    4. Alpha Test js-controller 4.0
      A Former User @apollon77 last edited by A Former User
      @apollon77
      eben auch auf js-controller 4.03 mal gegangen, iobroker laeuft, kam beim update hier was :
      ilovegym@VMC123-iobroker /opt/iobroker $ npm i iobroker.js-controller@next
      > iobroker.js-controller@4.0.3 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.15
      > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      In file included from ../../nan/nan.h:56,
                       from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X'
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
       NODE_MODULE(unix_dgram, Initialize)
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
      > iobroker.js-controller@4.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      object _design/system updated
      Fehler kommt auf den Raspis als Multihost-slave ebenfalls..
      Thomas Braun apollon77 F 3 Replies Last reply Reply Quote 0
        apollon77 @Feuersturm last edited by
        @feuersturm ok der iobrokernew ist der Slave oder ist das der Master?und wo lief das Update? Zu wem gehört die genannte ip?
          @ilovegym
          Welcher Fehler? Das sind ganz normale build messages
            apollon77 @Guest last edited by
            @ilovegym keine Fehler. Sind die üblichen Warnungen die manchmal kommen wenn native Pakete gebaut werden. Wie immer ignore. Es ist ja alles durchgelaufen
            • Feuersturm
              Feuersturm @apollon77 last edited by
              @apollon77 sagte in Alpha Test js-controller 4.0:
              @apollon77 iobrokernew ist der Slave mit der IP 192.168.178.78. Das update lief auf dem Master "ioBrokerTestsystem" mit der IP 192.168.178.77
                Fortune95 @Guest last edited by
                @apollon77
                Upadate auf 4.0.3 lief mit den bereits bekannten Warnungen von den Adaptern Yamaha, Shelly und shuttercontrol durch. 👍
                Braucht der neue js-controller weniger Speicher?
                  A Former User @Thomas Braun last edited by
                  @thomas-braun oh , ich meine das warning incompatible function types.. ok, wenn das so sein soll, soll mir recht sein, geht ja auch alles.. 🙂
                    @feuersturm also wenn das das Update vom Master war und der Slave noch lief Bzw sich neu gestartet hat dann kann sowas ggf passieren.
                    Feuersturm Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Feuersturm
                      Ok. Slave lief in diesem Falle noch.
                        Thomas Braun Most Active @apollon77 last edited by
                        @apollon77
                        Hab auch 4.0.3 laufen. Keine Auffälligkeiten hier.
                          apollon77 @Fortune95 last edited by
                          @fortune95 Speicherverbrauchstechnisch haben wir nicht wirklich etwas geändert wenn ich mich recht entsinne. Und daher: kann gut sein, wäre interessant ;-)) beobachte es mal
                            @feuersturm machst bitte trotzdem ein github issue. Will mir das ansehen
                            F Feuersturm 2 Replies Last reply Reply Quote 0
                              Fortune95 @apollon77 last edited by
                              @apollon77
                              Ok, werde ich weiter beobachten. Aktuell etwas über 1GB weniger :-))
                                @apollon77 hab auch 1GB weniger in use...
                                  apollon77 @foxriver76 last edited by
                                  @foxriver76 wäre auch meine Vermutung. Sonst upload all mal machen
                                    Thomas Braun Most Active @Fortune95 last edited by
                                    @fortune95 sagte in Alpha Test js-controller 4.0:
                                    Nach so kurzer uptime kannst du das eher nicht beurteilen. Schau nach ein paar Stunden nochmal danach.
                                    • Feuersturm
                                      Erledigt, ist in meinem obigen Post verlinkt.
                                      • Feuersturm
                                        @apollon77
                                        Ich hab gerade den Slave (iobrokerNew) ebenfalls auf 4.0.3 aktualisiert.
                                        Danach hab ich mal den Master per iobroker stop ausgeschaltet. Der Slave meldet berechtigterweise
                                        host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                        danach hab ich den Master wieder gestartet. Beim hochfahren war im Log folgende Warnungen / Fehler vom Master / Slave im Log
                                        05 Feb 2022 12:09:23.686
                                        iobrokerTestsystemSlave host.ioBrokerNew Could not execute primary host determination: Error Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
                                        05 Feb 2022 12:09:23.683
                                        05 Feb 2022 12:09:23.678
                                        iobrokerTestsystem host.ioBrokerTestsystem-Server Objects 192.168.178.78:48414 Error from InMemDB: Error: Unknown Script b0bd9e6fd92479ccf43654a7ba7443c915d0a742
                                        05 Feb 2022 12:09:23.675
                                        iobrokerTestsystemSlave host.ioBrokerNew States database error: connect ECONNREFUSED 192.168.178.77:9000
                                        Vollständiges Log:
                                        05 Feb 2022 12:09:30.646
                                        iobrokerTestsystem admin.0 (26234) requesting all objects
                                        05 Feb 2022 12:09:30.644
                                        iobrokerTestsystem admin.0 (26234) requesting all states
                                        05 Feb 2022 12:09:30.554
                                        iobrokerTestsystem admin.0 (26234) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.3
                                        05 Feb 2022 12:09:30.327
                                        iobrokerTestsystem host.ioBrokerTestsystem instance system.adapter.javascript.0 started with pid 26245
                                        05 Feb 2022 12:09:28.683
                                        iobrokerTestsystemSlave host.ioBrokerNew Objects database successfully reconnected
                                        05 Feb 2022 12:09:26.363
                                        iobrokerTestsystem host.ioBrokerTestsystem instance system.adapter.admin.0 started with pid 26234
                                        05 Feb 2022 12:09:26.110
                                        iobrokerTestsystem host.ioBrokerTestsystem starting 29 instances
                                        05 Feb 2022 12:09:25.968
                                        iobrokerTestsystem host.ioBrokerTestsystem 58 instances found
                                        05 Feb 2022 12:09:24.957
                                        iobrokerTestsystem host.ioBrokerTestsystem added notifications configuration of host
                                        05 Feb 2022 12:09:24.923
                                        iobrokerTestsystem host.ioBrokerTestsystem connected to Objects and States
                                        05 Feb 2022 12:09:23.585
                                        05 Feb 2022 12:09:22.215
                                        iobrokerTestsystem host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
                                        05 Feb 2022 12:09:22.212
                                        iobrokerTestsystem host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v14.19.0
                                        05 Feb 2022 12:09:22.210
                                        iobrokerTestsystem host.ioBrokerTestsystem Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        05 Feb 2022 12:09:22.204
                                        iobrokerTestsystem host.ioBrokerTestsystem iobroker.js-controller version 4.0.3 js-controller starting
                                        05 Feb 2022 12:09:18.668
                                        05 Feb 2022 12:09:18.576
                                        iobrokerTestsystemSlave host.ioBrokerNew Objects database error: connect ECONNREFUSED 192.168.178.77:9001
                                        05 Feb 2022 12:09:13.660
                                        05 Feb 2022 12:09:13.569
                                        • MalleRalle
                                          MalleRalle last edited by
                                          Hier mit der 4.0.3 auch alles ordentlich durchgelaufen.
                                            @feuersturm aber danach tat alles oder? Mach auch mal issue. Schauen wir uns an.
                                            196
                                            25895
