    3. Einsteigerfragen
    4. SONOFF ZigBee 3.0 USB DONGLE in Docker
    • Glasfaser
      Glasfaser @edz last edited by
      @edz
      Hier :
      und so hier dargestellt :
      2022-02-05 20:29:36.043 - info: zigbee.0 (18548) cleaned everything up...
      2022-02-05 20:29:36.070 - info: zigbee.0 (18548) Zigbee: disabling joining new devices.
      2022-02-05 20:29:36.547 - info: zigbee.0 (18548) terminating
      2022-02-05 20:29:36.550 - info: zigbee.0 (18548) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-02-05 20:29:37.090 - info: host.iobrokerv6 stopInstance system.adapter.zigbee.0 killing pid 18548
      2022-02-05 20:29:37.398 - info: host.iobrokerv6 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-05 20:29:39.174 - info: host.iobrokerv6 instance system.adapter.zigbee.0 started with pid 8159
      2022-02-05 20:29:48.615 - info: zigbee.0 (8159) starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
      2022-02-05 20:29:49.000 - info: zigbee.0 (8159) Starting Zigbee npm ...
      2022-02-05 20:29:49.716 - info: zigbee.0 (8159) Installed Version: iobroker.zigbee@1.6.14
      2022-02-05 20:29:49.879 - info: zigbee.0 (8159) Coordinator firmware version: {"type":"zStack30x","meta":
        edz @Glasfaser last edited by
        @glasfaser
        zigbee.0 2022-02-05 20:29:37.890 error getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
        Ist die einzige Zeile die drinnen steht
        • Glasfaser
          Glasfaser @edz last edited by Glasfaser
          @edz
          Das error sagt mir gerade nicht viel .
          Starte die Instanz mal neu , da sollte mehr drin stehe ..
          ist der Stick verbunden usw...
            @glasfaser
            zigbee.0
            2022-02-05 20:43:36.295 error Error herdsman start
            zigbee.0
            2022-02-05 20:43:36.295 error Failed to start Zigbee
            zigbee.0
            2022-02-05 20:43:36.294 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0
            2022-02-05 20:43:36.058 info Installed Version: iobroker.zigbee@1.6.6
            zigbee.0
            2022-02-05 20:43:36.043 info Starting Zigbee npm ...
            zigbee.0
            2022-02-05 20:43:36.042 info Try to reconnect. 1 attempts left
            zigbee.0
            2022-02-05 20:43:26.040 error Error herdsman start
            zigbee.0
            2022-02-05 20:43:26.039 error Failed to start Zigbee
            zigbee.0
            2022-02-05 20:43:26.039 error Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
            zigbee.0
            2022-02-05 20:43:25.925 error Re-commissioning your network will require re-pairing of all devices!
            zigbee.0
            2022-02-05 20:43:25.924 error If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
            zigbee.0
            2022-02-05 20:43:25.924 error Please update configuration to prevent further issues.
            zigbee.0
            2022-02-05 20:43:25.924 error - Channel List: configured=11, adapter=11
            zigbee.0
            2022-02-05 20:43:25.923 error - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
            zigbee.0
            2022-02-05 20:43:25.923 error - Extended PAN ID: configured=00124b0024c94b24, adapter=00124b0024c94b24
            zigbee.0
            2022-02-05 20:43:25.922 error - PAN ID: configured=6754, adapter=6752
            zigbee.0
            2022-02-05 20:43:25.921 error Configuration is not consistent with adapter state/backup!
            zigbee.0
            2022-02-05 20:43:25.775 info Installed Version: iobroker.zigbee@1.6.6
            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @edz last edited by
              @edz sagte in SONOFF ZigBee 3.0 USB DONGLE in Docker:
              Angleichen.
              • Glasfaser
                Adapter stoppen ... und
                  @glasfaser
                  Ich habe beim Zigbee Adapter ganz unten den Haken gesetzt, jetzt alles auf Grün !😊 👏 👏
                  Danke , nochmal für die Hilfe
                  grüsse
                  • Glasfaser
                    Meinst du hier :
                      edz @Glasfaser last edited by edz
                      @glasfaser
                      Ganz unten
                        @edz
                        Du hättest auch ganz einfach und sauber die PAN-Id anpassen können.
                        1.2k
                        4764
