    4. Backitup nach Start grün und dann rot
      hennerich @simatec last edited by hennerich
      @simatec sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
      @hennerich
      Mach mal einen iobroker restart
      Hab ich eben gemacht. Dauerte nur ewig wegen diesem Problem hier.
      Hier das Log (sorry, wenns etwas länger ist)
      2022-02-03 12:21:48.266 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 10583
      2022-02-03 12:21:49.801 - debug: backitup.0 (10583) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-02-03 12:21:49.890 - debug: backitup.0 (10583) Objects client ready ... initialize now
      2022-02-03 12:21:49.893 - debug: backitup.0 (10583) Objects create System PubSub Client
      2022-02-03 12:21:49.895 - debug: backitup.0 (10583) Objects create User PubSub Client
      2022-02-03 12:21:49.897 - debug: backitup.0 (10583) Objects client initialize lua scripts
      2022-02-03 12:21:49.938 - debug: backitup.0 (10583) Objects connected to redis: 127.0.0.1:9001
      2022-02-03 12:21:49.950 - debug: backitup.0 (10583) objectDB connected
      2022-02-03 12:21:49.953 - debug: backitup.0 (10583) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-02-03 12:21:49.965 - debug: backitup.0 (10583) States create System PubSub Client
      2022-02-03 12:21:49.967 - debug: backitup.0 (10583) States create User PubSub Client
      2022-02-03 12:21:49.981 - debug: backitup.0 (10583) States connected to redis: 127.0.0.1:9000
      2022-02-03 12:21:49.983 - debug: backitup.0 (10583) statesDB connected
      2022-02-03 12:21:50.388 - debug: backitup.0 (10583) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-03 12:21:50.722 - info: backitup.0 (10583) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 12:21:50.797 - debug: backitup.0 (10583) Backitup has recognized a linux system
      2022-02-03 12:21:52.329 - info: host.raspberrypi instance system.adapter.trashschedule.0 started with pid 10598
      2022-02-03 12:21:54.544 - info: trashschedule.0 (10598) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 12:21:54.756 - info: trashschedule.0 (10598) configurured iCal preview is 60 days - increase this value to find more events in the future
      2022-02-03 12:21:54.853 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.bioabfalltonne.nextWeekday" has to be type "string" but received type "number"
      2022-02-03 12:21:54.893 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.restabfalltonne.nextWeekday" has to be type "string" but received type "number"
      2022-02-03 12:21:54.937 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.papiertonne.nextWeekday" has to be type "string" but received type "number"
      2022-02-03 12:21:55.051 - info: trashschedule.0 (10598) State value to set for "trashschedule.0.type.gelbeTonne.nextWeekday" has to be type "string" but received type "number"
      2022-02-03 12:21:58.046 - info: vis-google-fonts.0 (10613) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 12:21:58.730 - info: vis-google-fonts.0 (10613) Terminated (NO_ERROR): Without reason
      2022-02-03 12:21:59.327 - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
      2022-02-03 12:22:00.320 - info: host.raspberrypi instance system.adapter.device-reminder.0 started with pid 10628
      2022-02-03 12:22:02.172 - info: device-reminder.0 (10628) starting. Version 1.2.9 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 12:22:02.290 - info: device-reminder.0 (10628) Device "Waschmaschine" was successfully created
      2022-02-03 12:22:02.469 - info: device-reminder.0 (10628) Device "Trockner" was successfully created
      2022-02-03 12:22:03.449 - info: daswetter.0 (10553) still wrong data structure from server received! repaired...
      2022-02-03 12:22:04.323 - info: host.raspberrypi instance system.adapter.sourceanalytix.0 started with pid 10643
      2022-02-03 12:22:06.599 - info: sourceanalytix.0 (10643) starting. Version 0.4.12 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v12.22.10, js-controller: 3.3.22
      2022-02-03 12:22:06.640 - info: sourceanalytix.0 (10643) Welcome to SourceAnalytix, making things ready ...
      2022-02-03 12:22:06.711 - info: sourceanalytix.0 (10643) Found 4 SourceAnalytix enabled states
      2022-02-03 12:22:06.713 - info: sourceanalytix.0 (10643) Initialising (1 of 4) "javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal"
      2022-02-03 12:22:06.774 - error: sourceanalytix.0 (10643) Check settings for javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal ! Known valueAtDeviceReset : (8432.67) > known cumulative value (0) cannot proceed
      2022-02-03 12:22:06.774 - error: sourceanalytix.0 (10643) Troubleshoot Data javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal custom Data : {"_id":"javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal","type":"state","common":{"name":"HeizölVerbrauchTotal","role":"","type":"number","desc":"Manuell erzeugt","def":"","unit":"Liter","read":true,"write":true,"custom":{"influxdb.0":{"enabled":true,"changesOnly":false,"debounce":0,"maxLength":10,"retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"storageType":"","aliasId":""},"sourceanalytix.0":{"enabled":true,"alias":"","selectedPrice":"Oil","selectedUnit":"l","costs":true,"consumption":true,"meter_values":false,"start_day":8446.41,"start_week":8446.41,"start_month":8421.220000000001,"start_quarter":8421.220000000001,"start_year":8421.220000000001,"valueAtDeviceReset":8432.67,"valueAtDeviceInit":null,"cumulativeValue":8446.41}}},"native":{},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1641164400727,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator","state":1636}}
      2022-02-03 12:22:06.775 - error: sourceanalytix.0 (10643) Cannot handle calculations for javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal, check log messages and adjust settings!
      2022-02-03 12:22:06.777 - error: sourceanalytix.0 (10643) Initialization of javascript.0.Verbrauchszaehler.HeizölVerbrauchTotal failed, check warn messages !
      2022-02-03 12:22:06.777 - info: sourceanalytix.0 (10643) Initialising (2 of 4) "shelly.0.SHPLG-S#B4CF23#1.Relay0.Power"
      2022-02-03 12:22:08.657 - info: sourceanalytix.0 (10643) Initialization of shelly.0.SHPLG-S#B4CF23#1.Relay0.Power successfully
      2022-02-03 12:22:08.658 - info: sourceanalytix.0 (10643) Initialising (3 of 4) "shelly.0.SHPLG2-1#2F4EF7#1.Relay0.Power"
      2022-02-03 12:22:09.550 - info: daswetter.0 (10553) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2022-02-03 12:22:09.940 - info: sourceanalytix.0 (10643) Initialization of shelly.0.SHPLG2-1#2F4EF7#1.Relay0.Power successfully
      2022-02-03 12:22:09.941 - info: sourceanalytix.0 (10643) Initialising (4 of 4) "javascript.0.Verbrauchszaehler.StromVerbrauchTotal"
      2022-02-03 12:22:10.067 - info: daswetter.0 (10553) cleaned everything up...
      2022-02-03 12:22:10.138 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-03 12:22:10.808 - info: sourceanalytix.0 (10643) Initialization of javascript.0.Verbrauchszaehler.StromVerbrauchTotal successfully
      2022-02-03 12:22:10.817 - warn: sourceanalytix.0 (10643) Cannot handle calculations for 1 of 4 enabled states, check error messages
      2022-02-03 12:22:10.818 - info: sourceanalytix.0 (10643) Successfully activated SourceAnalytix for 3 of 4 states, will do my Job until you stop me!
        Homoran Global Moderator Administrators @hennerich last edited by
        @hennerich sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
        die ersten 270 Zeilen wären ja auch nicht nötig gewesen.
        und ab 292 auch nicht.
        Da ist nichts auffälliges
          hennerich @Homoran last edited by
          @homoran sagte in Backitup Adapter bleibt rot - keine Debug Meldungen:
          P.S. hab das Log oben eingekürzt
            Homoran Global Moderator Administrators @hennerich last edited by Homoran
            @hennerich jetzt gehen mir die Ideen aus.
            Versuch mal
            iobroker stop
            iobroker upload all
            iobroker start
            kann aber dauern
              hennerich @Homoran last edited by hennerich
              Na ich hab eben mal aus @apollon77 seiner Doku die node.js Version auf 14 angehoben und bin eben noch beim
              ioBroker fix
              Ich befürchte nur, dass das Script wieder hier hängen bleibt:
              Fixing directory permissions ...
                Jo, wie vermutet steht das Script seit 30min an dieser Stelle. Die letzten beiden Male hab ich dann mit CTRL+C abgebrochen und den ioBroker wieder gestartet. Keine Ahnung ob man das darf oder wie ich feststelle, wo das Script hängt.
                simatec 2 Replies Last reply Reply Quote 0
                • simatec
                  simatec Developer Most Active @hennerich last edited by
                  @hennerich Dann gehe ich stark dvon aus, dass dein System irgendwo ein grundliegendes Problem hat
                    Homoran Global Moderator Administrators @simatec last edited by
                    @hennerich
                    Das sehe ich dann genauso.
                    Ob neu aufsetzen und dann das letzte Backup einspielen hilft müsstest du testen.
                    Es kann natürlich sein, dass das Problem mit dem Restore wiederkommt
                    • simatec
                      @hennerich Sichere doch mal die Einstellungen von Backitup und lösche Instanz und Adapter
                      Im Anschluss mal neu installieren und durchstarten
                      Wenn das läuft, schiebe die Einstellungen von Backitup wieder zurück
                        Könnt ihr mir trotzdem kurz sagen, wie ich jetzt mit dem Fix Prozess umgehen soll?
                        • simatec
                          @hennerich Naja abbrechen ist nicht so gut
                          Der sollte auch durchlaufen ... Also denke ich, dass es mit deinem System zu tun hat.
                          Da ist was krum ... Deshalb auch die hohen Lasten in deinem anderen Thread
                            Naja, gestern Abend hatte ich den Fix um ca. 21 Uhr angestoßen und heute morgen gegen 03 Uhr lief der immer noch. Soll ich jetzt einfach noch länger warten?
                              Thomas Braun Most Active @hennerich last edited by
                              @hennerich
                              Da klemmt es anderswo.
                              Schau mal mit
                              dmesg -T | grep -i ext4
                              wie es dem Dateisystem geht.
                                hennerich @Thomas Braun last edited by
                                Ok, hab in einer neuen SSH Session den Befehl ausgeführt:
                                pi@raspberrypi:~ $ dmesg -T | grep -i ext4
                                [Fr Jan 14 18:14:58 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A8:F4:42 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=68f86542-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                [Fr Jan 14 18:14:59 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                [Fr Jan 14 18:14:59 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Fr Jan 14 18:15:01 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                  @hennerich
                                  Okay, das Dateisystem ruft schon mal nicht laut um Hilfe.
                                    @hennerich
                                    Du könntest aber einfach die Kiste mal nach 3 Wochen uptime neustarten.
                                    Eigentlich sollte das zwar möglich sein, wenn da aber kleiner Schluckauf herrscht kann das System so langsam werden. Speicherauslastung?
                                    free -ht --mega
                                      hier die Ausgabe und Danke noch mal
                                      pi@raspberrypi:~ $ free -ht --mega
                                      Mem:           3,8G        627M        1,2G        200M        2,0G        3,3G
                                      Swap:           99M         13M         86M
                                      Total:         3,9G        641M        1,3G
                                      Also Fix Script abbrechen, Raspberry neu starten und Fix wieder starten?
                                        der läuft noch?
                                        wäre interessant ob der auch aktiv ist.
                                        @Thomas-Braun
                                        htop???
                                          @hennerich
                                          Im Moment sieht die Auslastung gesund aus, aber es ist auf den Swap ausgewichen worden, d.h. der Speicher war komplett ausgenutzt.
                                          Wie groß ist das Backup? Irgendwelche Hollywood-Filme von Überwachungskameras dabei?
                                          H Homoran 2 Replies Last reply Reply Quote 0
                                            htop zeigt das hier:
                                            Meine Backupgröße ist
                                            2489
