iot Adapter bleibt gelb, "undefined" Fehlermeldung im Log
Danke Dir.
Hier das Log ab "Neustart".Der Adapter wurde nicht mehr grün nachdem ich mehrfach den Skill Amazon installiert habe und mehrfach auf "Verbinsgzertifikat" Button drückte.
Vorher habe ich Zigbee geupdatet.e6iob@NUCioBroker:/$ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.18.3 v14.18.3 6.14.15 nodejs: Installiert: 14.18.3-deb-1nodesource1 Installationskandidat: 14.19.0-deb-1nodesource1 Versionstabelle: 14.19.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages *** 14.18.3-deb-1nodesource1 100 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://deb.debian.org/debian bullseye/main amd64 Packages 500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages e6iob@NUCioBroker:/$e6iob@NUCioBroker:/$ iobroker update Used repository: beta hash changed or no sources cached => force download of new sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.2.4 , installed 2.2.3 [Updateable] Adapter "bydhvs" : 1.3.0 , installed 1.3.0 Adapter "cloud" : 4.1.0 , installed 4.1.0 Adapter "devices" : 1.0.9 , installed 1.0.9 Adapter "discovery" : 2.7.5 , installed 2.7.3 [Updateable] Adapter "fb-checkpresence": 1.1.13 , installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fritzdect" : 2.2.3 , installed 2.2.3 Adapter "habpanel" : 0.4.3 , installed 0.4.3 Adapter "ham" : 4.0.2 , installed 4.0.2 Adapter "history" : 1.10.5 , installed 1.9.14 [Updateable] Adapter "hm-rega" : 3.0.35 , installed 3.0.35 Adapter "hm-rpc" : 1.15.2 , installed 1.15.0 [Updateable] Adapter "hs100" : 2.0.7 , installed 2.0.7 Adapter "ical" : 1.11.6 , installed 1.11.6 Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.2 Adapter "influxdb" : 2.4.0 , installed 2.4.0 Adapter "iot" : 1.9.3 , installed 1.9.3 Adapter "javascript" : 5.2.21 , installed 5.2.21 Controller "js-controller" : 3.3.22 , installed 3.3.22 Adapter "mqtt" : 2.4.1 , installed 2.4.0 [Updateable] Adapter "node-red" : 2.4.1 , installed 2.4.1 Adapter "parser" : 1.0.7 , installed 1.0.7 Adapter "ping" : 1.5.2 , installed 1.5.0 [Updateable] Adapter "ring" : 1.2.8 , installed 1.2.8 Adapter "shelly" : 5.1.2 , installed 5.1.2 Adapter "simple-api" : 2.6.2 , installed 2.6.2 Adapter "socketio" : 4.1.0 , installed 3.1.5 [Updateable] Adapter "systeminfo" : 0.3.1 , installed 0.3.1 Adapter "telegram" : 1.11.1 , installed 1.11.1 Adapter "text2command" : 2.1.1 , installed 2.1.1 Adapter "vis" : 1.4.8 , installed 1.4.8 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-weather" : 2.5.5 , installed 2.5.5 Adapter "web" : 4.1.1 , installed 3.4.16 [Updateable] Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6 Adapter "yeelight-2" : 1.1.2 , installed 1.1.2 Adapter "zigbee" : 1.6.14 , installed 1.6.14 e6iob@NUCioBroker:/$ -
Ich würde ja mal den Update-Stau auflösen.
nodeJS und die Adapter. -
Du meinst mit iobroker upgrade alle Adapter der Liste updaten? Einfach so
 (Angst). -
@fraso sagte in iot Adapter bleibt gelb, "undefined" Fehlermeldung im Log:
(Angst).
und mit so einer Einstellung bist du als Beta-tester unterwegs?
 (Angst).Wie/was willst du denn sonst beta-testen? Die Versionen die du da hast sind schon getestet worden, sonst gäbe es ja kein Update dafür.
Wenn du das nicht machen willst, geh auf den stabilen Zweig.
Update durch.
Habe den iot.0 gelöscht, neu installiert. Dann eben den "Verbindungszertifikat" Button geklickt. Keine Änderung. Er bleibt gelb.
Fehlermeldungen im Log:
2022-02-04 17:36:15.881 - info: host.NUCioBroker "system.adapter.iot.0" enabled 2022-02-04 17:36:15.927 - info: host.NUCioBroker instance system.adapter.iot.0 started with pid 11530 2022-02-04 17:36:17.151 - info: iot.0 (11530) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.0, js-controller: 3.3.22 2022-02-04 17:36:17.184 - info: iot.0 (11530) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com 2022-02-04 17:36:17.662 - error: iot.0 (11530) Error in main: TypeError: Cannot read property 'certificates' of undefined 2022-02-04 17:36:20.005 - info: javascript.0 (8923) script.js.E6-HAUS.SICHERHEIT.CAM_AUTOSEND: /var/lib/motioneye/Camera6/2022-02-04/17-23.mp4 2022-02-04 17:36:26.774 - info: host.NUCioBroker stopInstance system.adapter.iot.0 (force=false, process=true) 2022-02-04 17:36:26.777 - info: host.NUCioBroker stopInstance system.adapter.iot.0 send kill signal 2022-02-04 17:36:26.777 - info: iot.0 (11530) Got terminate signal TERMINATE_YOURSELF 2022-02-04 17:36:26.778 - info: iot.0 (11530) terminating 2022-02-04 17:36:26.779 - info: iot.0 (11530) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2022-02-04 17:36:27.339 - info: host.NUCioBroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2022-02-04 17:36:29.826 - info: host.NUCioBroker instance system.adapter.iot.0 started with pid 11657 2022-02-04 17:36:30.003 - info: javascript.0 (8923) script.js.E6-HAUS.SICHERHEIT.CAM_AUTOSEND: /var/lib/motioneye/Camera6/2022-02-04/17-23.mp4 2022-02-04 17:36:30.848 - info: iot.0 (11657) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.iot, node: v14.19.0, js-controller: 3.3.22 2022-02-04 17:36:30.870 - info: iot.0 (11657) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com 2022-02-04 17:36:31.322 - error: iot.0 (11657) Error in main: TypeError: Cannot read property 'certificates' of undefinedHier aktueller Stand:
e6iob@NUCioBroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.0 v14.19.0 6.14.16 nodejs: Installiert: 14.19.0-deb-1nodesource1 Installationskandidat: 14.19.0-deb-1nodesource1 Versionstabelle: *** 14.19.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages 100 /var/lib/dpkg/status 12.22.5~dfsg-2~11u1 500 500 http://deb.debian.org/debian bullseye/main amd64 Packages 500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages e6iob@NUCioBroker:~$e6iob@NUCioBroker:~$ iobroker update Used repository: beta hash unchanged, use cached sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.2.4 , installed 2.2.4 Adapter "bydhvs" : 1.3.0 , installed 1.3.0 Adapter "cloud" : 4.1.0 , installed 4.1.0 Adapter "devices" : 1.0.9 , installed 1.0.9 Adapter "discovery" : 2.7.5 , installed 2.7.5 Adapter "fb-checkpresence": 1.1.13 , installed 1.1.13 Adapter "flot" : 1.10.7 , installed 1.10.7 Adapter "fritzdect" : 2.2.3 , installed 2.2.3 Adapter "habpanel" : 0.4.3 , installed 0.4.3 Adapter "ham" : 4.0.2 , installed 4.0.2 Adapter "history" : 1.10.5 , installed 1.10.5 Adapter "hm-rega" : 3.0.35 , installed 3.0.35 Adapter "hm-rpc" : 1.15.2 , installed 1.15.2 Adapter "hs100" : 2.0.7 , installed 2.0.7 Adapter "ical" : 1.11.6 , installed 1.11.6 Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.2 Adapter "influxdb" : 2.4.0 , installed 2.4.0 Adapter "iot" : 1.9.3 , installed 1.9.3 Adapter "javascript" : 5.2.21 , installed 5.2.21 Controller "js-controller" : 3.3.22 , installed 3.3.22 Adapter "mqtt" : 2.4.1 , installed 2.4.1 Adapter "node-red" : 2.4.1 , installed 2.4.1 Adapter "parser" : 1.0.7 , installed 1.0.7 Adapter "ping" : 1.5.2 , installed 1.5.2 Adapter "ring" : 1.2.8 , installed 1.2.8 Adapter "shelly" : 5.1.2 , installed 5.1.2 Adapter "simple-api" : 2.6.2 , installed 2.6.2 Adapter "socketio" : 4.1.0 , installed 4.1.0 Adapter "systeminfo" : 0.3.1 , installed 0.3.1 Adapter "telegram" : 1.11.1 , installed 1.11.1 Adapter "text2command" : 2.1.1 , installed 2.1.1 Adapter "vis" : 1.4.8 , installed 1.4.8 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-weather" : 2.5.5 , installed 2.5.5 Adapter "web" : 4.1.1 , installed 4.1.1 Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6 Adapter "yeelight-2" : 1.1.2 , installed 1.1.2 Adapter "zigbee" : 1.6.14 , installed 1.6.14 e6iob@NUCioBroker:~$ -
Und in der stable hast du den Fehler nicht?
Dann mach ein Issue auf. -
Ich deinstalliert mal den iot.0 und installiere den stable bevor ich das mache.
Macht das Sinn? -
Macht das Sinn?
nur wenn du alles auf stable hast, was da einen Einfluss haben könnte
Macht das Sinn?
Um heraus zu finden ob der Fehler in der Beta-Version eingeführt wurde macht das schon Sinn.
Ich habe 1.9.3 deinstalliert. Dann auf latest umgestellt. Dann versucht den Adapter neu zu installieren mit 1.8.??. Installiert wurde wieder der 1.9.3
Wie geht das sonst richtig? Danke.
iobroker upgrade iot@1.8.24 -
Du weißt schon, dass latest der beta-Zweig ist?
ja. jetzt
Ist installiert.
Der Adapter ist grün.
Die iot.0.certs sind jetzt auch ausgefüllt.
Alexa Skill deaktiviert, neu aktiviert - Geräte suchen-> Geräte da.
Dann hast du beim Beta-Testing wohl einen Fehler entdeckt.
Mach ein Issue auf. -
Na dafür machen wir das doch.
Davon bin ich überzeugt.
Wie immer - den Beteiligten ganz ganz herzlichen Dank.
