    4. Iobroker backitup error.. Wo liegt das problem
      elmos04 @Homoran last edited by
      @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
      iobroker update -i
      Habe ich so gemacht
      Started iobroker ...
      [DEBUG] [mount] - noserverino option: true
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
      [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
      [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
      [DEBUG] [iobroker] - done
      [DEBUG] [zigbee] - found zigbee database: zigbee.0
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - found Script: Garagentor_Status
      [DEBUG] [javascripts] - found Script: Taster_6Fach
      [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
      [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
      [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
      [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
      [DEBUG] [javascripts] - found Script: Gast_Wlan
      [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
      [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
      [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
      [DEBUG] [javascripts] - found Script: Überwachung_Temp
      [DEBUG] [javascripts] - found Script: Rauchmelder
      [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
      [DEBUG] [javascripts] - found Script: Xiaomi_Taster
      [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
      [DEBUG] [javascripts] - found Script: Ikea_Taster_
      [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
      [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
      [DEBUG] [javascripts] - found Script: Duty_Cycle
      [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
      [DEBUG] [javascripts] - found Script: Einbruch_erkannt
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_02_46_ioBroker_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [ERROR] [ftp] - [IGNORED] Error: Login incorrect.
      [DEBUG] [cifs] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 26
      Kommt noch immer
      • simatec
        simatec Developer Most Active @elmos04 last edited by
        @elmos04 wenn du auf ein NAS sicherst, warum dann noch ftp?
        Das macht kein Sinn.
        Aber selbst wenn musst du für ftp deine Zugangsdaten und IP prüfen.
        Da stimmt was nicht
          Homoran Global Moderator Administrators @elmos04 last edited by
          @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
          Habe ich so gemacht
          das gepostete ist doch nicht die Ein- und Ausgabe von dem Befehl iobroker update -i
            elmos04 @simatec last edited by
            @simatec ftp hatte ich gerade getestet. ist wieder raus. geht aber noch nicht es gibt nur ein neues backup vom Zigbee und Java
              Thomas Braun Most Active @elmos04 last edited by
              @elmos04
              NAS ist eine Fritzbox?
              Dann sind die Mountoptionen falsch.
                elmos04 @Thomas Braun last edited by
                Hallo
                Nein mein Backup geht an eine Synology. dort kommen auch neue Backups an. Zigbee und Java. Sonst kommt noch ein iobroker backup in das Verzeichnis. jetzt nicht mehr
                  @elmos04
                  Dann muss 'noserverino' ausgeschaltet sein und die smb-Version höher sein. Meist wird smb3 verwendet.
                    Loisverino ist an und smb 1.0
                    cifs ist ausgewählt
                      Thomas Braun Most Active @elmos04 last edited by Thomas Braun
                      @elmos04
                      Das sehe ich im Log.
                      Das ist aber zu 100% falsch eingestellt.
                      Stell 'noserverino' aus und die smb Version auf die, die auch dein NAS spricht.
                        code_text
                        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-12_18_53_ioBroker_backupiobroker.tar.gz
                        [EXIT] 26
                        Jetzt habe ich auf nas aus und speichere es Lokal.
                          @elmos04
                          Lokales speichern ist kein Backup.
                            Ja ich wollte nur sehen bo die Einstellungen für mein Nas falsch sind. dann sollte es ja lokal gehen.
                              JA, die sind FALSCH.
                              Hab ich doch eben schon geschrieben.
                              Lösch alles Dateien aus /opt/iobroker/backups wieder raus, das Verzeichnis muss leer sein beim mounten
                                aber trotzdem bekomme ich kein lokales backup hin.
                                wenn das geht schau ich mir die nas Einstellungen an. java und zigbee werden auf dem nas gesichert
                                  @elmos04
                                  mal anschauen. Das ist offenbar krumm.
                                    Ja wurde mir beim einspielen vom alten backup installiert. den 6fachtaster gab es da noch nicht. der wurde erst später im Zigbee installiert
                                      @elmos04
                                      Wurscht wo das herkommt, es ist offenbar kaputt.
                                        Okay das dachte ich mir ja schon
                                        Nur wie bekomme ich den weg?👍
                                          @elmos04
                                          Wie ist es denn hingekommen?
                                          Vielleicht mal löschen:
                                          sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                            Homoran Global Moderator Administrators @elmos04 last edited by Homoran
                                            @elmos04 liest du auch ab und zu mal was im log steht?
                                            Demnach ist das ein defekter View
                                            EDIT:
                                            oder ein defektes (abgebrochenes ???) backup
                                            E Thomas Braun 2 Replies Last reply Reply Quote 0
                                            156
                                            19322
