    4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
    • N
      Neo110 @Fabio last edited by
      @fa-bio ich habe das mit Blockly (siehe Post 125) gelöst
      Fabio 1 Reply Last reply Reply Quote 1
      • Fabio
        Fabio @Neo110 last edited by
        @neo110 Danke dir eine gute Lösung.
          loi83 last edited by
          Hallo zusammen
          ich hab die aktuelle Version und bekomme folgende Fehlermeldung.
          ainlogic.0	2021-11-01 10:47:22.975	debug	(19535) FW Scheduler Connection closed
          sainlogic.0	2021-11-01 10:47:22.973	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:59034)
          sainlogic.0	2021-11-01 10:47:22.972	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:46:22.971	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:45:22.974	debug	(19535) FW Scheduler Connection closed
          sainlogic.0	2021-11-01 10:45:22.972	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:58304)
          sainlogic.0	2021-11-01 10:45:22.970	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:44:22.969	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:43:22.973	debug	(19535) FW Scheduler Connection closed
          sainlogic.0	2021-11-01 10:43:22.971	error	(19535) Connection error on 192.168.178.103:8097: Error: connect EALREADY 192.168.178.103:8097 - Local (192.168.178.36:57516)
          sainlogic.0	2021-11-01 10:43:22.968	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:42:22.968	info	(19535) Scheduler pulling for new data
          sainlogic.0	2021-11-01 10:41:22.971	info	(19535) Starting Listener
          sainlogic.0	2021-11-01 10:41:22.970	debug	(19535) Forward URL:
          sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener protocol: wunderground
          sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener path: /weatherstation/updateweatherstation.php?
          sainlogic.0	2021-11-01 10:41:22.969	debug	(19535) Listener port: 8097
          sainlogic.0	2021-11-01 10:41:22.968	debug	(19535) Listener IP: 0.0.0.0
          sainlogic.0	2021-11-01 10:41:22.967	debug	(19535) Scheduler Interval: 60
          sainlogic.0	2021-11-01 10:41:22.967	debug	(19535) Weatherstation port: 8097
          sainlogic.0	2021-11-01 10:41:22.966	debug	(19535) Weatherstation IP: 192.168.178.103
          sainlogic.0	2021-11-01 10:41:22.965	info	(19535) Scheduler call ws_getcurrent activated
          sainlogic.0	2021-11-01 10:41:22.964	info	(19535) Scheduler call ws_getfirmware activated
          sainlogic.0	2021-11-01 10:41:22.963	info	(19535) Starting Scheduler
          Das Kuriose daran ist, das es am Anfang funktioniert hat, als sich die Temperatur nicht mehr änderte fand ich diesen Error vor. Neustart von Adapter und Container brachten keine Lösung.
          Fabio 1 Reply Last reply Reply Quote 0
          • Fabio
            Fabio @loi83 last edited by
            @loi83 er kann sich wohl nicht mit der IP Adresse deiner Wetterstation verbinden. Ist sie denn Online?
              loi83 @Fabio last edited by loi83
              @fa-bio ja eigentlich schon. Zumindest kann ich in der App drauf zugreifen und die Daten werden auch an Wunderground übermittelt.
              ##EDIT##
              Hab das Display mal vom Strom, jetzt gehts wieder 🤦
              • Fabio
                @loi83 Prima 👍
                  Waldmensch @Fabio last edited by
                  habe den Adapter installiert und greife die Daten von meiner ELV WS980 ab. Den Listener krieg ich nicht zum laufen, aber der Abruf rockt wie er soll. Das einzige, was stört ist, dass ich bei jedem Abruf folgendes Warning im Log hab. Vielleicht kann da mal wer nachschauen
                  State value to set for "sainlogic.0.weather.maxvalues.absolut.UVraw" has value "65535" greater than max "2000"
                    Blade1987 last edited by
                    @Fogg
                    Du hast ja vor langer Zeit mal bezüglich der Weiterleitung geschrieben.
                    Ich versuche diese verzweifelt einzurichten.
                    Benötige die Weiterleitung der EcoWitt Rohdaten an internen Server mit Port 45000 ( an diesem werden die Daten auch Empfangen )
                    Habe es mit sämtlichen URL´s versucht, wird aber nix rausgeschickt.
                    Im js habe ich ein paar Debugwerte hinzugefügt um rauszufinden wo es hackt.
                    Komme immer auf diese Ecke
                    got(fwd_url, { searchParams: json_response, method: 'GET', retry: 0 }).then(response => {
                    this.adapter.log.info('response.bodyurl' + response.body.url);
                    this.adapter.log.info('response.body.explanation' + response.body.explanation);
                    Die bodyurl sowohl als auch die explanation gibt er im Log als undefined aus.
                    Leider kenne ich mich mit got gar nicht aus und dem JS noch nicht zu tief um den Fehler zu finden.
                    Im Endeffekt soll er ja wie du beschrieben hast einfach den Request 1:1 an einen weiteren Host weitergeben.
                    Vielen Dank im Voraus und Vielen Dank für den Umfangreichen Adapter
                    PS: Genutzt wird die DNT Profi Wetterstation falls das noch interessant wäre
                    Liebe Grüße
                    Marco
                    • wendy2702
                      wendy2702 last edited by
                      Sehe ich das richtig das der Adapter den Weg ins Stable noch nicht geschafft hat?
                        Thomas Braun Most Active @wendy2702 last edited by
                        @wendy2702
                        Müsste drin sein:
                        sainlogic:
                        github:	0.8.1
                        latest:	0.8.1 for 27 days
                        stable:	0.8.1 for 27 days
                        • wendy2702
                          Adapter installiert. Als Protokoll Ecowitt ausgewählt weil da eigentlich auch der Batteriestatus übertragen wird.
                          Wenn ich auf Scheduler stelle sieht es bei meiner W830 so im log aus:
                          2022-02-10 18:02:28.044  - info: sainlogic.0 (4190) starting. Version 0.8.1 (non-npm: phifogg/ioBroker.sainlogic#9e7d2bc23ed5074f4a5d6d58a74764418f20b70e) in /opt/iobroker/node_modules/iobroker.sainlogic, node: v14.19.0, js-controller: 4.0.7
                          2022-02-10 18:02:28.079  - info: sainlogic.0 (4190) Starting Scheduler
                          2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getfirmware activated
                          2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getcurrent activated
                          2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getmax activated
                          2022-02-10 18:02:28.080  - info: sainlogic.0 (4190) Scheduler call ws_getmin activated
                          2022-02-10 18:02:28.081  - info: sainlogic.0 (4190) Scheduler call ws_getmaxdaily activated
                          2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Weatherstation IP: 192.168.178.137
                          2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Weatherstation port: 45000
                          2022-02-10 18:02:28.081  - debug: sainlogic.0 (4190) Scheduler Interval: 30
                          2022-02-10 18:02:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:02:58.096  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                          2022-02-10 18:02:58.099  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                          2022-02-10 18:02:58.100  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                          2022-02-10 18:02:58.101  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                          2022-02-10 18:02:58.101  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                          2022-02-10 18:02:58.102  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:02:58.102  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                          2022-02-10 18:03:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:03:28.082  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                          2022-02-10 18:03:28.084  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                          2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                          2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                          2022-02-10 18:03:28.085  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                          2022-02-10 18:03:28.085  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:03:28.086  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                          2022-02-10 18:03:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:03:58.083  - error: sainlogic.0 (4190) Connection error on 192.168.178.137:45000: Error: connect EISCONN 192.168.178.137:45000 - Local (192.168.178.18:57034)
                          2022-02-10 18:03:58.085  - debug: sainlogic.0 (4190) FW Scheduler Connection closed
                          2022-02-10 18:04:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:04:28.085  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                          2022-02-10 18:04:28.100  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                          2022-02-10 18:04:28.101  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                          2022-02-10 18:04:28.101  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                          2022-02-10 18:04:28.101  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                          2022-02-10 18:04:28.102  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:04:28.102  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                          2022-02-10 18:04:28.104  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                          2022-02-10 18:04:28.104  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                          2022-02-10 18:04:28.105  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                          2022-02-10 18:04:28.106  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                          2022-02-10 18:04:28.106  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:04:28.107  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,5,5,27
                          2022-02-10 18:04:58.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:04:58.082  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,80,3,83
                          2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) FW Scheduler Received data string: ffff501511456173795765617468657256312e362e31
                          2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) Data Command received: 80 subcommand 69
                          2022-02-10 18:04:58.092  - debug: sainlogic.0 (4190) Data object: {"softwaretype":"EasyWeatherV1.6.1"}
                          2022-02-10 18:04:58.092  - info: sainlogic.0 (4190) Scheduler updating IOBroker states
                          2022-02-10 18:04:58.093  - debug: sainlogic.0 (4190) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:04:58.093  - debug: sainlogic.0 (4190) Scheduler connected to weather station run 255,255,11,0,6,4,4,25
                          2022-02-10 18:05:28.081  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          2022-02-10 18:05:28.082  - error: sainlogic.0 (4190) Connection error on 192.168.178.137:45000: Error: connect EISCONN 192.168.178.137:45000 - Local (192.168.178.18:57768)
                          2022-02-10 18:05:28.085  - debug: sainlogic.0 (4190) FW Scheduler Connection closed
                          2022-02-10 18:05:58.082  - info: sainlogic.0 (4190) Scheduler pulling for new data
                          Und so in den Objecten:
                          Stelle ich auf Listener um kommt das:
                          2022-02-10 18:12:27.844  - debug: sainlogic.0 (4622) States create System PubSub Client
                          2022-02-10 18:12:27.844  - debug: sainlogic.0 (4622) States create User PubSub Client
                          2022-02-10 18:12:27.885  - debug: sainlogic.0 (4622) States connected to redis: 0.0.0.0:9000
                          2022-02-10 18:12:28.197  - info: sainlogic.0 (4622) starting. Version 0.8.1 (non-npm: phifogg/ioBroker.sainlogic#9e7d2bc23ed5074f4a5d6d58a74764418f20b70e) in /opt/iobroker/node_modules/iobroker.sainlogic, node: v14.19.0, js-controller: 4.0.7
                          2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener IP: 192.168.178.18
                          2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener port: 45000
                          2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener path: /weatherstation/updateweatherstation.php
                          2022-02-10 18:12:28.230  - debug: sainlogic.0 (4622) Listener protocol: ecowitt
                          2022-02-10 18:12:28.231  - debug: sainlogic.0 (4622) Forward URL:
                          2022-02-10 18:12:28.231  - info: sainlogic.0 (4622) Starting Listener
                          2022-02-10 18:12:33.771  - debug: sainlogic.0 (4622) Listener body is PASSKEY=6E8D338577B841F7DC608157C88988C7&stationtype=EasyWeatherV1.6.1&dateutc=2022-02-10+17:12:31&tempinf=71.1&humidityin=47&baromrelin=30.225&baromabsin=29.743&tempf=42.3&humidity=95&winddir=253&windspeedmph=0.7&windgustmph=1.1&maxdailygust=13.6&rainratein=0.000&eventrainin=0.110&hourlyrainin=0.000&dailyrainin=0.122&weeklyrainin=1.551&monthlyrainin=1.772&totalrainin=68.295&solarradiation=0.00&uv=0&wh65batt=0&freq=868M&model=WS2900_V2.01.10
                          2022-02-10 18:12:33.772  - debug: sainlogic.0 (4622) No mapping found for dataelement: PASSKEY
                          2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) Extracting value for info.softwaretype(stationtype)
                          2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) No mapping found for dataelement: dateutc
                          2022-02-10 18:12:33.773  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoortemp(tempinf)
                          2022-02-10 18:12:33.776  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoorhumidity(humidityin)
                          2022-02-10 18:12:33.777  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressurerel(baromrelin)
                          2022-02-10 18:12:33.777  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressureabs(baromabsin)
                          2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoortemp(tempf)
                          2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoorhumidity(humidity)
                          2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.winddir(winddir)
                          2022-02-10 18:12:33.778  - debug: sainlogic.0 (4622) Extracting value for weather.current.windspeed(windspeedmph)
                          2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.windgustspeed(windgustmph)
                          2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.maxdailygust(maxdailygust)
                          2022-02-10 18:12:33.779  - debug: sainlogic.0 (4622) Extracting value for weather.current.rain(rainratein)
                          2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) No mapping found for dataelement: eventrainin
                          2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) No mapping found for dataelement: hourlyrainin
                          2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.dailyrain(dailyrainin)
                          2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.weeklyrain(weeklyrainin)
                          2022-02-10 18:12:33.780  - debug: sainlogic.0 (4622) Extracting value for weather.current.monthlyrain(monthlyrainin)
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) No mapping found for dataelement: totalrainin
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for weather.current.solarradiation(solarradiation)
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for weather.current.uvi(uv)
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) No mapping found for dataelement: wh65batt
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for info.freq(freq)
                          2022-02-10 18:12:33.781  - debug: sainlogic.0 (4622) Extracting value for info.model(model)
                          2022-02-10 18:12:33.782  - debug: sainlogic.0 (4622) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:12:33.782  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoortemp to 21.7
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for indoortemp unit is set: °C, using conversion: null
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoorhumidity to 47
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressurerel to 1023.4
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for pressurerel unit is set: hPa, using conversion: null
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressureabs to 1007.1
                          2022-02-10 18:12:33.783  - debug: sainlogic.0 (4622) Target for pressureabs unit is set: hPa, using conversion: null
                          2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoortemp to 5.7
                          2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Target for outdoortemp unit is set: °C, using conversion: null
                          2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoorhumidity to 95
                          2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.winddir to 253
                          2022-02-10 18:12:33.784  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windspeed to 1.1
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for windspeed unit is set: km/h, using conversion: null
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windgustspeed to 1.8
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for windgustspeed unit is set: km/h, using conversion: null
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.maxdailygust to 21.9
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for maxdailygust unit is set: km/h, using conversion: null
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Setting value from data for weather.current.rain to 0
                          2022-02-10 18:12:33.785  - debug: sainlogic.0 (4622) Target for rain unit is set: mm, using conversion: null
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.dailyrain to 3.1
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for dailyrain unit is set: mm, using conversion: null
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.weeklyrain to 39.4
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for weeklyrain unit is set: mm, using conversion: null
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.monthlyrain to 45
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for monthlyrain unit is set: mm, using conversion: null
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Setting value from data for weather.current.solarradiation to 0
                          2022-02-10 18:12:33.786  - debug: sainlogic.0 (4622) Target for solarradiation unit is set: lx, using conversion: null
                          2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for weather.current.uvi to 0
                          2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for info.freq to 868M
                          2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Setting value from data for info.model to WS2900_V2.01.10
                          2022-02-10 18:12:33.787  - debug: sainlogic.0 (4622) Listener received EW update: {"PASSKEY":"6E8D338577B841F7DC608157C88988C7","stationtype":"EasyWeatherV1.6.1","dateutc":"2022-02-10 17:12:31","tempinf":"71.1","humidityin":"47","baromrelin":"30.225","baromabsin":"29.743","tempf":"42.3","humidity":"95","winddir":"253","windspeedmph":"0.7","windgustmph":"1.1","maxdailygust":"13.6","rainratein":"0.000","eventrainin":"0.110","hourlyrainin":"0.000","dailyrainin":"0.122","weeklyrainin":"1.551","monthlyrainin":"1.772","totalrainin":"68.295","solarradiation":"0.00","uv":"0","wh65batt":"0","freq":"868M","model":"WS2900_V2.01.10"}
                          2022-02-10 18:13:13.798  - debug: sainlogic.0 (4622) Listener body is PASSKEY=6E8D338577B841F7DC608157C88988C7&stationtype=EasyWeatherV1.6.1&dateutc=2022-02-10+17:13:10&tempinf=71.1&humidityin=47&baromrelin=30.225&baromabsin=29.743&tempf=42.3&humidity=95&winddir=253&windspeedmph=0.2&windgustmph=1.1&maxdailygust=13.6&rainratein=0.000&eventrainin=0.110&hourlyrainin=0.000&dailyrainin=0.122&weeklyrainin=1.551&monthlyrainin=1.772&totalrainin=68.295&solarradiation=0.00&uv=0&wh65batt=0&freq=868M&model=WS2900_V2.01.10
                          2022-02-10 18:13:13.799  - debug: sainlogic.0 (4622) No mapping found for dataelement: PASSKEY
                          2022-02-10 18:13:13.799  - debug: sainlogic.0 (4622) Extracting value for info.softwaretype(stationtype)
                          2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) No mapping found for dataelement: dateutc
                          2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoortemp(tempinf)
                          2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.indoorhumidity(humidityin)
                          2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressurerel(baromrelin)
                          2022-02-10 18:13:13.800  - debug: sainlogic.0 (4622) Extracting value for weather.current.pressureabs(baromabsin)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoortemp(tempf)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.outdoorhumidity(humidity)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.winddir(winddir)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.windspeed(windspeedmph)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.windgustspeed(windgustmph)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.maxdailygust(maxdailygust)
                          2022-02-10 18:13:13.801  - debug: sainlogic.0 (4622) Extracting value for weather.current.rain(rainratein)
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: eventrainin
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: hourlyrainin
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.dailyrain(dailyrainin)
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.weeklyrain(weeklyrainin)
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) Extracting value for weather.current.monthlyrain(monthlyrainin)
                          2022-02-10 18:13:13.802  - debug: sainlogic.0 (4622) No mapping found for dataelement: totalrainin
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for weather.current.solarradiation(solarradiation)
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for weather.current.uvi(uv)
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) No mapping found for dataelement: wh65batt
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for info.freq(freq)
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Extracting value for info.model(model)
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Setting value from data for info.softwaretype to EasyWeatherV1.6.1
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoortemp to 21.7
                          2022-02-10 18:13:13.803  - debug: sainlogic.0 (4622) Target for indoortemp unit is set: °C, using conversion: null
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.indoorhumidity to 47
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressurerel to 1023.4
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for pressurerel unit is set: hPa, using conversion: null
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.pressureabs to 1007.1
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for pressureabs unit is set: hPa, using conversion: null
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoortemp to 5.7
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Target for outdoortemp unit is set: °C, using conversion: null
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.outdoorhumidity to 95
                          2022-02-10 18:13:13.804  - debug: sainlogic.0 (4622) Setting value from data for weather.current.winddir to 253
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windspeed to 0.3
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for windspeed unit is set: km/h, using conversion: null
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.windgustspeed to 1.8
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for windgustspeed unit is set: km/h, using conversion: null
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Setting value from data for weather.current.maxdailygust to 21.9
                          2022-02-10 18:13:13.805  - debug: sainlogic.0 (4622) Target for maxdailygust unit is set: km/h, using conversion: null
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.rain to 0
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for rain unit is set: mm, using conversion: null
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.dailyrain to 3.1
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for dailyrain unit is set: mm, using conversion: null
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.weeklyrain to 39.4
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for weeklyrain unit is set: mm, using conversion: null
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.monthlyrain to 45
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Target for monthlyrain unit is set: mm, using conversion: null
                          2022-02-10 18:13:13.806  - debug: sainlogic.0 (4622) Setting value from data for weather.current.solarradiation to 0
                          2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Target for solarradiation unit is set: lx, using conversion: null
                          2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for weather.current.uvi to 0
                          2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for info.freq to 868M
                          2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Setting value from data for info.model to WS2900_V2.01.10
                          2022-02-10 18:13:13.807  - debug: sainlogic.0 (4622) Listener received EW update: {"PASSKEY":"6E8D338577B841F7DC608157C88988C7","stationtype":"EasyWeatherV1.6.1","dateutc":"2022-02-10 17:13:10","tempinf":"71.1","humidityin":"47","baromrelin":"30.225","baromabsin":"29.743","tempf":"42.3","humidity":"95","winddir":"253","windspeedmph":"0.2","windgustmph":"1.1","maxdailygust":"13.6","rainratein":"0.000","eventrainin":"0.110","hourlyrainin":"0.000","dailyrainin":"0.122","weeklyrainin":"1.551","monthlyrainin":"1.772","totalrainin":"68.295","solarradiation":"0.00","uv":"0","wh65batt":"0","freq":"868M","model":"WS2900_V2.01.10"}
                          Und ein Teil der DPs werden befüllt:
                          Datenpunkte wie z.B. UVRaw sollte doch aber im Ecowitt Protokoll enthalten sein zumindest bekomme ich bei Verwendung des Scripts einen Wert.
                          Liegt da nich was im Adapter oder ist meine Station nicht 100% kompatibel?
                            rotamint last edited by
                            Hallo zusammen! Ich habe eine grundlegende Frage zum Sainlogic-Adapter. Ich habe folgende Komponenten bei froggit.de gekauft:
                            Außeneinheit
                            zusammen mit
                            WiFi-USB-Dongle DP1500
                            Das ganze nach reichlich Nachlesem, "try & error" und wieder Nachlesen letztendlich mit dem Sainlogic-Adapter V.0.9.0 lauffähig bekommen:
                            Jedoch liefern die Datenpunkte "info, maxvalues und minvalues" keine Werte (null)
                            Ich vermute es hängt damit zusammen, dass die "Zeitplaneinstellungen" (pull) in der Config deaktiv steht (meine ich so bei Thomas Braun gelesen zu haben).
                            Setze ich die "Zeitplaneinstellungen" auf aktiv,
                            erhalte ich folgende Fehlermeldung ohne Veränderung der "null-Daten"
                            Hierzu meine Fragen:
                            Habe ich was falsch eingestellt (wenn ja - was), soviel kann da ja nicht konfiguriert werden.
                            Wer "erzeugt / liefert" die "Min- Maxvalues". Die Außeneinheit? Der DP1500 USB-Dongle? Ggf. das nicht vorhandene Display?
                            Wer hat eine Idee, wie ich das Problem lösen kann?
                            Danke für Eure Unterstützung, in diesem Sinne, ein tolles sonniges Wochenende!
                            S.
                            • mcm1957
                              mcm1957 @rotamint last edited by
                              @rotamint
                              I do not see Min/Max values using listener mode too. i'm using a Conrad Eurochron EFWS2900. Actual values seem to be ok. I've created a issue https://github.com/phifogg/ioBroker.sainlogic/issues/131
                              In respect to unknow subcommand this topic might be covered by issue
                              https://github.com/phifogg/ioBroker.sainlogic/issues/127
                              mcm1957 created this issue in phifogg/ioBroker.sainlogic
                              closed Min / Max Values not populated #131
                              heckmic created this issue in phifogg/ioBroker.sainlogic
                              closed Scheduler received data for unkown command 89 subcommand 95 #127
                              • mcm1957
                                mcm1957 @mcm1957 last edited by mcm1957
                                According to phifoggs responce at issue 131 the min/max values will be set ONLY if the station itself transmits min/max values. Tha adapter does NOT calculate any values.
                                Laut phifoggs Antwort auf Issue 131 werden die Min/Max-Werte NUR gesetzt, wenn die Station selbst Min/Max-Werte sendet. Der Adapter berechnet KEINE Werte.
                                  rotamint @mcm1957 last edited by
                                  @mcm57 sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                                  Schade. Ernüchternd. Trotzdem Danke für die Info, jetzt weiß ich wenigstens was ich zu tun habe 😉 Möchte da eigentlich nicht ewig dran rum basteln, dass es zum Schluss dann doch eine "holprige" Lösung wird... Daher meine Frage:
                                  Wer kann (welche?) Station empfehlen, die die Min-/Max-Werte mitliefert? Würde dann ggf. auf eine andere Ausseneinheit umsteigen.
                                  Danke schonmal, schönen Rest-Sonntag noch...
                                  LG Stefan.
                                  • Fabio
                                    Fabio @rotamint last edited by
                                    @rotamint sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
                                    Ich habe diese hier zuverlässig im Einsatz: https://www.froggit.de/product_info.php?info=p356_wh4000se-wifi-internet-funk-wetterstation---wunderground--ecowitt--pc-anbindung--auswertungssoftware.html
                                    Fabio
                                      rotamint @Fabio last edited by
                                      @fa-bio Besten Dank für die Info. Ich habe eben bestellt 😉
                                      LG Stefan.
                                      • Fabio
                                        @rotamint dann viel Spaß damit.👍
                                        Fabio
                                          @fa-bio Kurzes Feedback: Habe vieles probiert, verknüpft, visualisiert... Bin super glücklich und mehr als zufrieden damit. Absolut kein Vergleich zu der unzuverlässigen Homematic-Station, die ein vielfaches gekostet hat, vielfach weniger konnte und nur grobe "Schätzwerte" lieferte. Und letztendlich nach vier Jahren lt. EQ3 "irreparabel" defekt war...
                                          • Fabio
                                            @rotamint das freut mich doch.👍 ☺ Dann wünsche ich dir damit weiter viel Freude.
                                            Fabio
                                            1.0k
                                            adapter froggit wh4000sh sainlogic wetterstation ws980wifi
                                            60
                                            326
                                            73916
