    3. Cloud Dienste
    4. Cloud Probleme?
    Cloud Probleme?
    • haselchen
      haselchen Most Active @homecineplexx last edited by
      @homecineplexx
      Versuch mal in den Cloud Einstellungen unter erweiterte Einstellungen unter URL
      https://iobroker.net:10556
        homecineplexx @haselchen last edited by
        @haselchen ich kann in der Instanz im Feld Cloud URL nichts anderes angeben. Das ist dort so eingetragen
        Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @homecineplexx last edited by Thomas Braun
          @homecineplexx
          Ich glaube da klemmt es irgendwo auf dem Server. Ich komme jedenfalls weder in cloud noch in iot rein.
          2022-02-06 22:20:04.087  - info: cloud.0 (3763) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.13.2, js-controller: 4.0.4
          2022-02-06 22:20:04.158  - info: cloud.0 (3763) Connecting with https://iobroker.pro:10555 with "@pro_meine@email_einhash"
          2022-02-06 22:20:04.322  - info: cloud.0 (3763) Trying to connect as system.user.admin
          2022-02-06 22:20:04.503  - info: cloud.0 (3763) Connection changed: connect
          2022-02-06 22:20:04.538  - info: cloud.0 (3763) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
          2022-02-06 22:20:34.578  - info: cloud.0 (3763) Trying to connect as system.user.admin
          2022-02-06 22:20:34.736  - info: cloud.0 (3763) Connection changed: connect
          2022-02-06 22:20:34.769  - warn: cloud.0 (3763) Adapter stopped. Reason: command from server
          2022-02-06 22:20:34.771  - error: cloud.0 (3763) Please buy remote access to use pro. If you did it, please wait 5 minutes.
          2022-02-06 22:20:34.775  - info: cloud.0 (3763) Connection changed: io client disconnect
          2022-02-06 22:20:34.776  - info: cloud.0 (3763) Connection lost
          2022-02-06 22:20:34.777  - info: cloud.0 (3763) Restart adapter by disconnect
          2022-02-06 22:20:39.813  - info: host.chet "system.adapter.cloud.0" disabled
          2022-02-06 22:20:39.814  - info: host.chet stopInstance system.adapter.cloud.0 (force=false, process=true)
          2022-02-06 22:20:39.818  - info: host.chet stopInstance system.adapter.cloud.0 send kill signal
          2022-02-06 22:20:39.821  - info: cloud.0 (3763) Got terminate signal TERMINATE_YOURSELF
          2022-02-06 22:20:39.824  - info: cloud.0 (3763) terminating
          2022-02-06 22:20:39.827  - info: cloud.0 (3763) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-02-06 22:20:40.420  - info: host.chet instance system.adapter.cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          H haselchen 2 Replies Last reply Reply Quote 0
            homecineplexx @Thomas Braun last edited by
            @thomas-braun dann bin ich wenigstens nicht allein 😉
            • haselchen
              haselchen Most Active @homecineplexx last edited by haselchen
              @homecineplexx
              Na klar kannst du da manuell was eingeben
              • haselchen
                haselchen Most Active @Thomas Braun last edited by haselchen
                du kannst auch mal versuchen den Port 10556 einzugeben
                läuft damit bei mir.
                hatte vor zeiten auch den 10555. da hatte ich auch mit probleme.
                edit: sehe im log das du automatisch zu 10556 weitergeleitet wirst.
                nichtsdestotrotz kannste den ja mal so eingeben und nochmal starten.
                  Thomas Braun Most Active @haselchen last edited by
                  @haselchen
                  Bringt nix.
                  Auch hier kommt nix gescheites bei rum:
                  • haselchen
                    Haste mal versucht dich über den Key anzumelden?
                    Und Port 10556 eingeben.
                      @haselchen
                      Ja.
                        @haselchen das geht bei mir nicht...das ist grau hinterlegt und ich kann dort nichts editieren...warum auch immer
                          Homoran Global Moderator Administrators @haselchen last edited by
                          @haselchen sagte in Cloud Probleme?:
                          nicht bei pro!
                          cloud
                          476
