    4. js-controller 4.0 jetzt im BETA/LATEST!
    • wendy2702
      gerade meinen Master von 4.0.3 auf 4.0.5 upgedatet. Im Start log diese Zeile bekommen:
      2022-02-09 18:14:27.624  - error: javascript.0 (16362) In file included from ../src/binding.cc:6:
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/binding.cc:2003:1: note: in expansion of macro 'NODE_MODULE'
       NODE_MODULE(sshcrypto, init)
      Ich kann aber ehrlich nicht sagen ob es schon vorher vorhanden war oder erst mit 4.0.5 gekommen ist.
      Beim Update meines Slaves von 4.0.3 auf 4.0.5 kommt das:
      pi@pi-iobroker:~ $ iob stop
      pi@pi-iobroker:~ $ iob update
      Used repository: Beta (latest)
      Adapter    "admin"        : 5.2.3    , installed 5.2.3
      Adapter    "discovery"    : 2.7.5    , installed 2.7.5
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Controller "js-controller": 4.0.5    , installed 4.0.3  [Updatable]
      Adapter    "modbus"       : 3.4.17   , installed 3.4.17
      Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
      Adapter    "rpi2"         : 1.3.1    , installed 1.3.1
      Adapter    "smartmeter"   : 3.2.1    , installed 3.2.1
      Adapter    "terminal"     : 0.1.2    , installed 0.1.2
      Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
      pi@pi-iobroker:~ $ iob upgrade self
      Update js-controller from @4.0.3 to @4.0.5
      NPM version: 6.14.16
      Installing iobroker.js-controller@4.0.5... (System call)
      Could not check npm version: This directory tree does not contain a package.json
      Assuming that correct version is installed.
      pi@pi-iobroker:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.0
      v14.19.0
      6.14.16
      pi
      /opt/iobroker
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
      Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
      nodejs:
        Installiert:           14.19.0-deb-1nodesource1
        Installationskandidat: 14.19.0-deb-1nodesource1
        Versionstabelle:
       *** 14.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      Der zweite Slave sieht da schon besser aus:
      pi@iobroker-garage-gross:~ $ iob upgrade self
      > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      object _design/system updated
        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nMIIxxxgNq\r\n-----END RSA PRIVATE KEY-----\r\n",
        "defaultPublic": "-----BEGIN CERTIFICATE-----\r\nMIIxxxxx7aoggoSbkXD/Q\r\nHToWvyBM/KL37ZMRJ/M=\r\n-----END CERTIFICATE-----\r\n"
      Update certificate defaultPrivate
      The object "system.certificates" was updated successfully.
      Update certificate defaultPublic
      + iobroker.js-controller@4.0.5
      removed 75 packages and updated 25 packages in 53.294s
      32 packages are looking for funding
        run `npm fund` for details
      Zweiter Slave lies sich Problemlos updaten.
      Was kann/soll ich bei dem ersten Slave machen/probieren ausser der Holzhammer Methode?
        arteck Developer Most Active @wendy2702 last edited by arteck
        @wendy2702 dich richtig hinstellen
        cd /opt/iobroker
        und erst DANN ARBEITEN
        • wendy2702
          wendy2702 @arteck last edited by
          @arteck iob befehle lassen sich eigentlich von überall ausführen wie man am zweiten Slave sehen kann, aber bitte:
          pi@pi-iobroker:/opt/iobroker $ iob upgrade self
            @wendy2702
            schoon probiert mit
            iob fix
            iob update
            iob upgrade self
            • wendy2702
              @arteck Ja. Leider keine Änderung.
                e-s @apollon77 last edited by
                @apollon77 hatte die selben Fehler wie @Diginix, scheint also nicht unbedingt einmalig zu sein.
                santa@ubuntuserver:/opt/iobroker$ iob upgrade self
                Update js-controller from @3.3.22 to @4.0.5
                npm install iobroker.js-controller@4.0.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                In file included from ../../nan/nan.h:56,
                                 from ../src/unix_dgram.cc:5:
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  793 |       (node::addon_register_func) (regfunc),                          \
                /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                  827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                  404 | NODE_MODULE(unix_dgram, Initialize)
                Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                Server States 127.0.0.1:41258 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                Server States 127.0.0.1:41260 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                Server Objects 127.0.0.1:47886 Error from InMemDB: Error: Unknown LUA script load
                Server Objects 127.0.0.1:47886 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                • Alligator
                  Alligator @apollon77 last edited by
                  @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                  @alligator Und was hast Du genau getan?
                  Kann ich gar nicht genau sagen, hab's mehrfache versuche mit "iob fix" / "reboot" und "npm install iobroker.js-controller@3.3.22" in unterschiedlicher Reihenfolge. Und irgend wann hat es dann mit dem Downgrade geklappt. Sorry das ich es nicht genauer beschreiben kann.
                  Ich habe jetzt nochmal auf JS-C 4.0.5 geupdatet und wieder mit dem gleichen Erfolg das beim Update oder Downgrade die Meldung kommt:
                  und ein Up oder Downgrade von Adaptern nicht möglich ist.
                  Bei der Eingabe "whitch npm" kommt bei beiden JS-C Versionen (3.3.22 sowie 4.0.5) immer:
                  "/usr/local/bin/npm"
                  Ein nvm oder sowas nutze ich soweit ich weiß nicht. Wie kann ich das feststellen?
                  Ein Downgrade von 4.0.5 auf 3.3.22 hat jetzt aber ohne Probleme Funktioniert.
                    Thomas Braun Most Active @Alligator last edited by Thomas Braun
                    @alligator sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    Das ist der bekannte falsche Pfad. Schau in meiner Signatur wie man nodejs und npm sauber aufsetzt.
                      m0rph @apollon77 last edited by
                      @apollon77 6.14.16
                        die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
                        Alligator J 2 Replies Last reply Reply Quote 0
                          apollon77 @e-s last edited by
                          @e-s SInd halt die üblichen unix_dgram Compile Warnungen ...
                            Hi All,
                            vielen Dank für Euren Support, die 4.0.6 kommt über Nacht wieder ins Repo und hat:
                            4.0.6 (2022-02-09)
                            • (AlCalzone) Optimize some JSONL cases
                            • (foxriver76) Optimize Backup restore process
                            • (AlCalzone) Fix issues that prevented adapter installs/updates (npm can not be located error message)
                            • (Apollon77) Fix seq Logging issue
                            • (foxriver76/Apollon77) Prevent several crash cases seen in Sentry
                            Thomas Braun O 2 Replies Last reply Reply Quote 2
                              Thomas Braun Most Active @apollon77 last edited by Thomas Braun
                              @apollon77 @AlCalzone
                              Das finde ich interessant. Was war da der Grund das npm nicht im $PATH gefunden wurde?
                                A Former User last edited by
                                @apollon77 update von 4.0.5 auf 4.0.6 ohne besondere Vorkommnisse.
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                                  @apollon77
                                  Ist da mein Fall auch mit abgedeckt?
                                    apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                                    @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
                                    • O
                                      oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
                                      @apollon77
                                      # iobroker upgrade self
                                      Update js-controller from @3.3.22 to @4.0.6
                                      npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                      Uncaught Rejection: TypeError: Cannot read property '_id' of null
                                          at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
                                          at Array.map (<anonymous>)
                                          at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
                                          at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 6
                                      npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
                                      npm ERR! Exit status 6
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
                                      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                      npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
                                      host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
                                      Hilft das?:
                                      npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
                                      > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                      npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                                      foxriver76 2 Replies Last reply Reply Quote 0
                                      • AlCalzone
                                        AlCalzone Developer @Thomas Braun last edited by
                                        @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
                                        Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
                                        • foxriver76
                                          foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
                                          @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
                                          • O
                                            oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by
                                            @foxriver76
                                            Redis States und Objects.
                                            747
                                            194708
