    4. js-controller 4.0 jetzt im BETA/LATEST!
    • Diginix
      Diginix last edited by
      Update von 4.0.5 auf 4.0.6 ohne Probleme.
      CLI Ausgabe:
      Update js-controller from @4.0.5 to @4.0.6
      Stopped Objects DB
      Stopped States DB
      NPM version: 6.14.16
      Installing iobroker.js-controller@4.0.6... (System call)
      > iobroker.js-controller@4.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Successfully migrated 18783 objects to Redis Sets
      object _design/system updated
        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\n***\r\n-----END RSA PRIVATE KEY-----\r\n",
        "defaultPublic": "-----BEGIN CERTIFICATE-----\r\n***\r\n-----END CERTIFICATE-----\r\n"
      Update certificate defaultPrivate
      The object "system.certificates" was updated successfully.
      Update certificate defaultPublic
      + iobroker.js-controller@4.0.6
      updated 13 packages in 47.713s
      73 packages are looking for funding
        run `npm fund` for details
      • foxriver76
        foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        npm info lifecycle iobroker.js-controller@4.0.6~install: iobroker.js-controller@4.0.6 > iobroker.js-controller@4.0.6 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Uncaught Rejection: TypeError: Cannot read property '_id' of null at /opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3421:42 at Array.map (<anonymous>) at ObjectsInRedisClient._applyViewFunc (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3413:39) at processTicksAndRejections (internal/process/task_queues.js:95:5) npm info lifecycle iobroker.js-controller@4.0.6~install: Failed to exec install script
        Kannst du mal mittels npm i iobroker.js-controller@next im Verzeichnis /opt/iobroker das upgrade anstoßen, damit ich mehr Log sehe. Irgendein Object View liefert null zurück, das sollte nicht sein.
        • O
          oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by
          @foxriver76 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
          # pwd
          /opt/iobroker
          # npm i iobroker.js-controller@next
          > iobroker.js-controller@4.0.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > iobroker.js-controller@4.0.5 install /opt/iobroker/node_modules/iobroker.js-controller
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
          npm ERR! code ELIFECYCLE
          npm ERR! errno 6
          npm ERR! iobroker.js-controller@4.0.5 install: `node iobroker.js setup first`
          npm ERR! Exit status 6
          npm ERR!
          npm ERR! Failed at the iobroker.js-controller@4.0.5 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!     /root/.npm/_logs/2022-02-10T08_31_44_396Z-debug.log
          foxriver76 2 Replies Last reply Reply Quote 0
          • foxriver76
            @ofbeqnpolkkl6mby5e13 ok da passiert kein logging davor, thanks.
            • foxriver76
              @ofbeqnpolkkl6mby5e13 single host oder multihost?
              • O
                @foxriver76
                Single.
                • foxriver76
                  @ofbeqnpolkkl6mby5e13 super strange, dann müsste vor dem ersten view mindestens die ausgabe dass er zu sets migrieren möchte kommen. Zeig mal bitte Ausgabe von iob object list system.host.*
                  O 2 Replies Last reply Reply Quote 0
                  • O
                    Der JS-Controller ist ja jetzt nicht installiert, müsste ich erst die 3er wieder installieren.
                    # iob object list system.host.*
                    internal/modules/cjs/loader.js:905
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                        at internal/main/run_main_module.js:17:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    • O
                      ObjectAC | StateAC |     User     |     Group    | ID
                      rw-rw-r--                    admin  administrator system.host.NAS.notifications
                      rw-rw-r--                    admin  administrator system.host.NAS.plugins.sentry
                      rw-rw-r--                    admin  administrator system.host.NAS.zip
                      rw-rw-r--                    admin  administrator system.host.d631abdf99e6.plugins.sentry
                      rw-rw-r--                    admin  administrator system.host.d631abdf99e6.zip
                      rw-rw-r--                    admin  administrator system.host.iobroker
                      rw-rw-r--                    admin  administrator system.host.iobroker-d.notifications
                      rw-rw-r--                    admin  administrator system.host.iobroker-d.plugins.sentry
                      rw-rw-r--                    admin  administrator system.host.iobroker-d.zip
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.alive
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactModeEnabled
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.compactgroupProcesses
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cpu
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.cputime
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskFree
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskSize
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.diskWarning
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.eventLoopLag
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.freemem
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.inputCount
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsCompact
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.instancesAsProcess
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.load
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.logLevel
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.mem
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memAvailable
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapTotal
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memHeapUsed
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.memRss
                      rw-rw-r--                    admin  administrator system.host.iobroker.notifications
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.notifications.system
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.outputCount
                      rw-rw-r--                    admin  administrator system.host.iobroker.plugins.sentry
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.plugins.sentry.enabled
                      rw-rw-r-- rw-rw-r--          admin  administrator system.host.iobroker.uptime
                      rw-rw-r--                    admin  administrator system.host.iobroker.zip
                      • foxriver76
                        @ofbeqnpolkkl6mby5e13 Dann bitte
                        redis-cli keys cfg.o.system.host.*
                        • O
                          oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
                          Auf einem der Redis-Server?
                          # redis-cli keys cfg.o.system.host.*
                           1) "cfg.o.system.host.iobroker-d.cpu"
                           2) "cfg.o.system.host.iobroker-d"
                           3) "cfg.o.system.host.iobroker-d.diskFree"
                           4) "cfg.o.system.host.iobroker-d.memRss"
                           5) "cfg.o.system.host.iobroker-d.compactgroupProcesses"
                           6) "cfg.o.system.host.iobroker-d.freemem"
                           7) "cfg.o.system.host.iobroker-d.mem"
                           8) "cfg.o.system.host.iobroker-d.logLevel"
                           9) "cfg.o.system.host.iobroker-d.memAvailable"
                          10) "cfg.o.system.host.iobroker-d.memHeapTotal"
                          11) "cfg.o.system.host.iobroker-d.cputime"
                          12) "cfg.o.system.host.iobroker-d.plugins.sentry"
                          13) "cfg.o.system.host.iobroker-d.zip"
                          14) "cfg.o.system.host.iobroker-d.compactModeEnabled"
                          15) "cfg.o.system.host.iobroker-d.plugins.sentry.enabled"
                          16) "cfg.o.system.host.iobroker-d.alive"
                          17) "cfg.o.system.host.iobroker-d.diskWarning"
                          18) "cfg.o.system.host.iobroker-d.outputCount"
                          19) "cfg.o.system.host.iobroker-d.load"
                          20) "cfg.o.system.host.iobroker-d.uptime"
                          21) "cfg.o.system.host.iobroker-d.instancesAsCompact"
                          22) "cfg.o.system.host.iobroker-d.eventLoopLag"
                          23) "cfg.o.system.host.iobroker-d.inputCount"
                          24) "cfg.o.system.host.iobroker-d.instancesAsProcess"
                          25) "cfg.o.system.host.iobroker-d.memHeapUsed"
                          26) "cfg.o.system.host.iobroker-d.diskSize"
                          • O
                            @foxriver76
                            Soll ich den Hostname vielleicht noch mal setzen?
                            • foxriver76
                              Da sind aber noch host Leichen, und iwie stimmt das auch nicht ganz mit den Entries in der redis DB überein.
                              Was gibt ìob status?
                              • O
                                @foxriver76
                                Richtig, das liegt aber daran, dass in der iobroker_startup.sh des Containers bei jedem Container-Start der Hostname gesetzt wird. Und mal ist das Ergebnis der Name des NAS (bei mir halt NAS), mal der Name des Containers (iobroker-d) und mal eben der von mir bestimmte Name iobroker. Kann ich nicht ändern...
                                # iob status
                                iobroker is not running on this host.
                                No iobroker host is running.
                                Objects type: redis
                                States  type: redis
                                # iobroker version
                                3.3.22
                                Habe den 3.3.22 wieder installiert. Der macht keine Probleme.
                                  apollon77 last edited by
                                  Hey All
                                  die 4.0.7 ist auf dem Weg mit einem kleinen Fix nochmal wegen der Paketmanager-Erkennung
                                  wendy2702 1 Reply Last reply Reply Quote 1
                                  • foxriver76
                                    @ofbeqnpolkkl6mby5e13 mal bitte Ausgaben von
                                    redis-cli keys cfg.o.system.user.*
                                    redis-cli keys cfg.o.system.group.*
                                    iob object list system.user.*
                                    iob object list system.group.*
                                    • O
                                      # redis-cli keys cfg.o.system.user.*
                                      1) "cfg.o.system.user.admin"
                                      # redis-cli keys cfg.o.system.group.*
                                      1) "cfg.o.system.group.administrator"
                                      2) "cfg.o.system.group.user"
                                      # iob object list system.user.*
                                      rw-rw-r--                    admin  administrator system.user.admin
                                      # iob object list system.group.*
                                      rw-r--r--                    admin  administrator system.group.administrator
                                      rw-r--r--                    admin  administrator system.group.user
                                      • Alligator
                                        Alligator @apollon77 last edited by
                                        @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                        die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
                                        Danke damit läuft bei mir jetzt alles stabil 👍
                                        Update von 4.0.6 auf 4.0.7 auch ohne Probleme.
                                        • foxriver76
                                          @ofbeqnpolkkl6mby5e13 Schaut alles gut aus. Nachdem ich noch etwas nachgeschaut habe, verstehe ich es noch weniger 😉
                                          Letzte Idee gerade: iob object get _design/system
                                          • O
                                            # iob object get _design/system
                                            {"_id":"_design/system","language":"javascript","common":{"name":{"en":"Object's selectors","de":"Objekt-Selektoren","ru":"Селекторы объекта","pt":"Seletores de objetos","nl":"Objectkiezers","fr":"Sélecteurs d'objet","it":"Selettori di oggetti","es":"Selectores de objeto","pl":"Selektory obiektów","zh-cn":"对象的选择器"},"dontDelete":true},"views":{"host":{"map":"function(doc) { if (doc.type === 'host') emit(doc._id, doc) }"},"adapter":{"map":"function(doc) { if (doc.type === 'adapter') emit(doc._id, doc) }"},"instance":{"map":"function(doc) { if (doc.type === 'instance') emit(doc._id, doc) }"},"instanceStats":{"map":"function(doc) { if (doc.type === 'instance') emit(doc._id, parseInt(doc._id.split('.').pop(), 10)) }","reduce":"_stats"},"meta":{"map":"function(doc) { if (doc.type === 'meta') emit(doc._id, doc) }"},"device":{"map":"function(doc) { if (doc.type === 'device') emit(doc._id, doc) }"},"channel":{"map":"function(doc) { if (doc.type === 'channel') emit(doc._id, doc) }"},"state":{"map":"function(doc) { if (doc.type === 'state') emit(doc._id, doc) }"},"folder":{"map":"function(doc) { if (doc.type === 'folder') emit(doc._id, doc) }"},"enum":{"map":"function(doc) { if (doc.type === 'enum') emit(doc._id, doc) }"},"script":{"map":"function(doc) { if (doc.type === 'script') emit(doc._id, doc) }"},"group":{"map":"function(doc) { if (doc.type === 'group') emit(doc.common.name, doc) }"},"user":{"map":"function(doc) { if (doc.type === 'user') emit(doc.common.name, doc) }"},"config":{"map":"function(doc) { if (doc.type === 'config') emit(doc.common.name, doc) }"},"custom":{"map":"function(doc) { doc.type === 'state' && doc.common && doc.common.custom && emit(doc._id, doc.common.custom) }"}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1092},"from":"system.host.iobroker.cli","ts":1644483728921}
                                            Wäre der folgende Workaround eine Möglichkeit?:
                                            1. Mit JS-Controller 3.2.2 zurück zu File
                                            2. Auf neuen JS-Controller 4.X
                                            3. Wieder Migration auf Redis
                                            747
                                            171320
