    4. Iobroker backitup error.. Wo liegt das problem
      elmos04 @Thomas Braun last edited by
      @thomas-braun code_text
      code_text
      ```Started iobroker ...
      [DEBUG] [mount] - mount activ... umount is started before mount!!
      [DEBUG] [mount] - umount successfully completed
      [DEBUG] [mount] - noserverino option: true
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.raspberrypi 8760 states saved
      [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
      [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
      [DEBUG] [iobroker] - done
      [DEBUG] [zigbee] - found zigbee database: zigbee.0
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - found Script: Garagentor_Status
      [DEBUG] [javascripts] - found Script: Taster_6Fach
      [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
      [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
      [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
      [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
      [DEBUG] [javascripts] - found Script: Gast_Wlan
      [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
      [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
      [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
      [DEBUG] [javascripts] - found Script: Überwachung_Temp
      [DEBUG] [javascripts] - found Script: Rauchmelder
      [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
      [DEBUG] [javascripts] - found Script: Xiaomi_Taster
      [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
      [DEBUG] [javascripts] - found Script: Ikea_Taster_
      [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
      [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
      [DEBUG] [javascripts] - found Script: Duty_Cycle
      [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
      [DEBUG] [javascripts] - found Script: Einbruch_erkannt
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-11_58_19_ioBroker_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [ERROR] [ftp] - [IGNORED] Error: Login incorrect.
      [DEBUG] [cifs] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 26
      E Homoran simatec 3 Replies Last reply Reply Quote 0
        elmos04 @elmos04 last edited by
        @elmos04 😊 😊 😊 😊
          Homoran Global Moderator Administrators @elmos04 last edited by
          @elmos04 iobroker update -i
            elmos04 @Homoran last edited by
            @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
            iobroker update -i
            Habe ich so gemacht
            [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
            [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_02_46_ioBroker_backupiobroker.tar.gz
            [EXIT] 26
            Kommt noch immer
            • simatec
              simatec Developer Most Active @elmos04 last edited by
              @elmos04 wenn du auf ein NAS sicherst, warum dann noch ftp?
              Das macht kein Sinn.
              Aber selbst wenn musst du für ftp deine Zugangsdaten und IP prüfen.
              Da stimmt was nicht
                @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
                Habe ich so gemacht
                das gepostete ist doch nicht die Ein- und Ausgabe von dem Befehl iobroker update -i
                  elmos04 @simatec last edited by
                  @simatec ftp hatte ich gerade getestet. ist wieder raus. geht aber noch nicht es gibt nur ein neues backup vom Zigbee und Java
                    Thomas Braun Most Active @elmos04 last edited by
                    @elmos04
                    NAS ist eine Fritzbox?
                    Dann sind die Mountoptionen falsch.
                      Hallo
                      Nein mein Backup geht an eine Synology. dort kommen auch neue Backups an. Zigbee und Java. Sonst kommt noch ein iobroker backup in das Verzeichnis. jetzt nicht mehr
                        @elmos04
                        Dann muss 'noserverino' ausgeschaltet sein und die smb-Version höher sein. Meist wird smb3 verwendet.
                          Loisverino ist an und smb 1.0
                          cifs ist ausgewählt
                            Thomas Braun Most Active @elmos04 last edited by Thomas Braun
                            @elmos04
                            Das sehe ich im Log.
                            Das ist aber zu 100% falsch eingestellt.
                            Stell 'noserverino' aus und die smb Version auf die, die auch dein NAS spricht.
                              code_text
                              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_18_53_ioBroker_backupiobroker.tar.gz
                              [EXIT] 26
                              Jetzt habe ich auf nas aus und speichere es Lokal.
                                @elmos04
                                Lokales speichern ist kein Backup.
                                  Ja ich wollte nur sehen bo die Einstellungen für mein Nas falsch sind. dann sollte es ja lokal gehen.
                                    JA, die sind FALSCH.
                                    Hab ich doch eben schon geschrieben.
                                    Lösch alles Dateien aus /opt/iobroker/backups wieder raus, das Verzeichnis muss leer sein beim mounten
                                      aber trotzdem bekomme ich kein lokales backup hin.
                                      wenn das geht schau ich mir die nas Einstellungen an. java und zigbee werden auf dem nas gesichert
                                        @elmos04
                                        mal anschauen. Das ist offenbar krumm.
                                          Ja wurde mir beim einspielen vom alten backup installiert. den 6fachtaster gab es da noch nicht. der wurde erst später im Zigbee installiert
                                            @elmos04
                                            Wurscht wo das herkommt, es ist offenbar kaputt.
                                            156
                                            19321
