    3. Cloud Dienste
    4. Cloud Probleme?
    Cloud Probleme?
      homecineplexx last edited by
      Hallo
      gibt es irgendwelche Cloud Probleme?
      Meine Instanz kann sich nicht verbinden und sagt dauernd:
      cloud.0
      2022-02-06 21:53:08.482	info	Trying to connect as system.user.admin
      cloud.0
      2022-02-06 21:53:06.639	debug	Connection attempt to https://iobroker.pro:10555 ...
      cloud.0
      2022-02-06 21:52:46.647	error	Error while connecting to cloud: timeout
      cloud.0
      2022-02-06 21:52:37.052	info	Trying to connect as system.user.admin
      • haselchen
        haselchen Most Active @homecineplexx last edited by
        @homecineplexx
        Versuch mal in den Cloud Einstellungen unter erweiterte Einstellungen unter URL
        https://iobroker.net:10556
          homecineplexx @haselchen last edited by
          @haselchen ich kann in der Instanz im Feld Cloud URL nichts anderes angeben. Das ist dort so eingetragen
          Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @homecineplexx last edited by Thomas Braun
            @homecineplexx
            Ich glaube da klemmt es irgendwo auf dem Server. Ich komme jedenfalls weder in cloud noch in iot rein.
            2022-02-06 22:20:04.087  - info: cloud.0 (3763) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.13.2, js-controller: 4.0.4
            2022-02-06 22:20:04.158  - info: cloud.0 (3763) Connecting with https://iobroker.pro:10555 with "@pro_meine@email_einhash"
            2022-02-06 22:20:04.322  - info: cloud.0 (3763) Trying to connect as system.user.admin
            2022-02-06 22:20:04.503  - info: cloud.0 (3763) Connection changed: connect
            2022-02-06 22:20:04.538  - info: cloud.0 (3763) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
            2022-02-06 22:20:34.578  - info: cloud.0 (3763) Trying to connect as system.user.admin
            2022-02-06 22:20:34.736  - info: cloud.0 (3763) Connection changed: connect
            2022-02-06 22:20:34.769  - warn: cloud.0 (3763) Adapter stopped. Reason: command from server
            2022-02-06 22:20:34.771  - error: cloud.0 (3763) Please buy remote access to use pro. If you did it, please wait 5 minutes.
            2022-02-06 22:20:34.775  - info: cloud.0 (3763) Connection changed: io client disconnect
            2022-02-06 22:20:34.776  - info: cloud.0 (3763) Connection lost
            2022-02-06 22:20:34.777  - info: cloud.0 (3763) Restart adapter by disconnect
            2022-02-06 22:20:39.813  - info: host.chet "system.adapter.cloud.0" disabled
            2022-02-06 22:20:39.814  - info: host.chet stopInstance system.adapter.cloud.0 (force=false, process=true)
            2022-02-06 22:20:39.818  - info: host.chet stopInstance system.adapter.cloud.0 send kill signal
            2022-02-06 22:20:39.821  - info: cloud.0 (3763) Got terminate signal TERMINATE_YOURSELF
            2022-02-06 22:20:39.824  - info: cloud.0 (3763) terminating
            2022-02-06 22:20:39.827  - info: cloud.0 (3763) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-02-06 22:20:40.420  - info: host.chet instance system.adapter.cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            H haselchen 2 Replies Last reply Reply Quote 0
              homecineplexx @Thomas Braun last edited by
              @thomas-braun dann bin ich wenigstens nicht allein 😉
              • haselchen
                haselchen Most Active @homecineplexx last edited by haselchen
                @homecineplexx
                Na klar kannst du da manuell was eingeben
                • haselchen
                  haselchen Most Active @Thomas Braun last edited by haselchen
                  du kannst auch mal versuchen den Port 10556 einzugeben
                  läuft damit bei mir.
                  hatte vor zeiten auch den 10555. da hatte ich auch mit probleme.
                  edit: sehe im log das du automatisch zu 10556 weitergeleitet wirst.
                  nichtsdestotrotz kannste den ja mal so eingeben und nochmal starten.
                    Thomas Braun Most Active @haselchen last edited by
                    @haselchen
                    Bringt nix.
                    Auch hier kommt nix gescheites bei rum:
                    • haselchen
                      Haste mal versucht dich über den Key anzumelden?
                      Und Port 10556 eingeben.
                        @haselchen
                        Ja.
                          @haselchen das geht bei mir nicht...das ist grau hinterlegt und ich kann dort nichts editieren...warum auch immer
                            Homoran Global Moderator Administrators @haselchen last edited by
                            @haselchen sagte in Cloud Probleme?:
                            nicht bei pro!
                            cloud
                            476
