    4. Alpha Test js-controller 4.0
      apollon77 @Thomas Braun last edited by
      @thomas-braun Da wäre nochmal das log seeeeeeehr interessant (wenn du dazu kommst)
        Fortune95 @apollon77 last edited by
        @apollon77
        Hab gerade auch das update gemacht. Lief problemlos durch nur 4 Adpater liefern Warnings:
        2022-02-03 16:36:44.783 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.784 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.791 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.791 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.806 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.807 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.817 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.817 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.905 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.905 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.905 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.906 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:44.921 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:44.921 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:45.399 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019CFA0#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:45.399 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.449 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.449 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.467 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.467 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.474 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.474 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.491 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.491 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.528 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.528 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.533 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.533 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.545 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.545 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.546 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.546 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.658 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.658 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.659 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.659 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.702 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.702 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.705 - warn: shelly.0 (2570) Object SHDM-2#D8BFC019E084#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.705 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.719 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.719 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.751 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.751 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:46.756 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5433579#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:46.756 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.255 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.255 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.262 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.262 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.270 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.270 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.276 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.277 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.371 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.372 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.372 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.377 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.377 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:36:49.415 - warn: shelly.0 (2570) Object SHDM-2#E0980695A77B#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:36:49.415 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.911 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_2_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.912 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.915 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_2_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.915 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.923 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_7 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.923 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.925 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_6 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.925 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.929 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_10_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.929 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.931 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_B_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.931 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.935 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_6_1 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.935 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.937 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_6_2 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.937 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.940 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_6_3 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.940 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.942 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_6_4 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.942 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.945 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_7_1 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.946 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.948 - warn: gruenbeck.0 (2712) Object gruenbeck.0.network.D_C_3_7_2 is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:17.948 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.980 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_1_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.980 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.982 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_1_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.982 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.984 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_1_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.985 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.987 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_2_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.987 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.989 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_3_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.989 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:17.991 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_A_3_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:17.992 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.001 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.aktuellerWasserverbrauch is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.002 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.004 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Salzverbrauch is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.004 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.006 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Salzstand is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.006 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.009 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.SalzverbrauchGesamt is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.009 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.011 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.DatumSalzverbrauch is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:18.011 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.013 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.013 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.015 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.016 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.018 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.018 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.020 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.020 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.023 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.023 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.025 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.026 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.028 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.028 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.031 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.031 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.033 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.033 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.035 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_4 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.035 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.037 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_4 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.037 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.040 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_4 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.040 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.043 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_5 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.043 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.046 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_5 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.046 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.049 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_5 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.049 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.052 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_6 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.052 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.054 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_6 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.055 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.057 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_6 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.057 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.060 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_7 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.060 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.063 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_7 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.063 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.065 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_7 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.066 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.068 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_8 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.068 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.070 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_8 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.070 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.073 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_8 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.073 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.075 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_9 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.075 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.079 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_9 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.079 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.082 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_9 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.082 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.084 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_10 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.084 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.087 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_10 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.088 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.090 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_10 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.090 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.098 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_11 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.098 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.100 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_11 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.100 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.102 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_11 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.102 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.104 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_12 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.105 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.107 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_12 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.107 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.109 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_12 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.110 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.112 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_13 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.112 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.114 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_13 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.114 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.116 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_13 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.117 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.119 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_2_14 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.119 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.121 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Verschnittwasser_14 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.121 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.123 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_Y_4_14 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.124 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.126 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_1 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.126 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.128 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_2 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.128 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.130 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_3 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.130 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.133 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_4 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.133 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.138 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_7 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.138 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.140 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_8 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.141 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.143 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_K_9 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.143 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.146 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_F_5 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.146 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.148 - warn: gruenbeck.0 (2712) Object gruenbeck.0.info.D_F_6 is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.149 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.151 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.Wasserzaehler is invalid: Default value has to be type "number" but received type "boolean"
        2022-02-03 16:37:18.151 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:18.154 - warn: gruenbeck.0 (2712) Object gruenbeck.0.calculated.DatumWasserzaehler is invalid: Default value has to be type "string" but received type "boolean"
        2022-02-03 16:37:18.154 - warn: gruenbeck.0 (2712) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.117 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.117 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.124 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.124 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.133 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.133 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.135 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.135 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.236 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.236 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.298 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.298 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.301 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5437A2C#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.302 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.716 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.716 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.721 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.721 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.785 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.785 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.793 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.793 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.836 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.836 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.837 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.837 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.845 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.845 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.846 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.847 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.916 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.916 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.942 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.942 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.952 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.952 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.952 - warn: shelly.0 (2570) Object SHSW-1#A4CF12F42A41#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.987 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.987 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:33.989 - warn: shelly.0 (2570) Object SHSW-1#BA22F5#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:33.989 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.377 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.377 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.384 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.384 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.392 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.392 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.401 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.401 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.492 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.492 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.492 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.Event1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.497 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.Event2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.497 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:34.530 - warn: shelly.0 (2570) Object SHDM-2#E0980695A2CD#1.lights.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:34.530 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.628 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.628 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.630 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.631 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.644 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.644 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.648 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.648 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.728 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.729 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.773 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.774 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:35.774 - warn: shelly.0 (2570) Object SHSW-1#BA263F#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:35.775 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:39.968 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:39.968 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:39.975 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:39.976 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:39.987 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:39.987 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:39.990 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:39.990 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.077 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.078 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.111 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.112 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.115 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB542EE6D#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.115 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.159 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.159 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.178 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.178 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.192 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay1.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.193 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.195 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay1.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.195 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.203 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay2.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.203 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.204 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay2.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.204 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.215 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay3.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.215 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.216 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay3.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.216 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.620 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.Event is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.620 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.626 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.626 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.634 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.634 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.636 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.636 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.764 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.Input is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.764 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.775 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.775 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.777 - warn: shelly.0 (2570) Object SHSW-PM#8CAAB5431D1E#1.Relay0.ButtonReverse is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.777 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.782 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay0.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.782 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.785 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay1.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.785 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.787 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay2.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.787 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:40.796 - warn: shelly.0 (2570) Object SHSW-44#0624E6#1.Relay3.ButtonType is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2022-02-03 16:37:40.796 - warn: shelly.0 (2570) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:45.921 - warn: shuttercontrol.0 (3220) Object shuttercontrol.0.info.Elevation is invalid: Default value has to be type "number" but received type "string"
        2022-02-03 16:37:45.921 - warn: shuttercontrol.0 (3220) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:45.924 - warn: shuttercontrol.0 (3220) Object shuttercontrol.0.info.Azimut is invalid: Default value has to be type "number" but received type "string"
        2022-02-03 16:37:45.925 - warn: shuttercontrol.0 (3220) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.050 - warn: yamaha.0 (3265) Object yamaha.0.Commands.toggleMute is invalid: Default value has to be type "boolean" but received type "number"
        2022-02-03 16:37:58.051 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.059 - warn: yamaha.0 (3265) Object yamaha.0.mute is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.059 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.064 - warn: yamaha.0 (3265) Object yamaha.0.power is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.065 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.068 - warn: yamaha.0 (3265) Object yamaha.0.refresh is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.068 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.071 - warn: yamaha.0 (3265) Object yamaha.0.Commands.stop is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.072 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.074 - warn: yamaha.0 (3265) Object yamaha.0.Commands.pause is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.075 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.080 - warn: yamaha.0 (3265) Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.080 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.083 - warn: yamaha.0 (3265) Object yamaha.0.Commands.rewind is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.083 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.086 - warn: yamaha.0 (3265) Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.086 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.089 - warn: yamaha.0 (3265) Object yamaha.0.YPAOVolume is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.090 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.092 - warn: yamaha.0 (3265) Object yamaha.0.extraBass is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.092 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.095 - warn: yamaha.0 (3265) Object yamaha.0.adaptiveDRC is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.095 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.098 - warn: yamaha.0 (3265) Object yamaha.0.partyMode is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.098 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.101 - warn: yamaha.0 (3265) Object yamaha.0.Commands.partyModeVolumeUp is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.101 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.103 - warn: yamaha.0 (3265) Object yamaha.0.Commands.partyModeVolumeDown is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.104 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.106 - warn: yamaha.0 (3265) Object yamaha.0.hdmiOut1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.106 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.109 - warn: yamaha.0 (3265) Object yamaha.0.hdmiOut2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.109 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.111 - warn: yamaha.0 (3265) Object yamaha.0.pureDirect is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.112 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.132 - warn: yamaha.0 (3265) Object yamaha.0.zone1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.132 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.135 - warn: yamaha.0 (3265) Object yamaha.0.zone2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.135 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.137 - warn: yamaha.0 (3265) Object yamaha.0.zone3 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.138 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.145 - warn: yamaha.0 (3265) Object yamaha.0.zone4 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.145 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
        2022-02-03 16:37:58.149 - warn: yamaha.0 (3265) Object yamaha.0.powerAllZones is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
        2022-02-03 16:37:58.149 - warn: yamaha.0 (3265) This object will not be created in future versions. Please report this to the developer.
          apollon77 @Fortune95 last edited by
          @fortune95 Legst Du dann bitte 4 GitHub issues an? ;-)) (bzw 3 weil ich glaube shelly gibts schon)
          • wendy2702
            Habe das bei der Installation auf dem Master bekommen:
            mirko@iobroker:/opt/iobroker$ sudo npm i iobroker.js-controller@next
            [sudo] password for mirko:
            > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.16
            > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
            Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                at Object.mkdirSync (fs.js:1013:3)
                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1012:16)
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:567:23)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3316:5)
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                at Module._compile (internal/modules/cjs/loader.js:1085:14)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                at Module.load (internal/modules/cjs/loader.js:950:32)
                at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm ERR! code ELIFECYCLE
            npm ERR! errno 6
            npm ERR! iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install: `node iobroker.js setup first`
            npm ERR! Exit status 6
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /root/.npm/_logs/2022-02-03T15_47_09_558Z-debug.log
            Hier noch das NPM log
            IOB startet nicht mehr
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @wendy2702 last edited by Thomas Braun
              @wendy2702 sagte in Alpha Test js-controller 4.0:
              sudo npm
              Nich mit sudo rummachen an der Stelle.
              • wendy2702
                wendy2702 @Thomas Braun last edited by wendy2702
                @thomas-braun Beim ersten Versuch nur zugriffsrechte verweigert meldungen bekommen.
                Deshalb der Versuch mit sudo.
                Erstmal zurück auf JS3.3.22 ohne erfolg. Musste den JS mit
                sudo -H -u iobroker npm install iobroker.js-controller
                neu installieren.
                Dann den fixer nochmal laufen lassen.
                mirko@iobroker:/opt/iobroker$ iob fix
                library: loaded
                Library version=2021-12-27
                    Welcome to the ioBroker installation fixer!
                    Script version: 2021-12-27
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                Hit:1 http://security.debian.org buster/updates InRelease
                Hit:2 http://ftp.debian.org/debian buster InRelease
                Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                Hit:4 https://deb.nodesource.com/node_10.x buster InRelease
                Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
                Hit:6 https://deb.nodesource.com/node_14.x buster InRelease
                Reading package lists... Done
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                JS4 erneut versucht:
                mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@peter-murray/hue-bridge-model
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bottleneck
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/eyes
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/isarray
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/string_decoder
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/readable-stream
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsftp/node_modules/debug
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-listing
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/psl
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sax
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/unorm
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/vm2
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/webidl-conversions
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlbuilder
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr-064/node_modules/xml2js
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-ssh
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/node-forge
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js2fs/node_modules
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
                npm ERR! code EACCES
                npm ERR! syscall access
                npm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
                npm ERR! errno -13
                npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
                npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'] {
                npm ERR!   errno: -13,
                npm ERR!   code: 'EACCES',
                npm ERR!   syscall: 'access',
                npm ERR!   path: '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
                npm ERR! }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm ERR! If you believe this might be a permissions issue, please double-check the
                npm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator.
                npm ERR!     /home/mirko/.npm/_logs/2022-02-03T16_17_51_143Z-debug.log
                Und jetzt?
                Nach neustart von IOB sehe ich im Syslog davon tausende Einträge:
                iobroker bash[4117]: Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone
                  Dann musst du schauen, warum da Rechte fehlen. Der mirko ist in der Gruppe iobroker drin?
                  Wie sehen die Rechte an den angemeckerten Verzeichnissen aus?
                  Dateisystem fit?
                  dmesg -T | grep -i ext4
                  https://github.com/ioBroker/ioBroker.js-controller/issues/1528
                  realwax created this issue in ioBroker/ioBroker.js-controller
                  closed js-controller update 3.3.19 - "TZID without Luxon available is unsupported" #1528
                  wendy2702 1 Reply Last reply Reply Quote -1
                  • wendy2702
                    @thomas-braun Naja,
                    der mirko hat bisher immer die JS Controller Updates machen dürfen. 😊
                    mirko@iobroker:/opt/iobroker$ cat /etc/group |grep iob
                    tty:x:5:iobroker
                    dialout:x:20:iobroker
                    audio:x:29:iobroker
                    video:x:44:iobroker
                    iobroker:x:1000:mirko
                    mirko@iobroker:/opt/iobroker$ id mirko
                    uid=1001(mirko) gid=1001(mirko) groups=1001(mirko),27(sudo),1000(iobroker)
                    drwxrwxr-x+ 979 iobroker iobroker  36864 Feb  3 17:07 node_modules
                    Auch alle Unterverzeichnisse gehören iobroker.
                    Filesystem schaut gut aus:
                    mirko@iobroker:/opt/iobroker$ dmesg -T | grep -i ext4
                    [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
                    [Wed Aug  4 10:04:40 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:04:43 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:04:55 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 10:05:06 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:53:28 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 14:53:29 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 20:56:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 20:58:11 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:12:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:18:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:24:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:26:31 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:27:59 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:36:21 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:44:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug 18 12:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug 18 12:34:10 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug 18 15:48:18 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Aug 18 16:15:41 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 23 08:42:39 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Aug 23 08:55:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 08:51:25 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 08:51:48 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 08:53:00 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 08:54:55 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 08:56:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:10:03 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:11:15 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:36:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:43:41 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:44:47 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:48:19 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 09:48:48 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 10:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 10:35:12 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 10:35:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Dec 15 10:39:25 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Dec 16 14:21:32 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Jan 27 18:13:36 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Sat Jan 29 15:05:48 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Feb  3 16:42:25 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Feb  3 16:43:57 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    [Thu Feb  3 16:58:03 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
                    Noch eine Idee woran es liegen könnte?
                      Fortune95 @apollon77 last edited by
                      @apollon77 sagte in Alpha Test js-controller 4.0:
                      Done! 🙂
                        An der Uptime... 😛
                        Der rennt seit 04. August durch?
                        Ist das was gedockertes? EXT4-fs (dm-6) schaut so ungewohnt aus.
                        • wendy2702
                          @thomas-braun sagte in Alpha Test js-controller 4.0:
                          An der Uptime...
                          Ja.... wie ein Käfer.... der läuft und läuft....
                          Ist ein LXC im Proxmox
                            apollon77 @wendy2702 last edited by
                            @wendy2702 "iob fix" und ja ohne sudo 🙂 (eigentlich wie immer und wie es in der Anleitung steht gg)
                            • wendy2702
                              wendy2702 @apollon77 last edited by
                              @apollon77 Ja,
                              genau das habe ich ja beim zweiten Versuch gemacht und hier beschrieben:
                              https://forum.iobroker.net/post/755201
                              hat aber trotzdem nicht geklappt.
                                @wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
                                Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                                wendy2702 2 Replies Last reply Reply Quote 0
                                • wendy2702
                                  wendy2702 @apollon77 last edited by wendy2702
                                  @apollon77 Hier mal ein Beispiel:
                                  mirko@iobroker:/opt/iobroker$ ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                  total 836
                                  drwxrwxr-x+ 3 iobroker iobroker   4096 Feb  3 18:09 .
                                  drwxrwxr-x+ 4 iobroker iobroker   4096 Feb  3 18:09 ..
                                  -rwxr-xr-x+ 1 iobroker iobroker   1141 Feb  1 09:31 LICENSE
                                  -rwxr-xr-x+ 1 iobroker iobroker   2591 Feb  1 09:31 README.md
                                  -rwxr-xr-x+ 1 iobroker iobroker   5724 Feb  1 09:31 assert.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   9784 Feb  1 09:31 async_hooks.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   3097 Feb  1 09:31 buffer.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  26012 Feb  1 09:31 child_process.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  16301 Feb  1 09:31 cluster.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   6218 Feb  1 09:31 console.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker    598 Feb  1 09:31 constants.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  47240 Feb  1 09:31 crypto.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   7371 Feb  1 09:31 dgram.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  16763 Feb  1 09:31 dns.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker    778 Feb  1 09:31 domain.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   3477 Feb  1 09:31 events.d.ts
                                  drwxr-xr-x+ 2 iobroker iobroker   4096 Feb  3 18:09 fs
                                  -rwxr-xr-x+ 1 iobroker iobroker 121480 Feb  1 09:31 fs.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  25191 Feb  1 09:31 globals.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker     55 Feb  1 09:31 globals.global.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  25681 Feb  1 09:31 http.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  57454 Feb  1 09:31 http2.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  11799 Feb  1 09:31 https.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   4743 Feb  1 09:31 index.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker 123902 Feb  1 09:31 inspector.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   1736 Feb  1 09:31 module.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  13923 Feb  1 09:31 net.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   8231 Feb  1 09:31 os.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   5135 Feb  3 18:09 package.json
                                  -rwxr-xr-x+ 1 iobroker iobroker   6454 Feb  1 09:31 path.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  10735 Feb  1 09:31 perf_hooks.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  20658 Feb  1 09:31 process.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   3535 Feb  1 09:31 punycode.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   1157 Feb  1 09:31 querystring.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   7599 Feb  1 09:31 readline.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  18337 Feb  1 09:31 repl.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  19743 Feb  1 09:31 stream.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker    270 Feb  1 09:31 string_decoder.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker    889 Feb  1 09:31 timers.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  38658 Feb  1 09:31 tls.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   2186 Feb  1 09:31 trace_events.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   2497 Feb  1 09:31 tty.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   5490 Feb  1 09:31 url.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  13112 Feb  1 09:31 util.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   6822 Feb  1 09:31 v8.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   6508 Feb  1 09:31 vm.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker   3520 Feb  1 09:31 wasi.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  11705 Feb  1 09:31 worker_threads.d.ts
                                  -rwxr-xr-x+ 1 iobroker iobroker  14576 Feb  1 09:31 zlib.d.ts
                                  Wenn sonst nichts einfällt wird es wohl der Holzhammer werden...
                                    Schaut bei mir genauso aus
                                    • wendy2702
                                      @apollon77 Das ist nur der Master.....
                                      habe gerade ein wenig respekt wenn ich an meine Slaves denke wegen dem Holzhammer
                                        @wendy2702
                                        Da sind ACLs drauf.
                                        Schau mal mit
                                        getfacl /Pfad/zu/einer/meckerdatei
                                        Was da noch dranhängt
                                        • wendy2702
                                          getfacl
                                          Das hier z.B.:
                                          mirko@iobroker:/opt/iobroker$ getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                          getfacl: Removing leading '/' from absolute path names
                                          # file: opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                          # owner: iobroker
                                          # group: iobroker
                                          user::rwx
                                          group::r-x
                                          group:iobroker:rwx
                                          mask::rwx
                                          other::r-x
                                          default:user::rwx
                                          default:group::r-x
                                          default:group:iobroker:rwx
                                          default:mask::rwx
                                          default:other::r-x
                                          Sehe da auf Anhieb nichts verdächtiges.... bin aber mit einem Auge noch in einem Online Training
                                            Thomas Braun Most Active @apollon77 last edited by
                                            Nur der iobroker.parcel-Adapter muss bei jedem update des controllers neugebaut werden.
                                            Das wäre aber interessant warum das so ist. Was bringt der als Fehler? Läuft der renbuild machenaismus an?
                                            Hier das Log dazu:
                                            2022-02-03 15:24:15.366  - info: host.chet instance system.adapter.parcel.0 started with pid 66699
                                            2022-02-03 15:24:15.411  - info: miio.0 (66537) discover stoped after 30 seconds.
                                            2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                            2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                            2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]:                  ^
                                            2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                            2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                            2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                            2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                            2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                            2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                            2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            2022-02-03 15:24:16.648  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                            2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                            2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                            2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                            2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                            2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                            2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]: }
                                            2022-02-03 15:24:16.650  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-02-03 15:24:16.651  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                            2022-02-03 15:24:16.655  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                            2022-02-03 15:24:16.656  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                            2022-02-03 15:24:16.656  - info: host.chet iobroker rebuild
                                            2022-02-03 15:24:17.635  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                            2022-02-03 15:25:05.335  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                            2022-02-03 15:25:05.370  - info: host.chet iobroker npm-rebuild:
                                            2022-02-03 15:25:05.371  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                            2022-02-03 15:25:06.387  - info: host.chet iobroker npm-rebuild: exit 0
                                            2022-02-03 15:25:06.542  - info: host.chet instance system.adapter.parcel.0 started with pid 67346
                                            2022-02-03 15:25:07.862  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                            2022-02-03 15:25:07.863  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                            2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]:                  ^
                                            2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                            2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                            2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                            2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                            2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                            2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                            2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                            2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                            2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                            2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                            2022-02-03 15:25:07.873  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                            2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                            2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]: }
                                            2022-02-03 15:25:07.874  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-02-03 15:25:07.875  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                            2022-02-03 15:25:07.878  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                            2022-02-03 15:25:07.878  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                            2022-02-03 15:25:07.879  - info: host.chet iobroker rebuild
                                            2022-02-03 15:25:08.977  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                            2022-02-03 15:25:50.623  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                            2022-02-03 15:25:50.666  - info: host.chet iobroker npm-rebuild:
                                            2022-02-03 15:25:50.667  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                            2022-02-03 15:25:51.687  - info: host.chet iobroker npm-rebuild: exit 0
                                            2022-02-03 15:25:51.839  - info: host.chet instance system.adapter.parcel.0 started with pid 67981
                                            2022-02-03 15:25:53.048  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                            2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                            2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:                  ^
                                            2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                            2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                            2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                            2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                            2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                            2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                            2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                            2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                            2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                            2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                            2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]: }
                                            2022-02-03 15:25:53.054  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-02-03 15:25:53.054  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                            2022-02-03 15:25:53.054  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                            2022-02-03 15:25:53.055  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                            2022-02-03 15:25:53.055  - info: host.chet iobroker rebuild
                                            2022-02-03 15:25:54.004  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                            2022-02-03 15:26:35.390  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                            2022-02-03 15:26:35.433  - info: host.chet iobroker npm-rebuild:
                                            2022-02-03 15:26:35.434  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                            2022-02-03 15:26:36.447  - info: host.chet iobroker npm-rebuild: exit 0
                                            2022-02-03 15:26:36.588  - info: host.chet instance system.adapter.parcel.0 started with pid 68611
                                            2022-02-03 15:26:37.838  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                            2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                            2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:                  ^
                                            2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                            2022-02-03 15:26:37.840  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                            2022-02-03 15:26:37.841  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                            2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                            2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                            2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                            2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                            2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                            2022-02-03 15:26:37.844  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                            2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                            2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                            2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                            2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]: }
                                            2022-02-03 15:26:37.846  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-02-03 15:26:37.846  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                            habe ich dann gemacht, danach ging der iobroker.parcel.0 auch. Hat aber eher mit canvas zu tun, wenn ich das richtig sehe.
                                            1.0k
                                            196
                                            25763
