    4. Zigbee und LED-Trading Unterputz Schalt Aktoren 16A
      mguenther last edited by mguenther
      Hallo Zusammen,
      Zigbee Adapter V1.6.6 ist installiert, ich nutze ein Zigbee LAN/USB/WLAN Gateway CC2652P von @dimaiv
      https://forum.iobroker.net/topic/48312/verkaufe-zigbee-lan-usb-wlan-gateway-cc2652p
      Nodejs/node 14.19.0
      npm 6.14.16
      Folgender Paring Log-File:
      Error: Device 0x0c4314fffe9e5719 "ON/OFF -M" not described in statesMapping.. undefined
      Pairing time left
      Pairing time left: 1
      Pairing time left: 2
      Pairing time left: 3
      Pairing time left: 4
      Pairing time left: 5
      Pairing time left: 6
      Pairing time left: 7
      Pairing time left: 8
      Pairing time left: 9
      Pairing time left: 10
      Pairing time left: 11
      Pairing time left: 12
      Pairing time left: 13
      Pairing time left: 14
      Pairing time left: 15
      Pairing time left: 16
      Pairing time left: 17
      Pairing time left: 18
      Pairing time left: 19
      Pairing time left: 20
      Pairing time left: 21
      Pairing time left: 22
      Pairing time left: 23
      Pairing time left: 24
      Pairing time left: 25
      Pairing time left: 26
      Pairing time left: 27
      Pairing time left: 28
      Pairing time left: 29
      Pairing time left: 30
      Pairing time left: 31
      Pairing time left: 32
      Pairing time left: 33
      Pairing time left: 34
      Pairing time left: 35
      Pairing time left: 36
      Pairing time left: 37
      Pairing time left: 38
      Pairing time left: 39
      Pairing time left: 40
      Pairing time left: 41
      Pairing time left: 42
      Pairing time left: 43
      Pairing time left: 44
      Pairing time left: 45
      Pairing time left: 46
      Pairing time left: 47
      Pairing time left: 48
      Pairing time left: 49
      New device joined '0x0c4314fffe9e5719' model ON/OFF -M
      Interview successful: [object Object]
      Pairing time left: 50
      Pairing time left: 51
      Device '0x0c4314fffe9e5719' announced itself
      Interview started: 0x0c4314fffe9e5719
      Pairing time left: 52
      Pairing time left: 53
      Pairing time left: 54
      Pairing time left: 55
      Pairing time left: 56
      Pairing time left: 57
      Pairing time left: 58
      Pairing time left: 59
      Pairing time left: 60
      Pairing started
      es handelt sich um den Unterputz Schalt Aktor für 16A Steckdosen (UP-SA-9127P)
      https://www.led-trading.de/zigbee-unterputz-schalter-steuergeraet-controller-230v-16a
      @arteck
      @Asgothian
      ich habe andere Threads schon gefunden, mir sagen die Fehlermeldungen nur bedingt was, aber ich glaube, der Aktor ist nicht richtig im Adapter angelegt?
      Wenn ich noch was liefern soll/kann, helfe ich gerne.
      Ich habe dann noch einen anderen Schaltaktor für Licht-Schalter von LED Trading (Artikelnummer: UP-SA-9127S)
      https://www.led-trading.de/ZigBee-Einbaudose-Unterputz-Schaltaktor-Steuergeraet-Controller-ZigBee-30-fuer-Schalter
      da klappt das Pairing ohne Probleme
      Was kann ich machen?
      Danke für jede Unterstützung
      Marcus
      • Asgothian
        Asgothian Developer @mguenther last edited by
        @mguenther
        1. Zigbee adapter v. 1.6.12 installieren (unstable)
        2. Zigbee adapter v 1.6.15 installieren (GitHub)
        A.
          mguenther @Asgothian last edited by
          @asgothian
          wenn ich z.b. die 1.6.15 von Github installiere - dann als zusätzliche Instanz?
          Oder was muss ich machen?
            dimaiv @mguenther last edited by
            @mguenther sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
            @asgothian
            Einfach laufende Adapter updaten. Fertig.
              mguenther @dimaiv last edited by mguenther
              @dimaiv sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
              @asgothian
              äh - wie?
              ich habe die Repositiy auf beta (http://download.iobroker.net/sources-dist-latest.json) umgestellt. Da zeigt er mir beim Adapter die 1.6.14 als mögliche Version an. Ich gehe mal davon aus, dass die auch funktioniert, aber ich komme über die Oberfläche weder auf die 1.6.12, noch auf die 1.6.15...
              edit - ich war zu blöd... 1.6.14 wird gerade installiert...
                @mguenther 1.6.14 ist auch gut.
                  @dimaiv
                  @Asgothian
                  also, einen Aktor bekomme ich gepaired, anbei der Logfile:
                  Pairing time left
                  Pairing started
                  aber - ich sehe in der Übersicht nur:
                  bzw.
                  auch unter den Objekten sehe ich "nur":
                  bei einem 2.Aktor kommt erst eine Fehlermeldung, dann paired er, aber das Ergebnis ist bei dem 1. Aktor
                  Pairing time left
                  New device joined '0x0c4314fffea33114' model ON/OFF -M
                  Error: Device 0x0c4314fffea33114 "ON/OFF -M" not described in statesMapping.. undefined
                  Device '0x0c4314fffea33114' announced itself
                  Interview started: 0x0c4314fffea33114
                  Pairing started
                    nur weil das ding genau so aussieht heisst es nicht dass das gleiche drinne ist...
                    hab PR gestellt.. wird aber dauern..der heisst anders
                    ON/OFF -M
                    und der ist noch nicht drin
                    bist du linux affin dann kannst du es dir temporär selber fixen..
                      mguenther @arteck last edited by mguenther
                      @arteck sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
                      @arteck
                      nicht wirklich... 😞
                      aber - gibt es ne Anleitung, wie sowas eingerichtet werden kann?
                      braucht ihr noch andere Infos?
                        @mguenther ich kann dir ein Datei vorbereiten, den du nur in deiner System ersetzen muss. Schaffst du das?
                          @dimaiv
                          glaube schon 🙂
                          erste Idee wäre mittels ftp?
                          wenn keine Berechtigung vorhanden, müsste ich sie als sudo von Stelle 1 an Stelle 2 kopieren. - ich hätte dazu den Befehl "cp" genommen, aber bin für alle Hinweise offen...
                            dimaiv @mguenther last edited by dimaiv
                            @mguenther
                            sunricher.zip
                            Zigbee Instanz stoppen!
                            Datei runterladen und entpacken, dann in folgenden Verzeichnis kopieren (existierende ersetzen):
                            "/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/"
                            Zigbee Instanz starten.
                              @dimaiv
                              danke - hat erst einmal funktioniert
                              551
