    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    • Olli_M
      Olli_M @tombox last edited by
      @tombox
      da müsste ich mal im LogFile jetzt schauen , aber ich glaub ich lass es jetzt so wie es ist nachdem es geht 🙂
      wollte nur etwas Ressourcen sparen 🙂
        liv-in-sky last edited by
        falls jmd eine "schnelle" tabelle für die letzten vier amazon lieferungen braucht
        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<style type=\"text/css\">\n#{wid} .tg  {\n    border-collapse:collapse;border-color:#9ABAD9;border-spacing:0;\n    \n}\n#{wid} .tg td{\n    background-color:#EBF5FF;border-color:#9ABAD9;border-style:solid;border-width:0px;color:#444;\n  font-family:Arial, sans-serif;font-size:10px;overflow:hidden;padding:10px 5px;word-break:normal;\n    \n}\n#{wid} .tg th{\n    background-color:#409cff;border-color:#9ABAD9;border-style:solid;border-width:0px;color:#fff;\n  font-family:Arial, sans-serif;font-size:10px;font-weight:normal;overflow:hidden;padding:10px 5px;word-break:normal;\n    \n}\n#{wid} .tg .tg-vn85{\n    border-color:#ffcc67;text-align:left;vertical-align:top\n    \n}\n#{wid} .tg-sort-header::-moz-selection{\n    background:0 0}\n#{wid} .tg-sort-header::selection{\n    background:0 0}.tg-sort-header{\n        cursor:pointer\n        \n    }\n#{wid} .tg-sort-header:after{\n    content:'';float:right;margin-top:7px;border-width:0 5px 5px;border-style:solid;\n  border-color:#404040 transparent;visibility:hidden\n    \n}\n#{wid} .tg-sort-header:hover:after{\n    visibility:visible}\n#{wid} .tg-sort-asc:after,.tg-sort-asc:hover:after,.tg-sort-desc:after{\n    visibility:visible;opacity:.4\n    \n}\n#{wid}  .tg-sort-desc:after{\nborder-bottom:none;border-width:5px 5px 0\n}</style>\n<table id=\"tg-noEOi\" class=\"tg\">\n<thead>\n  <tr>\n    <th class=\"tg-vn85\">AMAZON ID</th>\n    <th class=\"tg-vn85\">Artikel</th>\n    <th class=\"tg-vn85\">Status</th>\n  </tr>\n</thead>\n<tbody>\n  <tr>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen01.id}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen01.name}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen01.status}</td>\n  </tr>\n  <tr>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen02.id}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen02.name}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen02.status}</td>\n  </tr>\n  <tr>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen03.id}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen03.name}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen03.status}</td>\n  </tr>\n  <tr>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen04.id}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen04.name}</td>\n    <td class=\"tg-vn85\">{parcel.0.amazon.sendungen04.status}</td>\n  </tr>\n</tbody>\n</table>\n"},"style":{"left":"976px","top":"291px","width":"602px","height":"349px","font-size":"x-small"},"widgetSet":"basic"}]
          tombox @Olli_M last edited by
          @olli_m Die fehlermeldung wäre hilfreich dann könnte ich die anleitung optimieren
            tombox @DJMarc75 last edited by
            @djmarc75 Ich habe mal eine Idee für Telegram in Beitrag #1 geschrieben aber da die Datenpunkte immer wieder gelöscht werden kann es sein das in jedem Interval die nachricht kommt, habe aber derzeit keine briefe zum testen
            DJMarc75 2 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @tombox last edited by DJMarc75
              @tombox said in Test Adapter Paketverfolgung DHL, Amazon, DPD, 17Track:
              Das mit den gelöschten Datenpunkten könnte man per Blockly "umgehen". Ich habe z.B. einen eigenen Datenpunkt erstellt
              "0_userdata.0.DHL.Briefe.Brief1" welcher sich mit dem Wert vom Datenpunkt "Advices01.image" befüllt. Natürlich nur wenn sich dieser ändert und nicht leer ist.
              • DJMarc75
                DJMarc75 @DJMarc75 last edited by DJMarc75
                Hier der Block
                <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="[r[D[:dmo^mZ|:+5T)#2" x="-187" y="-212">
                  <value name="OID0">
                    <shadow type="field_oid" id="cd_~w+HXC:oN}GnG$o}T">
                      <field name="oid">parcel.0.dhl.briefe.currentAdvice.date</field>
                    <block type="get_value_var" id="wm#OlZ1PZAxoZ`etX5/%">
                      <value name="OID">
                        <shadow type="text" id="YLc~8|ubcCak2hxLdT|A">
                          <field name="TEXT"></field>
                        <block type="text" id="ISBH/I#kRq,5t4EhLd`*">
                          <field name="TEXT">parcel.0.dhl.briefe.currentAdvice.image</field>
                    <block type="controls_if" id="Hgq8d#ta/@PPg}^2)kDF">
                        <block type="logic_compare" id="ftq%31z~7+j-uo)_HmE=">
                          <field name="OP">NEQ</field>
                            <block type="on_source" id="Iy)[C|;c`sKxJs2UEgJ|">
                            <block type="text" id="1mE|q{-`z[o:-;pkiII7">
                        <block type="control" id="9wxaA9mjU:S^_GPJ;J^l">
                          <field name="OID">0_userdata.0.DHL.Briefe.Brief1</field>
                            <block type="on_source" id="a2wjaWZk.c=dufyY}L4B">
                • DJMarc75
                  Oder besser noch, man überprüft per Blockly ob der jeweilige Datenpunkt existiert und befüllt den eigenen dann mit dem Wert von diesem...
                  <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="QmW*Cr={}Zcyn$%hP)4T" x="-262" y="-562">
                   <field name="SCHEDULE">* * * * *</field>
                     <block type="variables_set" id="`g+}1z5+cjdZh!zS{aJS">
                       <field name="VAR" id="ZItD3U;@9~^9Agn8O0Tv">Brief1</field>
                         <block type="selector" id="1|g|$D5TcZ_kO}p$])rU">
                           <field name="TEXT">parcel.0.dhl.briefe.currentAdvice.advices01.image</field>
                         <block type="controls_if" id="FWWujk3C?k:$W]|1-=ZS">
                             <block type="logic_compare" id="%E2%(0dEZO$QF1aQxf2a">
                               <field name="OP">GT</field>
                                 <block type="text_length" id="tK*dqCsHKsN*}`aLY]j=">
                                     <shadow type="text" id="{CalDV-nBc-;lpwej9Y|">
                                       <field name="TEXT">abc</field>
                                     <block type="variables_get" id="%C_a$NO)qznz3V1s5xEQ">
                                 <block type="math_number" id="1$k7,;Cp{CBbv7!~GYup">
                                   <field name="NUM">0</field>
                             <block type="control" id="c8-e_,j)#@(A50Wpg532">
                               <field name="OID">0_userdata.0.DHL.Briefe.Marc.Brief1</field>
                                 <block type="get_value_var" id="WW;SgXf}-%$Y[eegy~$c">
                                   <value name="OID">
                                     <shadow type="text" id="SmV_qdX7AA0[d#p~Fm(8">
                                     <block type="text" id="=-L-[OhB|F||p|GVD[z+">
                           <value name="IF1">
                             <block type="logic_compare" id="H08lkyo@fm2=AKD*64]#">
                               <field name="OP">EQ</field>
                                 <block type="text_length" id="AQod0EO(Tt-R@XqnvMr|">
                                     <shadow type="text">
                                     <block type="variables_get" id="A{1|sK~rmPS0UR;6j0hA">
                                 <block type="math_number" id="SrdF$X+Gd}p_cd.lz9xv">
                           <statement name="DO1">
                             <block type="control" id="r^!#rQ=1Yc]Zuob6GhRL">
                                 <block type="text" id="YT?THEk?3u3{H||IpK+S">
                  • DJMarc75
                    Bekomme wenn das Skript ausgeführt wird im Log folgende Fehler:
                    javascript.0
                    	2022-02-12 06:29:00.048	error	at processImmediate (internal/timers.js:464:21)
                    javascript.0
                    	2022-02-12 06:29:00.048	error	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5902:56)
                    javascript.0
                    	2022-02-12 06:29:00.047	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
                    javascript.0
                    	2022-02-12 06:29:00.047	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
                    javascript.0
                    	2022-02-12 06:29:00.046	error	at Object.<anonymous> (script.js.common.DHL.Telegram1:5:5)
                    javascript.0
                    	2022-02-12 06:29:00.046	error	Error in callback: ReferenceError: fs is not defined
                    • DJMarc75
                      @Olli_M
                      @tombox
                      Habe den Code erweitert in Zeile 1 und 2 ... der Datenpunkt im Skript ist ein eigener welcher per Blockly vom Datenpunkt "parcel.0.dhl.briefe.currentAdvice.advices01" befüllt wird, den also anpassen ...
                      // Define the `fs` at the beginning of the script
                      const fs = require('fs');
                      on({id:"0_userdata.0.DHL.Briefe.Marc.Brief1", change: "ne"}, function(obj){
                          const base64Data = obj.state.val.split("base64,")[1]
                          fs.writeFile("/tmp/snapshot1.jpg", base64Data, 'base64', function(err) {
                            if (err) {
                              console.error(err);
                            } else {
                              sendTo('telegram.0', '/tmp/snapshot1.jpg');
                      das Skript selbst lasse ich nur von 0 Uhr bis 6 Uhr laufen, da in diesem Zeitraum die aktuellen Briefankündigungen stattfinden.
                      Hoffe dies hilft einigen.
                        @djmarc75 Ich habe das skript mal angepasst das es generisch für alle bilder geht und man brauch auch kein zwischen state
                        DJMarc75 1 Reply Last reply Reply Quote 2
                          tombox @Flexer last edited by
                          @flexer Ich habe ein allgemeines Skript zum Telegram versenden hinzugefügt
                          • DJMarc75
                            Funktioniert soweit, nur werden zumindest beim Neustart des Skripts immer wieder auch die alten Briefe per Telegram gesendet. Für mich wäre es sinnvoll nur die aktuellen zu bekommen, da die von der Vergangenheit ja eh schon aus dem Briefkasten geholt und die Rechnungen darin erfolgreich ignoriert wurden 😂
                            Ich probier mal im Skript den Ordner zu ändern....
                            Zeile 3
                            on({id:/^parcel\.0\.dhl\.briefe.currentAdvice*image$/, change: "ne"}, async function(obj){
                              sigi234 Forum Testing Most Active @tombox last edited by
                              @tombox
                              Hallo, kann man es konfigurierbar machen , ich möchte nur Amazon verwenden?
                              • Chaot
                                Chaot @sigi234 last edited by
                                @sigi234 Geht doch, wenn ich mich nicht irre.
                                Zumindest 17Track kann ich an- und Abschalten wenn ich die Zugangsdaten rausnehme.
                                  Thomas Braun Most Active @tombox last edited by
                                  @tombox
                                  Heute mag Amazon nicht mehr:
                                  2022-02-15 19:51:02.640  - info: parcel.0 (106558) starting. Version 0.0.1 (non-npm: TA2k/ioBroker.parcel#efe97452da65037ef43987eba5f1dd37fd4b4bff) in /opt/iobroker/node_modules/iobroker.parcel, node: v16.14.0, js-controller: 4.0.9
                                  2022-02-15 19:51:02.723  - info: parcel.0 (106558) Login to DHL
                                  2022-02-15 19:51:03.493  - info: parcel.0 (106558) Login to DHL successful
                                  2022-02-15 19:51:03.526  - info: parcel.0 (106558) Login to DPD
                                  2022-02-15 19:51:05.233  - info: parcel.0 (106558) Login to DPD successful
                                  2022-02-15 19:51:05.239  - info: parcel.0 (106558) Login to T17 User
                                  2022-02-15 19:51:06.144  - info: parcel.0 (106558) Login to 17T successful
                                  2022-02-15 19:51:06.151  - info: parcel.0 (106558) Login to Amazon
                                  2022-02-15 19:51:39.755  - error: parcel.0 (106558) TimeoutError: waiting for selector `#ordersContainer` failed: timeout 30000ms exceeded
                                  2022-02-15 19:51:39.759  - error: parcel.0 (106558) Amazon login failed. Please check your credentials and login manually
                                  Login bei Amazon ist unverändert zu den bisherigen Tagen; Neueingabe ändert nichts an der Meldung.
                                    tombox @Thomas Braun last edited by
                                    @thomas-braun Irgendwas auffälliges auf deiner Bestellübersicht? Keine Bestellungen? Alles auf deutsch?
                                      @tombox
                                      Ich bin's, der eine, der gerade keine Bestellung bei Amazon offen hat. Und auch gestern oder heute nichts geliefert bekommen hat.
                                      Also keine Änderungen ersichtlich.
                                      wendy2702 T 2 Replies Last reply Reply Quote 0
                                      • wendy2702
                                        wendy2702 @Thomas Braun last edited by
                                        @thomas-braun sagte in Test Adapter Paketverfolgung DHL, Amazon, DPD, 17Track:
                                        @tombox
                                        Ne, der bin ich… schon seit Tagen 🙂
                                          @thomas-braun Ich habe mal den selector verändert kannst du mal neuinstallieren und schauen ob der funktioniert
                                            Thomas Braun Most Active @tombox last edited by Thomas Braun
                                            @tombox
                                            Nope:
                                            2022-02-15 20:30:17.153  - info: parcel.0 (107452) starting. Version 0.0.2 (non-npm: TA2k/ioBroker.parcel#ad3587a3ea6d5d80cfe97e27ceff87767057a4a7) in /opt/iobroker/node_modules/iobroker.parcel, node: v16.14.0, js-controller: 4.0.9
                                            2022-02-15 20:30:17.218  - info: parcel.0 (107452) Login to DHL
                                            2022-02-15 20:30:18.043  - info: parcel.0 (107452) Login to DHL successful
                                            2022-02-15 20:30:18.060  - info: parcel.0 (107452) Login to DPD
                                            2022-02-15 20:30:19.415  - warn: parcel.0 (107452) Login to DPD failed
                                            2022-02-15 20:30:19.416  - info: parcel.0 (107452) Login to T17 User
                                            2022-02-15 20:30:20.052  - info: parcel.0 (107452) Login to 17T successful
                                            2022-02-15 20:30:20.061  - info: parcel.0 (107452) Login to Amazon
                                            2022-02-15 20:30:53.800  - error: parcel.0 (107452) TimeoutError: waiting for selector `#yourOrdersContent` failed: timeout 30000ms exceeded
                                            2022-02-15 20:30:53.801  - error: parcel.0 (107452) Amazon login failed. Please check your credentials and login manually
                                            17track amazon briefe dhl dpd gls ups
                                            124
                                            1538
                                            537396
