    4. Iobroker backitup error.. Wo liegt das problem
    • simatec
      simatec Developer Most Active @elmos04 last edited by
      @elmos04
      Schaue mal, ob die Datei hier liegt
      /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
      Lösche diese bzw. lege sie woanders ab.
      Die hat einen Fehler und bricht beim parsen das Backup ab
        @thomas-braun sagte in Iobroker backitup error.. Wo liegt das problem:
        Dann ist es auch weg.
        oder er hat keine Rechte
          code_text
          pi@raspberrypi:/opt/iobroker $ /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
          -bash: /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json: Keine Berechtigung
            Thomas Braun Most Active @elmos04 last edited by
            @elmos04
            ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
              elmos04 @Thomas Braun last edited by
              code_text
              pi@raspberrypi:/opt/iobroker $ ls
              backups             iob       iobroker-data  node_modules  package-lock.json
              INSTALLER_INFO.txt  iobroker  log            package.json  reinstall.js
              pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
              -rw-rw-r--+ 1 iobroker iobroker 2405  4. Feb 17:57 /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
              simatec Homoran 2 Replies Last reply Reply Quote 0
                code_text
                Started iobroker ...
                [DEBUG] [mount] - noserverino option: true
                [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ElmoS04,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.31/home/ioBrokerVis /opt/iobroker/backups"
                [DEBUG] [mount] - mount successfully completed
                [DEBUG] [mount] - done
                [DEBUG] [iobroker] - host.raspberrypi 8762 states saved
                [DEBUG] [iobroker] - host.raspberrypi 10657 objects saved
                [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json is not a valid json file
                [DEBUG] [iobroker] - done
                [DEBUG] [zigbee] - found zigbee database: zigbee.0
                [DEBUG] [zigbee] - done
                [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                [DEBUG] [javascripts] - found Script: Garagentor_Status
                [DEBUG] [javascripts] - found Script: Taster_6Fach
                [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
                [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
                [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
                [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
                [DEBUG] [javascripts] - found Script: Gast_Wlan
                [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
                [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
                [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
                [DEBUG] [javascripts] - found Script: Überwachung_Temp
                [DEBUG] [javascripts] - found Script: Rauchmelder
                [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
                [DEBUG] [javascripts] - found Script: Xiaomi_Taster
                [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
                [DEBUG] [javascripts] - found Script: Ikea_Taster_
                [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
                [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
                [DEBUG] [javascripts] - found Script: Duty_Cycle
                [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
                [DEBUG] [javascripts] - found Script: Einbruch_erkannt
                [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-15_58_06_ioBroker_backupiobroker.tar.gz
                [DEBUG] [javascripts] - done
                [DEBUG] [cifs] - done
                [DEBUG] [clean] - done
                [DEBUG] [historyHTML] - new history html values created
                [DEBUG] [historyHTML] - done
                [DEBUG] [historyJSON] - new history json values created
                [DEBUG] [historyJSON] - done
                [DEBUG] [umount] - mount activ, umount is started ...
                [DEBUG] [umount] - umount successfully completed
                [DEBUG] [umount] - done
                [EXIT] 26
                • simatec
                  @elmos04 Das json Format ist nicht in Ordnung.
                  Speiche doch die Datei erstmal weg und lösche sie im Vis Pfad
                    elmos04 @simatec last edited by
                    @simatec
                    Ja super. 😊
                    Würde ich gerne machen. Ich kann nur copy und Paste.
                    • wendy2702
                      wendy2702 @elmos04 last edited by wendy2702
                      @elmos04 weg kopieren:
                      sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                      Die Kopie sollte dann erstmal bei /opt/iobroker/ landen. Kannst du dir dann in Ruhe ansehen oder komplett löschen wenn du die nicht mehr benötigst.
                      Löschen:
                      sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                        @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
                        code_text
                        pi@raspberrypi:/opt/iobroker $ sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                        cp: der Aufruf von stat für '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                        pi@raspberrypi:/opt/iobroker $ cd //
                        pi@raspberrypi:// $ sudo cp /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /opt/iobroker/6_Fach_Taster_1_Büro_licht.json.defekt
                        pi@raspberrypi:// $
                          Homoran Global Moderator Administrators @elmos04 last edited by
                          Es geht um diese Datei!
                          @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
                          pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json -rw-rw-r--+ 1 iobroker iobroker 2405 4. Feb 17:57 /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                          nicht um das tmp Verzeichnis
                            elmos04 @Homoran last edited by
                            @homoran 😢 Wenn ich das nur wüsste.
                              deswegen sag ich's ja.
                              das tmp Verzeichnis (oder sein Inhalt) existiert wahrscheinlich nicht mehr
                                deshalb glaub ich da ich damit leben muss.
                                Homoran simatec 2 Replies Last reply Reply Quote 0
                                  Liest du eigentlich was wir dir schreiben?
                                  und verstehst du was du da tust?
                                  Du hast doch extra nach der Datei gesucht (und sie gefunden)
                                  Diese Datei wird im Rahmen des Backups gepackt und vorher geprüft.
                                  Dafür liegt die (Kopie der) Datei kurzzeitig in diesem tmp-Verzeichnis.
                                  Der Fehler (das defekte json) ist aber in der Originaldatei, die jedesmal wieder das backup killen wird, wenn du sie nicht löschst oder verschiebst in ein Verzeichnis, das nicht gesichert wird
                                  Da gibt es kein mit leben müssen !!
                                  • simatec
                                    @elmos04
                                    sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /home/pi/6_Fach_Taster_1_Büro_licht.json
                                    sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                    Danach geht dein Backup
                                      Lesen -Ja
                                      Verstehen - nein
                                        @simatec
                                        habe beides Copy und Paste gemacht.
                                        Gleiche Meldung
                                        code_text
                                        [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
                                        [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
                                        [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
                                        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
                                        [EXIT] 26
                                        Homoran wendy2702 simatec 4 Replies Last reply Reply Quote 0
                                          pi@raspberrypi:~ $ sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /home/pi/6_Fach_Taster_1_Büro_licht.json
                                          pi@raspberrypi:~ $ sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
                                          pi@raspberrypi:~ $
                                          • wendy2702
                                            @elmos04
                                            156
                                            19322
