    4. Alpha Test js-controller 4.0
    • wendy2702
      Habe das bei der Installation auf dem Master bekommen:
      mirko@iobroker:/opt/iobroker$ sudo npm i iobroker.js-controller@next
      [sudo] password for mirko:
      > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
      Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
      Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
          at Object.mkdirSync (fs.js:1013:3)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1012:16)
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:567:23)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3316:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
          at Module._compile (internal/modules/cjs/loader.js:1085:14)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          at Module.load (internal/modules/cjs/loader.js:950:32)
          at Function.Module._load (internal/modules/cjs/loader.js:790:12)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 6
      npm ERR! iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install: `node iobroker.js setup first`
      npm ERR! Exit status 6
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.0-alpha.73-20220203-4ff5b7b6 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2022-02-03T15_47_09_558Z-debug.log
      Hier noch das NPM log
      IOB startet nicht mehr
      Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @wendy2702 last edited by Thomas Braun
        @wendy2702 sagte in Alpha Test js-controller 4.0:
        sudo npm
        Nich mit sudo rummachen an der Stelle.
        • wendy2702
          wendy2702 @Thomas Braun last edited by wendy2702
          @thomas-braun Beim ersten Versuch nur zugriffsrechte verweigert meldungen bekommen.
          Deshalb der Versuch mit sudo.
          Erstmal zurück auf JS3.3.22 ohne erfolg. Musste den JS mit
          sudo -H -u iobroker npm install iobroker.js-controller
          neu installieren.
          Dann den fixer nochmal laufen lassen.
          mirko@iobroker:/opt/iobroker$ iob fix
          library: loaded
          Library version=2021-12-27
              Welcome to the ioBroker installation fixer!
              Script version: 2021-12-27
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          Hit:1 http://security.debian.org buster/updates InRelease
          Hit:2 http://ftp.debian.org/debian buster InRelease
          Hit:3 http://ftp.debian.org/debian buster-updates InRelease
          Hit:4 https://deb.nodesource.com/node_10.x buster InRelease
          Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
          Hit:6 https://deb.nodesource.com/node_14.x buster InRelease
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          JS4 erneut versucht:
          mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@peter-murray/hue-bridge-model
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/tough-cookie
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asynckit
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bottleneck
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-compiler
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffee-script
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/delayed-stream
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/combined-stream
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/eyes
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/isarray
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/string_decoder
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ftp-response-parser/node_modules/readable-stream
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/isstream
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsbn
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsftp/node_modules/debug
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-schema-traverse
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stringify-safe
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonata
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/long-timeout
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/luxon
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-types
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/request
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-inspect
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/oauth-sign
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-listing
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/performance-now
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/picocolors
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/psl
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/punycode
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/node_modules/form-data
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-buffer
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safer-buffer
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sax
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/suncalc2
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tunnel-agent
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tweetnacl
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/unorm
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uri-js
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/uuid
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/verror/node_modules/core-util-is
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsprim
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/vm2
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wake_on_lan
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/webidl-conversions
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlbuilder
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr-064/node_modules/xml2js
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xtend
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-ssh
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/yallist
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/node-forge
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js2fs/node_modules
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
          npm ERR! code EACCES
          npm ERR! syscall access
          npm ERR! path /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
          npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'] {
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra'
          npm ERR! }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator.
          npm ERR!     /home/mirko/.npm/_logs/2022-02-03T16_17_51_143Z-debug.log
          Und jetzt?
          Nach neustart von IOB sehe ich im Syslog davon tausende Einträge:
          iobroker bash[4117]: Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone
            Dann musst du schauen, warum da Rechte fehlen. Der mirko ist in der Gruppe iobroker drin?
            Wie sehen die Rechte an den angemeckerten Verzeichnissen aus?
            Dateisystem fit?
            dmesg -T | grep -i ext4
            https://github.com/ioBroker/ioBroker.js-controller/issues/1528
            realwax created this issue in ioBroker/ioBroker.js-controller
            closed js-controller update 3.3.19 - "TZID without Luxon available is unsupported" #1528
            wendy2702 1 Reply Last reply Reply Quote -1
            • wendy2702
              @thomas-braun Naja,
              der mirko hat bisher immer die JS Controller Updates machen dürfen. 😊
              mirko@iobroker:/opt/iobroker$ cat /etc/group |grep iob
              tty:x:5:iobroker
              dialout:x:20:iobroker
              audio:x:29:iobroker
              video:x:44:iobroker
              iobroker:x:1000:mirko
              mirko@iobroker:/opt/iobroker$ id mirko
              uid=1001(mirko) gid=1001(mirko) groups=1001(mirko),27(sudo),1000(iobroker)
              drwxrwxr-x+ 979 iobroker iobroker  36864 Feb  3 17:07 node_modules
              Auch alle Unterverzeichnisse gehören iobroker.
              Filesystem schaut gut aus:
              mirko@iobroker:/opt/iobroker$ dmesg -T | grep -i ext4
              [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:04:27 2021] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
              [Wed Aug  4 10:04:40 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:04:43 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:04:49 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:04:55 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 10:05:06 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 12:51:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 12:57:37 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:01:58 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:03:38 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 13:10:24 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:16:43 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:23:39 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:45:22 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:53:28 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 14:53:29 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 15:04:40 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 17:25:45 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug  4 17:32:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 19:24:50 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 19:36:55 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 20:56:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 20:58:11 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:05:56 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:08:02 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:08:41 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:12:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:18:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:24:56 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:26:31 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:27:59 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:28:57 2021] EXT4-fs (dm-17): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:36:21 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:44:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 16 21:48:09 2021] EXT4-fs (dm-15): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug 18 12:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug 18 12:34:10 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug 18 15:48:18 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Aug 18 16:15:41 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 23 08:42:39 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Mon Aug 23 08:55:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 08:51:25 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 08:51:48 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 08:53:00 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 08:54:55 2021] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 08:56:17 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:10:03 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:11:15 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:36:36 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:43:41 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:44:47 2021] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:48:19 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 09:48:48 2021] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 10:24:08 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 10:35:12 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 10:35:55 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Wed Dec 15 10:39:25 2021] EXT4-fs (dm-16): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Dec 16 14:21:32 2021] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Jan 27 18:13:36 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Sat Jan 29 15:05:48 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Feb  3 16:42:25 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Feb  3 16:43:57 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Feb  3 16:58:03 2022] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
              Noch eine Idee woran es liegen könnte?
                Fortune95 @apollon77 last edited by
                @apollon77 sagte in Alpha Test js-controller 4.0:
                @fortune95 Legst Du dann bitte 4 GitHub issues an? ;-)) (bzw 3 weil ich glaube shelly gibts schon)
                Done! 🙂
                  An der Uptime... 😛
                  Der rennt seit 04. August durch?
                  Ist das was gedockertes? EXT4-fs (dm-6) schaut so ungewohnt aus.
                  • wendy2702
                    @thomas-braun sagte in Alpha Test js-controller 4.0:
                    An der Uptime...
                    Ja.... wie ein Käfer.... der läuft und läuft....
                    Ist ein LXC im Proxmox
                      apollon77 @wendy2702 last edited by
                      @wendy2702 "iob fix" und ja ohne sudo 🙂 (eigentlich wie immer und wie es in der Anleitung steht gg)
                      • wendy2702
                        wendy2702 @apollon77 last edited by
                        @apollon77 Ja,
                        genau das habe ich ja beim zweiten Versuch gemacht und hier beschrieben:
                        https://forum.iobroker.net/post/755201
                        hat aber trotzdem nicht geklappt.
                          @wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
                          Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                          wendy2702 2 Replies Last reply Reply Quote 0
                          • wendy2702
                            wendy2702 @apollon77 last edited by wendy2702
                            @apollon77 Hier mal ein Beispiel:
                            mirko@iobroker:/opt/iobroker$ ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                            total 836
                            drwxrwxr-x+ 3 iobroker iobroker   4096 Feb  3 18:09 .
                            drwxrwxr-x+ 4 iobroker iobroker   4096 Feb  3 18:09 ..
                            -rwxr-xr-x+ 1 iobroker iobroker   1141 Feb  1 09:31 LICENSE
                            -rwxr-xr-x+ 1 iobroker iobroker   2591 Feb  1 09:31 README.md
                            -rwxr-xr-x+ 1 iobroker iobroker   5724 Feb  1 09:31 assert.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   9784 Feb  1 09:31 async_hooks.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   3097 Feb  1 09:31 buffer.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  26012 Feb  1 09:31 child_process.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  16301 Feb  1 09:31 cluster.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   6218 Feb  1 09:31 console.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker    598 Feb  1 09:31 constants.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  47240 Feb  1 09:31 crypto.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   7371 Feb  1 09:31 dgram.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  16763 Feb  1 09:31 dns.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker    778 Feb  1 09:31 domain.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   3477 Feb  1 09:31 events.d.ts
                            drwxr-xr-x+ 2 iobroker iobroker   4096 Feb  3 18:09 fs
                            -rwxr-xr-x+ 1 iobroker iobroker 121480 Feb  1 09:31 fs.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  25191 Feb  1 09:31 globals.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker     55 Feb  1 09:31 globals.global.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  25681 Feb  1 09:31 http.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  57454 Feb  1 09:31 http2.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  11799 Feb  1 09:31 https.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   4743 Feb  1 09:31 index.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker 123902 Feb  1 09:31 inspector.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   1736 Feb  1 09:31 module.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  13923 Feb  1 09:31 net.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   8231 Feb  1 09:31 os.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   5135 Feb  3 18:09 package.json
                            -rwxr-xr-x+ 1 iobroker iobroker   6454 Feb  1 09:31 path.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  10735 Feb  1 09:31 perf_hooks.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  20658 Feb  1 09:31 process.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   3535 Feb  1 09:31 punycode.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   1157 Feb  1 09:31 querystring.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   7599 Feb  1 09:31 readline.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  18337 Feb  1 09:31 repl.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  19743 Feb  1 09:31 stream.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker    270 Feb  1 09:31 string_decoder.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker    889 Feb  1 09:31 timers.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  38658 Feb  1 09:31 tls.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   2186 Feb  1 09:31 trace_events.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   2497 Feb  1 09:31 tty.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   5490 Feb  1 09:31 url.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  13112 Feb  1 09:31 util.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   6822 Feb  1 09:31 v8.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   6508 Feb  1 09:31 vm.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker   3520 Feb  1 09:31 wasi.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  11705 Feb  1 09:31 worker_threads.d.ts
                            -rwxr-xr-x+ 1 iobroker iobroker  14576 Feb  1 09:31 zlib.d.ts
                            Wenn sonst nichts einfällt wird es wohl der Holzhammer werden...
                              Schaut bei mir genauso aus
                              • wendy2702
                                @apollon77 Das ist nur der Master.....
                                habe gerade ein wenig respekt wenn ich an meine Slaves denke wegen dem Holzhammer
                                  @wendy2702
                                  Da sind ACLs drauf.
                                  Schau mal mit
                                  getfacl /Pfad/zu/einer/meckerdatei
                                  Was da noch dranhängt
                                  • wendy2702
                                    getfacl
                                    Das hier z.B.:
                                    mirko@iobroker:/opt/iobroker$ getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                    getfacl: Removing leading '/' from absolute path names
                                    # file: opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                                    # owner: iobroker
                                    # group: iobroker
                                    user::rwx
                                    group::r-x
                                    group:iobroker:rwx
                                    mask::rwx
                                    other::r-x
                                    default:user::rwx
                                    default:group::r-x
                                    default:group:iobroker:rwx
                                    default:mask::rwx
                                    default:other::r-x
                                    Sehe da auf Anhieb nichts verdächtiges.... bin aber mit einem Auge noch in einem Online Training
                                      Thomas Braun Most Active @apollon77 last edited by
                                      Nur der iobroker.parcel-Adapter muss bei jedem update des controllers neugebaut werden.
                                      Das wäre aber interessant warum das so ist. Was bringt der als Fehler? Läuft der renbuild machenaismus an?
                                      Hier das Log dazu:
                                      2022-02-03 15:24:15.366  - info: host.chet instance system.adapter.parcel.0 started with pid 66699
                                      2022-02-03 15:24:15.411  - info: miio.0 (66537) discover stoped after 30 seconds.
                                      2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                      2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                      2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]:                  ^
                                      2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                      2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                      2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                      2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                      2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                      2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                      2022-02-03 15:24:16.648  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                      2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                      2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                      2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                      2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                      2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]: }
                                      2022-02-03 15:24:16.650  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2022-02-03 15:24:16.651  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                      2022-02-03 15:24:16.655  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                      2022-02-03 15:24:16.656  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                      2022-02-03 15:24:16.656  - info: host.chet iobroker rebuild
                                      2022-02-03 15:24:17.635  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                      2022-02-03 15:25:05.335  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                      2022-02-03 15:25:05.370  - info: host.chet iobroker npm-rebuild:
                                      2022-02-03 15:25:05.371  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                      2022-02-03 15:25:06.387  - info: host.chet iobroker npm-rebuild: exit 0
                                      2022-02-03 15:25:06.542  - info: host.chet instance system.adapter.parcel.0 started with pid 67346
                                      2022-02-03 15:25:07.862  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                      2022-02-03 15:25:07.863  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                      2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]:                  ^
                                      2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                      2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                      2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                      2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                      2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                      2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                      2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                      2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                      2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                      2022-02-03 15:25:07.873  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                      2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                      2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]: }
                                      2022-02-03 15:25:07.874  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2022-02-03 15:25:07.875  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                      2022-02-03 15:25:07.878  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                      2022-02-03 15:25:07.878  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                      2022-02-03 15:25:07.879  - info: host.chet iobroker rebuild
                                      2022-02-03 15:25:08.977  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                      2022-02-03 15:25:50.623  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                      2022-02-03 15:25:50.666  - info: host.chet iobroker npm-rebuild:
                                      2022-02-03 15:25:50.667  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                      2022-02-03 15:25:51.687  - info: host.chet iobroker npm-rebuild: exit 0
                                      2022-02-03 15:25:51.839  - info: host.chet instance system.adapter.parcel.0 started with pid 67981
                                      2022-02-03 15:25:53.048  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                      2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                      2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:                  ^
                                      2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                      2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                      2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                      2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                      2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                      2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                      2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                      2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                      2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]: }
                                      2022-02-03 15:25:53.054  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2022-02-03 15:25:53.054  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                                      2022-02-03 15:25:53.054  - info: host.chet system.adapter.parcel.0 will be rebuilt
                                      2022-02-03 15:25:53.055  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                      2022-02-03 15:25:53.055  - info: host.chet iobroker rebuild
                                      2022-02-03 15:25:54.004  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                                      2022-02-03 15:26:35.390  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                                      2022-02-03 15:26:35.433  - info: host.chet iobroker npm-rebuild:
                                      2022-02-03 15:26:35.434  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                                      2022-02-03 15:26:36.447  - info: host.chet iobroker npm-rebuild: exit 0
                                      2022-02-03 15:26:36.588  - info: host.chet instance system.adapter.parcel.0 started with pid 68611
                                      2022-02-03 15:26:37.838  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                                      2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                      2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:                  ^
                                      2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      2022-02-03 15:26:37.840  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                                      2022-02-03 15:26:37.841  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                                      2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                                      2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                                      2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                      2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                                      2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                                      2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      2022-02-03 15:26:37.844  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                      2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                      2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                                      2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                                      2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                      2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]: }
                                      2022-02-03 15:26:37.846  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2022-02-03 15:26:37.846  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                      habe ich dann gemacht, danach ging der iobroker.parcel.0 auch. Hat aber eher mit canvas zu tun, wenn ich das richtig sehe.
                                        mine
                                        • wendy2702
                                          @apollon77 Arrrgghhhhh.... Ein Screenshot 🙂
                                          Sieht aber aus wie bei mir.
                                            @wendy2702
                                            mount | sort
                                            Ich frag mich noch was das für ein komisches mount da bei dir immer ist.
                                            Aber Container... 😞
                                            196
                                            25776
