jarvis.system.cssThemes.12_jarvisHeader": {},
        "0_userdata.0.jarvis.system.cssThemes.13_jarvisSidebar": {
          "background-color": "#303030"
        "0_userdata.0.jarvis.system.cssThemes.14_jarvisSidebarItemPage": {},
        "0_userdata.0.jarvis.system.cssThemes.15_jarvisSidebarItemPageSelected": {},
        "0_userdata.0.jarvis.system.cssThemes.16_jarvisStateListItemPopup": {},
        "0_userdata.0.jarvis.system.cssThemes.17_jarvisWidgetHeader": {
          "background-color": "#606060 !important"
        "0_userdata.0.jarvis.system.cssThemes.18_jarvisTabs": {},
        "0_userdata.0.jarvis.system.cssThemes.19_qItemDark": {
          "background-color": "transparent"
        "0_userdata.0.jarvis.system.cssThemes.20_jarvisWidgetModuleStateList": {
        "0_userdata.0.jarvis.system.cssThemes.21_jarvisStateListItemBody": {
        "0_userdata.0.jarvis.system.cssThemes.22_jarvisJsonTable": {
          "background-color": "#303030 !important",
        "0_userdata.0.jarvis.system.cssThemes.23_rowItemsCenterqCardSectionVert": {
        "0_userdata.0.jarvis.system.cssThemes.24_qCardActioinsHorizRowJustifyEnd": {
        "0_userdata.0.jarvis.system.cssThemes.25_jarvisPageContainerScroll": {},
        "0_userdata.0.jarvis.system.cssThemes.26_jarvisPageContainerTextArea": {},
        "0_userdata.0.jarvis.system.cssThemes.27_qSliderThumb": {},
        "0_userdata.0.jarvis.system.cssThemes.28_notificationDrawerButton": {
          "display": "none !important"
        "0_userdata.0.jarvis.system.cssThemes.29_jarvisDateTimeClock": {},
        "0_userdata.0.jarvis.system.cssThemes.30_qToggleThumb": {},
        "0_userdata.0.jarvis.system.cssThemes.31_jarvisSidebarItem": {},
        "0_userdata.0.jarvis.system.cssThemes.32_jarvisPage": {},
        "0_userdata.0.jarvis.system.cssThemes.33_jarvisIconPath": {},
        "0_userdata.0.jarvis.system.cssThemes.34_qSliderqSliderTrack": {},
        "0_userdata.0.jarvis.system.cssThemes.35_qItemSectionqItemLabelTextH6": {
        "0_userdata.0.jarvis.system.cssThemes.36_bodyDarkStickyTableHeaderTheadTrTh": {},
        "0_userdata.0.jarvis.system.cssThemes.37_bodyDarkTrNthChild2n": {},
        "0_userdata.0.jarvis.system.cssThemes.50_mediaColorCover": {},
        "0_userdata.0.jarvis.system.cssThemes.51_mediaControls": {},
        "0_userdata.0.jarvis.system.cssThemes.52_mediaTrackInformation": {},
        "0_userdata.0.jarvis.system.cssThemes.53_mediaTrackDuration": {},
        "0_userdata.0.jarvis.system.cssThemes.54_mediaTrackProgress": {},
        "0_userdata.0.jarvis.system.cssThemes.55_mediaControlsJarvisIconSvg": {},
        "0_userdata.0.jarvis.system.cssThemes.56_mediaControlsControlsLeftQbtnwrapper": {},
        "0_userdata.0.jarvis.system.cssThemes.57_mediaControlsQbtngroupQbtnitem": {},
        "0_userdata.0.jarvis.system.cssThemes.colorPrimary": "DodgerBlue",
        "0_userdata.0.jarvis.system.cssThemes.colorSecondary": "#26a69a",
        "0_userdata.0.jarvis.system.cssThemes.colorAccent": "#9c27b0",
        "0_userdata.0.jarvis.system.cssThemes.darkMode": true
      sigi234 M 3 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @Dominik F. last edited by
        @dominik-f
        Wie kann ich das importieren und abspeichern?
        Dominik F. 1 Reply Last reply Reply Quote 0
          MCU @Dominik F. last edited by
          @dominik-f Vielleicht eine anderen Namen wählen? Grey ein bisschen zu wenig?
          • Dominik F.
            Dominik F. @sigi234 last edited by
            @sigi234
            Du kopierst das hier herein:
            0_userdata.0.jarvis.system.cssThemes.theme.themeConfig
            Dann button: 0_userdata.0.jarvis.system.cssThemes.theme.themeConfigLoad drücken
            0_userdata.0.jarvis.system.cssThemes.theme.themeName musst du als nächstes vergeben
            dann 0_userdata.0.jarvis.system.cssThemes.theme.themeConfigSave
            • Dominik F.
              @mcu
              Gute Frage 😄 ich bin so kreativ wie du merkst 😄 Wenn du einen schöneren Namen hast, nimm den einfach 😄
                @dominik-f So sollte das nicht aussehen?
                sigi234 Dominik F. 2 Replies Last reply Reply Quote 0
                  sigi234 Forum Testing Most Active @MCU last edited by
                  @mcu
                  So bei mir:
                  • Dominik F.
                    @mcu
                    ne^^
                      MCU @sigi234 last edited by
                      @sigi234 Ja das Problem ist das die schon definierten Selektoren drin bleiben. Ich glaube ich muss sie vorher löschen, so daß nur noch das neue festgelegte Design ziehen kann.
                      • Dominik F.
                        @mcu
                        bei sigi siehts richtig aus. Das was du beschreibst ist mir auch aufgefallen gerade, ich hatte beim grauen Script noch 1 oder 2 Sachen vom transparenten drin
                          Hansi1234 @Dominik F. last edited by
                          Benutzt jemand von euch ein Fire TV Tablet?
                            @dominik-f Hast du die Farbe manuell eingetragen?
                            • Dominik F.
                              @mcu
                              Nein.
                              Ich kann mich jedoch dran erinnern, dass ich am Anfang mal die Standartfarbe gesucht habe und mit dodgerblue hantiert habe. Das muss dann irgendwo hängen geblieben sein. Ich finde bei mir auch nix mehr mit dodgerblue
                                MCU @Dominik F. last edited by MCU
                                @dominik-f Ist noch im "Grey"-Design vorhanden.
                                Mit v1.0.8 werden jetzt die alten Selektoren, die das neue Design stören würden gelöscht, sobald man configLoad auslöst.
                                Dominik F. sigi234 2 Replies Last reply Reply Quote 0
                                • Dominik F.
                                  Dominik F. @MCU last edited by Dominik F.
                                  @mcu
                                  Dann werde ich das mal ändern, danke.
                                  Edit: Im Grey Design ist es in Einstellungen -->Theme Einstellungen eingestellt
                                    sigi234 Forum Testing Most Active @MCU last edited by sigi234
                                    @mcu
                                    Beim starten von ThemeShow werden immer Backups gemacht von Jarvis ?
                                    jarvis.0
                                    2022-02-03 00:26:21.714	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:21.712	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:21.710	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:21.707	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:21.648	info	Backup styles..
                                    jarvis.0
                                    2022-02-03 00:26:06.677	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:06.675	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:06.674	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:06.672	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:26:06.629	info	Backup styles..
                                    jarvis.0
                                    2022-02-03 00:25:51.724	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:25:51.721	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:25:51.717	info	Backup settings..
                                    jarvis.0
                                    2022-02-03 00:25:51.715	info	Backup settings..
                                      MCU @sigi234 last edited by MCU
                                      @sigi234 Ja, bei jeder Änderung von dem CSS-DP in jarvis wird eine Sicherung vom DP durchgeführt. Das ist so im System hinterlegt. Kann ich nicht ändern. Und es wird ja bei einer Design-Änderung natürlich immer der CSS-DP geändert und auch Teile (colors) von den settings.
                                      Vielleicht kann man da im Zuge der CSS-Splittung ( CSS, CSS-Themes, CSS-Effects ) etwas andere Bedingungen festlegen, so dass man für bestimmte CSS-Teile die Sicherungshäufigkeit selber festlegen kann.
                                        Revo @Revo last edited by
                                        @revo said in jarvis v3.0.0 - just another remarkable vis:
                                        Moin,
                                        ich muss hier mal fragen, habe nix passendes dazu gefunden. Ich habe eine Zeit lang mit v3 rumprobiert, auch mit der aktuellen github Version.
                                        Ich habe plötzlich folgende Fehlermeldung bekommen und kann nicht mehr auf Jarvis zugreifen.
                                        Ich habe inzwischen iobroker neu installier, jarvis in allen möglichen Versionen neu installiert und geupdatet, sofort das gleiche Problem.
                                        "Connecting to http://raspberrypi:8400 (#1)...
                                        31.01.2022, 15:23:48 | INFO | CONNECTION
                                        Failed connecting to http://raspberrypi:8400 (#1)!
                                        31.01.2022, 15:23:53 | ERROR | CONNECTION
                                        Connecting to https://raspberrypi:8400 (#2)...
                                        31.01.2022, 15:23:53 | INFO | CONNECTION
                                        Failed connecting to https://raspberrypi:8400 (#2)!
                                        31.01.2022, 15:23:59 | ERROR | CONNECTION"
                                        http://raspberrypi:8400/ spuckt bei mir "This is the jarvis socket.io port!" aus.
                                        Weiß jemand, wie ich die Verbindung wieder hinbekomme? Dankeeee!!! 🙂
                                        MfG Dirk
                                        Bezüglich der Verbindungsprobleme:
                                        https://github.com/Zefau/ioBroker.jarvis/issues/847
                                        https://github.com/Zefau/ioBroker.jarvis/issues/865
                                        "has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource."
                                        Fehler gab es wohl schon einmal, taucht bei mir mit v3.0.11 auf.
                                        Habe mich nicht wahnsinnig schlau gelesen, dass ich es genau erklären könnte.
                                        Workaround für mich vorerst: IP Adresse statt Hostname im Link, dann gehts.
                                        Zefau created this issue in Zefau/ioBroker.jarvis
                                        closed jarvis hinter reverse proxy #847
                                        AFPass created this issue in Zefau/ioBroker.jarvis
                                        closed v3: Connection delayed #865
                                        • Bastian Lahrmann
                                          Bastian Lahrmann last edited by
                                          ich habe die Beta v3.0.11-beta.1 und habe ein Problem mit dem Widget DateTime. Ich bekomme es nicht hin die Größe der Uhrzeit anzupassen.
                                          Im Widget selbst kann man das irgendwie nicht mehr machen, in CSS habe ich folgendes ausprobiert (als DAU):
                                          .jarvis-DateTime-Container {
                                          	font-size: 85px;
                                          Leider verändert sich nichts. Wo kann ich bestenfalls noch ansetzen?
                                            sicadrip @Bastian Lahrmann last edited by
                                            @bastian-lahrmann
                                            https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/styles/datetime
                                            Bastian Lahrmann 1 Reply Last reply Reply Quote 1
                                            254
                                            4489
                                            2600235
