    4. Iobroker backitup error.. Wo liegt das problem
      elmos04 @Homoran last edited by
      Lesen -Ja
      Verstehen - nein
        elmos04 @simatec last edited by
        @simatec
        habe beides Copy und Paste gemacht.
        Gleiche Meldung
        code_text
        Started iobroker ...
        [DEBUG] [iobroker] - host.raspberrypi 8766 states saved
        [DEBUG] [iobroker] - host.raspberrypi 10664 objects saved
        [ERROR] [iobroker] - host.raspberrypi Backup not created: Error: host.raspberrypi /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json is not a valid json file
        [DEBUG] [iobroker] - done
        [DEBUG] [zigbee] - found zigbee database: zigbee.0
        [DEBUG] [zigbee] - done
        [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - found Script: Garagentor_Status
        [DEBUG] [javascripts] - found Script: Taster_6Fach
        [DEBUG] [javascripts] - found Script: Terrassen_Alexa_mit_Terrassentür
        [DEBUG] [javascripts] - found Script: Alarmanlage_Alexa_Terrasse_ein_und_aus
        [DEBUG] [javascripts] - found Script: Bewegung_UV_Durchsage
        [DEBUG] [javascripts] - found Script: Licht_Tür_UV_Vorraum_und_Eingang
        [DEBUG] [javascripts] - found Script: Gast_Wlan
        [DEBUG] [javascripts] - found Script: Durchsage_Scharf_unscharf
        [DEBUG] [javascripts] - found Script: Durchsage_Ender6_%
        [DEBUG] [javascripts] - found Script: Durchsage_FLsun_%
        [DEBUG] [javascripts] - found Script: Überwachung_Temp
        [DEBUG] [javascripts] - found Script: Rauchmelder
        [DEBUG] [javascripts] - found Script: Autoverbindung_Octopi
        [DEBUG] [javascripts] - found Script: Xiaomi_Taster
        [DEBUG] [javascripts] - found Script: Fenster_mit_WZ_Steckdoesn
        [DEBUG] [javascripts] - found Script: Ikea_Taster_
        [DEBUG] [javascripts] - found Script: Alarmmeldung_wird_abgeschaltet
        [DEBUG] [javascripts] - found Script: Einbruch_laut_melden
        [DEBUG] [javascripts] - found Script: Duty_Cycle
        [DEBUG] [javascripts] - found Script: Alarmmeldung_verhindern
        [DEBUG] [javascripts] - found Script: Einbruch_erkannt
        [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_02_13-17_52_40_ioBroker_backupiobroker.tar.gz
        [DEBUG] [javascripts] - done
        [DEBUG] [clean] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [EXIT] 26
        Homoran wendy2702 simatec 4 Replies Last reply Reply Quote 0
          elmos04 last edited by wendy2702
          pi@raspberrypi:~ $ sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json /home/pi/6_Fach_Taster_1_Büro_licht.json
          pi@raspberrypi:~ $ sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_1_Büro_licht.json
          pi@raspberrypi:~ $
          • wendy2702
            wendy2702 @elmos04 last edited by
            @elmos04
            ls -la  /opt/iobroker/iobroker-data/files/vis.0/Tech/
              @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
              insgesamt 1560
              drwxrwxr-x+ 3 iobroker iobroker   4096 13. Feb 17:48  .
              drwxrwxr-x+ 4 iobroker iobroker   4096  4. Feb 18:02  ..
              -rw-rw-r--+ 1 iobroker iobroker   2417  4. Feb 17:57  6_Fach_Taster_2_Blaulicht.json
              -rw-rw-r--+ 1 iobroker iobroker   2603  4. Feb 17:57  6_fach_Taster_3_Rollo_Runter.json
              -rw-rw-r--+ 1 iobroker iobroker   2596  4. Feb 17:57  6_Fach_Taster_3_Rollo_Stop.json
              -rw-rw-r--+ 1 iobroker iobroker   2595  4. Feb 17:57  6_Fach_Taster_4_Rollo_Rauf.json
              -rw-rw-r--+ 1 iobroker iobroker   2596  4. Feb 17:57  6_fach_Taster_4_rollo_stop.json
              -rw-rw-r--+ 1 iobroker iobroker   8247  4. Feb 17:57  6_Fach_Taster_5_Anycubic.json
              -rw-rw-r--+ 1 iobroker iobroker   8332  4. Feb 17:57  6_Fach_Taster_6_Ender6.json
              -rw-rw-r--+ 1 iobroker iobroker   4441  4. Feb 17:57  Alexa_Aus_über_Alarmanlage.json
              -rw-rw-r--+ 1 iobroker iobroker  12207  4. Feb 17:57  Alexa__Mute_Terrasse_Werkstatt.json
              -rw-rw-r--+ 1 iobroker iobroker   7537  4. Feb 17:57  Anycubic_i3_LED_Licht_Automatisch_Ein_-_Aus.json
              -rw-rw-r--+ 1 iobroker iobroker 243253  5. Feb 15:32 'Bildschirmfoto 2021-10-14 um 09.04.49.jpg'
              -rw-rw-r--+ 1 iobroker iobroker 385758  5. Feb 15:32 'Bildschirmfoto 2021-10-14 um 09.05.28.jpg'
              -rw-rw-r--+ 1 iobroker iobroker   3660  4. Feb 17:57  BWM_UV.json
              -rw-rw-r--+ 1 iobroker iobroker   2031  4. Feb 17:57  Ender_6_Automatisch_Licht_aus_wenn_Ender_Aus.json
              -rw-rw-r--+ 1 iobroker iobroker   2218  4. Feb 17:57  Ender_6_Start_Automatic.json
              -rw-rw-r--+ 1 iobroker iobroker   7323  4. Feb 17:57  Ender_Licht_Temp_geschaltet.json
              -rw-rw-r--+ 1 iobroker iobroker   3407  4. Feb 17:57  ESP_Test_D6_D7.json
              -rw-rw-r--+ 1 iobroker iobroker   1704  4. Feb 17:57  Fenster_mit_Wohnzimmer_Steckdosen_Schalten.json
              -rw-rw-r--+ 1 iobroker iobroker   5662  5. Feb 15:32  Garagecapture.jpg
              -rw-rw-r--+ 1 iobroker iobroker   1772  4. Feb 17:57  Garagen_ESP_Status_HM.json
              -rw-rw-r--+ 1 iobroker iobroker   8975  4. Feb 17:57  Ikea_Links_Anycubic_Ein.json
              -rw-rw-r--+ 1 iobroker iobroker   2425  4. Feb 17:57  Ikea_Mitte_Licht.json
              -rw-rw-r--+ 1 iobroker iobroker   8730  4. Feb 17:57  Ikea_Recht_Ender_6_.json
              -rw-rw-r--+ 1 iobroker iobroker   2588  4. Feb 17:57  Ikea_Taster_Rollo_Rauf.json
              -rw-rw-r--+ 1 iobroker iobroker   2608  4. Feb 17:57  IKEA_Taster_Rollo_Runter.json
              -rw-rw-r--+ 1 iobroker iobroker   4827  4. Feb 17:57  Ikea_Taster_Rollo_Stop.json
              drwxrwxr-x+ 2 iobroker iobroker   4096  4. Feb 18:02  img
              -rw-rw-r--+ 1 iobroker iobroker   3403  4. Feb 17:57  NFC_TV.json
              -rw-rw-r--+ 1 iobroker iobroker   3108  4. Feb 17:57  Tasmota_Anycubic.json
              -rw-rw-r--+ 1 iobroker iobroker   1715  4. Feb 17:57  Tasmota_Büro_Shelly1.json
              -rw-rw-r--+ 1 iobroker iobroker   3116  4. Feb 17:57  Tasmota_Ender_6.json
              -rw-rw-r--+ 1 iobroker iobroker   1666  4. Feb 17:57  Tasmota_iPad.json
              -rw-rw-r--+ 1 iobroker iobroker   1666  4. Feb 17:57  Tasmota_Linus.json
              -rw-rw-r--+ 1 iobroker iobroker   1666  4. Feb 17:57  Tasmota_Steckdosen_Linus.json
              -rw-rw-r--+ 1 iobroker iobroker   1713  4. Feb 17:57  Tasmota_Vorraum.json
              -rw-rw-r--+ 1 iobroker iobroker   1667  4. Feb 17:57  Tasmota_Weihnachtsbeleuchtung.json
              -rw-rw-r--+ 1 iobroker iobroker   3145  4. Feb 17:57  Tasmota_Werkstatt_Licht.json
              -rw-rw-r--+ 1 iobroker iobroker   3113  4. Feb 17:57  Tasmota_Werkstatt_Steckdosen.json
              -rw-rw-r--+ 1 iobroker iobroker   3105  4. Feb 17:57  Taster_Doppel_Tür_öffnen.json
              -rw-rw-r--+ 1 iobroker iobroker   8912  4. Feb 17:57  Taster_kurz__TV_ein.json
              -rw-rw-r--+ 1 iobroker iobroker   9057  4. Feb 17:57  Taster_Lang_auPanik.json
              -rw-rw-r--+ 1 iobroker iobroker   1031  4. Feb 17:57  Telegram_Test.json
              -rw-rw-r--+ 1 iobroker iobroker   2061  4. Feb 17:57  Temp_bad.json
              -rw-rw-r--+ 1 iobroker iobroker   1994  4. Feb 17:57  Temp_Drucker_Creality.json
              -rw-rw-r--+ 1 iobroker iobroker   2048  4. Feb 17:57  Temp_Küche.json
              -rw-rw-r--+ 1 iobroker iobroker   2048  4. Feb 17:57  Temp_Linus.json
              -rw-rw-r--+ 1 iobroker iobroker   2065  4. Feb 17:57  Temp_Schlafzimmer.json
              -rw-rw-r--+ 1 iobroker iobroker   2062  4. Feb 17:57  Temp_Server.json
              -rw-rw-r--+ 1 iobroker iobroker   2530  4. Feb 17:57  UV_Tür_Licht_und_HM_SV.json
              -rw-rw-r--+ 1 iobroker iobroker      0 11. Feb 13:57  vis-user.css
              -rw-rw-r--+ 1 iobroker iobroker 645413 12. Feb 10:58  vis-views.json
              -rw-rw-r--+ 1 iobroker iobroker   1919  4. Feb 17:57  Wetter_Warnungen.json
              -rw-rw-r--+ 1 iobroker iobroker   3477  4. Feb 17:57  Würfel_180_Licht_Büro_aus.json
              -rw-rw-r--+ 1 iobroker iobroker   3469  4. Feb 17:57  Würfel_90_Licht_ein_Büro.json
              -rw-rw-r--+ 1 iobroker iobroker   2680  4. Feb 17:57  Würfel_Klopfen_Rollo_Stop.json
              -rw-rw-r--+ 1 iobroker iobroker   2703  4. Feb 17:57  Würfel_Links_drehen_Rollo_Runter.json
              -rw-rw-r--+ 1 iobroker iobroker   2694  4. Feb 17:57  Würfel_Rechts_drehen_Rollo_Rauf.json
              -rw-rw-r--+ 1 iobroker iobroker   1727  4. Feb 17:57  Xiaomi_Magnet_2_zu_HM_und_Alexa.json
              -rw-rw-r--+ 1 iobroker iobroker   4859  4. Feb 17:57  Zählen_der_Fenster.json
              pi@raspberrypi:~ $
                Homoran Global Moderator Administrators @elmos04 last edited by
                @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
                und wo ist EIn- un Ausgabe davon?
                  elmos04 @elmos04 last edited by
                  @elmos04
                  Das sind Daten aus dem alten Backup
                    Homoran Global Moderator Administrators @elmos04 last edited by Homoran
                    Gleiche Meldung
                    nein - "backup created" !!!!
                    Jetzt ist der Störenfried weg und alles läuft durch
                    • wendy2702
                      @simatec
                      Gleiche Meldung
                      Nicht die gleiche Meldung. Vorher war es das File
                        Ja wenn das Backup nun doch erstellt wird sage ich mal vielen vielen Dank an euch alle die mir dabei geholfen haben. Ich hoffe ich werde dieses Backup nie brauchen. Wenn ich nun auf wiederherstellen gehe sehe ich jedoch nur Javaskripte und Zigbee. Vielleicht sind dort aber dann auch die iobroker Daten gesichert.
                        Vielen Dank
                        wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          @elmos04 Was hast du denn im Adapter alles ausgewählt ?
                            wenn!
                            ich habe diese lange Zeile nicht zu Ende gesehen.
                            @Wendy hat recht.
                            Jetzt das gleiche Spiel mit dem Blaulicht
                              elmos04 @wendy2702 last edited by
                              @wendy2702
                              Java Zigbee und den iobroker
                              E wendy2702 2 Replies Last reply Reply Quote 0
                                @elmos04
                                das steht im iobroker Protokoll
                                code_text
                                p.0
                                2022-02-13 17:52:31.393	error	[iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!
                                backitup.0
                                2022-02-13 17:52:30.642	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                                backitup.0
                                2022-02-13 17:52:30.556	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
                                host.raspberrypi
                                2022-02-13 17:52:27.918	info	instance system.adapter.backitup.0 started with pid 26735
                                host.raspberrypi
                                2022-02-13 17:52:25.539	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                backitup.0
                                2022-02-13 17:52:24.868	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                backitup.0
                                2022-02-13 17:52:24.866	info	terminating
                                backitup.0
                                2022-02-13 17:52:24.865	info	cleaned everything up...
                                host.raspberrypi
                                2022-02-13 17:52:24.865	info	stopInstance system.adapter.backitup.0 send kill signal
                                backitup.0
                                2022-02-13 17:52:24.863	info	Got terminate signal TERMINATE_YOURSELF
                                • wendy2702
                                  Was sind die xxx.json files? Sind das Widgets oder Views?
                                  Werden die noch benötigt?
                                  Kannst du mal den Inhalt eines solchen Files posten?
                                  Z.B.
                                  cat  /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json
                                  • wendy2702
                                    @elmos04
                                    Du muss auch mal anfangen die Logfiles zu lesen. Da steht zumindest mal ein Hinweis drin was gemacht werden soll
                                    Homoran E 2 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @wendy2702 last edited by
                                      Lesen -Ja
                                      Verstehen - nein
                                      • wendy2702
                                        wendy2702 @Homoran last edited by
                                        @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                                        Lesen -Ja
                                        Verstehen - nein
                                        OK.
                                        Aber ich hoffe ja das die Leute auch Interesse haben das irgendwann mal zu verstehen.
                                          code_text
                                          /* -- do not edit following lines - START --
                                            "expert": true,
                                            "engineType": "Blockly",
                                            "debug": false,
                                            "verbose": false
                                          -- do not edit previous lines - END --*/
                                          on({id: 'zigbee.0.04cf8cdf3c7d6fde.button_2_click', val: true}, async function (obj) {
                                            var value = obj.state.val;
                                            getState("hm-rpc.1.LTK0075338.1.STATE", function (err, state) {
                                                setState("hm-rpc.1.LTK0075338.1.STATE"/*Blaulicht.STATE*/, state ? !state.val : true);
                                            console.log('Blaulicht Taster geschaltet');
                                          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@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspberrypi:~ $
                                            das sind skripte
                                            Was machen die unter vis?
                                            156
                                            19317
