    4. Backitup nach Start grün und dann rot
      hennerich @Homoran last edited by hennerich
      Aha, das wusste ich nicht.
      Das sind aber mehr als 100000 Zeichen, kann ich das irgendwie sinnvoll filtern beim Herunterladen?
      Ok, ich hab eben die Instanz noch mal neu gestartet und packe jetzt nur die letzten 2min hier rein:
      2022-02-03 11:45:00.177 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 8469
      2022-02-03 11:45:01.974 - info: dwd.0 (8469) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 11:45:02.781 - info: dwd.0 (8469) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-02-03 11:45:03.316 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-03 11:45:04.225 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 8484
      2022-02-03 11:45:05.947 - info: daswetter.0 (8484) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 11:45:21.151 - info: daswetter.0 (8484) still wrong data structure from server received! repaired...
      2022-02-03 11:45:25.265 - info: daswetter.0 (8484) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-02-03 11:45:25.778 - info: daswetter.0 (8484) cleaned everything up...
      2022-02-03 11:45:25.791 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-03 11:47:58.420 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-02-03 11:47:58.431 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2022-02-03 11:47:59.435 - info: host.raspberrypi stopInstance system.adapter.backitup.0 killing pid 7796
      2022-02-03 11:48:01.503 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 8588
      2022-02-03 11:48:03.357 - info: backitup.0 (8588) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.10, js-controller: 3.3.22
        Homoran Global Moderator Administrators @hennerich last edited by Homoran
        @hennerich sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
        nur das markieren und hierein kopieren, was relevant ist.
        DWD und DasWetter interessiern nicht wirklich
        immer noch kein einziger debug Eintrag
        hast du die Instanz überhaupt auf debug gestellt?
        Hier wird backitup beendet:
        und dann in der letzten Zeile gestartet
        und jetzt würde es interessant
          Schau doch mal in meine Adapterkonfiguration. Was muss ich denn einstellen? Dachte, dass der Haken bei Debug aktivieren ausreichen würde.
          Homoran simatec 2 Replies Last reply Reply Quote 0
            wo??
            die Logstufe der Instanz musst du auf debug stellen.
            • Seite Instanzen
            • Expertenmodus an
            • Zeile Backitup
            • Spalte Logstufe
              umschalten auf debug
            https://www.iobroker.net/#de/documentation/admin/instances.md?12logstufe
            • simatec
              simatec Developer Most Active @hennerich last edited by
              @hennerich
              Mach mal einen iobroker restart
                Oh man, das muss einer wissen. Sorry! Ich dachte immer, dass der Schalter innerhalb der Adapterkonfiguration den Loglevel setzen würde. Über den Expertenmodus bin ich nie gegangen. Danke für die hilfreiche Info!
                Hier die Logs:
                2022-02-03 12:10:57.674 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-02-03 12:10:57.757 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                2022-02-03 12:10:58.762 - info: host.raspberrypi stopInstance system.adapter.backitup.0 killing pid 9458
                2022-02-03 12:11:00.830 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9542
                2022-02-03 12:11:01.976 - debug: backitup.0 (9542) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2022-02-03 12:11:02.016 - debug: backitup.0 (9542) Objects client ready ... initialize now
                2022-02-03 12:11:02.030 - debug: backitup.0 (9542) Objects create System PubSub Client
                2022-02-03 12:11:02.032 - debug: backitup.0 (9542) Objects create User PubSub Client
                2022-02-03 12:11:02.033 - debug: backitup.0 (9542) Objects client initialize lua scripts
                2022-02-03 12:11:02.051 - debug: backitup.0 (9542) Objects connected to redis: 127.0.0.1:9001
                2022-02-03 12:11:02.061 - debug: backitup.0 (9542) objectDB connected
                2022-02-03 12:11:02.063 - debug: backitup.0 (9542) Redis States: Use Redis connection: 127.0.0.1:9000
                2022-02-03 12:11:02.074 - debug: backitup.0 (9542) States create System PubSub Client
                2022-02-03 12:11:02.075 - debug: backitup.0 (9542) States create User PubSub Client
                2022-02-03 12:11:02.087 - debug: backitup.0 (9542) States connected to redis: 127.0.0.1:9000
                2022-02-03 12:11:02.088 - debug: backitup.0 (9542) statesDB connected
                2022-02-03 12:11:02.466 - debug: backitup.0 (9542) Plugin sentry Initialize Plugin (enabled=true)
                2022-02-03 12:11:02.987 - info: backitup.0 (9542) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.10, js-controller: 3.3.22
                2022-02-03 12:11:03.041 - debug: backitup.0 (9542) Backitup has recognized a linux system
                  dafür gibt's die verlinkte Doku
                  Hier die Logs:
                  ...und was kommt danach??
                  bis dahin sieht alles gut aus. Da muss der Adapter laufen.
                  Hast du mal den Rat von @simatec befolgt?
                  Oder komplett rebooted?
                    hennerich @simatec last edited by hennerich
                    @simatec sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
                    @hennerich
                    Hab ich eben gemacht. Dauerte nur ewig wegen diesem Problem hier.
                    Hier das Log (sorry, wenns etwas länger ist)
                    2022-02-03 12:21:48.266 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 10583
                    2022-02-03 12:21:49.801 - debug: backitup.0 (10583) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2022-02-03 12:21:49.890 - debug: backitup.0 (10583) Objects client ready ... initialize now
                    2022-02-03 12:21:49.893 - debug: backitup.0 (10583) Objects create System PubSub Client
                    2022-02-03 12:21:49.895 - debug: backitup.0 (10583) Objects create User PubSub Client
                    2022-02-03 12:21:49.897 - debug: backitup.0 (10583) Objects client initialize lua scripts
                    2022-02-03 12:21:49.938 - debug: backitup.0 (10583) Objects connected to redis: 127.0.0.1:9001
                    2022-02-03 12:21:49.950 - debug: backitup.0 (10583) objectDB connected
                    2022-02-03 12:21:49.953 - debug: backitup.0 (10583) Redis States: Use Redis connection: 127.0.0.1:9000
                    2022-02-03 12:21:49.965 - debug: backitup.0 (10583) States create System PubSub Client
                    2022-02-03 12:21:49.967 - debug: backitup.0 (10583) States create User PubSub Client
                    2022-02-03 12:21:49.981 - debug: backitup.0 (10583) States connected to redis: 127.0.0.1:9000
                    2022-02-03 12:21:49.983 - debug: backitup.0 (10583) statesDB connected
                    2022-02-03 12:21:50.388 - debug: backitup.0 (10583) Plugin sentry Initialize Plugin (enabled=true)
                    2022-02-03 12:21:50.722 - info: backitup.0 (10583) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.10, js-controller: 3.3.22
                    2022-02-03 12:21:50.797 - debug: backitup.0 (10583) Backitup has recognized a linux system
                    2022-02-03 12:21:52.329 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 10598
                    2022-02-03 12:21:54.544 - info: trashschedule.0 (10598) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.10, js-controller: 3.3.22
                    2022-02-03 12:21:54.756 - info: trashschedule.0 (10598) configurured iCal preview is 60 days - increase this value to find more events in the future
                    2022-02-03 12:21:54.853 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.bioabfalltonne.nextWeekday" has to be type "string" but received type "number"
                    2022-02-03 12:21:54.893 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.restabfalltonne.nextWeekday" has to be type "string" but received type "number"
                    2022-02-03 12:21:54.937 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.papiertonne.nextWeekday" has to be type "string" but received type "number"
                    2022-02-03 12:21:55.051 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
                    2022-02-03 12:21:58.046 - info: vis-google-fonts.0 (10613) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v12.22.10, js-controller: 3.3.22
                    2022-02-03 12:21:58.730 - info: vis-google-fonts.0 (10613) Terminated (NO_ERROR): Without reason
                    2022-02-03 12:21:59.327 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
                    2022-02-03 12:22:00.320 - info: host.raspberrypi instance system.adapter.device-reminder.0 started with pid 10628
                    2022-02-03 12:22:02.172 - info: device-reminder.0 (10628) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v12.22.10, js-controller: 3.3.22
                    2022-02-03 12:22:02.290 - info: device-reminder.0 (10628) Device "Waschmaschine" was successfully created
                    2022-02-03 12:22:02.469 - info: device-reminder.0 (10628) Device "Trockner" was successfully created
                    2022-02-03 12:22:03.449 - info: daswetter.0 (10553) still wrong data structure from server received! repaired...
                    2022-02-03 12:22:04.323 - info: host.raspberrypi instance system.adapter.sourceanalytix.0 started with pid 10643
                    2022-02-03 12:22:06.599 - info: sourceanalytix.0 (10643) starting. Version 0.4.12 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.22.10, js-controller: 3.3.22
                    2022-02-03 12:22:06.640 - info: sourceanalytix.0 (10643) Welcome to SourceAnalytix, making things ready ...
                    2022-02-03 12:22:06.711 - info: sourceanalytix.0 (10643) Found 4 SourceAnalytix enabled states
                    2022-02-03 12:22:06.713 - info: sourceanalytix.0 (10643) Initialising (1 of 4) "javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal"
                    2022-02-03 12:22:06.774 - error: sourceanalytix.0 (10643) Check settings for javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal ! Known valueAtDeviceReset : (8432.67) > known cumulative value (0) cannot proceed
                    2022-02-03 12:22:06.774 - error: sourceanalytix.0 (10643) Troubleshoot Data javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal custom Data : {"_id":"javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal","type":"state","common":{"name":"HeizölVerbrauchTotal","role":"","type":"number","desc":"Manuell erzeugt","def":"","unit":"Liter","read":true,"write":true,"custom":{"influxdb.0":{"enabled":true,"changesOnly":false,"debounce":0,"maxLength":10,"retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"storageType":"","aliasId":""},"sourceanalytix.0":{"enabled":true,"alias":"","selectedPrice":"Oil","selectedUnit":"l","costs":true,"consumption":true,"meter_values":false,"start_day":8446.41,"start_week":8446.41,"start_month":8421.220000000001,"start_quarter":8421.220000000001,"start_year":8421.220000000001,"valueAtDeviceReset":8432.67,"valueAtDeviceInit":null,"cumulativeValue":8446.41}}},"native":{},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1641164400727,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator","state":1636}}
                    2022-02-03 12:22:06.775 - error: sourceanalytix.0 (10643) Cannot handle calculations for javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal, check log messages and adjust settings!
                    2022-02-03 12:22:06.777 - error: sourceanalytix.0 (10643) Initialization of javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal failed, check warn messages !
                    2022-02-03 12:22:06.777 - info: sourceanalytix.0 (10643) Initialising (2 of 4) "shelly.0.SHPLG-S#B4CF23#1.Relay0.Power"
                    2022-02-03 12:22:08.657 - info: sourceanalytix.0 (10643) Initialization of shelly.0.SHPLG-S#B4CF23#1.Relay0.Power successfully
                    2022-02-03 12:22:08.658 - info: sourceanalytix.0 (10643) Initialising (3 of 4) "shelly.0.SHPLG2-1#2F4EF7#1.Relay0.Power"
                    2022-02-03 12:22:09.550 - info: daswetter.0 (10553) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                    2022-02-03 12:22:09.940 - info: sourceanalytix.0 (10643) Initialization of shelly.0.SHPLG2-1#2F4EF7#1.Relay0.Power successfully
                    2022-02-03 12:22:09.941 - info: sourceanalytix.0 (10643) Initialising (4 of 4) "javascript.0.Verbrauchszaehler.StromVerbrauchTotal"
                    2022-02-03 12:22:10.067 - info: daswetter.0 (10553) cleaned everything up...
                    2022-02-03 12:22:10.138 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-02-03 12:22:10.808 - info: sourceanalytix.0 (10643) Initialization of javascript.0.Verbrauchszaehler.StromVerbrauchTotal successfully
                    2022-02-03 12:22:10.817 - warn: sourceanalytix.0 (10643) Cannot handle calculations for 1 of 4 enabled states, check error messages
                    2022-02-03 12:22:10.818 - info: sourceanalytix.0 (10643) Successfully activated SourceAnalytix for 3 of 4 states, will do my Job until you stop me!
                      die ersten 270 Zeilen wären ja auch nicht nötig gewesen.
                      und ab 292 auch nicht.
                      Da ist nichts auffälliges
                        @homoran sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
                        P.S. hab das Log oben eingekürzt
                          @hennerich jetzt gehen mir die Ideen aus.
                          Versuch mal
                          iobroker stop
                          iobroker upload all
                          iobroker start
                          kann aber dauern
                            Na ich hab eben mal aus @apollon77 seiner Doku die node.js Version auf 14 angehoben und bin eben noch beim
                            ioBroker fix
                            Ich befürchte nur, dass das Script wieder hier hängen bleibt:
                            Fixing directory permissions ...
                              Jo, wie vermutet steht das Script seit 30min an dieser Stelle. Die letzten beiden Male hab ich dann mit CTRL+C abgebrochen und den ioBroker wieder gestartet. Keine Ahnung ob man das darf oder wie ich feststelle, wo das Script hängt.
                              • simatec
                                @hennerich Dann gehe ich stark dvon aus, dass dein System irgendwo ein grundliegendes Problem hat
                                  Homoran Global Moderator Administrators @simatec last edited by
                                  @hennerich
                                  Das sehe ich dann genauso.
                                  Ob neu aufsetzen und dann das letzte Backup einspielen hilft müsstest du testen.
                                  Es kann natürlich sein, dass das Problem mit dem Restore wiederkommt
                                  • simatec
                                    @hennerich Sichere doch mal die Einstellungen von Backitup und lösche Instanz und Adapter
                                    Im Anschluss mal neu installieren und durchstarten
                                    Wenn das läuft, schiebe die Einstellungen von Backitup wieder zurück
                                      Könnt ihr mir trotzdem kurz sagen, wie ich jetzt mit dem Fix Prozess umgehen soll?
                                      • simatec
                                        @hennerich Naja abbrechen ist nicht so gut
                                        Der sollte auch durchlaufen ... Also denke ich, dass es mit deinem System zu tun hat.
                                        Da ist was krum ... Deshalb auch die hohen Lasten in deinem anderen Thread
                                          Naja, gestern Abend hatte ich den Fix um ca. 21 Uhr angestoßen und heute morgen gegen 03 Uhr lief der immer noch. Soll ich jetzt einfach noch länger warten?
                                            Thomas Braun Most Active @hennerich last edited by
                                            @hennerich
                                            Da klemmt es anderswo.
                                            Schau mal mit
                                            dmesg -T | grep -i ext4
                                            wie es dem Dateisystem geht.
                                            2489
