    4. Test Alpha Homekit-Controller 0.0.x
      tklein last edited by tklein
      was kann ich tun, damit der Adapter grün wird? Der VP2 Steckerleiste habe ich inzwischen resetet. Wird mir jetzt nicht mehr angezeigt. Ferner find ich keinen DP, wo ich das Pairing triggern könnte.
      Im Log steht dieses:
      homekit-controller.0	2022-02-08 11:52:17.280	info	(7899) IP-7D:15:F7:88:80:A6 (iobroker 064B) found without known pairing data and already paired: ignoring
      homekit-controller.0	2022-02-08 11:52:17.071	info	(7899) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.17.0, js-controller: 3.3.22
      bzw:
      pi@raspberrypi-iob:~ $ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs
      2022-02-08 12:05:23.596  - debug: homekit-controller.0 (9559) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-02-08 12:05:23.677  - debug: homekit-controller.0 (9559) Objects client ready ... initialize now
      2022-02-08 12:05:23.682  - debug: homekit-controller.0 (9559) Objects create System PubSub Client
      2022-02-08 12:05:23.685  - debug: homekit-controller.0 (9559) Objects create User PubSub Client
      2022-02-08 12:05:23.688  - debug: homekit-controller.0 (9559) Objects client initialize lua scripts
      2022-02-08 12:05:24.690  - debug: homekit-controller.0 (9559) Objects connected to redis: 127.0.0.1:9001
      2022-02-08 12:05:24.706  - debug: homekit-controller.0 (9559) objectDB connected
      2022-02-08 12:05:24.710  - debug: homekit-controller.0 (9559) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-02-08 12:05:24.857  - debug: homekit-controller.0 (9559) States create System PubSub Client
      2022-02-08 12:05:24.859  - debug: homekit-controller.0 (9559) States create User PubSub Client
      2022-02-08 12:05:24.895  - debug: homekit-controller.0 (9559) States connected to redis: 127.0.0.1:9000
      2022-02-08 12:05:24.896  - debug: homekit-controller.0 (9559) statesDB connected
      2022-02-08 12:05:25.908  - debug: homekit-controller.0 (9559) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-08 12:05:26.405  - error: homekit-controller.0 (9559) adapter disabled
      2022-02-08 12:05:26.412  - info: homekit-controller.0 (9559) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.17.0, js-controller: 3.3.22
      2022-02-08 12:05:26.529  - debug: homekit-controller.0 (9559) state homekit-controller.0.info.connection changed: false (ack = true)
      2022-02-08 12:05:26.567  - debug: homekit-controller.0 (9559) Discovered IP device up: 7d:15:f7:88:80:a6/iobroker 064B
      2022-02-08 12:05:26.568  - debug: homekit-controller.0 (9559) IP-7D:15:F7:88:80:A6 Discovered IP device: {"name":"iobroker 064B","address":"192.168.0.20","port":43409,"c#":78,"ff":0,"id":"7d:15:f7:88:80:a6","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
      2022-02-08 12:05:26.570  - info: homekit-controller.0 (9559) IP-7D:15:F7:88:80:A6 (iobroker 064B) found without known pairing data and already paired: ignoring
      2022-02-08 12:05:31.690  - warn: homekit-controller.0 (9559) Got terminate signal. Checking desired PID: 0 vs own PID 9559
      2022-02-08 12:05:31.753  - warn: homekit-controller.0 (9559) Got terminate signal. Checking desired PID: 9577 vs own PID 9559
      2022-02-08 12:06:04.274  - warn: homekit-controller.0 (9559) Got terminate signal. Checking desired PID: 0 vs own PID 9559
      2022-02-08 12:06:04.377  - warn: homekit-controller.0 (9559) Got terminate signal. Checking desired PID: 9633 vs own PID 9559
      ^C2022-02-08 12:06:14.527  - debug: homekit-controller.0 (9559) Plugin sentry destroyed
      2022-02-08 12:06:14.529  - info: homekit-controller.0 (9559) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        apollon77 @tklein last edited by
        @tklein Naja der Adapter wird grün wenn er mit mindestens einem Gerät verbunden ist - bei dir ist er mit keinem Gerät verbunden - ergo Gelb.
        Wenn der Adapter sagt das das gerät bereits gepaired ist dann ist das erstmal so. Dann musst DU das Gerät resetten oder aus von da wo es gepaired ist wieder unpairen, Ein Gerät kann nur mit einem Controller gepaired sein.
          tklein @apollon77 last edited by
          @apollon77 said in Test Alpha Homekit-Controller 0.0.x:
          thx dafür. Das eine gepairte ist ja der iobroker als bridge selber. Die schaltbare Steckdosenleiste hatte ich ja resettet. Aber wo/wie kann ich den Pairingcode dann eingeben? Ich habe ja nicht den DP, mit dem ich das Triggern kann. So hatte ich das zumindest bei Github gelesen.
            @tklein wenn er ein Gerät als „ready to pair“ findet dann erscheint der state Bzw in der ui gibt es die Möglichkeit es zu pairen. Das debug log zeigt das dann auch so an … war bei dir oben aber nicht der Fall. Also sicher das reset geklappt hat?
              tklein @apollon77 last edited by tklein
              jetzt sieht es zmindest etwas besser aus, Pairen geht aber immer nch nicht. Den Pin habe ich mit xxx-xx-xxx angegeben. Im DP und in der GUI-Popup
              Nachtrag:
              Jetzt konnte ich erfolgreich pairen. Keine Ahnung warum die Steckerleiste doppelt drin ist (mit unterschiedlichen IDs:
                @tklein
                1.) EHOSTUNREACH bedeutet das das gerät in deinem Netzwerk nicht erreichbar war zu dem Zeitpunkt
                2.) Was heisst "in Vocolinc App konfiguriert"? Hast du es dann dort gepaired? Naja dann kanns nicht nochmal sein
                3.) Ich denke das Gerät hat mit dem Reset (oder dem pairing) seine ID gendert, damit kennt der Adapter beide. Kannst du in den Adapter-Objekten löschen
                  --> thx für die Info
                  --> nachdem es nach dem reset nicht geklappt hatte, habe ich das Device in der entsprechende App angelernt. Mir war/ist nicht bekannt, wie nach einem Device ohne konfigurierten WLAN nur mit dem Code eine Verbindung mit dem IOB erstellt werden kann
                  --> ok, werde ich dann löschen
                    pql @apollon77 last edited by
                    @apollon77 Versuche ein Eve Energy zu koppeln, aber ohne Erfolg.
                    Hardware ist ein RPI4 mit integriertem Bluetooth.
                    Noch eine Idee?
                    2022-02-13 12:30:06.032  - debug: homekit-controller.0 (17060) Discovered BLE device up: 0d:30:8f:xx:xx:xx/Eve Energy EA06
                    2022-02-13 12:30:06.033  - debug: homekit-controller.0 (17060) BLE-0D:30:8F:xx:xx:xx Discovered BLE device: {"name":"Eve Energy EA06","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"0d:30:8f:xx:xx:xx","ACID":7,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"0d:30:8f:xx:xx:xx","ci":7,"availableToPair":true}
                    2022-02-13 12:30:06.035  - info: homekit-controller.0 (17060) BLE-0D:30:8F:xx:xx:xx (Eve Energy EA06) found without pairing data but available for pairing: Create basic objects
                    2022-02-13 12:30:06.036  - debug: homekit-controller.0 (17060) Service: {"name":"Eve Energy EA06","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"0d:30:8f:xx:xx:xx","ACID":7,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"0d:30:8f:xx:xx:xx","ci":7,"availableToPair":true}
                    2022-02-13 12:30:06.088  - debug: homekit-controller.0 (17060) state homekit-controller.0.BLE-0D:30:8F:xx:xx:xx.info.connectionType changed: BLE (ack = true)
                    2022-02-13 12:30:06.114  - debug: homekit-controller.0 (17060) state homekit-controller.0.BLE-0D:30:8F:xx:xx:xx.info.id changed: 0d:30:8f:xx:xx:xx (ack = true)
                    2022-02-13 12:30:06.136  - debug: homekit-controller.0 (17060) state homekit-controller.0.BLE-0D:30:8F:xx:xx:xx.info.connected changed: false (ack = true)
                    2022-02-13 12:30:06.158  - debug: homekit-controller.0 (17060) state homekit-controller.0.BLE-0D:30:8F:xx:xx:xx.admin.isPaired changed: false (ack = true)
                    2022-02-13 12:30:06.171  - debug: homekit-controller.0 (17060) state homekit-controller.0.BLE-0D:30:8F:xx:xx:xx.info.lastDiscovered changed: 1644751806037 (ack = true)
                    2022-02-13 12:30:36.166  - debug: homekit-controller.0 (17060) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":77,"ack":false,"time":1644751836163},"_id":61388363})
                    2022-02-13 12:30:36.167  - debug: homekit-controller.0 (17060) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-0D:30:8F:xx:xx:xx","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Energy EA06","discoveredCategory":"Outlet","pairedWithThisInstance":false},{"id":"BLE-14:36:5E:xx:xx:xx","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Nuki_XXXXX","discoveredCategory":"Lock","pairedWithThisInstance":false}]}
                    2022-02-13 12:30:36.169  - debug: homekit-controller.0 (17060) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                    2022-02-13 12:30:48.359  - debug: homekit-controller.0 (17060) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx","pin":"yyy-yy-yyy"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx","pin":"yyy-yy-yyy"},"id":78,"ack":false,"time":1644751848356},"_id":61388364})
                      hap-controller:gatt-connection connect peripheral +0ms
                      hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Write for characteristic 0000004f0000100080000026bb765291 0003001100 +857ms
                      hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Received data for characteristic 0000004f0000100080000026bb765291 0200000300010102 +58ms
                      hap-controller:gatt-connection disconnect peripheral +1ms
                      hap-controller:gatt-connection Peripheral disconnected +16ms
                    2022-02-13 12:30:49.301  - info: homekit-controller.0 (17060) Use PairMethod 0 to pair BLE-0D:30:8F:xx:xx:xx
                    2022-02-13 12:30:49.303  - debug: homekit-controller.0 (17060) BLE-0D:30:8F:xx:xx:xx Start Homekit Device Client initialization
                      hap-controller:gatt-connection connect peripheral +8ms
                      hap-controller:gatt-connection Peripheral disconnected +308ms
                    2022-02-13 12:30:49.616  - debug: homekit-controller.0 (17060) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-0D:30:8F:xx:xx:xx because of error undefined (undefined): undefined"}
                    2022-02-13 12:30:49.617  - debug: homekit-controller.0 (17060) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      apollon77 @pql last edited by
                      @pql In dem Fall bekommt das Adapter keine Antwort vom Gerät. Geht ein Identify? Ich hab inzwischen so bissl da sGefühl das der RPI "Onboard" BLE zickig ist ... ggf mal mit nem BLE USB Stick versuchen?
                        @apollon77 Identify funktioniert, Gerät blinkt entsprechend und der Debug bestätigt dies auch mit einem "Success"
                        2022-02-13 13:36:36.527  - debug: homekit-controller.0 (28302) Message identify received: {"command":"identify","message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx"},"id":95,"ack":false,"time":1644755796524},"_id":61388381})
                        2022-02-13 13:36:36.529  - debug: homekit-controller.0 (28302) Device BLE-0D:30:8F:xx:xx:xx: Identify triggered
                          hap-controller:tlv Add 1 bytes for tag 1: 01 +0ms
                          hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Write for characteristic 000000140000100080000026bb765291 00020002000300010101 +924ms
                          hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Received data for characteristic 000000140000100080000026bb765291 020000 +59ms
                          hap-controller:gatt-connection disconnect peripheral +0ms
                          hap-controller:gatt-connection Peripheral disconnected +17ms
                        2022-02-13 13:36:37.538  - debug: homekit-controller.0 (28302) Response to Command identify: {"success":true,"error":false}
                        2022-02-13 13:36:37.542  - debug: homekit-controller.0 (28302) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                        USB BLE Stick hab ich nicht zur Hand, müsste mir dann erst einen besorgen
                          apollon77 @pql last edited by apollon77
                          @pql Also beimn Pairen sieht man das das Gerät auf den Connect versuch antwortet wo die unterstützten Pairing Methoden gelesen werden.Danach aber eine zweite Verbindung nicht annimmt um das eigentliche Pairing zu machen. Ich schaue nachher nochmal
                          EDIT: Code Seitig sieht an sich alles korrekt aus ... keine Ahnung warum das zickt und kann es auch nicht nachstellen
                            @apollon77 Hab jetzt einen USB Stick, gleiches Spiel; Identify funktioniert, Pairing nicht.
                            Log-Output ist diesmal aber etwas mehr was den Pairing Connect an geht.. Es kommt auf jeden Fall etwas zurück
                            2022-02-15 17:46:01.425  - debug: homekit-controller.0 (3773) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx","pin":"xxx-xx-xxx"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-0D:30:8F:xx:xx:xx","pin":"xxx-xx-xxx"},"id":16,"ack":false,"time":1644943561422},"_id":32016392})
                              hap-controller:gatt-connection connect peripheral +16s
                              hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Write for characteristic 0000004f0000100080000026bb765291 0003001100 +538ms
                              hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Received data for characteristic 0000004f0000100080000026bb765291 0200000300010102 +75ms
                              hap-controller:gatt-connection Peripheral disconnected +2s
                            2022-02-15 17:46:04.048  - info: homekit-controller.0 (3773) Use PairMethod 0 to pair BLE-0D:30:8F:xx:xx:xx
                            2022-02-15 17:46:04.051  - debug: homekit-controller.0 (3773) BLE-0D:30:8F:xx:xx:xx Start Homekit Device Client initialization
                              hap-controller:gatt-connection connect peripheral +7ms
                              hap-controller:tlv Add 1 bytes for tag 6: 01 +19s
                              hap-controller:tlv Add 1 bytes for tag 0: 00 +1ms
                              hap-controller:tlv Add 6 bytes for tag 1: 060101000100 +0ms
                              hap-controller:tlv Add 1 bytes for tag 9: 01 +0ms
                              hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Write for characteristic 0000004c0000100080000026bb765291 0002000f000b000106060101000100090101 +435ms
                              hap-controller:gatt-connection dbc159db8b1b/db:c1:59:db:8b:1b Received data for characteristic 0000004c0000100080000026bb765291 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 +583ms
                              hap-controller:gatt-connection Peripheral disconnected +45ms
                            2022-02-15 17:46:05.118  - debug: homekit-controller.0 (3773) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-0D:30:8F:xx:xx:xx because of error undefined (undefined): undefined"}
                            2022-02-15 17:46:05.119  - debug: homekit-controller.0 (3773) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                              @pql Inndem Fall kommt er etwas weiter aber das Gerät macht immer noch einen Disconnect. IST es vllt zu nah oder zu weit weg? mal frisch resetten?
                              Also wenn ich es richtig verstehe, dann sagen die Daten das 500 Byte kommen, es sind aber nur 150 und dann disconnect ...
                                @apollon77 frisch resettet (mehrfach) und näher dran leider ohne Erfolg. Gleiche Thematik.
                                Aber ok, dann wird das wohl am Eve Energy liegen. Direktes Pairing mit iOS funktioniert tadelos.
                                  @pql ich hab auch einen eve Energy undeniable mir tut alles - aber von nem Mac aus.
                                  Also du könntest jetzt nochmal das hci debugging parallel laufen lassen. Siehe troubleshooting in der readme. Vllt sieht man da noch was.
                                    Fortune95 @apollon77 last edited by
                                    @apollon77
                                    So bin gerade mal wieder mit Eve am testen aber mit gleichem Ergebnis....😞
                                    Über BLE zickt er immer noch.
                                    2022-02-16 19:05:03.537 - debug: homekit-controller.0 (115079) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2022-02-16 19:05:03.642 - debug: homekit-controller.0 (115079) Objects client ready ... initialize now
                                    2022-02-16 19:05:03.647 - debug: homekit-controller.0 (115079) Objects create System PubSub Client
                                    2022-02-16 19:05:03.650 - debug: homekit-controller.0 (115079) Objects create User PubSub Client
                                    2022-02-16 19:05:03.753 - debug: homekit-controller.0 (115079) Objects client initialize lua scripts
                                    2022-02-16 19:05:03.779 - debug: homekit-controller.0 (115079) Objects connected to redis: 127.0.0.1:9001
                                    2022-02-16 19:05:03.816 - debug: homekit-controller.0 (115079) Redis States: Use Redis connection: 127.0.0.1:6379
                                    2022-02-16 19:05:03.828 - debug: homekit-controller.0 (115079) States create System PubSub Client
                                    2022-02-16 19:05:03.830 - debug: homekit-controller.0 (115079) States create User PubSub Client
                                    2022-02-16 19:05:03.846 - debug: homekit-controller.0 (115079) States connected to redis: 127.0.0.1:6379
                                    2022-02-16 19:05:03.913 - debug: homekit-controller.0 (115079) Plugin sentry Initialize Plugin (enabled=true)
                                    2022-02-16 19:05:04.430 - info: homekit-controller.0 (115079) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
                                    2022-02-16 19:05:04.709 - debug: homekit-controller.0 (115079) state homekit-controller.0.info.connection changed: false (ack = true)
                                    2022-02-16 19:05:04.710 - debug: homekit-controller.0 (115079) Init 2 known devices without discovery ...
                                    2022-02-16 19:05:04.711 - debug: homekit-controller.0 (115079) Init IP-10:92:E9:E7:AE:8F as known device
                                    2022-02-16 19:05:04.713 - info: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without pairing data but available for pairing: Create basic objects
                                    2022-02-16 19:05:04.714 - debug: homekit-controller.0 (115079) Service: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":12,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":1,"ci":2,"availableToPair":true}
                                    2022-02-16 19:05:04.765 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connectionType changed: IP (ack = true)
                                    2022-02-16 19:05:04.778 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.id changed: 10:92:E9:E7:AE:8F (ack = true)
                                    2022-02-16 19:05:04.792 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.address changed: 192.168.95.50 (ack = true)
                                    2022-02-16 19:05:04.804 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connected changed: false (ack = true)
                                    2022-02-16 19:05:04.827 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.admin.isPaired changed: false (ack = true)
                                    2022-02-16 19:05:04.841 - debug: homekit-controller.0 (115079) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.lastDiscovered changed: 1645034704716 (ack = true)
                                    2022-02-16 19:05:04.860 - debug: homekit-controller.0 (115079) Init BLE-EA:80:43:5F:2E:FE as known device
                                    2022-02-16 19:05:04.861 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                    2022-02-16 19:05:04.862 - debug: homekit-controller.0 (115079) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true}
                                    2022-02-16 19:05:04.900 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true)
                                    2022-02-16 19:05:04.913 - debug: homekit-controller.0 (115079) Discovered IP device up: 10:92:E9:E7:AE:8F/Eve Extend C054
                                    2022-02-16 19:05:04.914 - debug: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F Discovered IP device: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":14,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:05:04.915 - info: homekit-controller.0 (115079) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:05:04.930 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true)
                                    2022-02-16 19:05:04.943 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true)
                                    2022-02-16 19:05:04.966 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true)
                                    2022-02-16 19:05:04.979 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034704863 (ack = true)
                                    2022-02-16 19:05:05.002 - debug: homekit-controller.0 (115079) Discovered IP device up: 47:FB:8F:AA:80:82/Eve Extend 726E
                                    2022-02-16 19:05:05.003 - debug: homekit-controller.0 (115079) IP-47:FB:8F:AA:80:82 Discovered IP device: {"name":"Eve Extend 726E","address":"169.254.182.94","port":8080,"c#":5,"ff":1,"id":"47:FB:8F:AA:80:82","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:05:05.004 - info: homekit-controller.0 (115079) IP-47:FB:8F:AA:80:82 (Eve Extend 726E) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:05:05.636 - debug: homekit-controller.0 (115079) Discovered BLE device up: f6:36:ed:19:09:14/Eve Thermo 8FE8
                                    2022-02-16 19:05:05.636 - debug: homekit-controller.0 (115079) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8861,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false}
                                    2022-02-16 19:05:05.637 - info: homekit-controller.0 (115079) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:05:05.951 - debug: homekit-controller.0 (115079) Discovered IP device up: 77:a2:42:96:a1:50/ioBroker B13E
                                    2022-02-16 19:05:05.951 - debug: homekit-controller.0 (115079) IP-77:A2:42:96:A1:50 Discovered IP device: {"name":"ioBroker B13E","address":"192.168.95.212","port":44763,"c#":21,"ff":0,"id":"77:a2:42:96:a1:50","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:05:05.952 - info: homekit-controller.0 (115079) IP-77:A2:42:96:A1:50 (ioBroker B13E) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:05:07.173 - debug: homekit-controller.0 (115079) Discovered BLE device up: ea:80:43:5f:2e:fe/Eve
                                    2022-02-16 19:05:07.174 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true}
                                    2022-02-16 19:05:07.174 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve) found without pairing data but available for pairing: Create basic objects
                                    2022-02-16 19:05:07.175 - debug: homekit-controller.0 (115079) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true}
                                    2022-02-16 19:05:07.218 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true)
                                    2022-02-16 19:05:07.237 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true)
                                    2022-02-16 19:05:07.268 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true)
                                    2022-02-16 19:05:07.334 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true)
                                    2022-02-16 19:05:07.354 - debug: homekit-controller.0 (115079) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034707176 (ack = true)
                                    2022-02-16 19:05:07.736 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":51,"ack":false,"time":1645034707733},"_id":61965836})
                                    2022-02-16 19:05:07.738 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]}
                                    2022-02-16 19:05:12.329 - debug: homekit-controller.0 (115079) Message identify received: {"command":"identify","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"id":52,"ack":false,"time":1645034712328},"_id":61965837})
                                    2022-02-16 19:05:12.330 - debug: homekit-controller.0 (115079) Device BLE-EA:80:43:5F:2E:FE: Identify triggered
                                    2022-02-16 19:05:17.002 - debug: homekit-controller.0 (115079) Response to Command identify: {"success":true,"error":false}
                                    2022-02-16 19:05:18.514 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":53,"ack":false,"time":1645034718512},"_id":61965838})
                                    2022-02-16 19:05:18.515 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]}
                                    2022-02-16 19:05:34.097 - debug: homekit-controller.0 (115079) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE","pin":"843-54-008"},"id":54,"ack":false,"time":1645034734094},"_id":61965839})
                                    2022-02-16 19:05:38.076 - info: homekit-controller.0 (115079) Use PairMethod 0 to pair BLE-EA:80:43:5F:2E:FE
                                    2022-02-16 19:05:38.078 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Start Homekit Device Client initialization
                                    2022-02-16 19:05:47.900 - debug: homekit-controller.0 (115079) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-EA:80:43:5F:2E:FE because of error undefined (undefined): undefined"}
                                    2022-02-16 19:05:48.355 - debug: homekit-controller.0 (115079) Discovered BLE device changed: ea:80:43:5f:2e:fe/Eve Degree 5980
                                    2022-02-16 19:05:48.357 - debug: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false}
                                    2022-02-16 19:05:48.358 - info: homekit-controller.0 (115079) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:06:32.001 - debug: homekit-controller.0 (115079) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":58,"ack":false,"time":1645034791999},"_id":61965843})
                                    2022-02-16 19:06:32.002 - debug: homekit-controller.0 (115079) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"BLE-F6:36:ED:19:09:14","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Thermo 8FE8","discoveredCategory":"Thermostat","pairedWithThisInstance":false},{"id":"IP-77:A2:42:96:A1:50","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"ioBroker B13E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]}
                                    2022-02-16 19:06:58.307 - info: homekit-controller.0 (115079) Got terminate signal TERMINATE_YOURSELF
                                    2022-02-16 19:06:58.322 - info: homekit-controller.0 (115079) terminating
                                    2022-02-16 19:06:58.325 - debug: homekit-controller.0 (115079) Plugin sentry destroyed
                                    2022-02-16 19:06:58.326 - info: homekit-controller.0 (115079) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-02-16 19:07:04.162 - debug: homekit-controller.0 (115115) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2022-02-16 19:07:04.275 - debug: homekit-controller.0 (115115) Objects client ready ... initialize now
                                    2022-02-16 19:07:04.282 - debug: homekit-controller.0 (115115) Objects create System PubSub Client
                                    2022-02-16 19:07:04.286 - debug: homekit-controller.0 (115115) Objects create User PubSub Client
                                    2022-02-16 19:07:04.375 - debug: homekit-controller.0 (115115) Objects client initialize lua scripts
                                    2022-02-16 19:07:04.393 - debug: homekit-controller.0 (115115) Objects connected to redis: 127.0.0.1:9001
                                    2022-02-16 19:07:04.471 - debug: homekit-controller.0 (115115) Redis States: Use Redis connection: 127.0.0.1:6379
                                    2022-02-16 19:07:04.489 - debug: homekit-controller.0 (115115) States create System PubSub Client
                                    2022-02-16 19:07:04.490 - debug: homekit-controller.0 (115115) States create User PubSub Client
                                    2022-02-16 19:07:04.501 - debug: homekit-controller.0 (115115) States connected to redis: 127.0.0.1:6379
                                    2022-02-16 19:07:04.551 - debug: homekit-controller.0 (115115) Plugin sentry Initialize Plugin (enabled=true)
                                    2022-02-16 19:07:05.037 - info: homekit-controller.0 (115115) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
                                    2022-02-16 19:07:05.299 - debug: homekit-controller.0 (115115) state homekit-controller.0.info.connection changed: false (ack = true)
                                    2022-02-16 19:07:05.311 - debug: homekit-controller.0 (115115) Init 2 known devices without discovery ...
                                    2022-02-16 19:07:05.312 - debug: homekit-controller.0 (115115) Init IP-10:92:E9:E7:AE:8F as known device
                                    2022-02-16 19:07:05.314 - info: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without pairing data but available for pairing: Create basic objects
                                    2022-02-16 19:07:05.315 - debug: homekit-controller.0 (115115) Service: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":12,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":1,"ci":2,"availableToPair":true}
                                    2022-02-16 19:07:05.367 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connectionType changed: IP (ack = true)
                                    2022-02-16 19:07:05.384 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.id changed: 10:92:E9:E7:AE:8F (ack = true)
                                    2022-02-16 19:07:05.405 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.address changed: 192.168.95.50 (ack = true)
                                    2022-02-16 19:07:05.417 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.connected changed: false (ack = true)
                                    2022-02-16 19:07:05.441 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.admin.isPaired changed: false (ack = true)
                                    2022-02-16 19:07:05.456 - debug: homekit-controller.0 (115115) state homekit-controller.0.IP-10:92:E9:E7:AE:8F.info.lastDiscovered changed: 1645034825317 (ack = true)
                                    2022-02-16 19:07:05.485 - debug: homekit-controller.0 (115115) Init BLE-EA:80:43:5F:2E:FE as known device
                                    2022-02-16 19:07:05.486 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve) found without pairing data but available for pairing: Create basic objects
                                    2022-02-16 19:07:05.487 - debug: homekit-controller.0 (115115) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":true}
                                    2022-02-16 19:07:05.527 - debug: homekit-controller.0 (115115) Discovered IP device up: 10:92:E9:E7:AE:8F/Eve Extend C054
                                    2022-02-16 19:07:05.528 - debug: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F Discovered IP device: {"name":"Eve Extend C054","address":"192.168.95.50","port":8080,"c#":14,"ff":1,"id":"10:92:E9:E7:AE:8F","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:07:05.529 - info: homekit-controller.0 (115115) IP-10:92:E9:E7:AE:8F (Eve Extend C054) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:07:05.547 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connectionType changed: BLE (ack = true)
                                    2022-02-16 19:07:05.553 - debug: homekit-controller.0 (115115) Discovered IP device up: 47:FB:8F:AA:80:82/Eve Extend 726E
                                    2022-02-16 19:07:05.554 - debug: homekit-controller.0 (115115) IP-47:FB:8F:AA:80:82 Discovered IP device: {"name":"Eve Extend 726E","address":"169.254.182.94","port":8080,"c#":5,"ff":1,"id":"47:FB:8F:AA:80:82","md":"Eve Extend 20EAB9901","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:07:05.555 - info: homekit-controller.0 (115115) IP-47:FB:8F:AA:80:82 (Eve Extend 726E) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:07:05.571 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.id changed: ea:80:43:5f:2e:fe (ack = true)
                                    2022-02-16 19:07:05.585 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.connected changed: false (ack = true)
                                    2022-02-16 19:07:05.606 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.admin.isPaired changed: false (ack = true)
                                    2022-02-16 19:07:05.618 - debug: homekit-controller.0 (115115) state homekit-controller.0.BLE-EA:80:43:5F:2E:FE.info.lastDiscovered changed: 1645034825487 (ack = true)
                                    2022-02-16 19:07:05.750 - debug: homekit-controller.0 (115115) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":59,"ack":false,"time":1645034825748},"_id":61965844})
                                    2022-02-16 19:07:05.752 - debug: homekit-controller.0 (115115) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-EA:80:43:5F:2E:FE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-10:92:E9:E7:AE:8F","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend C054","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-47:FB:8F:AA:80:82","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Extend 726E","discoveredCategory":"Bridge","pairedWithThisInstance":false}]}
                                    2022-02-16 19:07:06.006 - debug: homekit-controller.0 (115115) Discovered IP device up: 77:a2:42:96:a1:50/ioBroker B13E
                                    2022-02-16 19:07:06.007 - debug: homekit-controller.0 (115115) IP-77:A2:42:96:A1:50 Discovered IP device: {"name":"ioBroker B13E","address":"192.168.95.212","port":44763,"c#":21,"ff":0,"id":"77:a2:42:96:a1:50","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                    2022-02-16 19:07:06.008 - info: homekit-controller.0 (115115) IP-77:A2:42:96:A1:50 (ioBroker B13E) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:07:07.862 - debug: homekit-controller.0 (115115) Discovered BLE device up: ea:80:43:5f:2e:fe/Eve Degree 5980
                                    2022-02-16 19:07:07.863 - debug: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false}
                                    2022-02-16 19:07:07.864 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:07:12.512 - debug: homekit-controller.0 (115115) Message identify received: {"command":"identify","message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-EA:80:43:5F:2E:FE"},"id":60,"ack":false,"time":1645034832511},"_id":61965845})
                                    2022-02-16 19:07:12.514 - debug: homekit-controller.0 (115115) Device BLE-EA:80:43:5F:2E:FE: Identify triggered
                                    2022-02-16 19:07:23.539 - debug: homekit-controller.0 (115115) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-EA:80:43:5F:2E:FE because of error undefined: Identify returned error status: 5"}
                                    2022-02-16 19:07:27.848 - debug: homekit-controller.0 (115115) Discovered BLE device up: f6:36:ed:19:09:14/Eve Thermo 8FE8
                                    2022-02-16 19:07:27.849 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8861,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false}
                                    2022-02-16 19:07:27.850 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:07:27.861 - debug: homekit-controller.0 (115115) Discovered BLE device changed: f6:36:ed:19:09:14/Eve Thermo 8FE8
                                    2022-02-16 19:07:27.862 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8862,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false}
                                    2022-02-16 19:07:27.862 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:08:47.689 - debug: homekit-controller.0 (115115) Discovered BLE device changed: f6:36:ed:19:09:14/Eve Thermo 8FE8
                                    2022-02-16 19:08:47.691 - debug: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 Discovered BLE device: {"name":"Eve Thermo 8FE8","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f6:36:ed:19:09:14","ACID":9,"GSN":8863,"CN":5,"CV":2,"c#":5,"id":"f6:36:ed:19:09:14","ci":9,"availableToPair":false}
                                    2022-02-16 19:08:47.692 - info: homekit-controller.0 (115115) BLE-F6:36:ED:19:09:14 (Eve Thermo 8FE8) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:09:35.906 - debug: homekit-controller.0 (115115) Discovered BLE device up: 9b:3d:c6:d0:82:9b/Eve
                                    2022-02-16 19:09:35.907 - debug: homekit-controller.0 (115115) BLE-9B:3D:C6:D0:82:9B Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"9b:3d:c6:d0:82:9b","ACID":9,"GSN":8239,"CN":5,"CV":2,"c#":5,"id":"9b:3d:c6:d0:82:9b","ci":9,"availableToPair":false}
                                    2022-02-16 19:09:35.907 - info: homekit-controller.0 (115115) BLE-9B:3D:C6:D0:82:9B (Eve) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:09:51.356 - debug: homekit-controller.0 (115115) Discovered BLE device up: 91:90:ed:a6:89:85/Eve
                                    2022-02-16 19:09:51.357 - debug: homekit-controller.0 (115115) BLE-91:90:ED:A6:89:85 Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"91:90:ed:a6:89:85","ACID":9,"GSN":6582,"CN":5,"CV":2,"c#":5,"id":"91:90:ed:a6:89:85","ci":9,"availableToPair":false}
                                    2022-02-16 19:09:51.357 - info: homekit-controller.0 (115115) BLE-91:90:ED:A6:89:85 (Eve) found without known pairing data and already paired: ignoring
                                    2022-02-16 19:10:59.889 - debug: homekit-controller.0 (115115) Discovered BLE device changed: ea:80:43:5f:2e:fe/Eve Degree 5980
                                    2022-02-16 19:10:59.891 - debug: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"ea:80:43:5f:2e:fe","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"ea:80:43:5f:2e:fe","ci":10,"availableToPair":false}
                                    2022-02-16 19:10:59.893 - info: homekit-controller.0 (115115) BLE-EA:80:43:5F:2E:FE (Eve Degree 5980) found without known pairing data and already paired: ignoring
                                      apollon77 @Fortune95 last edited by
                                      @fortune95 sagte in Test Alpha Homekit-Controller 0.0.x:
                                      Also Fehler 5 sagt laut Specs
                                      Server reached its maximum number of authentication attempts.
                                      Resette mal ...
                                        @apollon77
                                        So kurz zum setup, habe jetzt eine VM mit externen USB BLE von Edimax. Debian Bullseye und js-controller 4.0.10.
                                        Den Eve Degree kann ich im adapter sehen (habe ihn zuvor frisch resettet)kann ihn aber nicht identifizieren.
                                        Erhalte dann diese Fehlermeldung:
                                        Danach habe ich den Adapter gestoppt.
                                        Und über die Shell den Debug wie oben erwähnt gestartet.
                                        Hier das Log:
                                        iobroker@iobroker:~DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debugug
                                        2022-02-17 18:44:50.094  - debug: homekit-controller.0 (2380) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2022-02-17 18:44:50.129  - debug: homekit-controller.0 (2380) Objects client ready ... initialize now
                                        2022-02-17 18:44:50.130  - debug: homekit-controller.0 (2380) Objects create System PubSub Client
                                        2022-02-17 18:44:50.131  - debug: homekit-controller.0 (2380) Objects create User PubSub Client
                                        2022-02-17 18:44:50.147  - debug: homekit-controller.0 (2380) Objects client initialize lua scripts
                                        2022-02-17 18:44:50.149  - debug: homekit-controller.0 (2380) Objects connected to redis: 127.0.0.1:9001
                                        2022-02-17 18:44:50.162  - debug: homekit-controller.0 (2380) Redis States: Use Redis connection: 127.0.0.1:6379
                                        2022-02-17 18:44:50.164  - debug: homekit-controller.0 (2380) States create System PubSub Client
                                        2022-02-17 18:44:50.165  - debug: homekit-controller.0 (2380) States create User PubSub Client
                                        2022-02-17 18:44:50.168  - debug: homekit-controller.0 (2380) States connected to redis: 127.0.0.1:6379
                                        2022-02-17 18:44:50.182  - debug: homekit-controller.0 (2380) Plugin sentry Initialize Plugin (enabled=true)
                                        2022-02-17 18:44:50.244  - error: homekit-controller.0 (2380) adapter disabled
                                        2022-02-17 18:44:50.299  - info: homekit-controller.0 (2380) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
                                        2022-02-17 18:44:50.370  - debug: homekit-controller.0 (2380) state homekit-controller.0.info.connection changed: false (ack = true)
                                        2022-02-17 18:44:50.373  - debug: homekit-controller.0 (2380) Init 1 known devices without discovery ...
                                        2022-02-17 18:44:50.373  - debug: homekit-controller.0 (2380) Init BLE-BA:0A:DB:84:F2:CE as known device
                                        2022-02-17 18:44:50.374  - info: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                        2022-02-17 18:44:50.374  - debug: homekit-controller.0 (2380) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                        2022-02-17 18:44:50.384  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                        2022-02-17 18:44:50.388  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                        2022-02-17 18:44:50.391  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                        2022-02-17 18:44:50.395  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                        2022-02-17 18:44:50.399  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645119890375 (ack = true)
                                        2022-02-17 18:44:51.467  - debug: homekit-controller.0 (2380) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980
                                        2022-02-17 18:44:51.467  - debug: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                        2022-02-17 18:44:51.467  - info: homekit-controller.0 (2380) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                        2022-02-17 18:44:51.468  - debug: homekit-controller.0 (2380) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                        2022-02-17 18:44:51.476  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                        2022-02-17 18:44:51.479  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                        2022-02-17 18:44:51.482  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                        2022-02-17 18:44:51.487  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                        2022-02-17 18:44:51.490  - debug: homekit-controller.0 (2380) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645119891468 (ack = true)
                                        2022-02-17 18:45:09.680  - debug: homekit-controller.0 (2380) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":25,"ack":false,"time":1645119909679},"_id":16181572})
                                        2022-02-17 18:45:09.680  - debug: homekit-controller.0 (2380) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                        2022-02-17 18:45:11.831  - debug: homekit-controller.0 (2380) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":26,"ack":false,"time":1645119911830},"_id":16181573})
                                        2022-02-17 18:45:11.831  - debug: homekit-controller.0 (2380) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
                                          hap-controller:gatt-connection disconnect peripheral +3s
                                          hap-controller:gatt-connection Peripheral disconnected +47ms
                                        2022-02-17 18:45:14.949  - debug: homekit-controller.0 (2380) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BA:0A:DB:84:F2:CE because of error undefined: undefined"}
                                        Kannst Du damit was anfangen?
                                          @apollon77
                                          So habe noch eine Ergänzung nach Google Recherche... im Bluetooth Service vorgenommen.
                                          Zumindest lieferte der Bluetooth Service danach keine Fehler mehr.
                                          Und auch das identifizieren ging dann wieder.
                                          Habe diese Zeile so abgeändert
                                          ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
                                          Nur das pairen will einfach nicht.
                                          Hier das Log:
                                          iobroker@iobroker:~$ sudo systemctl status bluetooth.service
                                          ● bluetooth.service - Bluetooth service
                                               Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
                                               Active: active (running) since Thu 2022-02-17 18:58:26 CET; 13s ago
                                                 Docs: man:bluetoothd(8)
                                             Main PID: 2443 (bluetoothd)
                                               Status: "Running"
                                                Tasks: 1 (limit: 7090)
                                               Memory: 740.0K
                                                  CPU: 9ms
                                               CGroup: /system.slice/bluetooth.service
                                                       └─2443 /usr/libexec/bluetooth/bluetoothd --noplugin=sap
                                          Feb 17 18:58:26 iobroker systemd[1]: Starting Bluetooth service...
                                          Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth daemon 5.55
                                          Feb 17 18:58:26 iobroker systemd[1]: Started Bluetooth service.
                                          Feb 17 18:58:26 iobroker bluetoothd[2443]: Starting SDP server
                                          Feb 17 18:58:26 iobroker bluetoothd[2443]: Excluding (cli) sap
                                          Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth management interface 1.18 initialized
                                          iobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug
                                          2022-02-17 19:00:01.818  - debug: homekit-controller.0 (2501) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2022-02-17 19:00:01.856  - debug: homekit-controller.0 (2501) Objects client ready ... initialize now
                                          2022-02-17 19:00:01.857  - debug: homekit-controller.0 (2501) Objects create System PubSub Client
                                          2022-02-17 19:00:01.858  - debug: homekit-controller.0 (2501) Objects create User PubSub Client
                                          2022-02-17 19:00:01.879  - debug: homekit-controller.0 (2501) Objects client initialize lua scripts
                                          2022-02-17 19:00:01.881  - debug: homekit-controller.0 (2501) Objects connected to redis: 127.0.0.1:9001
                                          2022-02-17 19:00:01.896  - debug: homekit-controller.0 (2501) Redis States: Use Redis connection: 127.0.0.1:6379
                                          2022-02-17 19:00:01.898  - debug: homekit-controller.0 (2501) States create System PubSub Client
                                          2022-02-17 19:00:01.899  - debug: homekit-controller.0 (2501) States create User PubSub Client
                                          2022-02-17 19:00:01.901  - debug: homekit-controller.0 (2501) States connected to redis: 127.0.0.1:6379
                                          2022-02-17 19:00:01.917  - debug: homekit-controller.0 (2501) Plugin sentry Initialize Plugin (enabled=true)
                                          2022-02-17 19:00:01.992  - error: homekit-controller.0 (2501) adapter disabled
                                          2022-02-17 19:00:02.039  - info: homekit-controller.0 (2501) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
                                          2022-02-17 19:00:02.112  - debug: homekit-controller.0 (2501) state homekit-controller.0.info.connection changed: false (ack = true)
                                          2022-02-17 19:00:02.114  - debug: homekit-controller.0 (2501) Init 1 known devices without discovery ...
                                          2022-02-17 19:00:02.115  - debug: homekit-controller.0 (2501) Init BLE-BA:0A:DB:84:F2:CE as known device
                                          2022-02-17 19:00:02.116  - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                          2022-02-17 19:00:02.116  - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:00:02.128  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                          2022-02-17 19:00:02.134  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                          2022-02-17 19:00:02.138  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                          2022-02-17 19:00:02.145  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                          2022-02-17 19:00:02.149  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802117 (ack = true)
                                          2022-02-17 19:00:02.689  - debug: homekit-controller.0 (2501) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980
                                          2022-02-17 19:00:02.689  - debug: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:00:02.690  - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                          2022-02-17 19:00:02.690  - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:00:02.698  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                          2022-02-17 19:00:02.701  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                          2022-02-17 19:00:02.705  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                          2022-02-17 19:00:02.710  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                          2022-02-17 19:00:02.714  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802690 (ack = true)
                                          2022-02-17 19:00:07.994  - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":33,"ack":false,"time":1645120807993},"_id":16181580})
                                          2022-02-17 19:00:07.994  - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                          2022-02-17 19:00:09.643  - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":34,"ack":false,"time":1645120809642},"_id":16181581})
                                          2022-02-17 19:00:09.643  - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
                                            hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +4s
                                            hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +224ms
                                          2022-02-17 19:00:13.890  - debug: homekit-controller.0 (2501) Response to Command identify: {"success":true,"error":false}
                                          2022-02-17 19:00:15.413  - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":35,"ack":false,"time":1645120815413},"_id":16181582})
                                          2022-02-17 19:00:15.414  - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                          2022-02-17 19:00:25.994  - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":36,"ack":false,"time":1645120825994},"_id":16181583})
                                          2022-02-17 19:00:25.995  - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
                                            hap-controller:gatt-connection connect peripheral +12s
                                            hap-controller:gatt-connection disconnect peripheral +5s
                                          2022-02-17 19:01:00.829  - debug: homekit-controller.0 (2501) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2)"}
                                          ^Ciobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug
                                          2022-02-17 19:01:16.958  - debug: homekit-controller.0 (2526) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2022-02-17 19:01:16.994  - debug: homekit-controller.0 (2526) Objects client ready ... initialize now
                                          2022-02-17 19:01:16.995  - debug: homekit-controller.0 (2526) Objects create System PubSub Client
                                          2022-02-17 19:01:16.996  - debug: homekit-controller.0 (2526) Objects create User PubSub Client
                                          2022-02-17 19:01:17.016  - debug: homekit-controller.0 (2526) Objects client initialize lua scripts
                                          2022-02-17 19:01:17.018  - debug: homekit-controller.0 (2526) Objects connected to redis: 127.0.0.1:9001
                                          2022-02-17 19:01:17.031  - debug: homekit-controller.0 (2526) Redis States: Use Redis connection: 127.0.0.1:6379
                                          2022-02-17 19:01:17.033  - debug: homekit-controller.0 (2526) States create System PubSub Client
                                          2022-02-17 19:01:17.034  - debug: homekit-controller.0 (2526) States create User PubSub Client
                                          2022-02-17 19:01:17.036  - debug: homekit-controller.0 (2526) States connected to redis: 127.0.0.1:6379
                                          2022-02-17 19:01:17.049  - debug: homekit-controller.0 (2526) Plugin sentry Initialize Plugin (enabled=true)
                                          2022-02-17 19:01:17.110  - error: homekit-controller.0 (2526) adapter disabled
                                          2022-02-17 19:01:17.159  - info: homekit-controller.0 (2526) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
                                          2022-02-17 19:01:17.232  - debug: homekit-controller.0 (2526) state homekit-controller.0.info.connection changed: false (ack = true)
                                          2022-02-17 19:01:17.235  - debug: homekit-controller.0 (2526) Init 1 known devices without discovery ...
                                          2022-02-17 19:01:17.236  - debug: homekit-controller.0 (2526) Init BLE-BA:0A:DB:84:F2:CE as known device
                                          2022-02-17 19:01:17.237  - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                          2022-02-17 19:01:17.238  - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:01:17.248  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                          2022-02-17 19:01:17.252  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                          2022-02-17 19:01:17.255  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                          2022-02-17 19:01:17.259  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                          2022-02-17 19:01:17.262  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120877239 (ack = true)
                                          2022-02-17 19:01:20.744  - debug: homekit-controller.0 (2526) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980
                                          2022-02-17 19:01:20.745  - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:01:20.745  - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                          2022-02-17 19:01:20.745  - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
                                          2022-02-17 19:01:20.752  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
                                          2022-02-17 19:01:20.755  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
                                          2022-02-17 19:01:20.759  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
                                          2022-02-17 19:01:20.766  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
                                          2022-02-17 19:01:20.769  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120880745 (ack = true)
                                          2022-02-17 19:01:25.279  - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":37,"ack":false,"time":1645120885278},"_id":16181584})
                                          2022-02-17 19:01:25.280  - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                          2022-02-17 19:01:26.989  - debug: homekit-controller.0 (2526) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":38,"ack":false,"time":1645120886988},"_id":16181585})
                                          2022-02-17 19:01:26.990  - debug: homekit-controller.0 (2526) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
                                            hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +3s
                                            hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +225ms
                                          2022-02-17 19:01:30.649  - debug: homekit-controller.0 (2526) Response to Command identify: {"success":true,"error":false}
                                          2022-02-17 19:01:32.166  - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":39,"ack":false,"time":1645120892163},"_id":16181586})
                                          2022-02-17 19:01:32.167  - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                          2022-02-17 19:01:51.108  - debug: homekit-controller.0 (2526) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"id":40,"ack":false,"time":1645120911107},"_id":16181587})
                                            hap-controller:gatt-connection connect peripheral +20s
                                            hap-controller:gatt-connection disconnect peripheral +7s
                                          2022-02-17 19:02:27.867  - info: homekit-controller.0 (2526) Cannot retrieve BLE PairMethod for device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2), try default
                                          2022-02-17 19:02:27.868  - info: homekit-controller.0 (2526) Use PairMethod 0 to pair BLE-BA:0A:DB:84:F2:CE
                                          2022-02-17 19:02:27.868  - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Start Homekit Device Client initialization
                                            hap-controller:gatt-connection disconnect peripheral to reconnect +30s
                                          2022-02-17 19:02:57.870  - debug: homekit-controller.0 (2526) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-BA:0A:DB:84:F2:CE because of error undefined (undefined): undefined"}
                                            Interessant, den Fehler hatte ich in einem Issue schonmal gesehen, aber tja dann wirds ganz interessant. Bitte schaumal da durch https://github.com/Apollon77/ioBroker.homekit-controller/#for-ble-devices und versuche es blt mach dieses Log parallel
                                            260
                                            41196
