    4. js-controller 4.0 jetzt im BETA/LATEST!
      ChrisXY last edited by
      Bei mir sind folgende fehler gekommen. Danach liefen fast keine Adapter alle Lese/Schreib Probleme wohl...
      iob fix hilft nicht
      root@iobroker:/# iob upgrade self
      Update js-controller from @3.3.22 to @4.0.4
      NPM version: 6.14.10
      npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      In file included from ../src/unix_dgram.cc:5:
      ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)':
      ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      In file included from ../../nan/nan.h:54,
      ../src/unix_dgram.cc: At global scope:
      /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
       NODE_MODULE(unix_dgram, Initialize)
      Im log auch bisschen was:
      host.iobroker
      2022-02-08 10:01:30.519	error	instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-02-08 10:01:30.519	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:81:21)
      host.iobroker
      2022-02-08 10:01:30.519	error	Caught by controller[0]: at doListen (net.js:1503:7)
      host.iobroker
      2022-02-08 10:01:30.519	error	Caught by controller[0]: at listenInCluster (net.js:1366:12)
      host.iobroker
      2022-02-08 10:01:30.519	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1301:21)
      host.iobroker
      2022-02-08 10:01:30.519	error	Caught by controller[0]: Error: listen EADDRNOTAVAIL: address not available 192.168.2.200:2001
      Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @ChrisXY last edited by
        @chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        Außer
        root@iobroker
        sind da keine Fehler zu sehen.
          crunchip Forum Testing Most Active @homecineplexx last edited by crunchip
          @homecineplexx hatte ich auch
          @apollon77 bin soeben auf v4, habe allerdings danach ein paar Adapter Update's angestoßen, die Meldung kommt bei jedem Adapter update
          2022-02-08 09:44:29.782 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
          2022-02-08 09:44:29.818 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
          2022-02-08 09:45:52.304 - info: shelly.0 (653) Got terminate signal TERMINATE_YOURSELF
          2022-02-08 09:45:52.305 - info: shelly.0 (653) Closing Adapter
          2022-02-08 09:46:12.167 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
          2022-02-08 09:46:12.171 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
          2022-02-08 09:46:12.774 - info: shuttercontrol.0 (1872) Adapter is disabled => stop
          2022-02-08 09:46:12.783 - info: shuttercontrol.0 (1872) cleaned everything up...
          2022-02-08 09:58:07.286 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)(node:14307) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:14307) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
          2022-02-08 09:58:07.293 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
          2022-02-08 09:59:24.076 - info: trashschedule.0 (2332) Got terminate signal TERMINATE_YOURSELF
          2022-02-08 09:59:24.078 - info: trashschedule.0 (2332) cleaned everything up...
          2022-02-08 10:01:14.838 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
          2022-02-08 10:01:14.853 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
          2022-02-08 10:02:40.396 - info: jarvis.0 (1316) Got terminate signal TERMINATE_YOURSELF
          2022-02-08 10:02:40.423 - info: jarvis.0 (1316) Adapter stopped und unloaded.
          Nachtrag:
          habe das nun eine Weile beobachtet, an der Performance hat sich nicht groß was verändert, da ich sowieso schon jsonl verwende, jedoch sehe ich nun einen erhöhten Ram Verbrauch, ob das vom Controller Update kommt oder den 4 Adapter Updates geschuldet ist, keine Ahnung.
            ChrisXY @Thomas Braun last edited by
            @thomas-braun wie den besser?
            Nochmal Installieren auch iob fix bringr das:
            root@iobroker:/# sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/debug
            npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/node-forge
            npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/semver
            npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/mime
            npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/tar
            npm WARN checkPermissions Missing write access to /node_modules/@iobroker
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN enoent ENOENT: no such file or directory, open '/package.json'
            npm WARN !invalid#1 No description
            npm WARN !invalid#1 No repository field.
            npm WARN !invalid#1 No README data
            npm WARN !invalid#1 No license field.
            npm ERR! code EACCES
            npm ERR! syscall access
            npm ERR! path /node_modules/iobroker.js-controller/node_modules/debug
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'
            npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'] {
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'access',
            npm ERR!   path: '/node_modules/iobroker.js-controller/node_modules/debug'
            npm ERR! }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR!     /home/iobroker/.npm/_logs/2022-02-08T09_17_51_107Z-debug.log
              Thomas Braun Most Active @ChrisXY last edited by Thomas Braun
              seufz
              Kommt vermutlich vom rumgehampel als root.
              iobroker stop
              iobroker fix
              versuchen.
                ChrisXY @Thomas Braun last edited by ChrisXY
                Kann sein aber das mach ich so schon seit Jahren. Früher war das doch oft so?
                fix habe ich natürlich schon Probiert.
                Werde ich wohl ein Backup zurückspielen müssen komisch .. bisher gab es nie Probleme alles sauber durch.
                  Dann machst du es seit Jahren falsch. Als root meldet man sich seit 'ewig' nicht mehr an.
                    @thomas-braun okay ja das ist die Proxmox Konsole
                      e-s @ChrisXY last edited by
                      @chrisxy auch mal wieder falscher Ordner, versuche es mal in /opt/iobroker
                        ChrisXY @e-s last edited by ChrisXY
                        @e-s Danke da habe ich keine Fehler bekommen. Jedoch bei iobroker Start kommt auch die Migrations meldung. Aber mein iobroker Menü links ist auch leer. Zigbee usw. alles fehlt. Einige Adapter werden auch nicht mehr grün
                        Fhem, Zigbee ... ich lass iobroker mal etwas Zeit
                        iobroker status sagt auch nicht mehr redis
                        Objects type: file
                        States type: file
                        Scheinbar beim Update mein Redis verloren gegangen. Bekomm es auch nicht hin iob fix usw.. immer Zugriffs Probleme
                        Connecting to previous DB "file"...
                        Creating backup ...
                        This can take some time ... please be patient!
                        host.iobroker 19727 states saved
                        host.iobroker 22369 objects saved
                        Backup created: /opt/iobroker/backups/2022_02_08-12_52_25_backupiobroker-migration.tar.gz
                        updating conf/iobroker.json
                        Uncaught Rejection: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak'
                            at Object.openSync (fs.js:476:3)
                            at Object.writeFileSync (fs.js:1467:35)
                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24
                        This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        root@iobroker:/dev# iob status
                        iobroker is not running on this host.
                        Objects type: file
                        States  type: file
                        • OliverIO
                          OliverIO last edited by OliverIO
                          Hallo hier meine Erkenntnisse des Tests. Ob die alle durch den js-controller verursacht sind weiß ich nicht. sind aber auch keine Kriitischen Fehler:
                          Ausganslage:
                          Getestet wird in einem docker-container auf Basis buanet/iobroker:latest in einem macvlan. volumes wurden nicht in einen Ordner herausgeführt
                          docker-compose-file
                          version: '2.1'
                          services:
                            iobrokertest4_0_0:
                              restart: always
                              image: buanet/iobroker:latest
                              container_name: iobrokertest4_0_0
                              hostname: iobrokertest4_0_0
                              ports:
                                - "8081:8081"
                              volumes:
                                - iobrokertest4_0_0:/opt/iobroker
                              networks:
                                dockerMACVLAN:
                                  ipv4_address: 192.168.1.87
                          networks:
                            dockerMACVLAN:
                              external: true
                          volumes:
                            iobrokertest4_0_0:
                          Testablauf
                          Nach Erzeugen des Containers wurden das repo auf latest gesetzt. Hier ist mir aufgefallen, das beim Speichern des Konfigurationsdialog eine Fehlermeldung auftrat "DB cannot be read " oder so ähnlich. Der Dialog konnte nicht geschlossen werden, sondern man musste erneut die http-adresse des iobrokers eingeben.
                          Fehler/Problem1: Beim Speichern des Konfigurationsdialog konnte der Dialog nicht geschlossen werden.
                          im Anschluss habe ich alle Adapter aktualisiert
                          Danach Update von js-controller
                          Fehler/Problem2: Bei den Hinweisen gibt es einen Fehler im adapterfixer. Es fehlt ein leerzeichen zwischen bash und -
                          curl -sL https://iobroker.net/fix.sh | bash-
                          upgrade lief soweit gut, bis auf die oben bereits benannten Probleme (angezeigte Fehlermeldungen, Fixer muss durchgeführt werden, sonst Fehlermeldung "operation not permittet"
                          Im Anschluss dann noch Update des Admin-Adapters
                          Beim installieren von Adaptern traten 2 Probleme auf.
                          Der Adapter hat eine Abhängigkeit zu vis, vis eine Abhängigkeit zu web. Beide wurden auch installiert, nur am Ende brach die Installation des eigentlichen Adapters mit Fehlermeldung ab (meldung landete nicht im log)
                          Fehler/Problem3:
                          Bei Installation von Adaptern mit Abhängigkeiten zu vis/web wird der eigentliche Adapter nicht installiert.
                          Ein erneuter Aufruf der Installation endete dann mit der folgenden Fehlermeldung
                          iobroker adapter "rssfeed" cannot be installed: Cannot read property 'startsWith' of undefined
                          iobroker adapter "tvprogram" cannot be installed: Cannot read property 'startsWith' of undefined
                          Fehler/Problem4:
                          Innerhalb einer gewissen zeit nach Umstellung und Start von iobroker können keine Adapter installiert werden. Das sollte über eine Meldung dem Nutzer signalisiert werden.
                          Nach einer gewissen Zeit, klappte dann die erneute Installation der Adapter
                          AlCalzone apollon77 2 Replies Last reply Reply Quote 0
                          • AlCalzone
                            AlCalzone Developer @OliverIO last edited by
                            @oliverio sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                            Wenn ich das oben im Post markieren und kopiere, ist da ein Leerzeichen.
                            @apollon77 vielleicht als Block-Code formatieren?
                            • OliverIO
                              OliverIO @AlCalzone last edited by OliverIO
                              @alcalzone
                                apollon77 @OliverIO last edited by
                                @oliverio Mist, dann ist der Fallback text im Admin falsch ... Bitte Admin Issue anlegen - bzw es gibt eins von Feuersturm das der Fallback Text anstelle ein anderer angezeigt wird ... da am besten dazu bitte
                                • OliverIO
                                  OliverIO @apollon77 last edited by
                                  @apollon77
                                  https://github.com/ioBroker/ioBroker.admin/issues/1311#issuecomment-1032599083
                                    apollon77 last edited by apollon77
                                    @ice987 @fastfoot einer Von euch mal Zeit für nen docker test einer neuen Version die hoffentlich das "iob fix nach erstem Start" weg machen sollte ... ? Bitte mich mal direkt anschreiben
                                    EDIT: habs mit @fastfoot probiert. Fix tut. 🙂 Kommt bald offiziell
                                      apollon77 @ChrisXY last edited by
                                      Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
                                        apollon77 @crunchip last edited by
                                        @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                        Kannst Das ggf nochmal versuchen nachzustellen und dazu das kommando anstelle über "iob upgrade name" mal mittels ´node --trace-warnings /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade name` machen ... dann sollten mehr infos kommen ...
                                        crunchip 2 Replies Last reply Reply Quote 1
                                          Naja, npm macht hier inzwischen auch einige Dinge sehr anders ... also "vor einigen Jahren" war auch da einiges anders. Inzwischen verhält sich mit aktuelleren npm Versionen hier einiges anders bzw manchmal wie ne Diva
                                            @chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
                                            Um es jetzt zu fixen:
                                            1.) iob fix um die Rechtefehler zu fixen
                                            2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.
                                            Danach sollte erstmal alles wieder laufen
                                            747
                                            194648
