    4. Installation unter Debian 11 Bullseye
      heiner1976 last edited by heiner1976
      @jan1
      Danke für die Antwort! Ich hatte die Node Version aus der alten Installation im Kopp. 😞 Sorry Du hast recht 🙂
      • wendy2702
        Ist ja noch nicht so alt hier.
        Versuche gerade unter Proxmox 6.4-13 in einem CT mit Bullseye iobroker zu installieren.
        Jetzt schaue ich schon seit ca. 30 minuten auf diese Anzeige:
        mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2021-12-27
            Welcome to the ioBroker installer!
            Installer version: 2021-12-27
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://ftp.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org bullseye-security InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
        Reading package lists... Done
            Node.js not found. Installing...
        ## Installing the NodeSource Node.js 14.x repo...
        ## Populating apt-get cache...
        + apt-get update
        ## Installing packages required for setup: lsb-release gnupg...
        + apt-get install -y lsb-release gnupg > /dev/null 2>&1
        ## Confirming "bullseye" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
        ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Get:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
        Get:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
        Fetched 5359 B in 1s (5365 B/s)
        ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
        ## You may also need development tools to build native addons:
             sudo apt-get install gcc g++ make
        ## To install the Yarn package manager, run:
             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
             sudo apt-get update && sudo apt-get install yarn
        Installed nodejs
        Node.js Installed successfully!
        Changing npm registry to https://registry.npmjs.org
        Installed acl
        Installed build-essential
        Installed gcc-c++
        Installed libavahi-compat-libdnssd-dev
        Installed libudev-dev
        Installed libpam0g-dev
        Installed git
        Installed unzip
        Installed libcairo2-dev
        Installed libpango1.0-dev
        Installed libjpeg-dev
        Installed libgif-dev
        Installed librsvg2-dev
        Installed net-tools
        Installed python-dev
        Installed cmake
            Creating ioBroker user and directory (2/4)
        User iobroker created
        Created /etc/sudoers.d/iobroker
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
        [#.................] - fetchMetadata: sill pacote range manifest for is-fullwidth-code-point@^1.0.0 fetched in 41ms
        Und nichts passiert.
        • AlCalzone
          AlCalzone Developer @wendy2702 last edited by
          @wendy2702 sagte in Installation unter Debian 11 Bullseye:
          fetchMetadata
          Kommt von npm was gerade etwas installieren will und dafür Informationen aus dem Netz lädt. Könnte sein, dass dein Internet gerade etwas hängt.
          • wendy2702
            wendy2702 @AlCalzone last edited by
            @alcalzone Hm...
            mir ist bei keiner anderen Anwendung ein hänger aufgefallen.
            2 VPN Verbindungen ohne Unterbrechung
            Teams Meeting ohne Unterbrechung
            Live Stream ohne Unterbrechung
            Aber egal, habe es neu gestartet und der zweite Versuch lief durch
            • AlCalzone
              @wendy2702 Vielleicht lags auch an der Gegenstelle... Passiert bei mir manchmal auch abseits von ioBroker.
              • NT_Olli
                NT_Olli @heiner1976 last edited by
                Hallo @heiner1976 ich habe gerade ähnliches vor wie von Dir oben beschrieben.
                Ich habe heute eine aktuelle Debian 11 Installation auf einem amd64 System aufgesetzt. Vor dem Versuch ein ioBroker zu installieren habe ich nur den openmediavault und den Logitech MEdia Server 8.2.0 installiert.
                Halte ich mich an die Anleitung auf https://www.iobroker.net/#de/documentation/install/linux.md bekomme ich neben den von Dir geposteten Warnings auch noch folgende Zeilen:
                npm ERR! code ELIFECYCLE
                npm ERR! errno 22
                npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                npm ERR! Exit status 22
                npm ERR!
                npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
                npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                Eine Recherche im web hat ergeben, dass es wohl beim Update des js-controllers dieses Problem geben kann. Leider haben die Hinweise zur Bewältigung kein Erfolg gebracht und der ioBroker startet nicht.
                root@homeserver:/opt/iobroker# node -v
                v14.19.0
                root@homeserver:/opt/iobroker# nodejs -v
                v14.19.0
                root@homeserver:/opt/iobroker# npm -v
                6.14.16
                Weiß jemand Rat?
                Vorab vielen Dank und viele Grüße,
                Olli
                  Thomas Braun Most Active @NT_Olli last edited by Thomas Braun
                  @dh2wq sagte in Installation unter Debian 11 Bullseye:
                  Weiß jemand Rat?
                  Ja.
                  Nicht als root rumhampeln wäre der erste Rat.
                  Der zweite: Mehr Output aus der Konsole posten.
                  Der dritte: npm cache löschen
                  • NT_Olli
                    Danke für den schnellen Rat,
                    leider hat das rumhampeln per sudo in den scripten das gleiche Ergebnis. Der Vollständigkeit habe ich auch wie geraten die komplette Ausgabe bis auf das abklappern der Quellen gepostet. Der NPM cache wurde vorher auch noch mal geleert.
                    olli@openmediavault:~$ curl -sL https://iobroker.net/install.sh | bash -
                    library: loaded
                    Installed gcc-c++
                    In file included from ../../nan/nan.h:58,
                                     from ../src/main.cpp:3:
                    /home/olli/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast betw        een incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node:        :addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>        , void*)’} [-Wcast-function-type]
                      793 |       (node::addon_register_func) (regfunc),                          \
                    /home/olli/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion        of macro ‘NODE_MODULE_X’
                      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_        usage)
                    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                       42 | NODE_MODULE(diskusage, Init)
                                     from ../src/unix_dgram.cc:5:
                    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                      404 | NODE_MODULE(unix_dgram, Initialize)
                    npm ERR! errno 22
                    npm ERR!
                    npm ERR!     /home/olli/.npm/_logs/2022-02-04T21_40_48_160Z-debug.log
                        Finalizing installation (4/4)
                    Enabling autostart...
                    Autostart enabled!
                    Fixing directory permissions...
                        ioBroker was installed successfully
                        Open http://192.168.2.10:8081 in a browser and start configuring!
                    You need to re-login before doing anything else on the console!
                    Thomas Braun AlCalzone 2 Replies Last reply Reply Quote 0
                      @nt_olli
                      Jetzt ist der Hostname anders.
                      NT_Olli 1 Reply Last reply Reply Quote 0
                      • NT_Olli
                        NT_Olli @Thomas Braun last edited by
                        Richtig, gleiche Machine, nur eine Änderung aus der GUI des openmediavaults raus und der gewünschte user.
                          @nt_olli
                          So ganz verstehe nicht wie das Ding da bei dir aufgesetzt ist.
                          • AlCalzone
                            AlCalzone Developer @NT_Olli last edited by
                            @nt_olli sagte in Installation unter Debian 11 Bullseye:
                            Steht da ggf. mehr drin?
                            • NT_Olli
                              NT_Olli @AlCalzone last edited by
                              Guten Morgen @alcalzone,
                              ja da steht mehr drin. Ich denke der letzte Teil könnte Aufschluss geben:
                              5889 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                              5890 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
                              5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
                              5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
                              5891 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
                              5892 verbose stack Error: iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                              5892 verbose stack Exit status 22
                              5892 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                              5892 verbose stack     at EventEmitter.emit (events.js:400:28)
                              5892 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                              5892 verbose stack     at ChildProcess.emit (events.js:400:28)
                              5892 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                              5892 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                              5893 verbose pkgid iobroker.js-controller@3.3.22
                              5894 verbose cwd /opt/iobroker
                              5895 verbose Linux 5.10.0-11-amd64
                              5896 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--loglevel" "error" "--unsafe-perm"
                              5897 verbose node v14.19.0
                              5898 verbose npm  v6.14.16
                              5899 error code ELIFECYCLE
                              5900 error errno 22
                              5901 error iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                              5901 error Exit status 22
                              5902 error Failed at the iobroker.js-controller@3.3.22 install script.
                              5902 error This is probably not a problem with npm. There is likely additional logging output above.
                              5903 verbose exit [ 22, true ]
                              Da ich nicht weiß ob in den Ausgaben weiter ober mehr Inhalt steckt die ganze Datei:
                              Schonmal Dank für alle Mhen mir zu helfen. Um die Verwirrung des umsystems zu lösen, kann ich es ggf. nochmal ohne die openmediavault aufsetzen.
                              • NT_Olli
                                NT_Olli @NT_Olli last edited by
                                Guten Morgen,
                                da ich ja noch eine laufende Lösung auf meinem PI 2 habe is es nicht kritisch und ich habe es mit einem neuen sauberen Ubuntu Server 20.04.3 LTS installiert und auch den openmediavault erstmal unten gelassen. Leider kommt es zur genau gleichen Fehlermeldung.
                                Ich werde es jetzt nochmal in einer VM probieren.
                                • NT_Olli
                                  da auf den physischen Maschinen als erstes der logitechmediaserver (lms) installiert wurde, habe ich diese Möglichkeit leider übersehen. Tausche ich die Installationsreihenfolge, macht dann der lms beim Starten Probleme.
                                  Die Fehlermeldung ist hier aber für mich verständlicher. Hier finde ich die Information, dass der Port 9000 schon belegt ist.
                                  Daraufhin habe ich im lms den Port auf 9002 geändert und schon geht es.
                                  Ein Test auf der physischen Maschine hat gezeigt, dass sich nun der js-controller installieren lässt.
                                  Wenn möglich, wäre eine Fehlerausgabe in diese Richtung hilfreich.
                                  Viele Grüße,
                                  Olli
                                    Homoran Global Moderator Administrators @NT_Olli last edited by
                                    Welche Richtung?
                                    Ich bin mir sicher, dass beim Start (nach der Inst) im log der Hinweis auf den belegten Port steht
                                    so in der Art:
                                    2022-02-06 08:17:27.035  - error: backitup.0 (1445) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                    2022-02-06 08:17:27.235  - error: backitup.0 (1445) States database error: connect ECONNREFUSED 127.0.0.1:9000
                                    • NT_Olli
                                      NT_Olli @Homoran last edited by NT_Olli
                                      ich konnte das setup script zur Installation ja nicht erfolgreich durchführen, da der Port schon belegt war. Da ich mit ps auch kein laufenden iobroker gesehen habe, bin ich davon ausgegangen das ich hier gar nicht in die logs schauen muss.
                                      Meine Debugfähigkeiten haben bei error Failed at the iobroker.js-controller@3.3.22 install script. aufgehört.
                                      Hätte ich hier einen Hinweis in die Richtung belegter Port gefunden, wäre ich vermutlich weiter gekommen. Im Ende ist ja auch alles gelöst. Ich kenne mich auch nur bedingt mit den Details aus und bin über die Unterstützung der Community sehr dankbar.
                                      Viele Grüße
                                        @nt_olli Ich verstehe!
                                        Das Installationsskript könnte man mit Sicherheit aufbohren. Aber bis wohin??
                                        Jetzt die Ports, später was noch alles?
                                        Die Installationsroutinen gehen davon aus, dass noch nichts anderes auf dem Server läuft.
                                        Ähnliche Diskussionen gab es auch bereits für andere, ich will mal sagen Custom-Betriebssysteme, wo wür deren Installation einiges anders war, als es bei dem selben nativen OS gewesen wäre.
                                        Im Prinzip gehen wir davon aus, dass wenn jemand es nicht auf einem eigenen System installiert, weiß was er hat und tut.
                                        Du könntest ein Feature Request in Form eines Issues erstellen, damit die Idee nicht verloren geht
                                        • AlCalzone
                                          AlCalzone Developer @Homoran last edited by
                                          @homoran Wir haben tatsächlich einen offenen PR, der genau das checken soll. Müsste man mal fertig stellen.
                                          3912
