    4. js-controller 4.0 jetzt im BETA/LATEST!
    • wendy2702
      wendy2702 @arteck last edited by
      @arteck iob befehle lassen sich eigentlich von überall ausführen wie man am zweiten Slave sehen kann, aber bitte:
      pi@pi-iobroker:/opt/iobroker $ iob upgrade self
      Update js-controller from @4.0.3 to @4.0.5
      NPM version: 6.14.16
      Installing iobroker.js-controller@4.0.5... (System call)
      Could not check npm version: This directory tree does not contain a package.json
      Assuming that correct version is installed.
        arteck Developer Most Active @wendy2702 last edited by
        @wendy2702
        schoon probiert mit
        iob fix
        iob update
        iob upgrade self
        • wendy2702
          @arteck Ja. Leider keine Änderung.
            e-s @apollon77 last edited by
            @apollon77 hatte die selben Fehler wie @Diginix, scheint also nicht unbedingt einmalig zu sein.
            santa@ubuntuserver:/opt/iobroker$ iob upgrade self
            Update js-controller from @3.3.22 to @4.0.5
            npm install iobroker.js-controller@4.0.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            In file included from ../../nan/nan.h:56,
                             from ../src/unix_dgram.cc:5:
            /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
              793 |       (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
              827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
              404 | NODE_MODULE(unix_dgram, Initialize)
            Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server States 127.0.0.1:41258 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
            Server Objects 127.0.0.1:47886 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server States 127.0.0.1:41260 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
            Server Objects 127.0.0.1:47886 Error from InMemDB: Error: Unknown LUA script load
            Server Objects 127.0.0.1:47886 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            • Alligator
              Alligator @apollon77 last edited by
              @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
              @alligator Und was hast Du genau getan?
              Kann ich gar nicht genau sagen, hab's mehrfache versuche mit "iob fix" / "reboot" und "npm install iobroker.js-controller@3.3.22" in unterschiedlicher Reihenfolge. Und irgend wann hat es dann mit dem Downgrade geklappt. Sorry das ich es nicht genauer beschreiben kann.
              Ich habe jetzt nochmal auf JS-C 4.0.5 geupdatet und wieder mit dem gleichen Erfolg das beim Update oder Downgrade die Meldung kommt:
              und ein Up oder Downgrade von Adaptern nicht möglich ist.
              Bei der Eingabe "whitch npm" kommt bei beiden JS-C Versionen (3.3.22 sowie 4.0.5) immer:
              "/usr/local/bin/npm"
              Ein nvm oder sowas nutze ich soweit ich weiß nicht. Wie kann ich das feststellen?
              Ein Downgrade von 4.0.5 auf 3.3.22 hat jetzt aber ohne Probleme Funktioniert.
                Thomas Braun Most Active @Alligator last edited by Thomas Braun
                @alligator sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                Das ist der bekannte falsche Pfad. Schau in meiner Signatur wie man nodejs und npm sauber aufsetzt.
                  m0rph @apollon77 last edited by
                  @apollon77 6.14.16
                    die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
                    Alligator J 2 Replies Last reply Reply Quote 0
                      apollon77 @e-s last edited by
                      @e-s SInd halt die üblichen unix_dgram Compile Warnungen ...
                        Hi All,
                        vielen Dank für Euren Support, die 4.0.6 kommt über Nacht wieder ins Repo und hat:
                        4.0.6 (2022-02-09)
                        • (AlCalzone) Optimize some JSONL cases
                        • (foxriver76) Optimize Backup restore process
                        • (AlCalzone) Fix issues that prevented adapter installs/updates (npm can not be located error message)
                        • (Apollon77) Fix seq Logging issue
                        • (foxriver76/Apollon77) Prevent several crash cases seen in Sentry
                        Thomas Braun O 2 Replies Last reply Reply Quote 2
                          Thomas Braun Most Active @apollon77 last edited by Thomas Braun
                          @apollon77 @AlCalzone
                          Das finde ich interessant. Was war da der Grund das npm nicht im $PATH gefunden wurde?
                            A Former User last edited by
                            @apollon77 update von 4.0.5 auf 4.0.6 ohne besondere Vorkommnisse.
                            • O
                              oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                              @apollon77
                              Ist da mein Fall auch mit abgedeckt?
                                apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
                                @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
                                  @apollon77
                                  # iobroker upgrade self
                                  Update js-controller from @3.3.22 to @4.0.6
                                  npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                  Uncaught Rejection: TypeError: Cannot read property '_id' of null
                                      at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
                                      at Array.map (<anonymous>)
                                      at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
                                      at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 6
                                  npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
                                  npm ERR! Exit status 6
                                  npm ERR!
                                  npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
                                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                  npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
                                  host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
                                  Hilft das?:
                                  npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
                                  > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                  npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                                  foxriver76 2 Replies Last reply Reply Quote 0
                                  • AlCalzone
                                    AlCalzone Developer @Thomas Braun last edited by
                                    @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
                                    Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
                                    • foxriver76
                                      foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
                                      @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
                                      • O
                                        oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by
                                        @foxriver76
                                        Redis States und Objects.
                                        • Diginix
                                          Diginix last edited by
                                          Update von 4.0.5 auf 4.0.6 ohne Probleme.
                                          CLI Ausgabe:
                                          Update js-controller from @4.0.5 to @4.0.6
                                          Stopped Objects DB
                                          Stopped States DB
                                          Installing iobroker.js-controller@4.0.6... (System call)
                                          > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                          > node lib/preinstallCheck.js
                                          Successfully migrated 18783 objects to Redis Sets
                                          object _design/system updated
                                            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
                                            "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
                                          Update certificate defaultPrivate
                                          The object "system.certificates" was updated successfully.
                                          Update certificate defaultPublic
                                          + iobroker.js-controller@4.0.6
                                          updated 13 packages in 47.713s
                                          73 packages are looking for funding
                                            run `npm fund` for details
                                          • foxriver76
                                            @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                            npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                                            Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
                                            747
                                            171996
