    4. Alpha Test js-controller 4.0
      lonsimbt @apollon77 last edited by
      @apollon77
      Hier läuft iobroker im (privilegierten) lxc (debian) unter proxmox. Installation des js-controller als "normaler" Benutzer funktioniert ohne Probleme.
      Node.js v14.19.0
      NPM v6.14.16
      • wendy2702
        wendy2702 last edited by
        @apollon77
        Mal noch einen anderen Versuch gewagt: Key und Cert etwas gekürzt.
        mirko@iobroker:/opt/iobroker$ sudo -H -u iobroker npm i iobroker.js-controller@next
        > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Cannot clean up invalid user group assignments: Cannot read property 'length' of null
        object system.licenses created
        object _design/system updated
        The following notifications happened during sync:
        - Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nxxxxOHqAJ6mqZ\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----\rxxxfraHQ==\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        States DB type migrated from "file" to "jsonl"
        Objects DB type migrated from "file" to "jsonl"
        ioBroker configuration updated
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1
        added 37 packages from 42 contributors, removed 109 packages, updated 42 packages and moved 2 packages in 32.791s
        163 packages are looking for funding
          run `npm fund` for details
        Startet erstmal:
        2022-02-04 12:17:07.056  - info: host.iobroker iobroker.js-controller version 4.0.0 js-controller starting
        2022-02-04 12:17:07.059  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2022-02-04 12:17:07.059  - info: host.iobroker hostname: iobroker, node: v14.19.0
        2022-02-04 12:17:07.059  - info: host.iobroker ip addresses: 192.168.178.18 fd30:4253:5f21:46be:805a:fcff:fedc:3d66 2a01:c22:b4d1:b000:805a:fcff:fedc:3d66 fe80::805a:fcff:fedc:3d66
        2022-02-04 12:17:08.206  - info: host.iobroker Sets unsupported
        2022-02-04 12:17:08.708  - info: host.iobroker connected to Objects and States
        2022-02-04 12:17:08.715  - info: host.iobroker added notifications configuration of host
        2022-02-04 12:17:08.716  - info: host.iobroker Node.js version has changed from unknown to 14.19.0
        2022-02-04 12:17:08.748  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2022-02-04 12:17:09.188  - info: host.iobroker 95 instances found
        2022-02-04 12:17:09.255  - info: host.iobroker starting 53 instances
        2022-02-04 12:17:09.378  - info: host.iobroker instance system.adapter.admin.0 started with pid 12443
        2022-02-04 12:17:10.133  - info: admin.0 (12443) Sets unsupported
        2022-02-04 12:17:10.134  - info: admin.0 (12443) Sets unsupported
        2022-02-04 12:17:10.453  - info: admin.0 (12443) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
        2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all states
        2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all objects
        2022-02-04 12:17:11.958  - info: admin.0 (12443) received all objects
        2022-02-04 12:17:12.246  - info: admin.0 (12443) http server listening on port 8081
        2022-02-04 12:17:12.246  - info: admin.0 (12443) Use link "http://localhost:8081" to configure.
        2022-02-04 12:17:13.284  - info: host.iobroker instance system.adapter.email.0 started with pid 12460
        2022-02-04 12:17:13.848  - info: email.0 (12460) Sets unsupported
        2022-02-04 12:17:13.849  - info: email.0 (12460) Sets unsupported
        2022-02-04 12:17:14.158  - info: email.0 (12460) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
        2022-02-04 12:17:17.376  - info: host.iobroker instance system.adapter.history.0 started with pid 12477
        2022-02-04 12:17:18.051  - info: history.0 (12477) Sets unsupported
        2022-02-04 12:17:18.052  - info: history.0 (12477) Sets unsupported
        2022-02-04 12:17:18.345  - info: history.0 (12477) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
        2022-02-04 12:17:21.425  - info: host.iobroker instance system.adapter.javascript.0 started with pid 12494
        2022-02-04 12:17:22.471  - info: javascript.0 (12494) Sets unsupported
        2022-02-04 12:17:22.472  - info: javascript.0 (12494) Sets unsupported
        2022-02-04 12:17:22.808  - info: javascript.0 (12494) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
        2022-02-04 12:17:22.849  - info: javascript.0 (12494) npm install jsftp --production (System call)
        2022-02-04 12:17:25.381  - info: host.iobroker instance system.adapter.javascript.1 started with pid 12522
        2022-02-04 12:17:26.603  - info: javascript.1 (12522) Sets unsupported
        2022-02-04 12:17:26.604  - info: javascript.1 (12522) Sets unsupported
        2022-02-04 12:17:26.999  - info: javascript.1 (12522) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
        2022-02-04 12:17:27.030  - info: javascript.1 (12522) npm install xml2js --production (System call)
        apollon77 foxriver76 2 Replies Last reply Reply Quote 0
          apollon77 @wendy2702 last edited by
          @wendy2702 Das siht auch alles perfekt aus. Was war der Unterschied? Das obige sudo-Kommando was es unter dem iobroker user ausführt?
          • wendy2702
            wendy2702 @apollon77 last edited by
            @apollon77 Ja. Nur das Kommando....
            verstehen muss ich das aktuell noch nicht.
            • foxriver76
              foxriver76 Developer @wendy2702 last edited by foxriver76
              @wendy2702 sagte in Alpha Test js-controller 4.0:
              Unabhängig von der Problematik mit dem Install: Kannst du mal deine system.group Objekte zeigen, irgendeins hat da wohl kein common.members Attribut.
              • wendy2702
                wendy2702 @foxriver76 last edited by
                @foxriver76 sagte in Alpha Test js-controller 4.0:
                Meinst du das:
                • foxriver76
                  @wendy2702 mal hinten dran auf den Stift und das raw JSON posten
                  • wendy2702
                      "_id": "system.group.administrator",
                      "type": "group",
                      "common": {
                        "name": "Administrator",
                        "description": {
                          "en": "Can do everything with ioBroker"
                        "members": [
                          "system.user.admin"
                        "dontDelete": true,
                        "acl": {
                          "object": {
                            "list": true,
                            "read": true,
                            "write": true,
                            "delete": true
                          "state": {
                            "list": true,
                            "read": true,
                            "write": true,
                            "create": true,
                            "delete": true
                          "users": {
                            "list": true,
                            "read": true,
                            "write": true,
                            "create": true,
                            "delete": true
                          "other": {
                            "execute": true,
                            "http": true,
                            "sendto": true
                          "file": {
                            "list": true,
                            "read": true,
                            "write": true,
                            "create": true,
                            "delete": true
                        "icon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPGcgZmlsbD0iY3VycmVudENvbG9yIj4NCiAgICAgICAgPHBhdGggZD0iTTQsMTh2LTAuNjVjMC0wLjM0LDAuMTYtMC42NiwwLjQxLTAuODFDNi4xLDE1LjUzLDguMDMsMTUsMTAsMTVjMC4wMywwLDAuMDUsMCwwLjA4LDAuMDFjMC4xLTAuNywwLjMtMS4zNywwLjU5LTEuOTggQzEwLjQ1LDEzLjAxLDEwLjIzLDEzLDEwLDEzYy0yLjQyLDAtNC42OCwwLjY3LTYuNjEsMS44MkMyLjUxLDE1LjM0LDIsMTYuMzIsMiwxNy4zNVYyMGg5LjI2Yy0wLjQyLTAuNi0wLjc1LTEuMjgtMC45Ny0ySDR6Ii8+DQogICAgICAgIDxwYXRoIGQ9Ik0xMCwxMmMyLjIxLDAsNC0xLjc5LDQtNHMtMS43OS00LTQtNEM3Ljc5LDQsNiw1Ljc5LDYsOFM3Ljc5LDEyLDEwLDEyeiBNMTAsNmMxLjEsMCwyLDAuOSwyLDJzLTAuOSwyLTIsMiBjLTEuMSwwLTItMC45LTItMlM4LjksNiwxMCw2eiIvPg0KICAgICAgICA8cGF0aCBkPSJNMjAuNzUsMTZjMC0wLjIyLTAuMDMtMC40Mi0wLjA2LTAuNjNsMS4xNC0xLjAxbC0xLTEuNzNsLTEuNDUsMC40OWMtMC4zMi0wLjI3LTAuNjgtMC40OC0xLjA4LTAuNjNMMTgsMTFoLTJsLTAuMywxLjQ5IGMtMC40LDAuMTUtMC43NiwwLjM2LTEuMDgsMC42M2wtMS40NS0wLjQ5bC0xLDEuNzNsMS4xNCwxLjAxYy0wLjAzLDAuMjEtMC4wNiwwLjQxLTAuMDYsMC42M3MwLjAzLDAuNDIsMC4wNiwwLjYzbC0xLjE0LDEuMDEgbDEsMS43M2wxLjQ1LTAuNDljMC4zMiwwLjI3LDAuNjgsMC40OCwxLjA4LDAuNjNMMTYsMjFoMmwwLjMtMS40OWMwLjQtMC4xNSwwLjc2LTAuMzYsMS4wOC0wLjYzbDEuNDUsMC40OWwxLTEuNzNsLTEuMTQtMS4wMSBDMjAuNzIsMTYuNDIsMjAuNzUsMTYuMjIsMjAuNzUsMTZ6IE0xNywxOGMtMS4xLDAtMi0wLjktMi0yczAuOS0yLDItMnMyLDAuOSwyLDJTMTguMSwxOCwxNywxOHoiLz4NCiAgICA8L2c+DQo8L3N2Zz4="
                      "acl": {
                        "owner": "system.user.admin",
                        "object": 1604
                      "user": "system.user.admin",
                      "ts": 1621797197839
                    und
                      "_id": "system.group.user",
                      "type": "group",
                      "common": {
                        "name": "User",
                        "description": {
                          "en": "Cannot modify anything"
                        "members": null,
                        "dontDelete": true,
                        "url": "https://github.com/ioBroker/ioBroker.js-controller/archive/master.zip",
                        "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/io-package.json",
                        "acl": {
                          "object": {
                            "list": true,
                            "read": true,
                            "write": false,
                            "delete": false
                          "state": {
                            "list": true,
                            "read": true,
                            "write": true,
                            "create": true,
                            "delete": false
                          "users": {
                            "list": true,
                            "read": true,
                            "write": false,
                            "create": false,
                            "delete": false
                          "other": {
                            "execute": false,
                            "http": true,
                            "sendto": false
                          "file": {
                            "list": true,
                            "read": true,
                            "write": false,
                            "create": false,
                            "delete": false
                        "icon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgNmMxLjEgMCAyIC45IDIgMnMtLjkgMi0yIDItMi0uOS0yLTIgLjktMiAyLTJtMCAxMGMyLjcgMCA1LjggMS4yOSA2IDJINmMuMjMtLjcyIDMuMzEtMiA2LTJtMC0xMkM5Ljc5IDQgOCA1Ljc5IDggOHMxLjc5IDQgNCA0IDQtMS43OSA0LTQtMS43OS00LTQtNHptMCAxMGMtMi42NyAwLTggMS4zNC04IDR2MmgxNnYtMmMwLTIuNjYtNS4zMy00LTgtNHoiLz4NCjwvc3ZnPg=="
                      "acl": {
                        "object": 1604
                      "ts": 1621797197839
                      @wendy2702 Foxriver hat den Fix schon gemacht. kommt dann in die 4.0.1 für Latest heute Abend
                      • Feuersturm
                        Feuersturm @apollon77 last edited by
                        @apollon77 sagte in Alpha Test js-controller 4.0:
                        (foxriver76) Optimize meta object sync
                        Update auf Alpha 74
                        @foxriver76 Jetzt sind es nur noch 3. Wobei der iogo.admin nicht mehr installiert ist und eine Leiche ist.
                        Hilft es die anderen beiden Adapter einfach mal zu deinstallieren und neu zu installieren und mit der 4.0.1 dann zu schauen ob die Meldungen weiterhin kommen?
                        - Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
                        - Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
                        - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
                          apollon77 @Feuersturm last edited by
                          @feuersturm ich denke der tr-064-Community ist auch ne Altlast oder?!
                          • foxriver76
                            foxriver76 Developer @Feuersturm last edited by
                            @feuersturm zeig mal die Objekte ob es Typ Meta sind sonst jammert er korrekterweise
                            • Feuersturm
                              Feuersturm @apollon77 last edited by Feuersturm
                              @apollon77 @foxriver76
                              So wie es aussieht sind die drei monierten "Adapter" alles Leichen wenn man sich die Zeitstempel der Dateien so ansieht.
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ ls -l
                              total 216
                              -rw-rwxr--+ 1 iobroker iobroker 154292 Feb  4 18:48 _data.json
                              -rw-rwxr--+ 1 iobroker iobroker   2589 Feb  3 22:06 daswettercom.png
                              drwxrwxr-x+ 5 iobroker iobroker   4096 Jan 12  2020 icons
                              -rw-rwxr--+ 1 iobroker iobroker   4195 May  2  2020 index.html
                              -rw-rwxr--+ 1 iobroker iobroker  20265 Feb  3 22:06 index_m.html
                              -rw-rwxr--+ 1 iobroker iobroker   5673 Feb  3 22:06 jsonConfig.json
                              -rw-rwxr--+ 1 iobroker iobroker  14893 Feb  3 22:06 words.js
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ cd ..
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd daswetter
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ ls -l
                              total 64
                              -rw-rwxr--+ 1 iobroker iobroker 60096 Jan 16  2021 _data.json
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ cd ..
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr
                              tr-064-community.admin/ tr-064.admin/           trashschedule.admin/
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064-community.admin/
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ ls -l
                              total 92
                              -rw-rwxr--+  1 iobroker iobroker  3035 Jan 10  2021 _data.json
                              drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 20  2020 i18n
                              -rw-rwxr--+  1 iobroker iobroker 21842 Jan 20  2020 index.html
                              -rw-rwxr--+  1 iobroker iobroker 22279 Jan 20  2020 index_m.html
                              -rw-rwxr--+  1 iobroker iobroker 30797 Jan 20  2020 words.js
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ cd ..
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064.admin/
                              proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064.admin$ ls -l
                              total 100
                              -rw-rwxr--+  1 iobroker iobroker  3103 Feb  4 18:48 _data.json
                              drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 24  2020 i18n
                              -rw-rwxr--+  1 iobroker iobroker 21822 Jan 27  2020 index.html
                              -rw-rwxr--+  1 iobroker iobroker 28639 Feb  3 22:04 index_m.html
                              -rw-rwxr--+  1 iobroker iobroker  1736 Feb  3 22:04 tr-064.png
                              -rw-rwxr--+  1 iobroker iobroker 34320 Feb  3 22:04 words.js
                              • foxriver76
                                @feuersturm dann passt die Meldung ja: please remove directory 👍🏼
                                • wendy2702
                                  Ok.
                                  Schaffe ich hoffentlich morgen einzuspielen
                                    darkiop Most Active last edited by
                                    Guten Abend, hatte bis heute leider keine Zeit den neuen 4.0.0 zu testen.
                                    Eben aber direkt mein P-System (redis/redis + node14 / npm6) umgestellt. Melde mich bei Auffälligkeiten.
                                      apollon77 last edited by apollon77
                                      Hallo alle zusammen,
                                      ich habe @next nochmals aktualisiert mit der 4.0.3, was die geplante Beta/Latest version für heute Nachmittag/Abend ist. Meine Tests sehen soweit gut aus.
                                      Von daher wäre cool wenn Ihr, wie Zeit, es nochmal bei euch aktualisiert - dann habt Ihr auch gleich die Latest Version drauf 🙂
                                      Änderungen sind minimaler Kleinkram und Fixes der noch gemeldet wurde (und einige Version haben wir "verloren" weil der Release-Prozess nicht so wollte wie wir 😉 )
                                      • (foxriver76) Fix user-group objects with invalid member list - reported by @wendy2702
                                      • (foxriver76) Fix multihost commands - reported in GitHub
                                      • (foxriver76) Fix meto object check/sync to prevent false positive logs
                                      L Feuersturm 2 Replies Last reply Reply Quote 0
                                        @apollon77
                                        Ich war mal so mutig und habe die 4.0.3 auf mein Produktivsystem losgelassen (ein Hoch auf proxmox und die Möglichkeit von snapshots). Dabei sind folgende Meldungen noch hochgekommen:
                                        - Ignoring Directory "gartenbewaesserung.admin" because officially not created as meta object. Please remove directory!
                                        - Ignoring Directory "robonect.admin" because officially not created as meta object. Please remove directory!
                                        Beide Adapter sind zzt. nicht in Benutzung. Können die Ordner tatsächlich gefahrlos gelöscht werden?
                                        Ferner folgende Warnungen im Log:
                                        shuttercontrol.0
                                        	2022-02-05 11:15:36.840	warn	This object will not be created in future versions. Please report this to the developer.
                                        shuttercontrol.0
                                        	2022-02-05 11:15:36.839	warn	Object shuttercontrol.0.info.Azimut is invalid: Default value has to be type "number" but received type "string"
                                        shuttercontrol.0
                                        	2022-02-05 11:15:36.832	warn	This object will not be created in future versions. Please report this to the developer.
                                        shuttercontrol.0
                                        	2022-02-05 11:15:36.830	warn	Object shuttercontrol.0.info.Elevation is invalid: Default value has to be type "number" but received type "string"
                                        mqtt.0
                                        	2022-02-05 11:15:00.871	warn	This object will not be created in future versions. Please report this to the developer.
                                        mqtt.0
                                        	2022-02-05 11:15:00.870	warn	Object mqtt.0.info.connection is invalid: Default value has to be type "string" but received type "boolean"
                                        Issue beim Adapter erstellen?
                                        Gruß Marco
                                        simatec apollon77 foxriver76 3 Replies Last reply Reply Quote 0
                                        • simatec
                                          simatec Developer Most Active @lonsimbt last edited by
                                          @lonsimbt
                                          Für Shuttercontrol gibt es dazu bereits ein Issue
                                            apollon77 @lonsimbt last edited by
                                            @lonsimbt korrekt. Fehlende issue Bitte erstellen. Zu den beiden Verzeichnissen: wenn du da aktuell keine Instanzen hast dann kannst du das löschen.
                                            196
                                            25827
