    4. Ram läuft voll
    Ram läuft voll
      crunchip Forum Testing Most Active @D3ltoroxp last edited by crunchip
      @d3ltoroxp sagte in Ram läuft voll:
      @crunchip Müsste ich wahrscheinlich was installieren, Kommando nicht gefunden.
      was soll da installiert werden, du rufst die Details deiner VM vom Host aus auf
      sieht dann so aus
      • D3ltoroxp
        Ich bin mir nicht sicher, den habe ich gestern aktiviert seitdem wieder diese Ram Überläufe, grad schon wieder... Ich habs wieder deaktiviert.
        // momentjs is required as dependecies in javascript adapter
        const moment = require("moment");
        var instances = $(`[id=ical.*.data.table]`);
        instances.on(ical2CalendarWidget);
        // remove this, if you know to use your own datapoint
        let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
        createState(datapointId, "[]", {
          read: true,
          write: false,
          desc: "JSON String for Calendar Widget",
          type: "string",
          def: "[]"
        function ical2CalendarWidget() {
            try {
                let calList = [];
                for (var inst = 0; inst <= instances.length - 1; inst++) {
                    let icalObj = getState(instances[inst]).val;
                    if (icalObj) {
                        for (var i = 0; i <= icalObj.length - 1; i++) {
                            let item = icalObj[i];
                            // extract calendar color
                            let calendarName = item._class.split(' ')[0].replace('ical_', '');
                            let startTime = moment(item._date);
                            let endTime = moment(item._end);
                            let start = startTime.format("YYYY-MM-DD HH:mm");
                            let end = endTime.format("YYYY-MM-DD HH:mm");
                            if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                                // is full-day event
                                if (endTime.diff(startTime, 'hours') === 24) {
                                    // full-day event, one day
                                    start = startTime.format("YYYY-MM-DD");
                                    end = startTime.format("YYYY-MM-DD");
                                } else {
                                    // full-day event, multiple days
                                    end = endTime.format("YYYY-MM-DD");
                            // create object for calendar widget
                            calList.push({
                                color: getMyCalendarColor(calendarName),
                                colorText: getMyCalendarTextColor(calendarName),
                                start: start,
                                end: end
                        function getMyCalendarColor(calendarName) {
                            // assign colors via the calendar names, use calendar name as set in ical
                            if (calendarName === 'Geburtstage') {
                                return '#FF8040';
                            } else if (calendarName === 'Abfallentsorgung') {
                                return '#FFFF00'
                            } else if (calendarName === 'Events') {
                                return '#13EC5F'
                            } else if (calendarName === 'Feiertage') {
                                return '#14ECF0'
                            } else if (calendarName === 'SchulplanPräsenzunterricht') {
                                return '#E31CD2'
                        function getMyCalendarTextColor(calendarName) {
                            if (calendarName === 'calendar1') {
                                return '#FFFFFF';
                            } else if (calendarName === 'calendar2') {
                                return '#FFFFFF'
                            } else if (calendarName === 'calendar3') {
                                return '#FFFFFF'
                    // Enter the destination data point that is to be used as object ID in the widget
                    setState(datapointId, JSON.stringify(calList), true);
            } catch (e) {
                console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
        ical2CalendarWidget();
        OliverIO 2 Replies Last reply Reply Quote 0
        • OliverIO
          OliverIO @D3ltoroxp last edited by OliverIO
          @d3ltoroxp
          Grundsätzlich sehe ich ersteinmal keine Anhaltspunkt für ein speicherleck
          Allerdings sehe ich ineffiziente Programmierung
          Kannst du mal bitte ermitteln wieviel Objekte durch den selektor
          In zeile 4 betroffen sind?
          Immer wenn eine Änderung eines datenpunktes erfolgt wird ja
          Dann ical2CalendarWidget aufgerufen.
          Als parameter werden dann Details zum Status mit übergeben, was du aber nicht nutzt.
          Trotzdem rechnest du die Details für alle datenpunkte durch.
          Wenn die Anzahl der datenpunkte gering ist dürfte auch das kein Problem sein.
          Wenn sie aber höher ist, und die Anzahl der Änderungen häufig, dann erfolgt da sehr viel rechenarbeit für unnötig Zuviel Daten.
          Wenn du das optimierst, müsste sich das normalisieren.
          • D3ltoroxp
            D3ltoroxp @OliverIO last edited by
            @oliverio Schau ich mal rein, weiß nur nicht genau, wie ich das ermitteln soll ? Das Script dürfte von @Scrounger sein für sein Kalender Widget.
            • OliverIO
              console.log(instances.length);
              • D3ltoroxp
                @oliverio Den DP hab ich gefunden, soll ich alles was dort drin steht posten ?
                • OliverIO
                  @d3ltoroxp wieso den datenpunkt?
                  du sollst das skript ausführen was ich gepostet habe.
                  das zählt die anzahl der states, die durch den filter angezogen werden.
                  die zahl die da im skript-log ausgegeben wird postest du hier.
                  ich gehe davon aus das es eine sehr hohe zahl ist
                  • D3ltoroxp
                    @oliverio ach jetzt kapier ich, ich dachte immer das wäre ein Ausschnitt aus dem Script was ich gepostet hatte ? Ei jei jei.
                    Sollte das sofort was anzeigen oder erst wenn das eigentliche Script durchläuft ?
                    javascript.0
                    	2022-02-07 20:46:34.378	info	script.js.Test_Scripte.Ausgabe: registered 0 subscriptions and 0 schedules
                    javascript.0
                    	2022-02-07 20:46:34.378	info	script.js.Test_Scripte.Ausgabe: 1
                    javascript.0
                    	2022-02-07 20:46:34.363	info	Start javascript script.js.Test_Scripte.Ausgabe
                    javascript.0
                    	2022-02-07 20:46:31.769	info	Stop script script.js.Test_Scripte.Ausgabe
                    bahnuhr OliverIO 2 Replies Last reply Reply Quote 0
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @D3ltoroxp last edited by
                      @d3ltoroxp
                      Ne, du hast es nicht verstanden !
                      Du sollst die Zeile mit dem "log" hinter deiner zeile mit dem selektor einfügen.
                      und dann laufen lassen.
                      Im log erscheint dann eine zahl und die sollst du zeigen.
                      • D3ltoroxp
                        D3ltoroxp @bahnuhr last edited by D3ltoroxp
                        @bahnuhr
                        20:51:40.819	info	javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: 1
                        456 ist die gesuchte Zahl ?
                        • OliverIO
                          javascript.0 2022-02-07 20:46:34.378 info script.js.Test_Scripte.Ausgabe: 1
                          sofort und es zeigt leider nur 1 an.
                          dann probieren wir es damit. ich habe in zeile 20 ein log hinzugefügt
                          Das sollte jedesmal wenn da was aktualisiert wird im skript log so etwas ausgeben.
                          Wenn das auch nicht so oft passiert, dann sehe ich im skript nix was einen hohen speicherverbrauch oder performance verursacht.
                          Ausführen:Mon Feb 07 2022 20:52:57 GMT+0100 (Mitteleuropäische Normalzeit)
                            read: true,
                            write: false,
                            type: "string",
                            def: "[]"
                              try {
                                  console.log("ausführen:"+new Date());
                                  let calList = [];
                                      if (icalObj) {
                                                  } else {
                                              calList.push({
                                                  start: start,
                                                  end: end
                                                  return '#FF8040';
                                                  return '#FFFF00'
                                                  return '#13EC5F'
                                                  return '#14ECF0'
                                                  return '#E31CD2'
                                                  return '#FFFFFF';
                                                  return '#FFFFFF'
                                                  return '#FFFFFF'
                              } catch (e) {
                          • D3ltoroxp
                            @oliverio Also in der Log steht irgendwie nichts... Bisher blieb der Ram auch ruhig.
                            • OliverIO
                              @d3ltoroxp
                              Im Skript-Log / Debug-Fenster
                              Nicht im iobroker log
                              • D3ltoroxp
                                D3ltoroxp @OliverIO last edited by D3ltoroxp
                                @oliverio Das hier ?
                                16.2.2022, 17:01:22.292	[info ]: javascript.0 (456) Stop script script.js.VIS.Ical_Umwandler_Calende_Widget
                                16.2.2022, 17:01:22.301	[info ]: javascript.0 (456) Start javascript script.js.VIS.Ical_Umwandler_Calende_Widget
                                16.2.2022, 17:01:22.326	[info ]: javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: ausführen:Wed Feb 16 2022 17:01:22 GMT+0100 (Mitteleuropäische Normalzeit)
                                16.2.2022, 17:01:22.335	[warn ]: javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: setForeignState(id=javascript.0.materialdesignwidgets.calendar.ical2calendar, state={"val":"[{\"name\":\"Restmüllgefäß\",\"color\":\"#FFFF00\",\"start\":\"2022-02-16\",\"end\":\"2022-02-16\"},{\"name\":\"xxxx
                                16.2.2022, 17:01:22.335	[info ]: javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: registered 1 subscription and 0 schedules
                                16.2.2022, 17:01:50.309	[info ]: javascript.0 (456) Stop script script.js.VIS.Ical_Umwandler_Calende_Widget
                                16.2.2022, 17:01:50.314	[info ]: javascript.0 (456) Start javascript script.js.VIS.Ical_Umwandler_Calende_Widget
                                16.2.2022, 17:01:50.319	[info ]: javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: ausführen:Wed Feb 16 2022 17:01:50 GMT+0100 (Mitteleuropäische Normalzeit)
                                16.2.2022, 17:01:50.322	[info ]: javascript.0 (456) script.js.VIS.Ical_Umwandler_Calende_Widget: registered 1 subscription and 0 schedules
                                Homoran OliverIO 2 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @D3ltoroxp last edited by
                                  wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                  schalt den mal ab und lösch deine privaten Daten im log
                                  • OliverIO
                                    @d3ltoroxp
                                    ja genau nur hast du es nicht lange laufen lassen.
                                    das skript sollte immer dann so eine Zeile wie bei Zeile 3 und Zeile 8
                                    ausgeben, wenn es eine Änderung gibt.
                                    Eine hohe Performance oder Viel RAM wird auch dann verbraucht, wenn ein Trigger sehr oft aufgerufen wird.
                                    Zumindest in der Zeit 17:01:22 bis 17:01:50 gab es nur einmal den initialen Trigger für den Datenpunkt.
                                    Wenn das jetzt sehr oft dran stehen würde,, aber auch hier kein Hinweis auf viel Speicherverbrauch.
                                    Das Skript ist aus meiner Sicht safe
                                    • D3ltoroxp
                                      Also das muss noch aktiv sein ?
                                      Ich hab oben mal die Zeile gelöscht mit den Daten.
                                      Komisch ich habe noch mal zwei Scripte aktiviert, bei denen ich vermutet hätte das sie es sind. Weil komischerweise als sie liefen auch dann das mit dem Ram wieder auftrat. Nach dem deaktivieren war's wieder ruhig paar Tage. Jetzt habe ich die vor 1-2 Tagen wieder aktiviert. Mal sehen...
                                        nein!
                                        das debug muss aus - so stand es doch auch im log
                                        • OliverIO
                                          @d3ltoroxp
                                          lese dir bitte mal die folgenden threads durch
                                          https://forum.iobroker.net/topic/42792/javascript-heap-out-of-memory-workaround?=1623240989781
                                          https://forum.iobroker.net/topic/40101/gelöst-speicherlecks-im-iobroker?
                                          =1623241091971
                                          da sind ähnliche fälle mit Vorgehensweisen, wie man das lösen kann.
                                          allerdings kann man keine generelle Standardvorgehensweisen Vorschlagen, da es da doch sehr individiuell wird.
                                          • D3ltoroxp
                                            @oliverio Hm ich nutze von Pettini das Fenster offen Script. Ich habe da zwei am laufen, eins für meine Tore und das andere für Fenster und Türen. Ich meine wenn ich die aktiviere gehts los. Ich hab sie seit 2 Tagen wieder aus und Ruhe ist. Aktiviere ich sie geht es nicht lange und ich kann schon wieder nicht auf ioBroker zugreifen. Muss ich mich mal bei ihm melden.
                                            EDIT::
                                            Definitiv das Script, ich aktiviere es und es geht 1-3 Tage gut danach kackt ioB wieder rum. Mittlerweile schießt er sich immer ab ich komm gar nicht mehr auf das WebIF. Muss die VM immer neu starten.
                                            Deaktiviere ich dieses Script, läuft er Tage lang durch.
                                            OliverIO P 2 Replies Last reply Reply Quote 0
                                            196
                                            22405
