    4. js-controller 4.0 jetzt im BETA/LATEST!
    • ice987
      ice987 last edited by
      ich hab' mich auch versucht mit dem
      System: ioBroker.docker v6.0.0
      und erhalte folgende Fehlermeldung:
      root@iobroker-v600-testsystem7:/opt/iobroker# pkill -u iobroker
      root@iobroker-v600-testsystem7:/opt/iobroker# iobroker update
      Used repository: latest
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.2.3    , installed 5.1.25 [Updateable]
      Controller "js-controller" : 4.0.4    , installed 3.3.21 [Updateable]
      root@iobroker-v600-testsystem7:/opt/iobroker# iobroker upgrade self
      Update js-controller from @3.3.21 to @4.0.4
      NPM version: 6.14.16
      npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      In file included from ../../nan/nan.h:58,
                       from ../src/unix_dgram.cc:5:
      /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        793 |       (node::addon_register_func) (regfunc),                          \
      /opt/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
        404 | NODE_MODULE(unix_dgram, Initialize)
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
      Server States 127.0.0.1:45560 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
      Server States 127.0.0.1:45562 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: Unknown LUA script load
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
      Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: multi NOT SUPPORTED
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: sadd NOT SUPPORTED
      Server Objects 127.0.0.1:36016 Error from InMemDB: Error: exec NOT SUPPORTED
      This upgrade of "admin" will introduce the following changes:
      -> 5.2.3:
      Fixed error in `AutocompleteSendTo`
      Fixed error in charts
      -> 5.2.2:
      Changed the minimal required js-controller version to 3.3.22
      Used web-socket library 8 (no node 10 support anymore)
      -> 5.2.1:
      Allow in expert mode the creation of states and channels in mqtt branch
      -> 5.2.0:
      Fix crash cases reported via sentry
      Added support for multi-repositories
      -> 5.1.29:
      -> 5.1.28:
      Fixed discovery function
      Fixed some GUI bugs
      Would you like to upgrade admin from @5.1.25 to @5.2.3 now? [(y)es, (n)o]: y
      Update admin from @5.1.25 to @5.2.3
      host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is stopped.
      Installing iobroker.admin@5.2.3... (System call)
      + iobroker.admin@5.2.3
      updated 7 packages in 32.186s
      17 packages are looking for funding
        run `npm fund` for details
      host.iobroker-v600-testsystem7 Adapter "system.adapter.admin.0" is started
      Update "system.adapter.admin.0"
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      root@iobroker-v600-testsystem7:/opt/iobroker# iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 1425
      ioBroker ist nicht zu erreichen
      apollon77 ste_glei 2 Replies Last reply Reply Quote 0
        apollon77 @ice987 last edited by
        @ice987 ok was steht im log? Ich Seherin den Ausgaben keine Fehler. Da ist an sich alles ok
        ice987 1 Reply Last reply Reply Quote 0
        • ice987
          ice987 @apollon77 last edited by
          @apollon77
          der Restart vom Container ergibt nun:
          -------------------------     2022-02-06 15:04:25      -------------------------
          -----                 Welcome to your ioBroker-container!                  -----
          -----                    Startupscript is now running.                     -----
          -----                          Please be patient!                          -----
          -----                        Debugging information                         -----
          -----                                System                                -----
          -----                    arch:                x86_64                       -----
          -----                             Docker-Image                             -----
          -----                    image:               v6.0.0                       -----
          -----                    build:               2021-12-17T03:48:21+00:00    -----
          -----                               Versions                               -----
          -----                    /opt/scripts/iobroker_startup.sh: line 48: /usr/bin/node: Operation not permitted
          node:                                             -----
          -----                    /usr/bin/env: ‘node’: Operation not permitted
          npm:                                              -----
          -----                                 ENV                                  -----
          -----                    SETGID:              1000                         -----
          -----                    SETUID:              1000                         -----
          -----                  Step 1 of 5: Preparing container                   -----
          Nothing to do here.
          -----             Step 2 of 5: Detecting ioBroker installation             -----
          Existing installation of ioBroker detected in /opt/iobroker.
          -----             Step 3 of 5: Checking ioBroker installation              -----
          (Re)Setting folder permissions (This might take a while! Please be patient!)...
          Done.
          Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
          Done.
          error: exec failed: operation not permitted
          /opt/scripts/iobroker_startup.sh: line 199: [: !=: unary operator expected
          -----                Step 4 of 5: Applying special settings                -----
          Some adapters have special requirements/ settings which can be activated by the use of environment variables.
          For more information take a look at readme.md on Github!
          -----                    Step 5 of 5: ioBroker startup                     -----
          Starting ioBroker...
            apollon77 @Chaot last edited by
            @chaot was ist denn de ubuntu Adapter? Und was gefällt ihm nicht?
            • ste_glei
              ste_glei @ice987 last edited by
              @ice987
              Ich hatte den gleichen log
              iobroker fix
              hat geholfen
                e-i-k-e @apollon77 last edited by
                @apollon77
                anbei wie gewünscht die komplette log.
                b04d2521-d6ec-46a9-ab5a-18d5ad80331e-iobroker.2022-02-06.log
                • ice987
                  ice987 @ste_glei last edited by
                  @ste_glei
                  kann ich bestätigen:
                  iobroker fix
                  hilft und ioBroker läuft nun
                  apollon77 E 2 Replies Last reply Reply Quote 0
                  • Chaot
                    Chaot @apollon77 last edited by
                    @apollon77 Das ist ne uralte Leiche die mitgelaufen ist.
                    https://github.com/Standarduser/ioBroker.ubuntu
                    Ist mir nie aufgefallen dass das noch aktiv ist.
                    Meinerseits bereits entsorgt, da überflüssig.
                    Ausgegebener Fehler:
                    ubuntu.0
                    2022-02-06 12:57:13.847	error	Cannot read property 'getObjectList' of undefined
                    ubuntu.0
                    2022-02-06 12:57:13.846	error	TypeError: Cannot read property 'getObjectList' of undefined at Object.ready (/opt/iobroker/node_modules/iobroker.ubuntu/main.js:35:25) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8225:68
                    ubuntu.0
                    2022-02-06 12:57:13.842	error	unhandled promise rejection: Cannot read property 'getObjectList' of undefined
                    ubuntu.0
                    2022-02-06 12:57:13.837	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    amg_666 apollon77 2 Replies Last reply Reply Quote 1
                    • amg_666
                      amg_666 @Chaot last edited by
                      Eben den latest/Beta runtergeladen, einmal Raspi Slave, ohne Probleme und danach auf Proxmox/Debian, biedes ohne irgendwelche Probleme.
                        @chaot Naja,d er Hätte mit controller 3.x schon Fehler wegen "adapter.objects.getObjectList" loggen müssen und muss angepasst werden. Leg doch mal ein issue an
                          @ice987 Verstehe ich nicht weil der Container macht eigentlich genauein Fix beim startup soweit ich weiss ... also das wäre interessant das sich das Andre mal anschaut
                          ice987 F 3 Replies Last reply Reply Quote 0
                            apollon77 @e-i-k-e last edited by
                            @e-i-k-e Ahhh der RPI2 Adapter ist "zu nett" und fängt den Fehler so ab das der Rebuild Mechanismus vom Controller nicht greifen kann. Willste mal was versuchen?
                            Editiere mal /opt/iobroker/node_modules/iobroker.rp2/main.js und füge bei Zeile 648 das hinzu https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/master/main.js#L648
                            Danach bitte adapter neu starten ... Dann schauen wir mal was das System so macht. Hätte dann gern das log. Also er sollte - wenn er sich dann wegen dem Folgefehler beendet - der Controller sagen das er rebuild machen will ... bis zu 3x !!
                            frankthegreat E 2 Replies Last reply Reply Quote 1
                            • Chaot
                              @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                              .... Leg doch mal ein issue an
                              Beim Adapter? Der wird scheinbar seit 3 Jahren nicht mehr gepflegt bzw. ist nie über die eine Version hinausentwickelt worden. Letzte Aktivität 20.01.2019
                              Ist eher sinnlos. Löschen und nicht darüber nachdenken.
                                @chaot Jo ... aber dann sehen es andere das es bekannt ist 🙂
                                • frankthegreat
                                  frankthegreat @apollon77 last edited by
                                  @apollon77
                                  Update auf 4.0.4 auf meinem Testsystem sauber durchgelaufen. 👍
                                  Was mir auf die Schnelle aufgefallen ist:
                                  Die "Clean" Befehle zicken rum. Weis aber nicht, ob es damit zusammenhängt. Mit der 3.0.3 ging das denk ich.
                                  pi@raspberrypi:~ $ iob stop
                                  pi@raspberrypi:~ $ Sudo apt-get clean
                                  -bash: Sudo: Kommando nicht gefunden.
                                  pi@raspberrypi:~ $ Sudo apt-get autoclean
                                    apollon77 @frankthegreat last edited by
                                    @frankthegreat Also jetzt langsam ....
                                    1.) "apt" ist ein Linux kommando und hat mit ioBroker NICHTS zu tun
                                    2.) Steht genau da was das issue is ... "Sudo" gibts nicht ... weil heisst "sudo"
                                    frankthegreat 1 Reply Last reply Reply Quote 0
                                      e-i-k-e @apollon77 last edited by e-i-k-e
                                      l ... bis zu 3x !!
                                      Ja gerne! Allerdings endet meine Datei bei Zeile 525. 😕
                                      cb4f762f-0e18-47f5-8016-a54e92ccd659-main.js
                                      • frankthegreat
                                        Ahh, sorry, sch... Rechtschreibkorrektur in Word 😉
                                        Läuft jetzt.
                                          @e-i-k-e Dann hast du ne ältere verison. Dann suche im FIle nach "Cannot initialize GPIO" und mach zusätzlich zu dem adapter.log.error noch eine zeile mit console.error dahinter oder davor
                                            console.error
                                            Den Eintrag gibt es schon, oder noch einen zusätzlichen ?
                                                if (anyEnabled) {
                                                    try {
                                                        gpio = require('rpi-gpio');
                                                    } catch (e) {
                                                        gpio = null;
                                                        adapter.log.error('Cannot initialize GPIO: ' + e);
                                                        console.error('Cannot initialize GPIO: ' + e);
                                                    try {
                                                        gpio.setMode(gpio.MODE_BCM);
                                                    } catch (e) {
                                                        gpio = null;
                                                        adapter.log.error('cannot use GPIO: ' + e);
                                            747
                                            168915
