    4. Test PV Forecast Adapter
    • sonnenschein
      sonnenschein @PatrickWalther last edited by
      @patrickwalther super, aber vor dem Wochenende werde ich nicht zum Testen kommen
      • Steff
        Steff last edited by
        @PatrickWalther
        ich habe die neue Version installiert, kann zwar bezüglich der neuen Funktion nichts sagen, da ich werde SQL noch Influxdb nutze. Es kommt nun beim Starten die folgende Warnung, mit dem Hinweis "... report this to the developer".
        2022-02-08 16:49:48.600 - info: pvforecast.0 (23092) starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v12.16.3, js-controller: 3.3.22
        2022-02-08 16:49:49.022 - warn: pvforecast.0 (23092) Object pvforecast.0.summary.prognose is invalid: obj.common.type has an invalid value (JSON) but has to be one of number, string, boolean, array, object, mixed, file, json
        2022-02-08 16:49:49.022 - warn: pvforecast.0 (23092) This object will not be created in future versions. Please report this to the developer.
        2022-02-08 16:49:49.029 - info: pvforecast.0 (23092) State value to set for "pvforecast.0.summary.prognose" has to be type "JSON" but received type "number"
        Was ich auch noch bei jedem Start habe sind die folgenden Warnungen:
        2022-02-08 10:40:32.674 - warn: pvforecast.0 (29189) State "pvforecast.0.1.everyhour_kw.07:36:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.676 - warn: pvforecast.0 (29189) State "pvforecast.0.summary.everyhour_kw.07:36:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.679 - warn: pvforecast.0 (29189) State "pvforecast.0.1.everyhour_kw.07:48:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.682 - warn: pvforecast.0 (29189) State "pvforecast.0.summary.everyhour_kw.07:48:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.707 - warn: pvforecast.0 (29189) State "pvforecast.0.1.everyhour_kw.17:19:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.709 - warn: pvforecast.0 (29189) State "pvforecast.0.summary.everyhour_kw.17:19:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.711 - warn: pvforecast.0 (29189) State "pvforecast.0.1.everyhour_kw.17:38:00" has no existing object, this might lead to an error in future versions
        2022-02-08 10:40:32.713 - warn: pvforecast.0 (29189) State "pvforecast.0.summary.everyhour_kw.17:38:00" has no existing object, this might lead to an error in future versions
        Gruß Steffen
          PatrickWalther Developer last edited by
          @steff Danke für die Hilfe, schaue ich mir morgen an.
          • Diginix
            Diginix @Steff last edited by Diginix
            @steff Die Fehler beim Start habe ich auch schon mit 0.1.6: https://forum.iobroker.net/topic/45315/test-pv-forecast-adapter/182?_=1644347976690
            Hab den Loglevel vom Adapter seit dem auf error. Dann sieht man sie wenigstens nicht. 😉
              Test PV Forecast Adapter 0.1.8
              Veröffentlichungsdatum 09.02.2022
              Github Link https://github.com/Patrick-Walther/ioBroker.pvforecast
              Guten Tag,
              habe den Wunsch von @sonnenschein eingepflegt und ein paar Bugfixes erledigt.
              Das schreiben der Daten funktioniert in influxdb einwandfrei, sql konnte ich leider nicht testen.
              Die Log Fehler sollten jetzt alle der Vergangenheit angehören.
              P.s falls ihr Fehler findet, macht bitte ein Issue auf, bin Momentan nicht sehr oft im Forum.
              Patrick
              sonnenschein 1 Reply Last reply Reply Quote 2
              • Sebastianb_80
                Sebastianb_80 last edited by
                folgende Situation, ich "Anfänger" habe den Adapter installiert, funktioniert auch alles perfekt. Ich habe 2 Anlagen eingepflegt (OST und West) bekomme im Pfad "Summery" auch eine .json welche dann in der VIS folgendermaßen aussieht.
                Ist es möglich die Daten der beiden Kurven (blaues unschönes Widget) in einer Kurve zu "vereinigen?
                  @sebastianb_80 Hi,
                  Wir können dir gerne helfen.
                  Kannst du uns sagen:
                  welche Widgets du benutzt?
                  Woher kommt die andere Grafik?
                  Benutzt du Garafana?
                  Welche Datenbank wir benutzt?
                  In der Adapter Version V1.8 kannst du auch direkt in die Datenbank schreiben so solltest du die Daten auch direkt übereinander gelegt haben.
                  Sebastianb_80 1 Reply Last reply Reply Quote 0
                  • sonnenschein
                    @patrickwalther sagte in Test PV Forecast Adapter:
                    So jetzt hatte ich doch Zeit den aktuellen Adpater zu installieren. 0.1.8
                    Eine Verständnisfrage: Im Adapter ist SQL gewählt. Unter den Objekten im IOBroker keine Speicherung der Werte in SQL aktiviert.
                    Ich habe das so verstanden, das der Adapter direkt in die SQL DB schreibt. Der Zeitpunkt sollte doch dann der Stundenwert und nicht das Speicherdatum sein Richtig?
                    Wenn ich jetzt aber mit HeidiSQL in de DB schaue, finde ich keine aktuellen Werte vom Adapter.
                    Vor dem Update hatte ich Iobroker speichern aktiviert. Diese Datenpunkte und DAtensätze finde ich auch.
                    Oder muß ich da abwarten bis der Adapter geschrieben hat? Wenn ja wann tut er das?
                    Die Zweite Frage welches Panel in Grafana hast Du verwendet und wie angebunden? simpleJson und Timeserie?
                    Ich bekomme so eine Anzeige wie bei Dir nicht hin!
                    • Steff
                      @PatrickWalther ,
                      kurze Rückmeldung auch von m ir, die Warnmeldungen "... has no existing object ..." sind nun mir der neuen Version weg.
                      Vielen Dank!
                        PatrickWalther Developer @sonnenschein last edited by PatrickWalther
                        @sonnenschein
                        Die Werte siehst du nicht in Iobroker direkt nur in der Datenbank und in Grafana.
                        Meine Aufbau ist wie folgt:
                        Influxdb mit Grafana und der Graph bzw. Timewerkes geht auch.
                        Folgende Anleitung kannst du verwenden.
                        https://www.smarthome-tricks.de/software-iobroker/1-2-grafana-installation-von-influxdb-und-integration-in-iobroker/amp/
                        Der Adapter schreibt die Werte alle X Minuten (wie du es eingestellt hast) in die SQL / Influx Datenbank.
                        Kannst auch gerne per Discord oder Chat schreiben, dann geht es schneller.
                        • Sebastianb_80
                          Sebastianb_80 @PatrickWalther last edited by
                          @patrickwalther
                          • um die blaue Grafik zu erzeugen habe ich das Material Design json chart Widget benutzt
                          • die andere Grafik kommt aus dem Modbusadapter --> History-->Flot Charts
                          • Nein
                          • Mit InfluxDB usw. hab ich noch keine Erfahrungen sammeln können...
                          z.B. mit Blockly? Sprich die einzelnen Daten von 05:00Uhr - 21:00Uhr (aus der summery) Zusammenzuführen und dann Grafisch darzustellen?
                            PatrickWalther Developer @Sebastianb_80 last edited by
                            @sebastianb_80 hast du im Adapter - Settings SQL aktiviert (checkbox) und SQL.0 ausgewählt?
                            Ich wusste aus dem steh Greif keine andere Variante als die Daten in die Datenbank direkt zu schreiben.
                            Würde dir Grafana empfehlen, dort kann man viele Einstellungen machen.
                            • Sebastianb_80
                              @patrickwalther
                              Danke für den Hinweis, dann werde ich mich wohl oder über mal mit Grafana beschäftigen müssen.
                              DANKE
                                @sebastianb_80 habe gerade mal den SQL Adapter installiert und die Funktion getestet. Diese funktioniert nicht richtig.
                                Werde den Fehler versuchen jetzt zu beheben.
                                sonnenschein 1 Reply Last reply Reply Quote 0
                                • sonnenschein
                                  @patrickwalther Hallo!
                                  Ich habe soeben noch mal in meine SQL DB geschaut. So wie du festgestellt hast, kommen die Daten in der DB nicht "an".
                                  Im Logfile erscheinen aber keine Fehlermeldungen dazu.
                                  • sonnenschein
                                    sonnenschein last edited by sonnenschein
                                    @sonnenschein sagte in Test PV Forecast Adapter:
                                    Inhalt wieder gelöscht da Fehlerhaft, Tschuldigung
                                      @sonnenschein Kein Problem.
                                      @sebastianb_80 und @sonnenschein
                                      Habs hin bekommen das die Daten sowohl in Grafana, ECharts und Flot angezeigt werden. Auch die Daten werden unter Object Einstellungen angzeigt.
                                      Einstellungen unter Objekte:
                                      Grafana:
                                      E-Charts:
                                      Update ist online. Probiert es gerne aus. Habe allerdings keine längeren Tests damit gemacht.
                                      Falls Fehler auftreten bitte melden.
                                        @Sputnik24 wie verhinderst du doppelte Einträge mit deinem Script?
                                        • BananaJoe
                                          BananaJoe Most Active @PatrickWalther last edited by
                                          @patrickwalther kannst du noch mal genau erklären was man machen muss um die Daten im SQL zu haben?
                                          Was ich gemacht habe:
                                          • auf aktuelle GitHub-Version 1.9.0 aktualisiert
                                          • in den Adapter-Einstellungen activate SQL gesetzt und meine Instanz sql.0 ausgewählt.
                                            Im Log erhalte ich Fehlermeldungen dieser Art:
                                          2022-02-12 05:22:31.650  - warn: sql.0 (1721) States system pmessage messagebox.system.adapter.sql.0 {"command":"storeState","message":{"id":"pvforecast.0.summary.prognose","state":{"ts":1644757200000,"val":71,"ack":true,"from":"pvforecast"}},"from":"system.adapter.pvforecast.0","_id":78689077} Cannot read property 'ignoreZero' of undefined
                                          2022-02-12 05:22:31.650  - warn: sql.0 (1721) TypeError: Cannot read property 'ignoreZero' of undefined
                                              at pushValueIntoDB (/opt/iobroker/node_modules/iobroker.sql/main.js:1575:39)
                                              at storeState (/opt/iobroker/node_modules/iobroker.sql/main.js:2294:9)
                                              at processMessage (/opt/iobroker/node_modules/iobroker.sql/main.js:916:9)
                                              at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/main.js:219:34)
                                              at Adapter.emit (events.js:400:28)
                                              at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5294:34)
                                              at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:324:37)
                                              at processImmediate (internal/timers.js:464:21)
                                          Der Datenpunkt pvforecast.0.summary.prognose wird als Typ JSON erstellt.
                                          Ich wollte das auch nutzen um Prognose und Realität in einer Grafik übereinanderlegen zu können.
                                            @bananajoe ich habe in den Objekt Einstellungen des Datenpunktes das Logging aktiviert und die Einstellungen in den Adapter Einstellungen wie du es gesagt hast.
                                            forecast photovoltaik
                                            113
                                            879
                                            279895
