    4. js-controller 4.0 jetzt im BETA/LATEST!
      A Former User last edited by
      @apollon77 update von 4.0.5 auf 4.0.6 ohne besondere Vorkommnisse.
      • O
        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
        @apollon77
        Ist da mein Fall auch mit abgedeckt?
          apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
          @ofbeqnpolkkl6mby5e13 das logfile hatte nicht mehr Infos drin. Von daher puuhhh. Ich sag mal so; Versuchs nochmal.
          • O
            oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
            @apollon77
            # iobroker upgrade self
            Update js-controller from @3.3.22 to @4.0.6
            NPM version: 6.14.16
            npm install iobroker.js-controller@4.0.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
            Uncaught Rejection: TypeError: Cannot read property '_id' of null
                at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42
                at Array.map (<anonymous>)
                at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39)
                at processTicksAndRejections (internal/process/task_queues.js:95:5)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 6
            npm ERR! iobroker.js-controller@4.0.6 install: `node iobroker.js setup first`
            npm ERR! Exit status 6
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@4.0.6 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /opt/iobroker/.npm/_logs/2022-02-10T06_53_37_143Z-debug.log
            host.iobroker Cannot install iobroker.js-controller@4.0.6: 6
            Hilft das?:
            npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6
            > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
            npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
            foxriver76 2 Replies Last reply Reply Quote 0
            • AlCalzone
              AlCalzone Developer @Thomas Braun last edited by
              @thomas-braun Wir verwenden seit 4.x (m)eine Library, die sich um die Aufrufe vom Paketmanager kümmert. Mein Hintergedanke ist, dass wir dann irgendwann ohne großen Ärger zu einem anderen wechseln können, der nicht jedes halbe Jahr alles anders macht und unsere Installation breakt.
              Die Library sucht eigentlich vom aktuellen Pfad (bzw. da wo die .js-Datei liegt) aus nach einem lockfile (z.B. package-lock.json), um den aktiven Paketmanager zu bestimmen. Bei einigen Usern existiert das nicht.
              • foxriver76
                foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
                @ofbeqnpolkkl6mby5e13 welcher Datenbanktyp ist im Einsatz?
                • O
                  oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by
                  @foxriver76
                  Redis States und Objects.
                  • Diginix
                    Diginix last edited by
                    Update von 4.0.5 auf 4.0.6 ohne Probleme.
                    CLI Ausgabe:
                    Update js-controller from @4.0.5 to @4.0.6
                    Stopped Objects DB
                    Stopped States DB
                    Installing iobroker.js-controller@4.0.6... (System call)
                    > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                    > node lib/preinstallCheck.js
                    Successfully migrated 18783 objects to Redis Sets
                    object _design/system updated
                      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
                      "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
                    Update certificate defaultPrivate
                    The object "system.certificates" was updated successfully.
                    Update certificate defaultPublic
                    + iobroker.js-controller@4.0.6
                    updated 13 packages in 47.713s
                    73 packages are looking for funding
                      run `npm fund` for details
                    • foxriver76
                      @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                      npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
                      Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
                      • O
                        @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                        # pwd
                        /opt/iobroker
                        # npm i iobroker.js-controller@next
                        > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                        npm ERR! errno 6
                        npm ERR! iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
                        npm ERR!
                        npm ERR! Failed at the iobroker.js-controller@4.0.5 install script.
                        npm ERR!     /root/.npm/_logs/2022-02-10T08_31_44_396Z-debug.log
                        • foxriver76
                          @ofbeqnpolkkl6mby5e13 ok da passiert kein logging davor, thanks.
                          • foxriver76
                            @ofbeqnpolkkl6mby5e13 single host oder multihost?
                            • O
                              @foxriver76
                              Single.
                              • foxriver76
                                @ofbeqnpolkkl6mby5e13 super strange, dann müsste vor dem ersten view mindestens die ausgabe dass er zu sets migrieren möchte kommen. Zeig mal bitte Ausgabe von iob object list system.host.*
                                O 2 Replies Last reply Reply Quote 0
                                • O
                                  Der JS-Controller ist ja jetzt nicht installiert, müsste ich erst die 3er wieder installieren.
                                  # iob object list system.host.*
                                  internal/modules/cjs/loader.js:905
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                      at internal/main/run_main_module.js:17:47 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  • O
                                    ObjectAC | StateAC |     User     |     Group    | ID
                                    rw-rw-r--                    admin  administrator system.host.NAS.notifications
                                    rw-rw-r--                    admin  administrator system.host.NAS.plugins.sentry
                                    rw-rw-r--                    admin  administrator system.host.NAS.zip
                                    rw-rw-r--                    admin  administrator system.host.d631abdf99e6.plugins.sentry
                                    rw-rw-r--                    admin  administrator system.host.d631abdf99e6.zip
                                    rw-rw-r--                    admin  administrator system.host.iobroker
                                    rw-rw-r--                    admin  administrator system.host.iobroker-d.notifications
                                    rw-rw-r--                    admin  administrator system.host.iobroker-d.plugins.sentry
                                    rw-rw-r--                    admin  administrator system.host.iobroker-d.zip
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.alive
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactModeEnabled
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactgroupProcesses
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cpu
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cputime
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskFree
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskSize
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskWarning
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.eventLoopLag
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.freemem
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.inputCount
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsCompact
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsProcess
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.load
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.logLevel
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.mem
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memAvailable
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapTotal
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapUsed
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memRss
                                    rw-rw-r--                    admin  administrator system.host.iobroker.notifications
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.notifications.system
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.outputCount
                                    rw-rw-r--                    admin  administrator system.host.iobroker.plugins.sentry
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.plugins.sentry.enabled
                                    rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.uptime
                                    rw-rw-r--                    admin  administrator system.host.iobroker.zip
                                    • foxriver76
                                      @ofbeqnpolkkl6mby5e13 Dann bitte
                                      redis-cli keys cfg.o.system.host.*
                                      • O
                                        oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
                                        Auf einem der Redis-Server?
                                        # redis-cli keys cfg.o.system.host.*
                                         1) "cfg.o.system.host.iobroker-d.cpu"
                                         2) "cfg.o.system.host.iobroker-d"
                                         3) "cfg.o.system.host.iobroker-d.diskFree"
                                         4) "cfg.o.system.host.iobroker-d.memRss"
                                         5) "cfg.o.system.host.iobroker-d.compactgroupProcesses"
                                         6) "cfg.o.system.host.iobroker-d.freemem"
                                         7) "cfg.o.system.host.iobroker-d.mem"
                                         8) "cfg.o.system.host.iobroker-d.logLevel"
                                         9) "cfg.o.system.host.iobroker-d.memAvailable"
                                        10) "cfg.o.system.host.iobroker-d.memHeapTotal"
                                        11) "cfg.o.system.host.iobroker-d.cputime"
                                        12) "cfg.o.system.host.iobroker-d.plugins.sentry"
                                        13) "cfg.o.system.host.iobroker-d.zip"
                                        14) "cfg.o.system.host.iobroker-d.compactModeEnabled"
                                        15) "cfg.o.system.host.iobroker-d.plugins.sentry.enabled"
                                        16) "cfg.o.system.host.iobroker-d.alive"
                                        17) "cfg.o.system.host.iobroker-d.diskWarning"
                                        18) "cfg.o.system.host.iobroker-d.outputCount"
                                        19) "cfg.o.system.host.iobroker-d.load"
                                        20) "cfg.o.system.host.iobroker-d.uptime"
                                        21) "cfg.o.system.host.iobroker-d.instancesAsCompact"
                                        22) "cfg.o.system.host.iobroker-d.eventLoopLag"
                                        23) "cfg.o.system.host.iobroker-d.inputCount"
                                        24) "cfg.o.system.host.iobroker-d.instancesAsProcess"
                                        25) "cfg.o.system.host.iobroker-d.memHeapUsed"
                                        26) "cfg.o.system.host.iobroker-d.diskSize"
                                        • O
                                          @foxriver76
                                          Soll ich den Hostname vielleicht noch mal setzen?
                                          • foxriver76
                                            Da sind aber noch host Leichen, und iwie stimmt das auch nicht ganz mit den Entries in der redis DB überein.
                                            Was gibt ìob status?
                                            747
                                            194718
