    4. Test Adapter Meteoalarm v2.0.x
    • jackblackson
      jackblackson @sigi234 last edited by
      @sigi234 Hab grad umgestellt, bei mir find ich diesen Fehler nicht, hab grad noch das node.js aktualisiert auf 14. Einziger Unterschied ist, ich habs auf Linux laufen, nicht auf Windows..
      da_Woody sigi234 2 Replies Last reply Reply Quote 1
      • da_Woody
        da_Woody @jackblackson last edited by
        @jackblackson sieht irgendwie danach aus, das es an windows liegt...
          sigi234 Forum Testing Most Active @jackblackson last edited by sigi234
          @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
          Auf Version 2.0.8 geupdatet, derzeit kommt kein Fehler.
          • da_Woody
            da_Woody @sigi234 last edited by
            @sigi234 na das haste verschwiegen... 😉
              sigi234 Forum Testing Most Active @da_Woody last edited by
              @da_woody sagte in Test Adapter Meteoalarm v2.0.x:
              Jetzt kommt das schon wieder: V 2.0.10
              meteoalarm.5
              2021-12-28 20:54:05.320	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
              meteoalarm.4
              2021-12-28 20:52:08.398	error	DB closed
              meteoalarm.4
              2021-12-28 20:52:08.398	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6215:35)
              meteoalarm.4
              2021-12-28 20:52:08.388	error	unhandled promise rejection: DB closed
              meteoalarm.4
              2021-12-28 20:52:08.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              meteoalarm.4
              2021-12-28 20:52:07.749	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
              meteoalarm.5
              2021-12-28 20:27:05.600	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
              meteoalarm.4
              2021-12-28 20:26:05.370	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
              meteoalarm.4
              2021-12-28 20:00:12.959	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
              meteoalarm.5
              2021-12-28 20:00:12.233	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
              jackblackson 1 Reply Last reply Reply Quote 0
              • jackblackson
                @sigi234 Ok..seh da leider nichts im Sentry. Ist das nur einmal bei der Ausführung passiert, oder mehrmals?
                  Bei jeder Ausführung
                  Habe kein Redis:
                  meteoalarm.4
                  • jackblackson
                    @sigi234 Hast du Sentry aktiv, zumindest für diesen Adapter?
                      Ja
                      • jackblackson
                        jackblackson last edited by jackblackson
                        Für alle Anwender, die Alarme für die Schweiz laden möchten, die Version 2.1.0 ist in wenigen Stunden im Latest zu finden.
                        Ich würde mich über ein Feedback freuen, wenn alles funktioniert.
                        • jackblackson
                          jackblackson @da_Woody last edited by
                          @da_woody Es hat etwas gedauert, aber inzwischen gibt es (zumindest für Österreich) die Warnungen nicht mehr nur auf Bundesland, sondern feingliedriger - hilft dir vielleicht. Es ist auch grad eine Version im Latest (wird die nächsten Tage in die Stable kommen) -> 2.1.2 - die einen Fix beinhaltet, weil es Probleme mit dem Link gab.
                          • da_Woody
                            da_Woody @jackblackson last edited by da_Woody
                            @jackblackson oi! goil! schau ich mir an...
                            edith: hüstel... 351c6caa-95a5-4bbb-9784-abee0fdda94b-grafik.png hab aber nüscht vom l8est geupdatet...
                            verfeinerung ist da. allerdings doch noch grob. mal schauen. 👍
                            • jackblackson
                              @da_woody Ich glaub es sind nun die Bezirke - nicht perfekt, auch in Vorarlberg nicht, aber besser als vorher.
                              Wegen dem Update: wie meinst du das? im Stable ist noch die 2.1.1..
                              da_Woody Latzi 3 Replies Last reply Reply Quote 0
                              • da_Woody
                                das hab anscheinend ich missinterpretiert. hab geglaubt, die 2.1.2. ist frisch im latest. bin ja nur dort unterwegs.
                                hab jetzt mal für burgenland auf eisenstadt-umgebung eingestellt, sind 13 km von mir und für niederösterreich wr.neustadt(land) aud der richtung kommen dann auch meist unwetter zu uns rüber. mal schauen... 🙂
                                hoffe, daß die truppe das noch weiter runterbricht andererseits hab ich ja eh meine wetterstation im garten und auch forecast7 im iQontrol.
                                • da_Woody
                                  @jackblackson boah, heut gehts wieder ab mit den meldungen... 😄
                                  strahlender sonnenschein. ich hau mich in den pool! 😉
                                  • Latzi
                                    Latzi @jackblackson last edited by
                                    @jackblackson
                                    mit der 2.1.4 bekomme ich stündlich folgende Meldung:
                                    2022-05-31 17:28:01.139 - info: meteoalarm.0 (326580) starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                                    2022-05-31 17:28:01.206 - warn: host.ioBroker-Server Objects 127.0.0.1:41944 Error from InMemDB: Error: Not exists
                                    2022-05-31 17:28:01.871 - info: meteoalarm.0 (326580) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                    2022-05-31 17:28:01.873 - info: meteoalarm.0 (326580) Terminated (NO_ERROR): Without reason
                                    2022-05-31 17:28:01.877 - info: meteoalarm.0 (326580) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                    2022-05-31 17:28:02.393 - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                                    stelle ich zurück auf 2.1.3 ist die Meldung weg. Hast du eine Idee woran das liegen könnte? Brauchst du noch zusätzliche Informationen?
                                    Vielen Dank!
                                    • jackblackson
                                      jackblackson @Latzi last edited by
                                      @latzi Hallo! Danke für die Info..das ist komisch. Könntest du es mir mal mit "Debug" laufen lassen, damit ich das komplette Protokoll sehe?
                                      Latzi 1 Reply Last reply Reply Quote 0
                                      • jackblackson
                                        @da_woody Bin jetzt vermutlich zu spät dran, aber ich seh nur noch eine Warnung..entweder haben sie es behoben, oder es sind schon zwei davon hinfällig. Wäre spannend, ob alle Drei für die selbe Zeit gewesen wären.
                                        da_Woody liv-in-sky 3 Replies Last reply Reply Quote 0
                                        • Latzi
                                          Bitte sehr:
                                          2022-05-31 22:28:00.030 - info: host.ioBroker instance system.adapter.meteoalarm.0 started with pid 910529
                                          2022-05-31 22:28:00.509 - debug: meteoalarm.0 (910529) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                          2022-05-31 22:28:00.557 - debug: meteoalarm.0 (910529) Objects client ready ... initialize now
                                          2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create System PubSub Client
                                          2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create User PubSub Client
                                          2022-05-31 22:28:00.624 - debug: meteoalarm.0 (910529) Objects client initialize lua scripts
                                          2022-05-31 22:28:00.626 - debug: meteoalarm.0 (910529) Objects connected to redis: 0.0.0.0:9001
                                          2022-05-31 22:28:00.655 - debug: meteoalarm.0 (910529) Redis States: Use Redis connection: 0.0.0.0:9000
                                          2022-05-31 22:28:00.679 - debug: meteoalarm.0 (910529) States create System PubSub Client
                                          2022-05-31 22:28:00.680 - debug: meteoalarm.0 (910529) States create User PubSub Client
                                          2022-05-31 22:28:00.721 - debug: meteoalarm.0 (910529) States connected to redis: 0.0.0.0:9000
                                          2022-05-31 22:28:00.909 - debug: meteoalarm.0 (910529) Plugin sentry Initialize Plugin (enabled=true)
                                          2022-05-31 22:28:01.142 - info: meteoalarm.0 (910529) starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                                          2022-05-31 22:28:01.170 - debug: meteoalarm.0 (910529) Language: de
                                          2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
                                          2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
                                          2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) XML Language: de-DE
                                          2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) 0: Delete Alarms
                                          2022-05-31 22:28:01.174 - debug: meteoalarm.0 (910529) Language: de
                                          2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
                                          2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
                                          2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) XML Language: de-DE
                                          2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) 0: Delete Alarms
                                          2022-05-31 22:28:01.236 - warn: host.ioBroker-Server Objects 127.0.0.1:33394 Error from InMemDB: Error: Not exists
                                          2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
                                          2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
                                          2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
                                          2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
                                          2022-05-31 22:28:01.613 - debug: meteoalarm.0 (910529) 3: Received Atom
                                          2022-05-31 22:28:01.714 - debug: meteoalarm.0 (910529) 4: Process Atom
                                          2022-05-31 22:28:01.715 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
                                          2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
                                          2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 5: Processed Atom
                                          2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
                                          2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
                                          2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 11: Set State for Widget
                                          2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 12: All Done
                                          2022-05-31 22:28:01.751 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                          2022-05-31 22:28:01.752 - debug: meteoalarm.0 (910529) Plugin sentry destroyed
                                          2022-05-31 22:28:01.752 - info: meteoalarm.0 (910529) Terminated (NO_ERROR): Without reason
                                          2022-05-31 22:28:01.872 - debug: meteoalarm.0 (910529) 3: Received Atom
                                          2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4: Process Atom
                                          2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
                                          2022-05-31 22:28:01.996 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
                                          2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5: Processed Atom
                                          2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
                                          2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
                                          2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 11: Set State for Widget
                                          2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 12: All Done
                                          2022-05-31 22:28:02.083 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
                                          2022-05-31 22:28:02.267 - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                                          • da_Woody
                                            @jackblackson jau, 2 l8... 😄 heute keine warnungen.
                                            das witzige, da waren keine zeiten dabei. aber im burgenland zufällig gesehn, daß eine der 3 warnungen für eisenstadt-umgebung verschwand und ca. 3 min später wieder angezeigt wurde.
                                            liegt ja nicht am adapter, wollts nur vermelden... 😉
                                            412
                                            82287
