    4. js-controller 4.0 jetzt im BETA/LATEST!
      apollon77 @e-i-k-e last edited by
      @e-i-k-e hi, hier muss der binäre Teil neu ge auth. werden. Hast du mal da volle log? An sich sollte er jetzt bis zu drei mal versuchen über rebuilds das zu fixen
      • ice987
        ice987 last edited by
        ich hab' mich auch versucht mit dem
        System: ioBroker.docker v6.0.0
        und erhalte folgende Fehlermeldung:
        root@iobroker-v600-testsystem7:/opt/iobroker# pkill -u iobroker
        root@iobroker-v600-testsystem7:/opt/iobroker# iobroker update
        Used repository: latest
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 5.2.3    , installed 5.1.25 [Updateable]
        Controller "js-controller" : 4.0.4    , installed 3.3.21 [Updateable]
        root@iobroker-v600-testsystem7:/opt/iobroker# iobroker upgrade self
        Update js-controller from @3.3.21 to @4.0.4
        NPM version: 6.14.16
        npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
        In file included from ../../nan/nan.h:58,
                         from ../src/unix_dgram.cc:5:
        /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          793 |       (node::addon_register_func) (regfunc),                          \
        /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
          404 | NODE_MODULE(unix_dgram, Initialize)
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
        Server States 127.0.0.1:45560 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
        Server States 127.0.0.1:45562 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: Unknown LUA script load
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: multi NOT SUPPORTED
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: sadd NOT SUPPORTED
        Server Objects 127.0.0.1:36016 Error from InMemDB: Error: exec NOT SUPPORTED
        This upgrade of "admin" will introduce the following changes:
        -> 5.2.3:
        Fixed error in `AutocompleteSendTo`
        Fixed error in charts
        -> 5.2.2:
        Changed the minimal required js-controller version to 3.3.22
        Used web-socket library 8 (no node 10 support anymore)
        -> 5.2.1:
        Allow in expert mode the creation of states and channels in mqtt branch
        -> 5.2.0:
        Fix crash cases reported via sentry
        Added support for multi-repositories
        -> 5.1.29:
        -> 5.1.28:
        Fixed discovery function
        Fixed some GUI bugs
        Would you like to upgrade admin from @5.1.25 to @5.2.3 now? [(y)es, (n)o]: y
        Update admin from @5.1.25 to @5.2.3
        host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is stopped.
        Installing iobroker.admin@5.2.3... (System call)
        + iobroker.admin@5.2.3
        updated 7 packages in 32.186s
        17 packages are looking for funding
          run `npm fund` for details
        host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is started
        Update "system.adapter.admin.0"
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        root@iobroker-v600-testsystem7:/opt/iobroker# iobroker start
        Starting iobroker controller daemon...
        iobroker controller daemon started. PID: 1425
        ioBroker ist nicht zu erreichen
        apollon77 ste_glei 2 Replies Last reply Reply Quote 0
          apollon77 @ice987 last edited by
          @ice987 ok was steht im log? Ich Seherin den Ausgaben keine Fehler. Da ist an sich alles ok
          ice987 1 Reply Last reply Reply Quote 0
          • ice987
            ice987 @apollon77 last edited by
            @apollon77
            der Restart vom Container ergibt nun:
            -------------------------     2022-02-06 15:04:25      -------------------------
            -----                 Welcome to your ioBroker-container!                  -----
            -----                    Startupscript is now running.                     -----
            -----                          Please be patient!                          -----
            -----                        Debugging information                         -----
            -----                                System                                -----
            -----                    arch:                x86_64                       -----
            -----                             Docker-Image                             -----
            -----                    image:               v6.0.0                       -----
            -----                    build:               2021-12-17T03:48:21+00:00    -----
            -----                               Versions                               -----
            -----                    /opt/scripts/iobroker_startup.sh: line 48: /usr/bin/node: Operation not permitted
            node:                                             -----
            -----                    /usr/bin/env: ‘node’: Operation not permitted
            npm:                                              -----
            -----                                 ENV                                  -----
            -----                    SETGID:              1000                         -----
            -----                    SETUID:              1000                         -----
            -----                  Step 1 of 5: Preparing container                   -----
            Nothing to do here.
            -----             Step 2 of 5: Detecting ioBroker installation             -----
            Existing installation of ioBroker detected in /opt/iobroker.
            -----             Step 3 of 5: Checking ioBroker installation              -----
            (Re)Setting folder permissions (This might take a while! Please be patient!)...
            Done.
            Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
            Done.
            error: exec failed: operation not permitted
            /opt/scripts/iobroker_startup.sh: line 199: [: !=: unary operator expected
            -----                Step 4 of 5: Applying special settings                -----
            Some adapters have special requirements/ settings which can be activated by the use of environment variables.
            For more information take a look at readme.md on Github!
            -----                    Step 5 of 5: ioBroker startup                     -----
            Starting ioBroker...
              apollon77 @Chaot last edited by
              @chaot was ist denn de ubuntu Adapter? Und was gefällt ihm nicht?
              • ste_glei
                ste_glei @ice987 last edited by
                @ice987
                Ich hatte den gleichen log
                iobroker fix
                hat geholfen
                  e-i-k-e @apollon77 last edited by
                  @apollon77
                  anbei wie gewünscht die komplette log.
                  b04d2521-d6ec-46a9-ab5a-18d5ad80331e-iobroker.2022-02-06.log
                  • ice987
                    ice987 @ste_glei last edited by
                    @ste_glei
                    kann ich bestätigen:
                    iobroker fix
                    hilft und ioBroker läuft nun
                    apollon77 E 2 Replies Last reply Reply Quote 0
                    • Chaot
                      Chaot @apollon77 last edited by
                      @apollon77 Das ist ne uralte Leiche die mitgelaufen ist.
                      https://github.com/Standarduser/ioBroker.ubuntu
                      Ist mir nie aufgefallen dass das noch aktiv ist.
                      Meinerseits bereits entsorgt, da überflüssig.
                      Ausgegebener Fehler:
                      ubuntu.0
                      2022-02-06 12:57:13.847	error	Cannot read property 'getObjectList' of undefined
                      ubuntu.0
                      2022-02-06 12:57:13.846	error	TypeError: Cannot read property 'getObjectList' of undefined at Object.ready (/opt/iobroker/node_modules/iobroker.ubuntu/main.js:35:25) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8225:68
                      ubuntu.0
                      2022-02-06 12:57:13.842	error	unhandled promise rejection: Cannot read property 'getObjectList' of undefined
                      ubuntu.0
                      2022-02-06 12:57:13.837	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      amg_666 apollon77 2 Replies Last reply Reply Quote 1
                      • amg_666
                        amg_666 @Chaot last edited by
                        Eben den latest/Beta runtergeladen, einmal Raspi Slave, ohne Probleme und danach auf Proxmox/Debian, biedes ohne irgendwelche Probleme.
                          @chaot Naja,d er Hätte mit controller 3.x schon Fehler wegen "adapter.objects.getObjectList" loggen müssen und muss angepasst werden. Leg doch mal ein issue an
                            @ice987 Verstehe ich nicht weil der Container macht eigentlich genauein Fix beim startup soweit ich weiss ... also das wäre interessant das sich das Andre mal anschaut
                            ice987 F 3 Replies Last reply Reply Quote 0
                              @e-i-k-e Ahhh der RPI2 Adapter ist "zu nett" und fängt den Fehler so ab das der Rebuild Mechanismus vom Controller nicht greifen kann. Willste mal was versuchen?
                              Editiere mal /opt/iobroker/node_modules/iobroker.rp2/main.js und füge bei Zeile 648 das hinzu https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/master/main.js#L648
                              Danach bitte adapter neu starten ... Dann schauen wir mal was das System so macht. Hätte dann gern das log. Also er sollte - wenn er sich dann wegen dem Folgefehler beendet - der Controller sagen das er rebuild machen will ... bis zu 3x !!
                              frankthegreat E 2 Replies Last reply Reply Quote 1
                              • Chaot
                                @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                .... Leg doch mal ein issue an
                                Beim Adapter? Der wird scheinbar seit 3 Jahren nicht mehr gepflegt bzw. ist nie über die eine Version hinausentwickelt worden. Letzte Aktivität 20.01.2019
                                Ist eher sinnlos. Löschen und nicht darüber nachdenken.
                                  @chaot Jo ... aber dann sehen es andere das es bekannt ist 🙂
                                  • frankthegreat
                                    frankthegreat @apollon77 last edited by
                                    @apollon77
                                    Update auf 4.0.4 auf meinem Testsystem sauber durchgelaufen. 👍
                                    Was mir auf die Schnelle aufgefallen ist:
                                    Die "Clean" Befehle zicken rum. Weis aber nicht, ob es damit zusammenhängt. Mit der 3.0.3 ging das denk ich.
                                    pi@raspberrypi:~ $ iob stop
                                    pi@raspberrypi:~ $ Sudo apt-get clean
                                    -bash: Sudo: Kommando nicht gefunden.
                                    pi@raspberrypi:~ $ Sudo apt-get autoclean
                                      apollon77 @frankthegreat last edited by
                                      @frankthegreat Also jetzt langsam ....
                                      1.) "apt" ist ein Linux kommando und hat mit ioBroker NICHTS zu tun
                                      2.) Steht genau da was das issue is ... "Sudo" gibts nicht ... weil heisst "sudo"
                                      frankthegreat 1 Reply Last reply Reply Quote 0
                                        e-i-k-e @apollon77 last edited by e-i-k-e
                                        l ... bis zu 3x !!
                                        Ja gerne! Allerdings endet meine Datei bei Zeile 525. 😕
                                        cb4f762f-0e18-47f5-8016-a54e92ccd659-main.js
                                        • frankthegreat
                                          Ahh, sorry, sch... Rechtschreibkorrektur in Word 😉
                                          Läuft jetzt.
                                            @e-i-k-e Dann hast du ne ältere verison. Dann suche im FIle nach "Cannot initialize GPIO" und mach zusätzlich zu dem adapter.log.error noch eine zeile mit console.error dahinter oder davor
                                            747
                                            168930
