    4. Alpha Test js-controller 4.0
    • MalleRalle
      MalleRalle last edited by MalleRalle
      @apollon77
      Die Fehlermeldung im Alexa2 Adapter ist nun weg.
      @foxriver76
      Ich denke Du liest hier auch mit.
      Mit dem js-controller 4 habe ich Probleme mit dem hm-rega Adapter.
      Variablen Datenpunkte lassen sich nicht mehr korrekt schalten.
      true und false werden im Objektbaum zwar geschaltet, die Zustände sind allerdings in rot und kommen in der ccu nicht mehr an.
      Hier mal Debug von der Anwesenheit:
      2022-02-03 11:53:19.484  - debug: hm-rega.0 (366742) stateChange hm-rega.0.19287 {"val":true,"ack":false,"ts":1643885599480,"q":0,"c":"script.js.Datenpunkte.Anwesenheit-Blockly","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1643885599480}
      2022-02-03 11:53:19.486  - warn: hm-rega.0 (366742) Got unexpected ID: hm-rega.0.19287
      2022-02-03 11:53:19.504  - debug: hm-rega.0 (366742) stateChange hm-rega.0.950 {"val":true,"ack":false,"ts":1643885599500,"q":0,"c":"script.js.Datenpunkte.Anwesenheit-Blockly","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1643885599500}
      2022-02-03 11:53:19.506  - warn: hm-rega.0 (366742) Got unexpected ID: hm-rega.0.950
      @arteck
      hs100.0	2022-02-03 12:00:06.830	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.829	warn	(367993) Object 192_168_123_49.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0	2022-02-03 12:00:06.807	info	(367993) Start with IP : 192.168.123.49
      hs100.0	2022-02-03 12:00:06.806	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.805	warn	(367993) Object 192_168_123_37.ledState is invalid: Default value has to be type "string" but received type "boolean"
      hs100.0	2022-02-03 12:00:06.803	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.802	warn	(367993) Object 192_168_123_37.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0	2022-02-03 12:00:06.748	info	(367993) Start with IP : 192.168.123.37
      hs100.0	2022-02-03 12:00:06.746	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.745	warn	(367993) Object 192_168_123_30.ledState is invalid: Default value has to be type "string" but received type "boolean"
      hs100.0	2022-02-03 12:00:06.743	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.742	warn	(367993) Object 192_168_123_30.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0	2022-02-03 12:00:06.565	info	(367993) Start with IP : 192.168.123.30
      hs100.0	2022-02-03 12:00:06.560	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.558	warn	(367993) Object 192_168_123_27.ledState is invalid: Default value has to be type "string" but received type "boolean"
      hs100.0	2022-02-03 12:00:06.554	warn	(367993) This object will not be created in future versions. Please report this to the developer.
      hs100.0	2022-02-03 12:00:06.552	warn	(367993) Object 192_168_123_27.last_update is invalid: Default value has to be type "string" but received type "number"
      hs100.0	2022-02-03 12:00:06.482	info	(367993) Start with IP : 192.168.123.27
      apollon77 foxriver76 3 Replies Last reply Reply Quote 0
        apollon77 @MalleRalle last edited by
        @malleralle Sicher das die hm-rega Tehmatik seit controller 4 so ist? Ggf gabs ein Adapter update?
        MalleRalle 1 Reply Last reply Reply Quote 0
        • MalleRalle
          MalleRalle @apollon77 last edited by MalleRalle
          @apollon77 Absolut, sobald ich auf den 3er zurück gehe ist es wieder in Ordnung.
            @malleralle GitHub Issue für @arteck bitte
            • foxriver76
              foxriver76 Developer @MalleRalle last edited by
              @malleralle Welche DB läuft bei dir für objects
              • MalleRalle
                MalleRalle @foxriver76 last edited by
                @foxriver76
                Current configuration:
                - Objects database:
                  - Type: jsonl
                  - Host/Unix Socket: 0.0.0.0
                  - Port: 9001
                - States database:
                  - Type: jsonl
                  - Port: 9000
                - Data Directory: ../../iobroker-data/
                • foxriver76
                  @malleralle thx
                  • O
                    oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by
                    Was wird eigentlich "migriert", wenn man bereits eine Redis-Konfiguration (States und Objects) hatte?
                      apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                      @ofbeqnpolkkl6mby5e13 Nichts. Es wird nur das was "file" ist auf "jsonl" umgestellt ... Redis bleibt Redis. Bei Redis kommen nur ein paar interne neue Datenstrukturen dazu
                      • O
                        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                        @apollon77
                        Okay, nur weil die Meldung angezeigt wurde, dass die Objekte migriert wurden.
                          @ofbeqnpolkkl6mby5e13 Meinst du das "... States migrated to Redis Sets"? Das ist genau die Initialisierung der neuen Datenstrukturen
                          • O
                            @apollon77
                            Mist, dass ich mir das nicht gespeichert habe. Aber die Meldung sah eher so aus: 23.047 Objekte migriert. Soweit ich mich erinnere...
                            • amg_666
                              amg_666 last edited by
                              @malleralle sagte in Alpha Test js-controller 4.0:
                              @foxriver76
                              Hatte ich noch gar nicht bemerkt, scheint aber bei mir auch so zu sein:
                              Ich ändere in der VIS Oberfläche einen Wert, der hm-rega-Datenpunkt im iobroker wird geändert aber in der homematic kommt die Änderung nicht an:
                              hm-rega 3.0.35
                              homematic 2.61.7
                              iobroker setup:
                              - Objects database:
                                - Type: jsonl
                                - Port: 9001
                              - States database:
                                - Type: jsonl
                                - Port: 9000
                                Ja fix kommt nachher
                                  lonsimbt @apollon77 last edited by
                                  @apollon77
                                  alpha.72 läuft
                                  Ich beobachte kein Probleme mit den Homematic(-IP)-Adaptern.
                                  Gruß Marco
                                    apollon77 last edited by apollon77
                                    Hey,
                                    der von @MalleRalle berichtete Bug mit hm-rega ist in alpha.73 gefixt und @next ist aktualisiert.
                                    Bitte vor allem HM* testen aber auch schauen das zB noch alle JavaScript Skripte tun und im Frontend erscheinen und sowas
                                    Ingo
                                    amg_666 Thomas Braun 2 Replies Last reply Reply Quote 2
                                    • amg_666
                                      amg_666 @apollon77 last edited by
                                      @apollon77 sagte in Alpha Test js-controller 4.0:
                                      Top, jetzt läufts wieder rund, Änderungen in iob werden auch wieder in der homematic übernommen.
                                      Bei meinen Skripten habe ich bislang keine Fehler feststellen können.
                                        Thomas Braun Most Active @apollon77 last edited by
                                        @apollon77
                                        alpha.73 startet hier sauber durch, skripte laufen (hab aber kein hm-rega laufen).
                                        Nur der iobroker.parcel-Adapter muss bei jedem update des controllers neugebaut werden. Der ist wohl gegen node14 gebaut, ich fahre node16 hier. npm i --production im Verzeichnis des Adapters reicht aber aus und auch der Adapter läuft dann wieder.
                                          apollon77 @Thomas Braun last edited by
                                          @thomas-braun sagte in Alpha Test js-controller 4.0:
                                          Das wäre aber interessant warum das so ist. Was bringt der als Fehler? Läuft der renbuild machenaismus an?
                                            @apollon77
                                            Ich komme gerade nicht gescheit an das LogFile (bin nur mit dem Handy verbunden), sonst hätte ich es gepostet.
                                            Hol ich später nach. Rebuild wird gestartet, aber nach dem 3 vergeblichen Versuch wird abgebrochen und ich hol es manuell nach.
                                            1.0k
                                            196
                                            25762
