    4. Alpha Test js-controller 4.0
    • wendy2702
      wendy2702 @foxriver76 last edited by
      @foxriver76 sagte in Alpha Test js-controller 4.0:
      @wendy2702 sagte in Alpha Test js-controller 4.0:
      Cannot clean up invalid user group assignments: Cannot read property 'length' of null
      Unabhängig von der Problematik mit dem Install: Kannst du mal deine system.group Objekte zeigen, irgendeins hat da wohl kein common.members Attribut.
      Meinst du das:
      • foxriver76
        foxriver76 Developer @wendy2702 last edited by
        @wendy2702 mal hinten dran auf den Stift und das raw JSON posten
        • wendy2702
            "_id": "system.group.administrator",
            "type": "group",
            "common": {
              "name": "Administrator",
              "description": {
                "en": "Can do everything with ioBroker"
              "members": [
                "system.user.admin"
              "dontDelete": true,
              "acl": {
                "object": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "delete": true
                "state": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
                "users": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
                "other": {
                  "execute": true,
                  "http": true,
                  "sendto": true
                "file": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": true
              "icon": "data:image/svg+xml;base64,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"
            "acl": {
              "owner": "system.user.admin",
              "object": 1604
            "user": "system.user.admin",
            "ts": 1621797197839
          und
            "_id": "system.group.user",
            "type": "group",
            "common": {
              "name": "User",
              "description": {
                "en": "Cannot modify anything"
              "members": null,
              "dontDelete": true,
              "url": "https://github.com/ioBroker/ioBroker.js-controller/archive/master.zip",
              "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/io-package.json",
              "acl": {
                "object": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "delete": false
                "state": {
                  "list": true,
                  "read": true,
                  "write": true,
                  "create": true,
                  "delete": false
                "users": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "create": false,
                  "delete": false
                "other": {
                  "execute": false,
                  "http": true,
                  "sendto": false
                "file": {
                  "list": true,
                  "read": true,
                  "write": false,
                  "create": false,
                  "delete": false
              "icon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIGhlaWdodD0iMjRweCIgdmlld0JveD0iMCAwIDI0IDI0IiB3aWR0aD0iMjRweCI+DQogICAgPHBhdGggZmlsbD0iY3VycmVudENvbG9yIiBkPSJNMTIgNmMxLjEgMCAyIC45IDIgMnMtLjkgMi0yIDItMi0uOS0yLTIgLjktMiAyLTJtMCAxMGMyLjcgMCA1LjggMS4yOSA2IDJINmMuMjMtLjcyIDMuMzEtMiA2LTJtMC0xMkM5Ljc5IDQgOCA1Ljc5IDggOHMxLjc5IDQgNCA0IDQtMS43OSA0LTQtMS43OS00LTQtNHptMCAxMGMtMi42NyAwLTggMS4zNC04IDR2MmgxNnYtMmMwLTIuNjYtNS4zMy00LTgtNHoiLz4NCjwvc3ZnPg=="
            "acl": {
              "object": 1604
            "ts": 1621797197839
            apollon77 @wendy2702 last edited by
            @wendy2702 Foxriver hat den Fix schon gemacht. kommt dann in die 4.0.1 für Latest heute Abend
            • Feuersturm
              Feuersturm @apollon77 last edited by
              @apollon77 sagte in Alpha Test js-controller 4.0:
              (foxriver76) Optimize meta object sync
              Update auf Alpha 74
              @foxriver76 Jetzt sind es nur noch 3. Wobei der iogo.admin nicht mehr installiert ist und eine Leiche ist.
              Hilft es die anderen beiden Adapter einfach mal zu deinstallieren und neu zu installieren und mit der 4.0.1 dann zu schauen ob die Meldungen weiterhin kommen?
              The following notifications happened during sync:
              - Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
              - Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
              - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
              apollon77 foxriver76 2 Replies Last reply Reply Quote 0
                apollon77 @Feuersturm last edited by
                @feuersturm ich denke der tr-064-Community ist auch ne Altlast oder?!
                • foxriver76
                  foxriver76 Developer @Feuersturm last edited by
                  @feuersturm zeig mal die Objekte ob es Typ Meta sind sonst jammert er korrekterweise
                  • Feuersturm
                    Feuersturm @apollon77 last edited by Feuersturm
                    @apollon77 @foxriver76
                    So wie es aussieht sind die drei monierten "Adapter" alles Leichen wenn man sich die Zeitstempel der Dateien so ansieht.
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ ls -l
                    total 216
                    -rw-rwxr--+ 1 iobroker iobroker 154292 Feb  4 18:48 _data.json
                    -rw-rwxr--+ 1 iobroker iobroker   2589 Feb  3 22:06 daswettercom.png
                    drwxrwxr-x+ 5 iobroker iobroker   4096 Jan 12  2020 icons
                    -rw-rwxr--+ 1 iobroker iobroker   4195 May  2  2020 index.html
                    -rw-rwxr--+ 1 iobroker iobroker  20265 Feb  3 22:06 index_m.html
                    -rw-rwxr--+ 1 iobroker iobroker   5673 Feb  3 22:06 jsonConfig.json
                    -rw-rwxr--+ 1 iobroker iobroker  14893 Feb  3 22:06 words.js
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter.admin$ cd ..
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd daswetter
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ ls -l
                    total 64
                    -rw-rwxr--+ 1 iobroker iobroker 60096 Jan 16  2021 _data.json
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/daswetter$ cd ..
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr
                    tr-064-community.admin/ tr-064.admin/           trashschedule.admin/
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064-community.admin/
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ ls -l
                    total 92
                    -rw-rwxr--+  1 iobroker iobroker  3035 Jan 10  2021 _data.json
                    drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 20  2020 i18n
                    -rw-rwxr--+  1 iobroker iobroker 21842 Jan 20  2020 index.html
                    -rw-rwxr--+  1 iobroker iobroker 22279 Jan 20  2020 index_m.html
                    -rw-rwxr--+  1 iobroker iobroker 30797 Jan 20  2020 words.js
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064-community.admin$ cd ..
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files$ cd tr-064.admin/
                    proxmox@ioBrokerTestsystem:/opt/iobroker/iobroker-data/files/tr-064.admin$ ls -l
                    total 100
                    -rw-rwxr--+  1 iobroker iobroker  3103 Feb  4 18:48 _data.json
                    drwxrwxr-x+ 12 iobroker iobroker  4096 Jan 24  2020 i18n
                    -rw-rwxr--+  1 iobroker iobroker 21822 Jan 27  2020 index.html
                    -rw-rwxr--+  1 iobroker iobroker 28639 Feb  3 22:04 index_m.html
                    -rw-rwxr--+  1 iobroker iobroker  1736 Feb  3 22:04 tr-064.png
                    -rw-rwxr--+  1 iobroker iobroker 34320 Feb  3 22:04 words.js
                    • foxriver76
                      @feuersturm dann passt die Meldung ja: please remove directory 👍🏼
                      • wendy2702
                        wendy2702 @apollon77 last edited by
                        Ok.
                        Schaffe ich hoffentlich morgen einzuspielen
                          darkiop Most Active last edited by
                          Guten Abend, hatte bis heute leider keine Zeit den neuen 4.0.0 zu testen.
                          Eben aber direkt mein P-System (redis/redis + node14 / npm6) umgestellt. Melde mich bei Auffälligkeiten.
                            apollon77 last edited by apollon77
                            Hallo alle zusammen,
                            ich habe @next nochmals aktualisiert mit der 4.0.3, was die geplante Beta/Latest version für heute Nachmittag/Abend ist. Meine Tests sehen soweit gut aus.
                            Von daher wäre cool wenn Ihr, wie Zeit, es nochmal bei euch aktualisiert - dann habt Ihr auch gleich die Latest Version drauf 🙂
                            Änderungen sind minimaler Kleinkram und Fixes der noch gemeldet wurde (und einige Version haben wir "verloren" weil der Release-Prozess nicht so wollte wie wir 😉 )
                            • (foxriver76) Fix user-group objects with invalid member list - reported by @wendy2702
                            • (foxriver76) Fix multihost commands - reported in GitHub
                            • (foxriver76) Fix meto object check/sync to prevent false positive logs
                            L Feuersturm 2 Replies Last reply Reply Quote 0
                              lonsimbt @apollon77 last edited by
                              @apollon77
                              Ich war mal so mutig und habe die 4.0.3 auf mein Produktivsystem losgelassen (ein Hoch auf proxmox und die Möglichkeit von snapshots). Dabei sind folgende Meldungen noch hochgekommen:
                              - Ignoring Directory "gartenbewaesserung.admin" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "robonect.admin" because officially not created as meta object. Please remove directory!
                              Beide Adapter sind zzt. nicht in Benutzung. Können die Ordner tatsächlich gefahrlos gelöscht werden?
                              Ferner folgende Warnungen im Log:
                              shuttercontrol.0
                              	2022-02-05 11:15:36.840	warn	This object will not be created in future versions. Please report this to the developer.
                              shuttercontrol.0
                              	2022-02-05 11:15:36.839	warn	Object shuttercontrol.0.info.Azimut is invalid: Default value has to be type "number" but received type "string"
                              shuttercontrol.0
                              	2022-02-05 11:15:36.832	warn	This object will not be created in future versions. Please report this to the developer.
                              shuttercontrol.0
                              	2022-02-05 11:15:36.830	warn	Object shuttercontrol.0.info.Elevation is invalid: Default value has to be type "number" but received type "string"
                              mqtt.0
                              	2022-02-05 11:15:00.871	warn	This object will not be created in future versions. Please report this to the developer.
                              mqtt.0
                              	2022-02-05 11:15:00.870	warn	Object mqtt.0.info.connection is invalid: Default value has to be type "string" but received type "boolean"
                              Issue beim Adapter erstellen?
                              Gruß Marco
                              simatec apollon77 foxriver76 3 Replies Last reply Reply Quote 0
                              • simatec
                                simatec Developer Most Active @lonsimbt last edited by
                                @lonsimbt
                                Für Shuttercontrol gibt es dazu bereits ein Issue
                                  apollon77 @lonsimbt last edited by
                                  @lonsimbt korrekt. Fehlende issue Bitte erstellen. Zu den beiden Verzeichnissen: wenn du da aktuell keine Instanzen hast dann kannst du das löschen.
                                  • foxriver76
                                    foxriver76 Developer @lonsimbt last edited by
                                    @lonsimbt sagte in Alpha Test js-controller 4.0:
                                    Ich vermute die Adapter sind derzeit nicht mal installiert?
                                    apollon77 L 2 Replies Last reply Reply Quote 0
                                    • Feuersturm
                                      @apollon77 Habe gerade einmal ein update auf die 4.0.3 gemacht.
                                      Gestern abend hatte ich noch ein apt update / upgrade gemacht, wobei auch nodejs aktualisiert wurde. Aktuelle node und npm Version:
                                      proxmox@ioBrokerTestsystem:/opt/iobroker$ node -v
                                      v14.19.0
                                      proxmox@ioBrokerTestsystem:/opt/iobroker$ npm -v
                                      6.14.16
                                      Beim Update gab es diese Fehlermeldungen. Haben sie was zu bedeuten?
                                      Die IP 192.168.178.78 ist der ioBroker Slave. Ich habe gerade den Master aktualisiert, der Slave (js-controller 4.0 alpha 73) lief aber.
                                      Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.cputime: The database is not open!
                                      Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.mem: The database is not open!
                                      Server Objects 192.168.178.78:60268 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerNew.memHeapUsed: The database is not open!
                                      Hier die vollständie Ausgabe vom Update
                                      proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next
                                      [sudo] password for proxmox:
                                      > iobroker.js-controller@4.0.3 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                      > node lib/preinstallCheck.js
                                      NPM version: 6.14.16
                                      > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
                                      > node-gyp rebuild
                                      make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                                        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                      In file included from ../src/unix_dgram.cc:5:
                                      ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
                                      ../../nan/nan.h:2294:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
                                       2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                      In file included from ../../nan/nan.h:56,
                                      ../src/unix_dgram.cc: At global scope:
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                        793 |       (node::addon_register_func) (regfunc),                          \
                                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
                                        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                      ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                                        404 | NODE_MODULE(unix_dgram, Initialize)
                                        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                        COPY Release/unix_dgram.node
                                      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                                      > iobroker.js-controller@4.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
                                      > node iobroker.js setup first
                                      object _design/system updated
                                        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nV9blMZ0EBC/006ZLnsA6QLs0SqruVgPQbUjLP5Q7F4Dmudz9swxpuT0=\r\n-----END RSA PRIVATE KEY-----\r\n",
                                        "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\n0F41Cw5EmdU=\r\n-----END CERTIFICATE-----\r\n"
                                      Update certificate defaultPrivate
                                      The object "system.certificates" was updated successfully.
                                      Update certificate defaultPublic
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      + iobroker.js-controller@4.0.3
                                      removed 19 packages and updated 14 packages in 102.06s
                                      43 packages are looking for funding
                                        run `npm fund` for details
                                      Github issue
                                      https://github.com/ioBroker/ioBroker.js-controller/issues/1746
                                      Feuer-sturm created this issue in ioBroker/ioBroker.js-controller
                                      closed Error from InMemDB: Error: ERROR setObject id xxx The database is not open! #1746
                                      apollon77 2 Replies Last reply Reply Quote 1
                                        A Former User @apollon77 last edited by A Former User
                                        @apollon77
                                        eben auch auf js-controller 4.03 mal gegangen, iobroker laeuft, kam beim update hier was :
                                        ilovegym@VMC123-iobroker /opt/iobroker $ npm i iobroker.js-controller@next
                                        NPM version: 6.14.15
                                        > node-gyp rebuild
                                        /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                        /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X'
                                        Fehler kommt auf den Raspis als Multihost-slave ebenfalls..
                                        Thomas Braun apollon77 F 3 Replies Last reply Reply Quote 0
                                          @feuersturm ok der iobrokernew ist der Slave oder ist das der Master?und wo lief das Update? Zu wem gehört die genannte ip?
                                            @ilovegym
                                            Welcher Fehler? Das sind ganz normale build messages
                                            196
                                            25956
