    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Lucky_ESA Developer Most Active last edited by
      Hallo tombox,
      für Amazon:
      install chromium
      install chromium-browser
      Fehlermeldungen bleiben aber nach 8 Sekunden "Login to Amazon successful".
      Meine Lieferungen werden korrekt angezeigt.
      Gruß//Lucky
        tombox @Lucky_ESA last edited by
        @lucky_esa kannst du dazu nochmal den log posten
          Hier der Log.
          2022-02-10 21:43:17.607  - info: parcel.0 (8050) Got terminate signal TERMINATE_YOURSELF
          2022-02-10 21:43:17.610  - info: parcel.0 (8050) terminating
          2022-02-10 21:43:17.612  - info: parcel.0 (8050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-02-10 21:43:18.568  - info: host.raspberrypi instance system.adapter.parcel.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-02-10 21:43:21.472  - info: host.raspberrypi instance system.adapter.parcel.0 started with pid 8235
          2022-02-10 21:43:26.869  - info: parcel.0 (8235) starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.parcel, node: v14.19.0, js-controller: 4.0.7
          2022-02-10 21:43:26.956  - info: parcel.0 (8235) Login to Amazon
          2022-02-10 21:43:27.082  - error: parcel.0 (8235) Error: Failed to launch the browser process!
          /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: cannot open DLS]dq}����������������
          $-5DTY_hr: No such file
          /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: ������������: not found
          /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: @GKRahqx�������������
          9@MZp: not found
          /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 1: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: ELF: not found
          /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: 2: /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-961656/chrome-linux/chrome: Syntax error: Unterminated quoted string
          TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
          2022-02-10 21:43:27.084  - info: parcel.0 (8235) Try to start local instance of chromium
          2022-02-10 21:43:34.938  - info: parcel.0 (8235) Login to Amazon successful
          2022-02-10 21:45:00.013  - info: javascript.0 (1278) script.js.Scripts.Allgemein.Prüfung_Regen: Start Regen Check
          Gruß//Lucky
            @lucky_esa Gut da es jetzt auch auf ARM geht ich habe den Fehler noch verbessert
              Lucky_ESA Developer Most Active last edited by Lucky_ESA
              Habe den Fehler jetzt nicht mehr, muss aber noch testen.
              Suchen:
                         if (!this.browser) {
                             this.log.info("Try to start local instance of chromium");
                             this.browser = await puppeteer
                                 .launch({
                                     args: ["--no-sandbox", "--disable-setuid-sandbox"],
                                     executablePath: "/usr/bin/chromium-browser",
              Ersetzen:
                                 .launch({
                                     args: ["--no-sandbox", "--disable-setuid-sandbox", "--disable-gpu"],
                                     ignoreDefaultArgs: ["--disable-extensions"],
                                     slowMo: 100,
              Edit:
              Du kannst auch den catch auf debug setzen und nicht auf error. Dann wäre z. Bsp. bei mir alle Fehler weg.
              Edit 2:
                @lucky_esa ich denke nicht das die optionen notwendig sind. in der letzen version sollte nur ein warnung kommen
                • DJMarc75
                  DJMarc75 last edited by DJMarc75
                  Guten Morgen,
                  habe vorhin in mein LOG geschaut und seit der Aktualisierung gestern Abend hagelt es Errors beim Neustart und beim Updateintervall des Adapters. Hier ein kleiner Auszug:
                  parcel.0
                  	2022-02-11 08:07:09.505	error	https://briefankuendigung.dhl.de/pdapp-web/image/f0e44e5d-f6d7-4543-900d-0b9feb7bd53c Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.501	error	https://briefankuendigung.dhl.de/pdapp-web/image/c91e6de0-03aa-4eaf-b31c-d651edbfa71a Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.491	error	https://briefankuendigung.dhl.de/pdapp-web/image/f417c63b-158b-41f5-ad8c-3f2b6a3b3966 Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.455	error	https://briefankuendigung.dhl.de/pdapp-web/image/de964979-f844-4552-b0f2-fe070f72d2ad Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.445	error	https://briefankuendigung.dhl.de/pdapp-web/image/4f9078f3-085f-4ae2-ade4-e8da5c5483dd Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.409	error	https://briefankuendigung.dhl.de/pdapp-web/image/4955c6ee-861d-40ae-8313-3c260329f72c Error: Request failed with status code 401
                  parcel.0
                  	2022-02-11 08:07:09.383	error	https://briefankuendigung.dhl.de/pdapp-web/image/bbd2b403-ebcb-4b12-af03-d7fc07d96613 Error: Request failed with status code 401
                  bezieht sich auf Briefe welche ich in der APP sehen kann!
                  VG
                  • Olli_M
                    Olli_M @tombox last edited by
                    @tombox
                    Guten Morgen,
                    ist es möglich dass man die Bilder von den Briefankündigungen sich anzeigen lässt? z.b. in der VIS? oder vielleicht auch an den eigenen Telegram Bot weitergeben kann?
                    In der APP sehe ich die Bilder der Briefankündigungen aber die IMG URL kann man an sich nicht mal öffnen 😞
                    Ist das eine spezielle Datei?
                    • DJMarc75
                      DJMarc75 @Olli_M last edited by
                      @olli_m said in Test Adapter Paketverfolgung DHL, Amazon, DPD, 17Track:
                      Guten Morgen,
                      Mach mal ein Update vom Adapter. Es gibt einen Datenpunkt "image" der direkt über dem Datenpunkt "image_url" ist.
                      VG
                      Olli_M 2 Replies Last reply Reply Quote 1
                      • Olli_M
                        Olli_M @liv-in-sky last edited by
                        @liv-in-sky
                        Was muss ich denn noch installieren dass ich Amazon als Tracking reinbekomme?
                        Olli_M liv-in-sky 2 Replies Last reply Reply Quote 0
                        • Olli_M
                          Olli_M @DJMarc75 last edited by
                          @djmarc75
                          Wie mach ich denn ein Update, hatte das ja direkt über Github manuell installiert? sorry für die doofe Frage 🙂
                            sigi234 Forum Testing Most Active @Olli_M last edited by
                            @olli_m sagte in Test Adapter Paketverfolgung DHL, Amazon, DPD, 17Track:
                            @djmarc75
                            Benutzerdefiniert auswählen und die Url einfügen.
                            Olli_M 1 Reply Last reply Reply Quote 1
                            • Olli_M
                              Olli_M @sigi234 last edited by
                              @sigi234
                              Danke dir 🙂
                              • Olli_M
                                @djmarc75
                                hat geklappt, hast du schon versucht dass an Telegram zu schicken zufällig? 🙂
                                • Olli_M
                                  Olli_M @Olli_M last edited by
                                  @olli_m
                                  also bei mir ging Variante 2, aber noch während die Pakete installiert worden, hatte ich per Zufall den Adapter schon neugestartet und auf einmal ging es.
                                  Braucht man wirklich alle Pakete in Variante 2?
                                  • DJMarc75
                                    @djmarc75
                                    Noch nicht, aber den Wert des Datenpunktes kann man nicht senden weil zu lang. Und "image_url" ist ein Link welcher aber, wenn man den dann in Telegram öffnet, ins Leere läuft.
                                    Olli_M T 2 Replies Last reply Reply Quote 0
                                    • Olli_M
                                      @djmarc75
                                      okay schade 😉 aber trotzdem ist der Adapter schon nice
                                        liv-in-sky @Olli_M last edited by
                                        @olli_m ich habe nur die version 1 installiert - wie beschrieben in github - dann hat es funktioniert - mehr weiß ich leider nicht
                                          tombox @Olli_M last edited by
                                          @olli_m Kommt drauf an welchen Fehler du nach variante 1 bekommen hast
                                          Olli_M 1 Reply Last reply Reply Quote 0
                                          • Olli_M
                                            @tombox
                                            da müsste ich mal im LogFile jetzt schauen , aber ich glaub ich lass es jetzt so wie es ist nachdem es geht 🙂
                                            wollte nur etwas Ressourcen sparen 🙂
                                            17track amazon briefe dhl dpd gls ups
                                            124
                                            1538
                                            537306
