    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
      Krys last edited by
      Moin nochmal, ich hab auch mal die Schritte von @wendy2702 ausgeführt.
      Hat jemand eventuell einen Durchblick?
      Hier der Log:
      2022-02-07 08:02:02.010 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3eaffffffffffffffffffffffffffffffff
      2022-02-07 08:02:12.017 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3f4ffffffffffffffffffffffffffffffff
      2022-02-07 08:02:14.785 - debug: mihome-vacuum.0 (8236) command: roomClean parent: 279001036128
      2022-02-07 08:02:14.789 - debug: mihome-vacuum.0 (8236) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      2022-02-07 08:02:14.794 - debug: mihome-vacuum.0 (8236) We are in onMessage:{"command":"cleanSegments","message":{"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]},"from":"system.adapter.mihome-vacuum.0","_id":36761502}
      2022-02-07 08:02:14.795 - debug: mihome-vacuum.0 (8236) start Cleaning: 18 MObj: {"command":"cleanSegments","message":"18","from":"system.adapter.mihome-vacuum.0","_id":36761502,"segments":[18],"channels":["mihome-vacuum.0.rooms.279001036128"]}
      2022-02-07 08:02:14.797 - info: mihome-vacuum.0 (8236) trigger cleaning segment 18
      2022-02-07 08:02:14.797 - debug: mihome-vacuum.0 (8236) Message= {"id":401,"method":"app_segment_clean","params":[18]}
      2022-02-07 08:02:14.804 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":401}
      2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) command: fan_power parent: control
      2022-02-07 08:02:14.813 - debug: mihome-vacuum.0 (8236) Message= {"id":402,"method":"set_custom_mode","params":[102]}
      2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) command: water_box_mode parent: control
      2022-02-07 08:02:14.816 - debug: mihome-vacuum.0 (8236) Message= {"id":403,"method":"set_water_box_custom_mode","params":[202]}
      2022-02-07 08:02:14.820 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":402}
      2022-02-07 08:02:14.847 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["ok"],"id":403}
      2022-02-07 08:02:22.022 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c3feffffffffffffffffffffffffffffffff
      2022-02-07 08:02:32.028 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c408ffffffffffffffffffffffffffffffff
      2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
      2022-02-07 08:02:40.365 - debug: mihome-vacuum.0 (8236) Message= {"id":404,"method":"get_status"}
      2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":404}
      2022-02-07 08:02:40.375 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":248,"state":18,"battery":100,"clean_time":21,"clean_area":487500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
      2022-02-07 08:02:40.376 - debug: mihome-vacuum.0 (8236) Message= {"id":405,"method":"get_map_v1"}
      2022-02-07 08:02:40.377 - debug: mihome-vacuum.0 (8236) Message= {"id":406,"method":"get_network_info"}
      2022-02-07 08:02:40.392 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":405}
      2022-02-07 08:02:40.413 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":406}
      2022-02-07 08:02:40.485 - debug: mihome-vacuum.0 (8236) Message= {"id":407,"method":"get_sound_volume"}
      2022-02-07 08:02:40.495 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":407}
      2022-02-07 08:02:40.496 - debug: mihome-vacuum.0 (8236) Message= {"id":408,"method":"get_carpet_mode"}
      2022-02-07 08:02:40.506 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":408}
      2022-02-07 08:02:40.693 - debug: mihome-vacuum.0 (8236) Message= {"id":409,"method":"get_map_v1"}
      2022-02-07 08:02:40.704 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["retry"],"id":409}
      2022-02-07 08:02:41.005 - debug: mihome-vacuum.0 (8236) Message= {"id":410,"method":"get_map_v1"}
      2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":410}
      2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:41.016 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:41.017 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:02:41.122 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/3?Expires=1644219161000&GalaxyAccessKeyId=5271733786445&Signature=kZ9D+FdYDl/uXITgiZZe0cpNmWI=
      2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219161
      2022-02-07 08:02:41.123 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217361
      2022-02-07 08:02:41.499 - debug: mihome-vacuum.0 (8236) 25555
      2022-02-07 08:02:42.062 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c412ffffffffffffffffffffffffffffffff
      2022-02-07 08:02:44.555 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:02:44.556 - debug: mihome-vacuum.0 (8236) Message= {"id":411,"method":"get_map_v1"}
      2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":411}
      2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:44.567 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/4?Expires=1644219164000&GalaxyAccessKeyId=5271733786445&Signature=QXqCxEhbSSsV2OkZqb0skSJLxQg=
      2022-02-07 08:02:44.660 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219164
      2022-02-07 08:02:44.661 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217364
      2022-02-07 08:02:45.278 - debug: mihome-vacuum.0 (8236) 25555
      2022-02-07 08:02:47.869 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:02:47.870 - debug: mihome-vacuum.0 (8236) Message= {"id":412,"method":"get_map_v1"}
      2022-02-07 08:02:47.880 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":412}
      2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:47.881 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:02:48.271 - debug: mihome-vacuum.0 (8236) 25430
      2022-02-07 08:02:51.283 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:02:51.284 - debug: mihome-vacuum.0 (8236) Message= {"id":413,"method":"get_map_v1"}
      2022-02-07 08:02:51.296 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":413}
      2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:51.297 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/6?Expires=1644219171000&GalaxyAccessKeyId=5271733786445&Signature=JOVj8sTRRKKGWO3ButFXYYK6Nvc=
      2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219171
      2022-02-07 08:02:51.396 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217371
      2022-02-07 08:02:51.738 - debug: mihome-vacuum.0 (8236) 25238
      2022-02-07 08:02:52.259 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c41cffffffffffffffffffffffffffffffff
      2022-02-07 08:02:54.266 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:02:54.267 - debug: mihome-vacuum.0 (8236) Message= {"id":414,"method":"get_map_v1"}
      2022-02-07 08:02:54.275 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F7"],"id":414}
      2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:54.276 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:02:54.373 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/7?Expires=1644219174000&GalaxyAccessKeyId=5271733786445&Signature=QljmeiJHnN58Bu5siK+1HzGCs0k=
      2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219174
      2022-02-07 08:02:54.374 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217374
      2022-02-07 08:02:54.713 - debug: mihome-vacuum.0 (8236) 25312
      2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:02:57.788 - debug: mihome-vacuum.0 (8236) Message= {"id":415,"method":"get_map_v1"}
      2022-02-07 08:02:57.797 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":415}
      2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:02:57.798 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:02:57.799 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:02:57.874 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219177000&GalaxyAccessKeyId=5271733786445&Signature=qNhKJEZI78kvEMMQyBq/6R12N2U=
      2022-02-07 08:02:57.875 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219177
      2022-02-07 08:02:57.876 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217377
      2022-02-07 08:02:58.264 - debug: mihome-vacuum.0 (8236) 25354
      2022-02-07 08:03:00.838 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:00.840 - debug: mihome-vacuum.0 (8236) Message= {"id":416,"method":"get_map_v1"}
      2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F9"],"id":416}
      2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:00.858 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:00.859 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/9?Expires=1644219180000&GalaxyAccessKeyId=5271733786445&Signature=91LtXBVlrvGVblqAnfUsY9OmOeY=
      2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219180
      2022-02-07 08:03:00.958 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217380
      2022-02-07 08:03:01.270 - debug: mihome-vacuum.0 (8236) 25615
      2022-02-07 08:03:02.265 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c426ffffffffffffffffffffffffffffffff
      2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:04.242 - debug: mihome-vacuum.0 (8236) Message= {"id":417,"method":"get_map_v1"}
      2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F10"],"id":417}
      2022-02-07 08:03:04.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:04.256 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/10?Expires=1644219184000&GalaxyAccessKeyId=5271733786445&Signature=s4g+g1JZ/7hruZRLoo6u/QQowKc=
      2022-02-07 08:03:04.330 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219184
      2022-02-07 08:03:04.331 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217384
      2022-02-07 08:03:04.721 - debug: mihome-vacuum.0 (8236) 26110
      2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:07.288 - debug: mihome-vacuum.0 (8236) Message= {"id":418,"method":"get_map_v1"}
      2022-02-07 08:03:07.303 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F11"],"id":418}
      2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:07.304 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:07.409 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/11?Expires=1644219187000&GalaxyAccessKeyId=5271733786445&Signature=k0ovE5vRzOVlmC4bFnQWeGspjOE=
      2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219187
      2022-02-07 08:03:07.410 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217387
      2022-02-07 08:03:07.766 - debug: mihome-vacuum.0 (8236) 26406
      2022-02-07 08:03:10.754 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:10.755 - debug: mihome-vacuum.0 (8236) Message= {"id":419,"method":"get_map_v1"}
      2022-02-07 08:03:10.767 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F12"],"id":419}
      2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:10.768 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:10.769 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:10.871 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/12?Expires=1644219190000&GalaxyAccessKeyId=5271733786445&Signature=9L9+XjC6vv+u5bj8v1wxLvUUqYo=
      2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219190
      2022-02-07 08:03:10.872 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217390
      2022-02-07 08:03:11.256 - debug: mihome-vacuum.0 (8236) 26244
      2022-02-07 08:03:12.270 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c430ffffffffffffffffffffffffffffffff
      2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:13.781 - debug: mihome-vacuum.0 (8236) Message= {"id":420,"method":"get_map_v1"}
      2022-02-07 08:03:13.791 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F13"],"id":420}
      2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:13.792 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/13?Expires=1644219193000&GalaxyAccessKeyId=5271733786445&Signature=gaCFlo3zCP1aFleus0VRNaD/MbA=
      2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219193
      2022-02-07 08:03:13.900 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217393
      2022-02-07 08:03:14.265 - debug: mihome-vacuum.0 (8236) 25683
      2022-02-07 08:03:17.230 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:17.231 - debug: mihome-vacuum.0 (8236) Message= {"id":421,"method":"get_map_v1"}
      2022-02-07 08:03:17.254 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F14"],"id":421}
      2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:17.255 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/14?Expires=1644219197000&GalaxyAccessKeyId=5271733786445&Signature=g6zYQULvIEANtK+tZ3N3skLL+o0=
      2022-02-07 08:03:17.324 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219197
      2022-02-07 08:03:17.325 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217397
      2022-02-07 08:03:17.651 - debug: mihome-vacuum.0 (8236) 25668
      2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:20.191 - debug: mihome-vacuum.0 (8236) Message= {"id":422,"method":"get_map_v1"}
      2022-02-07 08:03:20.199 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F15"],"id":422}
      2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:20.200 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:20.298 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/15?Expires=1644219200000&GalaxyAccessKeyId=5271733786445&Signature=LPyMXhuNtIy9L4Sgs0Ks7HZSDxY=
      2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219200
      2022-02-07 08:03:20.299 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217400
      2022-02-07 08:03:20.641 - debug: mihome-vacuum.0 (8236) 25684
      2022-02-07 08:03:22.276 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c43affffffffffffffffffffffffffffffff
      2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:23.581 - debug: mihome-vacuum.0 (8236) Message= {"id":423,"method":"get_map_v1"}
      2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F16"],"id":423}
      2022-02-07 08:03:23.591 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:23.592 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:23.685 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/16?Expires=1644219203000&GalaxyAccessKeyId=5271733786445&Signature=XoFLOHO5qmhJsdlSqSqXXDlulfA=
      2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219203
      2022-02-07 08:03:23.686 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217403
      2022-02-07 08:03:24.117 - debug: mihome-vacuum.0 (8236) 26057
      2022-02-07 08:03:26.650 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:26.651 - debug: mihome-vacuum.0 (8236) Message= {"id":424,"method":"get_map_v1"}
      2022-02-07 08:03:26.663 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F17"],"id":424}
      2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:26.664 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/17?Expires=1644219206000&GalaxyAccessKeyId=5271733786445&Signature=Maxdse16d0Hv3gsCI7ZJH91xkEE=
      2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219206
      2022-02-07 08:03:26.756 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217406
      2022-02-07 08:03:27.064 - debug: mihome-vacuum.0 (8236) 26325
      2022-02-07 08:03:30.054 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:30.055 - debug: mihome-vacuum.0 (8236) Message= {"id":425,"method":"get_map_v1"}
      2022-02-07 08:03:30.074 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F0"],"id":425}
      2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:30.075 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:30.076 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:03:30.574 - debug: mihome-vacuum.0 (8236) 26198
      2022-02-07 08:03:32.283 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c444ffffffffffffffffffffffffffffffff
      2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:33.179 - debug: mihome-vacuum.0 (8236) Message= {"id":426,"method":"get_map_v1"}
      2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F1"],"id":426}
      2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:33.193 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:33.285 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/1?Expires=1644219213000&GalaxyAccessKeyId=5271733786445&Signature=TPYft0tbjPJPeVAVgMRG5KyDCNQ=
      2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219213
      2022-02-07 08:03:33.287 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217413
      2022-02-07 08:03:33.628 - debug: mihome-vacuum.0 (8236) 25786
      2022-02-07 08:03:36.615 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:36.616 - debug: mihome-vacuum.0 (8236) Message= {"id":427,"method":"get_map_v1"}
      2022-02-07 08:03:36.627 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F2"],"id":427}
      2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:36.628 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:36.629 - debug: mihome-vacuum.0 (8236) update_Map need new mapurl
      2022-02-07 08:03:36.739 - debug: mihome-vacuum.0 (8236) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/2?Expires=1644219216000&GalaxyAccessKeyId=5271733786445&Signature=rPO65+y7scFkbOvqG7y727RptP0=
      2022-02-07 08:03:36.741 - debug: mihome-vacuum.0 (8236) update_Map got new expires:1644219216
      2022-02-07 08:03:36.742 - debug: mihome-vacuum.0 (8236) update_Map got new time:1644217416
      2022-02-07 08:03:37.113 - debug: mihome-vacuum.0 (8236) 25588
      2022-02-07 08:03:39.655 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:39.656 - debug: mihome-vacuum.0 (8236) Message= {"id":428,"method":"get_map_v1"}
      2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F3"],"id":428}
      2022-02-07 08:03:39.667 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:39.668 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:03:40.045 - debug: mihome-vacuum.0 (8236) 25314
      2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) get params for stock Vacuum
      2022-02-07 08:03:41.011 - debug: mihome-vacuum.0 (8236) Message= {"id":429,"method":"get_status"}
      2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":429}
      2022-02-07 08:03:41.023 - debug: mihome-vacuum.0 (8236) setGetStatus {"msg_ver":2,"msg_seq":249,"state":18,"battery":100,"clean_time":80,"clean_area":1470000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
      2022-02-07 08:03:41.024 - debug: mihome-vacuum.0 (8236) Message= {"id":430,"method":"get_network_info"}
      2022-02-07 08:03:41.069 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":430}
      2022-02-07 08:03:41.174 - debug: mihome-vacuum.0 (8236) Message= {"id":431,"method":"get_sound_volume"}
      2022-02-07 08:03:41.183 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[79],"id":431}
      2022-02-07 08:03:41.184 - debug: mihome-vacuum.0 (8236) Message= {"id":432,"method":"get_carpet_mode"}
      2022-02-07 08:03:41.196 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":432}
      2022-02-07 08:03:42.312 - debug: mihome-vacuum.0 (8236) Receive <<< Helo <<< 213100200000000018cce8a76200c44effffffffffffffffffffffffffffffff
      2022-02-07 08:03:43.011 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:43.012 - debug: mihome-vacuum.0 (8236) Message= {"id":433,"method":"get_map_v1"}
      2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F4"],"id":433}
      2022-02-07 08:03:43.049 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:43.050 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:03:43.416 - debug: mihome-vacuum.0 (8236) 25246
      2022-02-07 08:03:46.012 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:46.013 - debug: mihome-vacuum.0 (8236) Message= {"id":434,"method":"get_map_v1"}
      2022-02-07 08:03:46.023 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F5"],"id":434}
      2022-02-07 08:03:46.024 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:46.025 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:03:46.408 - debug: mihome-vacuum.0 (8236) 25246
      2022-02-07 08:03:49.367 - debug: mihome-vacuum.0 (8236) Get Mappointer while cleaning
      2022-02-07 08:03:49.368 - debug: mihome-vacuum.0 (8236) Message= {"id":435,"method":"get_map_v1"}
      2022-02-07 08:03:49.379 - debug: mihome-vacuum.0 (8236) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F6"],"id":435}
      2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) Mappointer_updated
      2022-02-07 08:03:49.380 - debug: mihome-vacuum.0 (8236) update_Map Mimap enabled
      2022-02-07 08:03:49.381 - debug: mihome-vacuum.0 (8236) update_Map use old mapurl
      2022-02-07 08:03:49.754 - debug: mihome-vacuum.0 (8236) 25319
      2022-02-07 08:03:50.480 - error: host.raspberrypi Caught by controller[0]: -vacuum.0: ../node_modules/nan/nan_object_wrap.h:125: static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&): Assertion `wrap->refs_ == 0' failed.
      2022-02-07 08:03:50.485 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
      2022-02-07 08:03:50.486 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
      2022-02-07 08:04:20.548 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4153
      2022-02-07 08:04:22.550 - debug: mihome-vacuum.0 (4153) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-02-07 08:04:22.609 - debug: mihome-vacuum.0 (4153) Objects client ready ... initialize now
      2022-02-07 08:04:22.626 - debug: mihome-vacuum.0 (4153) Objects create System PubSub Client
      2022-02-07 08:04:22.628 - debug: mihome-vacuum.0 (4153) Objects create User PubSub Client
      2022-02-07 08:04:22.629 - debug: mihome-vacuum.0 (4153) Objects client initialize lua scripts
      2022-02-07 08:04:22.656 - debug: mihome-vacuum.0 (4153) Objects connected to redis: 127.0.0.1:9001
      2022-02-07 08:04:22.667 - debug: mihome-vacuum.0 (4153) objectDB connected
      2022-02-07 08:04:22.670 - debug: mihome-vacuum.0 (4153) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-02-07 08:04:22.686 - debug: mihome-vacuum.0 (4153) States create System PubSub Client
      2022-02-07 08:04:22.687 - debug: mihome-vacuum.0 (4153) States create User PubSub Client
      2022-02-07 08:04:22.709 - debug: mihome-vacuum.0 (4153) States connected to redis: 127.0.0.1:9000
      2022-02-07 08:04:22.710 - debug: mihome-vacuum.0 (4153) statesDB connected
      2022-02-07 08:04:23.340 - debug: mihome-vacuum.0 (4153) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-07 08:04:23.732 - info: mihome-vacuum.0 (4153) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
      2022-02-07 08:04:23.843 - debug: mihome-vacuum.0 (4153) load Map creator... true
      2022-02-07 08:04:24.449 - debug: mihome-vacuum.0 (4153) Create State for deviceInfo
      2022-02-07 08:04:24.453 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomac
      2022-02-07 08:04:24.459 - debug: mihome-vacuum.0 (4153) Create State for deviceInfomodel
      2022-02-07 08:04:24.461 - debug: mihome-vacuum.0 (4153) Create State for deviceInfofw_ver
      2022-02-07 08:04:24.462 - debug: mihome-vacuum.0 (4153) Create State for deviceInfowifi_signal
      2022-02-07 08:04:24.463 - debug: mihome-vacuum.0 (4153) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
      2022-02-07 08:04:24.468 - info: mihome-vacuum.0 (4153) IOT enabled, create state
      2022-02-07 08:04:24.476 - debug: mihome-vacuum.0 (4153) server started on 0.0.0.0:53421
      2022-02-07 08:04:24.490 - debug: mihome-vacuum.0 (4153) Receive <<< Helo <<< 213100200000000018cce8a76200c479ffffffffffffffffffffffffffffffff
      2022-02-07 08:04:24.491 - debug: mihome-vacuum.0 (4153) MAIN: Connected to device, try to get model..
      2022-02-07 08:04:24.494 - debug: mihome-vacuum.0 (4153) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2022-02-07 08:04:24.555 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644212115379,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
      2022-02-07 08:04:24.559 - debug: mihome-vacuum.0 (4153) Message= {"id":1,"method":"miIO.info"}
      2022-02-07 08:04:24.581 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
      2022-02-07 08:04:24.583 - debug: mihome-vacuum.0 (4153) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1566","ap":{"ssid":"Krystian","bssid":"00:5f:67:a3:93:84","rssi":-55},"netif":{"localIp":"192.168.178.58","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"B0:4A:39:13:19:DC","token":"62435048385749766e48576b37643449","life":15495}}
      2022-02-07 08:04:24.584 - debug: mihome-vacuum.0 (4153) Get Device data..0
      2022-02-07 08:04:24.585 - debug: mihome-vacuum.0 (4153) Get Device data from robot..
      2022-02-07 08:04:24.743 - debug: mihome-vacuum.0 (4153) DeviceModel selected to: roborock.vacuum.s5e
      2022-02-07 08:04:24.745 - info: mihome-vacuum.0 (4153) select standard vacuum protocol....
      2022-02-07 08:04:24.760 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Logging in
      2022-02-07 08:04:24.847 - debug: mihome-vacuum.0 (4153) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      2022-02-07 08:04:24.977 - debug: mihome-vacuum.0 (4153) Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
      2022-02-07 08:04:25.154 - debug: mihome-vacuum.0 (4153) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"wuSHUJeKc6HMhYWRCti0gg==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCRz7Q/RqjLTS3lbmKzg+q/22dNT+UcWAEgbFu9THRoseGojPLM5s8t4nH37bhEOrR7Meo/fhoeQ1f5pj7NL88F+45TiFuUapnNQaPDcPx0vp+qKSAAYGLOwChuR8Uo5JZrOyZWVlpg9OqrVlkyvr+hxELA8inBOJ0Kiuwhjj/BWmOpk59WDcB8iKlcgqqLGfMwyoxDyFb6ThAwnq9YKcqiQWf2CL4AKAC8CHBBGiug+jJ47mC2H4jKZglQzdWVw6Q34OyFvq1SNs7HG/woTrIcI=","description":"成功","securityStatus":0,"nonce":4666761058257411072,"userId":1669572361,"cUserId":"86_CG49N742pAF3a6YHfpffTQtQ","result":"ok","psecurity":"95LpPnR65AoP22oyffzJZw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=eilkfp&ticket=0&pwd=1&p_ts=1644217465000&fid=0&p_lm=1&auth=TVxiC72aDVg0qrlNI%2FeOG4zf0QMYoNNXPfh%2Fmee2Mlb0VoBvrR7ZyVebqWb8sqOCuS8RwvxfrnwOrgojDDqqE3XKJaRVo17mNKuE97uMIFWQSUmg0mO6GUzqWUALFrtCykxS9Cr%2BpPPJjgQH1Kk9f6zQmu25QeRXF9xyClWSVQ8%3D&m=1&tsl=0&nonce=2iQsgSYtnpcBoiVo&_ssign=k%2FnkQd%2FwFXEobjI8lJ1VVc8KfFQ%3D","pwd":1,"desc":"成功"}
      2022-02-07 08:04:25.327 - info: mihome-vacuum.0 (4153) settest next timer: not available
      2022-02-07 08:04:25.698 - debug: mihome-vacuum.0 (4153) Login step3: [{"key":"userId","value":"1669572361","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.669Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"cUserId","value":"86_CG49N742pAF3a6YHfpffTQtQ","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.680Z","lastAccessed":"2022-02-07T07:04:25.696Z"},{"key":"serviceToken","value":"u7ya0zGFshh2//i/lnx/mbrK7f0f/8fOmtUTmckUQSZIL+zxDyQqStIc2DcIEEN+frAAS+AQ4zqUIJD667DYgjBxu3pfcg5oUVVHqZQsk0ayp6NVpKdBpZimcin38cIF+vW1A3pU1wEVp7u+XtYgrg9CEHV1Ztl/aKOoZRTQnhE=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-02-07T07:04:25.687Z","lastAccessed":"2022-02-07T07:04:25.696Z"}]
      2022-02-07 08:04:25.699 - debug: mihome-vacuum.0 (4153) Xiaomi Cloud: Login successful
      2022-02-07 08:04:25.719 - debug: mihome-vacuum.0 (4153) Create State for Queue: queue
      2022-02-07 08:04:25.720 - debug: mihome-vacuum.0 (4153) Create State for Queue: clearQueue
      2022-02-07 08:04:25.721 - info: mihome-vacuum.0 (4153) Map selected create states...
      2022-02-07 08:04:25.725 - debug: mihome-vacuum.0 (4153) Create State for map:
      2022-02-07 08:04:25.727 - debug: mihome-vacuum.0 (4153) Create State for map: map64
      2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: actualMap
      2022-02-07 08:04:25.728 - debug: mihome-vacuum.0 (4153) Create State for map: mapStatus
      2022-02-07 08:04:25.729 - debug: mihome-vacuum.0 (4153) Create State for map: mapURL
      2022-02-07 08:04:25.731 - debug: mihome-vacuum.0 (4153) Create State for map: loadMap
      2022-02-07 08:04:25.733 - debug: mihome-vacuum.0 (4153) Create State done!
      2022-02-07 08:04:25.735 - debug: mihome-vacuum.0 (4153) get params for stock Vacuum
      2022-02-07 08:04:25.736 - debug: mihome-vacuum.0 (4153) Message= {"id":2,"method":"get_status"}
      2022-02-07 08:04:25.752 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0}],"id":2}
      2022-02-07 08:04:25.755 - debug: mihome-vacuum.0 (4153) setGetStatus {"msg_ver":2,"msg_seq":250,"state":18,"battery":100,"clean_time":128,"clean_area":2550000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"error_text":"No error"}
      2022-02-07 08:04:25.758 - info: mihome-vacuum.0 (4153) change states from State control.fan_power
      2022-02-07 08:04:25.778 - info: mihome-vacuum.0 (4153) create states for water box
      2022-02-07 08:04:25.786 - info: mihome-vacuum.0 (4153) create states for water box mode
      2022-02-07 08:04:25.790 - info: mihome-vacuum.0 (4153) create states for mop
      2022-02-07 08:04:25.846 - info: mihome-vacuum.0 (4153) State value to set for "mihome-vacuum.0.cleanmap.actualMap" has to be type "string" but received type "number"
      2022-02-07 08:04:25.921 - debug: mihome-vacuum.0 (4153) Message= {"id":3,"method":"get_map_v1"}
      2022-02-07 08:04:25.931 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["retry"],"id":3}
      2022-02-07 08:04:26.233 - debug: mihome-vacuum.0 (4153) Message= {"id":4,"method":"get_map_v1"}
      2022-02-07 08:04:26.325 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":4}
      2022-02-07 08:04:26.326 - debug: mihome-vacuum.0 (4153) Mappointer_updated
      2022-02-07 08:04:26.327 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
      2022-02-07 08:04:26.328 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
      2022-02-07 08:04:26.335 - debug: mihome-vacuum.0 (4153) Message= {"id":5,"method":"get_room_mapping"}
      2022-02-07 08:04:26.425 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[16,"279001039807"],[17,"279001039878"],[18,"279001036128"],[19,"279001039845"],[20,"279001039844"],[21,"279001039841"],[22,"279001039842"]],"id":5}
      2022-02-07 08:04:26.428 - debug: mihome-vacuum.0 (4153) Message= {"id":6,"method":"get_map_v1"}
      2022-02-07 08:04:26.430 - debug: mihome-vacuum.0 (4153) Message= {"id":7,"method":"get_network_info"}
      2022-02-07 08:04:26.441 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":["rubyslite%2F416082087%2F8"],"id":6}
      2022-02-07 08:04:26.442 - debug: mihome-vacuum.0 (4153) Mappointer_updated
      2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map Mimap enabled
      2022-02-07 08:04:26.443 - debug: mihome-vacuum.0 (4153) update_Map need new mapurl
      2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
      2022-02-07 08:04:26.466 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
      2022-02-07 08:04:26.468 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
      2022-02-07 08:04:26.490 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":{"ssid":"Krystian","ip":"192.168.178.58","mac":"b0:4a:39:13:19:dc","bssid":"00:5f:67:a3:93:84","rssi":-51},"id":7}
      2022-02-07 08:04:26.556 - debug: mihome-vacuum.0 (4153) Message= {"id":8,"method":"get_sound_volume"}
      2022-02-07 08:04:26.568 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[79],"id":8}
      2022-02-07 08:04:26.571 - debug: mihome-vacuum.0 (4153) Message= {"id":9,"method":"get_multi_maps_list"}
      2022-02-07 08:04:26.580 - debug: mihome-vacuum.0 (4153) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/416082087/8?Expires=1644219266000&GalaxyAccessKeyId=5271733786445&Signature=db2xT7xt6iD/9aiHnVfhBnCQXW8=
      2022-02-07 08:04:26.581 - debug: mihome-vacuum.0 (4153) update_Map got new expires:1644219266
      2022-02-07 08:04:26.582 - debug: mihome-vacuum.0 (4153) update_Map got new time:1644217466
      2022-02-07 08:04:26.597 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]}],"id":9}
      2022-02-07 08:04:26.599 - debug: mihome-vacuum.0 (4153) States for 1 Map: [{"mapFlag":0,"add_time":1644162511,"length":16,"name":"Werler Str. 235 ","bak_maps":[]}]
      2022-02-07 08:04:26.600 - debug: mihome-vacuum.0 (4153) States for Map: {"0":"Werler Str. 235 "}
      2022-02-07 08:04:26.604 - debug: mihome-vacuum.0 (4153) Startup: getMultiMapsList Answer: true
      2022-02-07 08:04:26.605 - debug: mihome-vacuum.0 (4153) Startup: Delete getMultiMapsList
      2022-02-07 08:04:26.606 - debug: mihome-vacuum.0 (4153) Message= {"id":10,"method":"get_clean_summary"}
      2022-02-07 08:04:26.623 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[52822,803020000,88,[1644160121,1644133383,1644044493,1643977111,1643975328,1643974745,1643965653,1643905243,1643901690,1643887247,1643875796,1643805243,1643797070,1643788111,1643785174,1643732552,1643729608,1643720501,1643720432,1643720002]],"id":10}
      2022-02-07 08:04:26.629 - debug: mihome-vacuum.0 (4153) Message= {"id":11,"method":"get_clean_record","params":[1644160121]}
      2022-02-07 08:04:26.641 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644160121,1644162495,2374,37522500,0,1,2,1,52]],"id":11}
      2022-02-07 08:04:26.643 - debug: mihome-vacuum.0 (4153) Message= {"id":12,"method":"get_clean_record","params":[1644133383]}
      2022-02-07 08:04:26.658 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644133383,1644137484,3347,28290000,0,0,2,3,60]],"id":12}
      2022-02-07 08:04:26.660 - debug: mihome-vacuum.0 (4153) Message= {"id":13,"method":"get_clean_record","params":[1644044493]}
      2022-02-07 08:04:26.674 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1644044493,1644046203,1710,29342500,0,1,2,3,56]],"id":13}
      2022-02-07 08:04:26.675 - debug: mihome-vacuum.0 (4153) Message= {"id":14,"method":"get_clean_record","params":[1643977111]}
      2022-02-07 08:04:26.688 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643977111,1643979360,2249,35265000,0,1,2,1,52]],"id":14}
      2022-02-07 08:04:26.690 - debug: mihome-vacuum.0 (4153) Message= {"id":15,"method":"get_clean_record","params":[1643975328]}
      2022-02-07 08:04:26.699 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643975328,1643975615,287,3947500,0,1,2,3,56]],"id":15}
      2022-02-07 08:04:26.701 - debug: mihome-vacuum.0 (4153) Message= {"id":16,"method":"get_clean_record","params":[1643974745]}
      2022-02-07 08:04:26.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643974745,1643975104,359,5960000,0,1,2,3,56]],"id":16}
      2022-02-07 08:04:26.720 - debug: mihome-vacuum.0 (4153) Message= {"id":17,"method":"get_clean_record","params":[1643965653]}
      2022-02-07 08:04:26.735 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643965653,1643966406,753,12455000,0,1,2,3,56]],"id":17}
      2022-02-07 08:04:26.737 - debug: mihome-vacuum.0 (4153) Message= {"id":18,"method":"get_clean_record","params":[1643905243]}
      2022-02-07 08:04:26.770 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643905243,1643906212,969,16470000,0,1,2,3,56]],"id":18}
      2022-02-07 08:04:26.771 - debug: mihome-vacuum.0 (4153) Message= {"id":19,"method":"get_clean_record","params":[1643901690]}
      2022-02-07 08:04:26.783 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643901690,1643903137,1447,23562500,0,1,2,3,56]],"id":19}
      2022-02-07 08:04:26.785 - debug: mihome-vacuum.0 (4153) Message= {"id":20,"method":"get_clean_record","params":[1643887247]}
      2022-02-07 08:04:26.797 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643887247,1643887856,605,9045000,0,0,2,1,60]],"id":20}
      2022-02-07 08:04:26.798 - debug: mihome-vacuum.0 (4153) Message= {"id":21,"method":"get_clean_record","params":[1643875796]}
      2022-02-07 08:04:27.121 - debug: mihome-vacuum.0 (4153) 26880
      2022-02-07 08:04:27.721 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643875796,1643875823,27,0,0,0,2,1,60]],"id":21}
      2022-02-07 08:04:27.723 - debug: mihome-vacuum.0 (4153) Message= {"id":22,"method":"get_clean_record","params":[1643805243]}
      2022-02-07 08:04:28.121 - debug: mihome-vacuum.0 (4153) 26880
      2022-02-07 08:04:28.672 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643805243,1643805481,236,4040000,0,0,2,1,60]],"id":22}
      2022-02-07 08:04:28.674 - debug: mihome-vacuum.0 (4153) Message= {"id":23,"method":"get_clean_record","params":[1643797070]}
      2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643797070,1643800012,2436,38702500,0,1,2,1,52]],"id":23}
      2022-02-07 08:04:28.689 - debug: mihome-vacuum.0 (4153) Message= {"id":24,"method":"get_clean_record","params":[1643788111]}
      2022-02-07 08:04:28.707 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643788111,1643788348,237,3467500,0,1,2,3,56]],"id":24}
      2022-02-07 08:04:28.708 - debug: mihome-vacuum.0 (4153) Message= {"id":25,"method":"get_clean_record","params":[1643785174]}
      2022-02-07 08:04:28.718 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643785174,1643785476,302,4052500,0,1,2,3,56]],"id":25}
      2022-02-07 08:04:28.719 - debug: mihome-vacuum.0 (4153) Message= {"id":26,"method":"get_clean_record","params":[1643732552]}
      2022-02-07 08:04:28.733 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643732552,1643734826,2274,37185000,0,1,2,1,52]],"id":26}
      2022-02-07 08:04:28.734 - debug: mihome-vacuum.0 (4153) Message= {"id":27,"method":"get_clean_record","params":[1643729608]}
      2022-02-07 08:04:28.743 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643729608,1643729616,8,0,0,0,2,1,60]],"id":27}
      2022-02-07 08:04:28.744 - debug: mihome-vacuum.0 (4153) Message= {"id":28,"method":"get_clean_record","params":[1643720501]}
      2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720501,1643720513,12,245000,0,0,2,3,60]],"id":28}
      2022-02-07 08:04:28.772 - debug: mihome-vacuum.0 (4153) Message= {"id":29,"method":"get_clean_record","params":[1643720432]}
      2022-02-07 08:04:28.784 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720432,1643720461,29,0,0,0,2,1,60]],"id":29}
      2022-02-07 08:04:28.785 - debug: mihome-vacuum.0 (4153) Message= {"id":30,"method":"get_clean_record","params":[1643720002]}
      2022-02-07 08:04:28.796 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[[1643720002,1643720057,55,0,0,0,2,1,60]],"id":30}
      2022-02-07 08:04:28.797 - debug: mihome-vacuum.0 (4153) finish logs all [{"Datum":"6.2","Start":"16:08","Saugzeit":"40 min","Fläche":"37.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"08:43","Saugzeit":"56 min","Fläche":"28.29 m²","Error":0,"Ende":false},{"Datum":"5.2","Start":"08:01","Saugzeit":"29 min","Fläche":"29.34 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"13:18","Saugzeit":"37 min","Fläche":"35.27 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:48","Saugzeit":"5 min","Fläche":"3.95 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"12:39","Saugzeit":"6 min","Fläche":"5.96 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"10:07","Saugzeit":"13 min","Fläche":"12.46 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"17:20","Saugzeit":"16 min","Fläche":"16.47 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"16:21","Saugzeit":"24 min","Fläche":"23.56 m²","Error":0,"Ende":true},{"Datum":"3.2","Start":"12:20","Saugzeit":"10 min","Fläche":"9.05 m²","Error":0,"Ende":false},{"Datum":"3.2","Start":"09:09","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"13:34","Saugzeit":"4 min","Fläche":"4.04 m²","Error":0,"Ende":false},{"Datum":"2.2","Start":"11:17","Saugzeit":"41 min","Fläche":"38.7 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"08:48","Saugzeit":"4 min","Fläche":"3.47 m²","Error":0,"Ende":true},{"Datum":"2.2","Start":"07:59","Saugzeit":"5 min","Fläche":"4.05 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"17:22","Saugzeit":"38 min","Fläche":"37.19 m²","Error":0,"Ende":true},{"Datum":"1.2","Start":"16:33","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:01","Saugzeit":"0 min","Fläche":"0.25 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"14:00","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"1.2","Start":"13:53","Saugzeit":"1 min","Fläche":"0 m²","Error":0,"Ende":false}]
      2022-02-07 08:04:28.801 - debug: mihome-vacuum.0 (4153) Startup: setGetCleanSummary Answer: true
      2022-02-07 08:04:28.802 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetCleanSummary
      2022-02-07 08:04:28.804 - debug: mihome-vacuum.0 (4153) Message= {"id":31,"method":"get_consumable"}
      2022-02-07 08:04:28.816 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"main_brush_work_time":52916,"side_brush_work_time":52916,"filter_work_time":52916,"filter_element_work_time":2217,"sensor_dirty_time":52822}],"id":31}
      2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: setGetConsumable Answer: true
      2022-02-07 08:04:28.818 - debug: mihome-vacuum.0 (4153) Startup: Delete setGetConsumable
      2022-02-07 08:04:28.820 - debug: mihome-vacuum.0 (4153) Message= {"id":32,"method":"get_carpet_mode"}
      2022-02-07 08:04:28.838 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
      2022-02-07 08:04:28.838 - info: mihome-vacuum.0 (4153) create state for carpet_mode
      2022-02-07 08:04:28.839 - debug: mihome-vacuum.0 (4153) Message= {"id":33,"method":"get_carpet_mode"}
      2022-02-07 08:04:28.863 - debug: mihome-vacuum.0 (4153) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
      2022-02-07 08:04:30.701 - debug: mihome-vacuum.0 (4153) Get Mappointer while cleaning
      2022-02-07 08:04:32.083 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
      2022-02-07 08:04:32.084 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
      2022-02-07 08:04:32.084 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
      2022-02-07 08:04:32.121 - info: web-speedy.0 (11730) The speed test has been completed successfully.
      2022-02-07 08:05:02.141 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 4591
      2022-02-07 08:05:03.727 - debug: mihome-vacuum.0 (4591) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-02-07 08:05:03.809 - debug: mihome-vacuum.0 (4591) Objects client ready ... initialize now
      2022-02-07 08:05:03.813 - debug: mihome-vacuum.0 (4591) Objects create System PubSub Client
      2022-02-07 08:05:03.816 - debug: mihome-vacuum.0 (4591) Objects create User PubSub Client
      2022-02-07 08:05:03.817 - debug: mihome-vacuum.0 (4591) Objects client initialize lua scripts
      2022-02-07 08:05:03.847 - debug: mihome-vacuum.0 (4591) Objects connected to redis: 127.0.0.1:9001
      2022-02-07 08:05:03.858 - debug: mihome-vacuum.0 (4591) objectDB connected
      2022-02-07 08:05:03.861 - debug: mihome-vacuum.0 (4591) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-02-07 08:05:03.878 - debug: mihome-vacuum.0 (4591) States create System PubSub Client
      2022-02-07 08:05:03.879 - debug: mihome-vacuum.0 (4591) States create User PubSub Client
      2022-02-07 08:05:03.903 - debug: mihome-vacuum.0 (4591) States connected to redis: 127.0.0.1:9000
      2022-02-07 08:05:03.905 - debug: mihome-vacuum.0 (4591) statesDB connected
      2022-02-07 08:05:04.688 - debug: mihome-vacuum.0 (4591) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-07 08:05:04.926 - info: mihome-vacuum.0 (4591) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 3.3.22
      2022-02-07 08:05:05.018 - debug: mihome-vacuum.0 (4591) load Map creator... true
      2022-02-07 08:05:05.054 - debug: mihome-vacuum.0 (4591) Create State for deviceInfo
      2022-02-07 08:05:05.055 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomac
      2022-02-07 08:05:05.056 - debug: mihome-vacuum.0 (4591) Create State for deviceInfomodel
      2022-02-07 08:05:05.057 - debug: mihome-vacuum.0 (4591) Create State for deviceInfofw_ver
      2022-02-07 08:05:05.058 - debug: mihome-vacuum.0 (4591) Create State for deviceInfowifi_signal
      2022-02-07 08:05:05.059 - debug: mihome-vacuum.0 (4591) MIIO: Config: ip:192.168.178.58 token: 62435048385749766e48576b37643449
      2022-02-07 08:05:05.064 - info: mihome-vacuum.0 (4591) IOT enabled, create state
      2022-02-07 08:05:05.069 - debug: mihome-vacuum.0 (4591) server started on 0.0.0.0:53421
      2022-02-07 08:05:05.097 - debug: mihome-vacuum.0 (4591) Receive <<< Helo <<< 213100200000000018cce8a76200c4a1ffffffffffffffffffffffffffffffff
      2022-02-07 08:05:05.098 - debug: mihome-vacuum.0 (4591) MAIN: Connected to device, try to get model..
      2022-02-07 08:05:05.102 - debug: mihome-vacuum.0 (4591) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1644217464631,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1643712474446}
      2022-02-07 08:05:05.104 - debug: mihome-vacuum.0 (4591) Message= {"id":1,"method":"miIO.info"}
      Rest folgt..
        Krys last edited by Krys
        Dann ein mal "top":
        pi@raspberrypi:~ $ top
        top - 08:09:58 up 5 days, 22:07,  1 user,  load average: 0.66, 0.96, 1.00
        Tasks: 178 total,   2 running, 176 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 11.2 us,  5.1 sy,  0.2 ni, 82.8 id,  0.0 wa,  0.0 hi,  0.7 si,  0.0 st
        MiB Mem :   3838.7 total,    477.7 free,   2311.3 used,   1049.7 buff/cache
        MiB Swap:    100.0 total,     83.2 free,     16.8 used.   1880.1 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
         8652 iobroker  20   0  292988 187668  34232 S  18.2   4.8   1011:16 iobroker.js-con
          569 root      20   0  317376 138804  25900 S  11.3   3.5   4061:23 motion
         9943 iobroker  20   0  193116  79904  28928 S   5.0   2.0  39:46.05 io.net-tools.0
         9256 iobroker  20   0  213924  93448  29084 S   4.6   2.4 169:04.11 io.hue.0
        11069 iobroker  20   0  184288  71588  29012 R   3.6   1.8 181:35.12 io.switchbot-bl
         8806 iobroker  20   0  262860 153448  34168 S   3.3   3.9 165:16.32 io.javascript.0
         8701 iobroker  20   0  239256 120404  34756 S   2.0   3.1  15:11.00 io.admin.0
          549 root      39  19   58424   6536   3504 S   0.7   0.2  14:44.84 rpimonitord
         8852 iobroker  20   0  197952  69400  29660 S   0.7   1.8   7:18.09 io.telegram.0
        28966 iobroker  20   0  191620  70628  29868 S   0.7   1.8   1:39.92 io.cloud.0
          356 pi        20   0  129404  41904  30744 S   0.3   1.1  72:02.59 deCONZ
          363 root      20   0    8336   3228   2564 S   0.3   0.1  25:53.14 deCONZ-WIFI2.sh
         1293 iobroker  20   0  185832  79628  33912 S   0.3   2.0   0:08.51 io.tuya.0
         7884 iobroker  20   0    9376    740    632 S   0.3   0.0   0:00.01 ping
         9118 iobroker  20   0  192624  72348  29852 S   0.3   1.8   3:50.66 io.alexa2.0
         9212 iobroker  20   0  203864  75844  29948 S   0.3   1.9  14:13.62 io.hmip.0
         9531 iobroker  20   0  193632  78324  28912 S   0.3   2.0  18:43.25 io.rpi2.0
        10275 iobroker  20   0  184152  63852  28952 S   0.3   1.6   3:31.41 io.geofency.0
        10366 iobroker  20   0  198772  85876  29876 S   0.3   2.2   4:00.00 io.iot.0
        10553 iobroker  20   0  185184  67036  29128 S   0.3   1.7   6:28.77 io.lgtv.1
        11515 iobroker  20   0  183016  61760  28928 S   0.3   1.6   3:27.58 io.vis-inventwo
        11863 iobroker  20   0  206444  95648  29084 S   0.3   2.4  26:46.10 io.yahka.0
        12982 iobroker  20   0  196396  80096  30508 S   0.3   2.0  20:21.84 io.chromecast.0
            1 root      20   0   34832   7696   6248 S   0.0   0.2   2:31.71 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:01.04 kthreadd
            3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
            8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
            9 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_rude_
           10 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_tasks_trace
           11 root      20   0       0      0      0 S   0.0   0.0   9:35.07 ksoftirqd/0
           12 root      20   0       0      0      0 I   0.0   0.0   9:36.60 rcu_sched
           13 root      rt   0       0      0      0 S   0.0   0.0   0:11.66 migration/0
           14 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
           15 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
           16 root      rt   0       0      0      0 S   0.0   0.0   0:10.47 migration/1
           17 root      20   0       0      0      0 S   0.0   0.0   0:32.44 ksoftirqd/1
           20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
           21 root      rt   0       0      0      0 S   0.0   0.0   0:09.52 migration/2
           22 root      20   0       0      0      0 S   0.0   0.0   0:32.02 ksoftirqd/2
           25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
           26 root      rt   0       0      0      0 S   0.0   0.0   0:08.44 migration/3
           27 root      20   0       0      0      0 S   0.0   0.0   0:31.82 ksoftirqd/3
        Dann einmal "free":
        pi@raspberrypi:~ $ free
        Mem:        3930860     2387076      468780       15168     1075004     1904096
        Swap:        102396       17152       85244
        Dann einmal "df -h":
        pi@raspberrypi:~ $ df -h
        Filesystem      Size  Used Avail Use% Mounted on
        /dev/root        30G  7.1G   21G  26% /
        devtmpfs        1.8G     0  1.8G   0% /dev
        tmpfs           1.9G   16K  1.9G   1% /dev/shm
        tmpfs           1.9G   18M  1.9G   1% /run
        tmpfs           5.0M  8.0K  5.0M   1% /run/lock
        tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1  253M   49M  204M  20% /boot
        tmpfs           384M     0  384M   0% /run/user/1000
        Und "dmesg"
        pi@raspberrypi:~ $ dmesg
        [    0.000000] Booting Linux on physical CPU 0x0
        [    0.000000] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:56 GMT 2021
        [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
        [    0.000000] random: fast init done
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
        [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [    0.000000] Zone ranges:
        [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        [    0.000000]   Normal   empty
        [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
        [    0.000000] Movable zone start for each node
        [    0.000000] Early memory node ranges
        [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
        [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
        [    0.000000] On node 0 totalpages: 1012736
        [    0.000000]   DMA zone: 1728 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
        [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
        [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:6A:A3:84 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  115200 console=tty1 root=PARTUUID=2a7ced16-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                       Please use sysfs to set IO scheduler for individual devices.
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
        [    0.000000] Memory: 3601132K/4050944K available (10240K kernel code, 1364K rwdata, 3192K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3264512K highmem)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 34315 entries in 68 pages
        [    0.000000] ftrace: allocated 68 pages with 2 groups
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000]  Rude variant of Tasks RCU enabled.
        [    0.000000]  Tracing variant of Tasks RCU enabled.
        [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
        [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [    0.000034] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [    0.000095] bcm2835: system timer (irq = 25)
        [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [    0.000764] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [    0.000785] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [    0.000803] Switching to timer-based delay loop, resolution 18ns
        [    0.001055] Console: colour dummy device 80x30
        [    0.001810] printk: console [tty1] enabled
        [    0.001878] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [    0.001932] pid_max: default: 32768 minimum: 301
        [    0.002107] LSM: Security Framework initializing
        [    0.002303] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.002347] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.003822] cgroup: Disabling memory control group subsystem
        [    0.004068] CPU: Testing write buffer coherency: ok
        [    0.004525] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.005734] Setting up static identity map for 0x200000 - 0x20003c
        [    0.005950] rcu: Hierarchical SRCU implementation.
        [    0.006873] smp: Bringing up secondary CPUs ...
        [    0.008052] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.009372] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [    0.010634] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [    0.010880] smp: Brought up 1 node, 4 CPUs
        [    0.010912] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [    0.010942] CPU: All CPU(s) started in HYP mode.
        [    0.010969] CPU: Virtualization extensions available.
        [    0.011818] devtmpfs: initialized
        [    0.025835] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [    0.026094] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.026147] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [    0.034360] pinctrl core: initialized pinctrl subsystem
        [    0.035441] NET: Registered protocol family 16
        [    0.039071] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.039847] audit: initializing netlink subsys (disabled)
        [    0.040122] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        [    0.040688] thermal_sys: Registered thermal governor 'step_wise'
        [    0.041419] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.041474] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.041880] Serial: AMBA PL011 UART driver
        [    0.074985] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [    0.090884] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
        [    0.100898] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
        [    0.142222] Kprobes globally optimized
        [    0.147424] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [    0.151609] vgaarb: loaded
        [    0.152075] SCSI subsystem initialized
        [    0.152300] usbcore: registered new interface driver usbfs
        [    0.152389] usbcore: registered new interface driver hub
        [    0.152487] usbcore: registered new device driver usb
        [    0.152840] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [    0.154711] clocksource: Switched to clocksource arch_sys_counter
        [    1.113285] VFS: Disk quotas dquot_6.6.0
        [    1.113403] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    1.113580] FS-Cache: Loaded
        [    1.113789] CacheFiles: Loaded
        [    1.123989] NET: Registered protocol family 2
        [    1.124227] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
        [    1.125785] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    1.125944] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [    1.126029] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    1.126117] TCP: Hash tables configured (established 8192 bind 8192)
        [    1.126282] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.126337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.126629] NET: Registered protocol family 1
        [    1.127345] RPC: Registered named UNIX socket transport module.
        [    1.127377] RPC: Registered udp transport module.
        [    1.127406] RPC: Registered tcp transport module.
        [    1.127434] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    1.127471] PCI: CLS 0 bytes, default 64
        [    1.130365] Initialise system trusted keyrings
        [    1.130625] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        [    1.139016] zbud: loaded
        [    1.141149] FS-Cache: Netfs 'nfs' registered for caching
        [    1.141941] NFS: Registering the id_resolver key type
        [    1.141994] Key type id_resolver registered
        [    1.142023] Key type id_legacy registered
        [    1.142180] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    1.142213] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
        [    1.143276] Key type asymmetric registered
        [    1.143308] Asymmetric key parser 'x509' registered
        [    1.143512] bounce: pool size: 64 pages
        [    1.143568] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [    1.143791] io scheduler mq-deadline registered
        [    1.143822] io scheduler kyber registered
        [    1.148137] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [    1.148190] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [    1.148290] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [    1.148399] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [    1.206814] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [    1.207209] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [    1.207247] pci_bus 0000:00: root bus resource [bus 00-ff]
        [    1.207295] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [    1.207406] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [    1.207661] pci 0000:00:00.0: PME# supported from D0 D3hot
        [    1.211133] PCI: bus0: Fast back to back transfers disabled
        [    1.211487] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [    1.211630] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [    1.212079] pci 0000:01:00.0: PME# supported from D0 D3cold
        [    1.215569] PCI: bus1: Fast back to back transfers disabled
        [    1.215647] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [    1.215688] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [    1.215789] pci 0000:00:00.0: PCI bridge to [bus 01]
        [    1.215828] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [    1.216246] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [    1.216488] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
        [    1.222362] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
        [    1.223262] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
        [    1.225793] iproc-rng200 fe104000.rng: hwrng registered
        [    1.226120] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        [    1.227018] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [    1.239006] brd: module loaded
        [    1.251103] loop: module loaded
        [    1.252856] Loading iSCSI transport class v2.0-870.
        [    1.256117] libphy: Fixed MDIO Bus: probed
        [    1.257818] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [    1.274758] libphy: bcmgenet MII bus: probed
        [    1.354875] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [    1.356048] usbcore: registered new interface driver r8152
        [    1.356133] usbcore: registered new interface driver lan78xx
        [    1.356222] usbcore: registered new interface driver smsc95xx
        [    1.357852] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
        [    1.358040] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.358090] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [    1.361586] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
        [    1.362924] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [    1.362965] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.363002] usb usb1: Product: xHCI Host Controller
        [    1.363031] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
        [    1.363062] usb usb1: SerialNumber: 0000:01:00.0
        [    1.363794] hub 1-0:1.0: USB hub found
        [    1.363908] hub 1-0:1.0: 1 port detected
        [    1.364594] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.364636] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [    1.364730] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [    1.365282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        [    1.365322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.365358] usb usb2: Product: xHCI Host Controller
        [    1.365388] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
        [    1.365418] usb usb2: SerialNumber: 0000:01:00.0
        [    1.366150] hub 2-0:1.0: USB hub found
        [    1.366256] hub 2-0:1.0: 4 ports detected
        [    1.367984] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    1.368313] dwc_otg: FIQ enabled
        [    1.368328] dwc_otg: NAK holdoff enabled
        [    1.368343] dwc_otg: FIQ split-transaction FSM enabled
        [    1.368361] Module dwc_common_port init
        [    1.368814] usbcore: registered new interface driver uas
        [    1.368940] usbcore: registered new interface driver usb-storage
        [    1.369159] mousedev: PS/2 mouse device common for all mice
        [    1.370815] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    1.374182] sdhci: Secure Digital Host Controller Interface driver
        [    1.374216] sdhci: Copyright(c) Pierre Ossman
        [    1.374974] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [    1.375657] sdhci-pltfm: SDHCI platform and OF driver helper
        [    1.379694] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.380057] hid: raw HID events driver (C) Jiri Kosina
        [    1.380261] usbcore: registered new interface driver usbhid
        [    1.380292] usbhid: USB HID core driver
        [    1.385883] Initializing XFRM netlink socket
        [    1.385948] NET: Registered protocol family 17
        [    1.386080] Key type dns_resolver registered
        [    1.386444] Registering SWP/SWPB emulation handler
        [    1.386627] registered taskstats version 1
        [    1.386669] Loading compiled-in X.509 certificates
        [    1.387614] Key type ._fscrypt registered
        [    1.387644] Key type .fscrypt registered
        [    1.387672] Key type fscrypt-provisioning registered
        [    1.399043] uart-pl011 fe201000.serial: there is not valid maps for state default
        [    1.399368] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [    1.399457] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        [    1.406791] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
        [    1.407696] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550
        [    1.408716] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [    1.409789] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [    1.409823] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [    1.439555] of_cfs_init
        [    1.439843] of_cfs_init: OK
        [    1.462105] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [    1.463813] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.465524] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.468557] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [    1.470260] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.477392] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
        [    1.478061] Waiting for root device PARTUUID=2a7ced16-02...
        [    1.552411] mmc1: new high speed SDIO card at address 0001
        [    1.584917] mmc0: new ultra high speed DDR50 SDHC card at address 0001
        [    1.585813] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
        [    1.587498]  mmcblk0: p1 p2
        [    1.604398] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.604496] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    1.609682] devtmpfs: mounted
        [    1.619517] Freeing unused kernel memory: 2048K
        [    1.644757] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [    1.665076] Run /sbin/init as init process
        [    1.665106]   with arguments:
        [    1.665121]     /sbin/init
        [    1.665135]     115200
        [    1.665149]   with environment:
        [    1.665164]     HOME=/
        [    1.665178]     TERM=linux
        [    1.827383] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [    1.827430] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    1.827464] usb 1-1: Product: USB2.0 Hub
        [    1.829462] hub 1-1:1.0: USB hub found
        [    1.829764] hub 1-1:1.0: 4 ports detected
        [    2.091281] systemd[1]: System time before build time, advancing clock.
        [    2.154779] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
        [    2.189242] NET: Registered protocol family 10
        [    2.190671] Segment Routing with IPv6
        [    2.259195] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    2.260693] systemd[1]: Detected architecture arm.
        [    2.300815] systemd[1]: Set hostname to <raspberrypi>.
        [    2.303873] usb 1-1.2: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
        [    2.303920] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.303957] usb 1-1.2: Product: ConBee II
        [    2.303986] usb 1-1.2: Manufacturer: dresden elektronik ingenieurtechnik GmbH
        [    2.304019] usb 1-1.2: SerialNumber: DE2251186
        [    2.807967] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
        [    2.809831] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
        [    2.879262] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
        [    2.903901] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
        [    2.996794] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.007780] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.008469] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
        [    3.009494] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.010027] systemd[1]: Listening on Journal Audit Socket.
        [    3.011003] systemd[1]: Listening on Journal Socket (/dev/log).
        [    3.646914] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [    3.742414] systemd-journald[113]: Received request to flush runtime journal from PID 1
        [    4.341189] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [    4.341775] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [    4.342627] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [    4.343199] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [    4.391236] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.393370] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    4.393396] [vc_sm_connected_init]: start
        [    4.394126] [vc_sm_connected_init]: installed successfully
        [    4.400026] mc: Linux media interface: v0.10
        [    4.425701] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.453648] videodev: Linux video capture interface: v2.00
        [    4.470424] bcm2835_audio bcm2835_audio: card created with 8 channels
        [    4.495343] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.514906] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.537416] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.538767] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.563980] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    4.564027] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    4.565429] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [    4.567787] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [    4.568901] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [    4.569867] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [    4.569897] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [    4.569936] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [    4.569962] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [    4.569999] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [    4.572671] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [    4.578889] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    4.579002] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    4.590976] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    4.591026] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    4.613586] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
        [    4.613630] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
        [    4.737216] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    4.762754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [    4.837021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        [    4.837163] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [    4.837674] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [    4.868383] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    4.921170] brcmfmac: F1 signature read @0x18000000=0x15264345
        [    4.925000] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
        [    4.928725] usbcore: registered new interface driver cdc_acm
        [    4.928743] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [    4.934934] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    4.935836] usbcore: registered new interface driver brcmfmac
        [    5.192384] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    5.193146] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    5.202354] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [    7.352014] uart-pl011 fe201000.serial: no DMA platform data
        [    7.612938] random: crng init done
        [    7.612959] random: 7 urandom warning(s) missed due to ratelimiting
        [    7.672507] 8021q: 802.1Q VLAN Support v1.8
        [    8.014812] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [    8.072509] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        [    8.420271] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [    8.420527] bcmgenet fd580000.ethernet eth0: Link is Down
        [   12.554918] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        [   12.554950] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   14.568933] Bluetooth: Core ver 2.22
        [   14.569026] NET: Registered protocol family 31
        [   14.569037] Bluetooth: HCI device and connection manager initialized
        [   14.569059] Bluetooth: HCI socket layer initialized
        [   14.569075] Bluetooth: L2CAP socket layer initialized
        [   14.569098] Bluetooth: SCO socket layer initialized
        [   14.577608] Bluetooth: HCI UART driver ver 2.3
        [   14.577624] Bluetooth: HCI UART protocol H4 registered
        [   14.577697] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [   14.577913] Bluetooth: HCI UART protocol Broadcom registered
        [   14.756909] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [   14.756918] Bluetooth: BNEP filters: protocol multicast
        [   14.756931] Bluetooth: BNEP socket layer initialized
        [  101.775676] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
        [308247.579319] Alignment trap: not handling instruction e1942f9f at [<b6cade64>]
        [308247.579328] 8<--- cut here ---
        [308247.579348] Unhandled fault: alignment exception (0x221) at 0x04b9db27
        [308247.579363] pgd = c8659170
        [308247.579375] [04b9db27] *pgd=11a24003, *pmd=67618003
        [456353.949063] Alignment trap: not handling instruction f4e2c83d at [<0121b100>]
        [456353.949072] 8<--- cut here ---
        [456353.949090] Unhandled fault: alignment exception (0x221) at 0x04d3167e
        [456353.949105] pgd = 19539af6
        [456353.949116] [04d3167e] *pgd=06a1d003, *pmd=9e051003
        pi@raspberrypi:~ $
        Danke im Voraus 😃
        Edit: hier noch der syslog:
        syslog
        nodejs
        v14.19.0
        node
        v14.19.0
        npm
        6.14.16
        rpi4 4 GB, 42 Prozesse, ca 50% Ram immer frei.
          dirkhe Developer @Krys last edited by
          Auf github gibt es eine neue Version 3.3.5. Probiert die mal aus, bitte. Es kann zwar sein, dass die Map dann nicht mehr erzeugt wird, aber hoffentlich stürzt der Adapter dann nicht mehr ab
          K gelberlemmy bahnuhr 3 Replies Last reply Reply Quote 1
            Krys @dirkhe last edited by Krys
            @dirkhe Moin, bei mir stürzt er weiterhin mit SIGSEGV/SIGABRT ab. Hab im Issue kommentiert.
            Edit: Vielen lieben Dank für die MÜHE!
            • gelberlemmy
              gelberlemmy @dirkhe last edited by
              @dirkhe Moin, bei mir läuft es jetzt ohne Abstürze, aber die Map läuft halt nicht mehr.
              Gruss André
                dirkhe Developer @gelberlemmy last edited by
                @gelberlemmy ich denke, dass die canvas Bibliothek das Problem ist, da bin ich nicht so tief drin und weiß auch nicht, ob wir da überhaupt was machen können.
                gelberlemmy bahnuhr 2 Replies Last reply Reply Quote 1
                • gelberlemmy
                  @dirkhe Ok, vor dem jetzigen Update war halt ständige Abstürze und die Map funktionierte. Wobei ich dann doch lieber auf die Map verzichte um die Funktionen zu nutzen. Ich habe, was auch immer Canvas ist, keine Ahnung davon. Aber vielleicht findet sich da ja noch jemand.... Danke aber für Deine super Arbeit.
                  Gruss André
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @dirkhe last edited by
                    @dirkhe sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                    Ich habe absolut keine Probleme mit dem Adapter.
                    Kein Absturz und map ist auch da.
                    Hast du den Adapter jetzt geändert.
                    d.h. beim nächsten update geht meine map auch nicht mehr ???
                      dirkhe Developer @bahnuhr last edited by
                      @bahnuhr nein, was ich gemacht habe, ist ein try catch um die map Generierung zu setzen. Also wenn die map nicht erzeugt werden kann, stürzt nicht sofort der ganze Adapter ab.
                      So wieves aussieht, gibt es Probleme mit der canvas lib unter einer bestimmten node Version.
                      • bahnuhr
                        Hier hast du doch geschrieben, dass mit der neuen Version es sein kann, dass die map nicht mehr erzeugt wird.
                        Oder wie muss man dies lesen?
                        D K 2 Replies Last reply Reply Quote 0
                          @bahnuhr nein, damit meinte ich, dass es nicht Probleme mit Karten löst, sonden nur die abstürze des Adapters. Ich hatte genau die Reaktion erwartet, dass jemand sagt, dass die Karte jetzt nicht mehr funktioniert. Das ist halt das Problem, dass der Adapter abstürzt und das als Problem angesehen wird. Jetzt läuft er halt weiter, nur die Karte wird nicht mehr erzeugt. Aber wwenn die Karte erzeugt werden kann, weil du eine funktionierende canvas lib hast, ist alles gut
                          gelberlemmy 1 Reply Last reply Reply Quote 0
                            Krys @bahnuhr last edited by
                            @bahnuhr mit welchem Setup betreibst du deinen ioBroker?
                            • gelberlemmy
                              @dirkhe guten Morgen. Hier wurde ja mal ein Workaround für die Canvas beschrieben. Sollte es Sinn ergeben, dass ich dies einmal ausführe ? Was macht die Canvas eigentlich ?
                              • gelberlemmy
                                gelberlemmy @Meistertr last edited by
                                @meistertr so jetzt habe ich wieder die ganzen Abstürtze.Aber erst nachdem er etwas länger gelaufen ist. Hmmm
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @Krys last edited by
                                  @krys sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                  admin 5.2.3
                                  xiaomi 3.3.1
                                  node.js 14.18.3
                                  npm 6.14.15
                                  host 3.3.22
                                  Läuft einwandfrei
                                  Keine Abstürze und die map geht auch.
                                    @bahnuhr Merkwürdig. Und auf welchem Gerät läuft dein System?
                                    • bahnuhr
                                      auf einem nuc
                                      und da proxmox und iob in einer vm
                                        A Former User @bahnuhr last edited by
                                        @bahnuhr und welches System ? Ubuntu, Redhat, Debian, Sles... ??
                                        • mrbungle64
                                          mrbungle64 Developer last edited by
                                          @bahnuhr @Krys
                                          Ihr habt bestimmt unterschiedliche canvas Versionen installiert.
                                          Schaut bitte mal nach:
                                          cd /opt/iobroker/
                                          npm list canvas
                                          gelberlemmy K 2 Replies Last reply Reply Quote 0
                                          • gelberlemmy
                                            gelberlemmy @mrbungle64 last edited by
                                            @mrbungle64 ich habe das auch einmal gemacht:
                                            [iobroker.inst@3.0.0 /opt/iobroker
                                            ├─┬ iobroker.iot@1.9.3
                                            │ └── canvas@2.9.0
                                            └─┬ iobroker.mihome-vacuum@3.3.5 (github:iobroker-community-adapters/ioBroker.mi home-vacuum#88dd939cd5a45d90c7e8603047a8f8ba2a72bbbb)
                                            └── canvas@2.9.0 deduped
                                            Was soll ich denn "depuped" bewerten?
                                            mrbungle64 1 Reply Last reply Reply Quote 0
                                            1198
                                            364086
