    4. js-controller 4.0 jetzt im BETA/LATEST!
      crunchip Forum Testing Most Active @homecineplexx last edited by crunchip
      @homecineplexx hatte ich auch
      @apollon77 bin soeben auf v4, habe allerdings danach ein paar Adapter Update's angestoßen, die Meldung kommt bei jedem Adapter update
      2022-02-08 09:44:29.782 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
      2022-02-08 09:44:29.818 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
      2022-02-08 09:45:52.304 - info: shelly.0 (653) Got terminate signal TERMINATE_YOURSELF
      2022-02-08 09:45:52.305 - info: shelly.0 (653) Closing Adapter
      2022-02-08 09:46:12.167 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
      2022-02-08 09:46:12.171 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
      2022-02-08 09:46:12.774 - info: shuttercontrol.0 (1872) Adapter is disabled => stop
      2022-02-08 09:46:12.783 - info: shuttercontrol.0 (1872) cleaned everything up...
      2022-02-08 09:58:07.286 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)(node:14307) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:14307) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
      2022-02-08 09:58:07.293 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
      2022-02-08 09:59:24.076 - info: trashschedule.0 (2332) Got terminate signal TERMINATE_YOURSELF
      2022-02-08 09:59:24.078 - info: trashschedule.0 (2332) cleaned everything up...
      2022-02-08 10:01:14.838 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
      2022-02-08 10:01:14.853 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
      2022-02-08 10:02:40.396 - info: jarvis.0 (1316) Got terminate signal TERMINATE_YOURSELF
      2022-02-08 10:02:40.423 - info: jarvis.0 (1316) Adapter stopped und unloaded.
      Nachtrag:
      habe das nun eine Weile beobachtet, an der Performance hat sich nicht groß was verändert, da ich sowieso schon jsonl verwende, jedoch sehe ich nun einen erhöhten Ram Verbrauch, ob das vom Controller Update kommt oder den 4 Adapter Updates geschuldet ist, keine Ahnung.
        ChrisXY @Thomas Braun last edited by
        @thomas-braun wie den besser?
        Nochmal Installieren auch iob fix bringr das:
        root@iobroker:/# sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/debug
        npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/node-forge
        npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/semver
        npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/mime
        npm WARN checkPermissions Missing write access to /node_modules/iobroker.js-controller/node_modules/tar
        npm WARN checkPermissions Missing write access to /node_modules/@iobroker
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN enoent ENOENT: no such file or directory, open '/package.json'
        npm WARN !invalid#1 No description
        npm WARN !invalid#1 No repository field.
        npm WARN !invalid#1 No README data
        npm WARN !invalid#1 No license field.
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /node_modules/iobroker.js-controller/node_modules/debug
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'
        npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.js-controller/node_modules/debug'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/node_modules/iobroker.js-controller/node_modules/debug'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2022-02-08T09_17_51_107Z-debug.log
          Thomas Braun Most Active @ChrisXY last edited by Thomas Braun
          @chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
          seufz
          Kommt vermutlich vom rumgehampel als root.
          iobroker stop
          iobroker fix
          versuchen.
            ChrisXY @Thomas Braun last edited by ChrisXY
            Kann sein aber das mach ich so schon seit Jahren. Früher war das doch oft so?
            fix habe ich natürlich schon Probiert.
            Werde ich wohl ein Backup zurückspielen müssen komisch .. bisher gab es nie Probleme alles sauber durch.
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
              Dann machst du es seit Jahren falsch. Als root meldet man sich seit 'ewig' nicht mehr an.
                @thomas-braun okay ja das ist die Proxmox Konsole
                  e-s @ChrisXY last edited by
                  @chrisxy auch mal wieder falscher Ordner, versuche es mal in /opt/iobroker
                    ChrisXY @e-s last edited by ChrisXY
                    @e-s Danke da habe ich keine Fehler bekommen. Jedoch bei iobroker Start kommt auch die Migrations meldung. Aber mein iobroker Menü links ist auch leer. Zigbee usw. alles fehlt. Einige Adapter werden auch nicht mehr grün
                    Fhem, Zigbee ... ich lass iobroker mal etwas Zeit
                    iobroker status sagt auch nicht mehr redis
                    Objects type: file
                    States type: file
                    Scheinbar beim Update mein Redis verloren gegangen. Bekomm es auch nicht hin iob fix usw.. immer Zugriffs Probleme
                    Connecting to previous DB "file"...
                    Creating backup ...
                    This can take some time ... please be patient!
                    host.iobroker 19727 states saved
                    host.iobroker 22369 objects saved
                    Backup created: /opt/iobroker/backups/2022_02_08-12_52_25_backupiobroker-migration.tar.gz
                    updating conf/iobroker.json
                    Uncaught Rejection: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak'
                        at Object.openSync (fs.js:476:3)
                        at Object.writeFileSync (fs.js:1467:35)
                        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24
                    This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    root@iobroker:/dev# iob status
                    iobroker is not running on this host.
                    Objects type: file
                    States  type: file
                    • OliverIO
                      OliverIO last edited by OliverIO
                      Hallo hier meine Erkenntnisse des Tests. Ob die alle durch den js-controller verursacht sind weiß ich nicht. sind aber auch keine Kriitischen Fehler:
                      Ausganslage:
                      Getestet wird in einem docker-container auf Basis buanet/iobroker:latest in einem macvlan. volumes wurden nicht in einen Ordner herausgeführt
                      docker-compose-file
                      version: '2.1'
                      services:
                        iobrokertest4_0_0:
                          restart: always
                          image: buanet/iobroker:latest
                          container_name: iobrokertest4_0_0
                          hostname: iobrokertest4_0_0
                          ports:
                            - "8081:8081"
                          volumes:
                            - iobrokertest4_0_0:/opt/iobroker
                          networks:
                            dockerMACVLAN:
                              ipv4_address: 192.168.1.87
                      networks:
                        dockerMACVLAN:
                          external: true
                      volumes:
                        iobrokertest4_0_0:
                      Testablauf
                      Nach Erzeugen des Containers wurden das repo auf latest gesetzt. Hier ist mir aufgefallen, das beim Speichern des Konfigurationsdialog eine Fehlermeldung auftrat "DB cannot be read " oder so ähnlich. Der Dialog konnte nicht geschlossen werden, sondern man musste erneut die http-adresse des iobrokers eingeben.
                      Fehler/Problem1: Beim Speichern des Konfigurationsdialog konnte der Dialog nicht geschlossen werden.
                      im Anschluss habe ich alle Adapter aktualisiert
                      Danach Update von js-controller
                      Fehler/Problem2: Bei den Hinweisen gibt es einen Fehler im adapterfixer. Es fehlt ein leerzeichen zwischen bash und -
                      curl -sL https://iobroker.net/fix.sh | bash-
                      upgrade lief soweit gut, bis auf die oben bereits benannten Probleme (angezeigte Fehlermeldungen, Fixer muss durchgeführt werden, sonst Fehlermeldung "operation not permittet"
                      Im Anschluss dann noch Update des Admin-Adapters
                      Beim installieren von Adaptern traten 2 Probleme auf.
                      Der Adapter hat eine Abhängigkeit zu vis, vis eine Abhängigkeit zu web. Beide wurden auch installiert, nur am Ende brach die Installation des eigentlichen Adapters mit Fehlermeldung ab (meldung landete nicht im log)
                      Fehler/Problem3:
                      Bei Installation von Adaptern mit Abhängigkeiten zu vis/web wird der eigentliche Adapter nicht installiert.
                      Ein erneuter Aufruf der Installation endete dann mit der folgenden Fehlermeldung
                      iobroker adapter "rssfeed" cannot be installed: Cannot read property 'startsWith' of undefined
                      iobroker adapter "tvprogram" cannot be installed: Cannot read property 'startsWith' of undefined
                      Fehler/Problem4:
                      Innerhalb einer gewissen zeit nach Umstellung und Start von iobroker können keine Adapter installiert werden. Das sollte über eine Meldung dem Nutzer signalisiert werden.
                      Nach einer gewissen Zeit, klappte dann die erneute Installation der Adapter
                      AlCalzone apollon77 2 Replies Last reply Reply Quote 0
                      • AlCalzone
                        AlCalzone Developer @OliverIO last edited by
                        @oliverio sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                        Wenn ich das oben im Post markieren und kopiere, ist da ein Leerzeichen.
                        @apollon77 vielleicht als Block-Code formatieren?
                        • OliverIO
                          OliverIO @AlCalzone last edited by OliverIO
                          @alcalzone
                            apollon77 @OliverIO last edited by
                            @oliverio Mist, dann ist der Fallback text im Admin falsch ... Bitte Admin Issue anlegen - bzw es gibt eins von Feuersturm das der Fallback Text anstelle ein anderer angezeigt wird ... da am besten dazu bitte
                            • OliverIO
                              OliverIO @apollon77 last edited by
                              @apollon77
                              https://github.com/ioBroker/ioBroker.admin/issues/1311#issuecomment-1032599083
                              Feuer-sturm created this issue in ioBroker/ioBroker.admin
                              closed Current version of instruction for js-controller update is not shown #1311
                                apollon77 last edited by apollon77
                                @ice987 @fastfoot einer Von euch mal Zeit für nen docker test einer neuen Version die hoffentlich das "iob fix nach erstem Start" weg machen sollte ... ? Bitte mich mal direkt anschreiben
                                EDIT: habs mit @fastfoot probiert. Fix tut. 🙂 Kommt bald offiziell
                                  apollon77 @ChrisXY last edited by
                                  EADDRNOTAVAIL: address not available 192.168.2.200:2001
                                  Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
                                    apollon77 @crunchip last edited by
                                    @crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                    Kannst Das ggf nochmal versuchen nachzustellen und dazu das kommando anstelle über "iob upgrade name" mal mittels ´node --trace-warnings /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade name` machen ... dann sollten mehr infos kommen ...
                                    crunchip 2 Replies Last reply Reply Quote 1
                                      Naja, npm macht hier inzwischen auch einige Dinge sehr anders ... also "vor einigen Jahren" war auch da einiges anders. Inzwischen verhält sich mit aktuelleren npm Versionen hier einiges anders bzw manchmal wie ne Diva
                                        @chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
                                        Um es jetzt zu fixen:
                                        1.) iob fix um die Rechtefehler zu fixen
                                        2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.
                                        Danach sollte erstmal alles wieder laufen
                                          @oliverio Zu Fehler 1: Ich verstehe nicht was Du meinst. Hast Du da mehr Infos? Screenshot? Whatever?
                                          zu Fehler 3: Unbekannt, bitte GitHub issue anlegen. Und am besten mehr logs bitte und so. Ich kann DAS nicht niachstellen, aber sehe ein anderes issue wenn ich tvprogram installiere und weder web noch vis habe
                                          Zu Fehler 4: Keine Ahnung was du meinst? Was sagt das system am anfang? Die Installation sollte an sich davon unabhängig sein ...Mehr details und Logs bitte
                                            m0rph last edited by m0rph
                                            Also ich kann nach dem Update keine adapter mehr updaten, das Update selbst ist ohne Probleme durchgelaufen bis auf die erwarteten Fehler.
                                            747
                                            194655
